[GRASS-SVN] r42873 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Jul 21 15:16:16 EDT 2010
Author: martinl
Date: 2010-07-21 19:16:16 +0000 (Wed, 21 Jul 2010)
New Revision: 42873
grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
wxGUI: fix r42872
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py 2010-07-21 11:57:16 UTC (rev 42872)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py 2010-07-21 19:16:16 UTC (rev 42873)
@@ -516,8 +516,20 @@
event.Skip()
return
- if not haveVDigit:
- from vdigit import errorMsg
+ if not self.mapdisplay.toolbars['vdigit']: # enable tool
+ self.mapdisplay.AddToolbar('vdigit')
+ else: # tool already enabled
+ pass
+ # mark layer as 'edited'
+ if not self.mapdisplay.toolbars['vdigit'].StartEditing(maplayer) or \
+ not haveVDigit:
+ if not haveVDigit:
+ from vdigit import errorMsg
+ else:
+ errorMsg = _("Unable to initialize display driver of vector "
+ "digitizer")
msg = _("Unable to start wxGUI vector digitizer.\nDo you want to start "
"TCL/TK digitizer (v.digit) instead?\n\n"
"Details: %s" % errorMsg)
@@ -532,16 +544,7 @@
switchPage=False)
dlg.Destroy()
- return
- if not self.mapdisplay.toolbars['vdigit']: # enable tool
- self.mapdisplay.AddToolbar('vdigit')
- else: # tool already enabled
- pass
- # mark layer as 'edited'
- self.mapdisplay.toolbars['vdigit'].StartEditing (maplayer)
def OnStopEditing(self, event):
Stop editing the current vector map layer
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py 2010-07-21 11:57:16 UTC (rev 42872)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py 2010-07-21 19:16:16 UTC (rev 42873)
@@ -1104,17 +1104,13 @@
return True
def StartEditing (self, mapLayer):
- Start editing selected vector map layer.
+ """!Start editing selected vector map layer.
@param mapLayer reference to MapLayer instance
# deactive layer
self.mapcontent.ChangeLayerActive(mapLayer, False)
- # clean map canvas
- ### self.parent.MapWindow.EraseMap()
# unset background map if needed
if mapLayer:
if UserSettings.Get(group='vdigit', key='bgmap',
@@ -1137,18 +1133,16 @@
self.mapLayer = mapLayer
# open vector map
- try:
- if not self.parent.MapWindow.CheckPseudoDC():
- raise gcmd.DigitError(parent=self.parent,
- message=_("Unable to initialize display driver of vector "
- "digitizer. See 'Command output' for details."))
- self.parent.digit.SetMapName(mapLayer.GetName())
- except gcmd.DigitError, e:
+ if not self.parent.MapWindow.CheckPseudoDC():
+ # gcmd.GMessage(parent = self.parent,
+ # message = _("Unable to initialize display driver of vector "
+ # "digitizer. See 'Command output' for details."))
self.mapLayer = None
self.StopEditing()
- print >> sys.stderr, e # wxMessageBox
return False
+ self.parent.digit.SetMapName(mapLayer.GetName())
# update toolbar
self.combo.SetValue(mapLayer.GetName())
self.parent.toolbars['map'].combo.SetValue (_('Digitize'))
@@ -1162,7 +1156,7 @@
# create pseudoDC for drawing the map
self.parent.MapWindow.pdcVector = vdigit.PseudoDC()
self.parent.digit.driver.SetDevice(self.parent.MapWindow.pdcVector)
if not self.parent.MapWindow.resize:
self.parent.MapWindow.UpdateMap(render=True)
