[GRASS-SVN] r42460 - grass-addons/raster/r.stream.pos
svn_grass at osgeo.org
Thu Jun 3 07:33:50 EDT 2010
Author: mmetz
Date: 2010-06-03 07:33:50 -0400 (Thu, 03 Jun 2010)
New Revision: 42460
grass-addons/raster/r.stream.pos/global.h
grass-addons/raster/r.stream.pos/io.c
grass-addons/raster/r.stream.pos/main.c
grass-addons/raster/r.stream.pos/pos.c
format and clean up code
Modified: grass-addons/raster/r.stream.pos/global.h
--- grass-addons/raster/r.stream.pos/global.h 2010-06-03 11:33:08 UTC (rev 42459)
+++ grass-addons/raster/r.stream.pos/global.h 2010-06-03 11:33:50 UTC (rev 42460)
@@ -40,7 +40,7 @@
STREAM {
int stream; /* index */
int init_r, init_c;
@@ -60,7 +60,7 @@
int trib_nums(int r, int c);
int init_streams(void);
int find_inits(void);
-int calculate (void);
+int calculate(void);
/* variables */
Modified: grass-addons/raster/r.stream.pos/io.c
--- grass-addons/raster/r.stream.pos/io.c 2010-06-03 11:33:08 UTC (rev 42459)
+++ grass-addons/raster/r.stream.pos/io.c 2010-06-03 11:33:50 UTC (rev 42460)
@@ -4,7 +4,6 @@
int open_raster(char *mapname)
int fd = 0;
char *mapset;
struct Cell_head cellhd; /* it stores region information, and header information of rasters */
@@ -14,8 +13,8 @@
if (mapset == NULL)
G_fatal_error(_("Raster map <%s> not found"), mapname);
- /* checking if the input maps type is CELL */
- if (G_raster_map_type(mapname, mapset) != CELL_TYPE)
+ /* checking if the input maps type is CELL */
+ if (G_raster_map_type(mapname, mapset) != CELL_TYPE)
G_fatal_error(_("<%s> is not of type CELL"), mapname);
if ((fd = G_open_cell_old(mapname, mapset)) < 0) /* file descriptor */
@@ -35,22 +34,21 @@
int create_base_maps(void)
int r, c;
- CELL *r_dirs=NULL, *r_streams=NULL, *r_mask=NULL;
- int in_dir_fd=0, in_stm_fd=0, in_mask_fd=0; /* input file descriptors: indir_fd - direction.... etc */
+ CELL *r_dirs = NULL, *r_streams = NULL;
+ int in_dir_fd = 0, in_stm_fd = 0; /* input file descriptors: indir_fd - direction.... etc */
in_dir_fd = open_raster(in_dirs);
in_stm_fd = open_raster(in_streams);
dirs = (CELL **) G_malloc(sizeof(CELL *) * nrows);
- streams = (CELL **) G_malloc(sizeof(CELL *) * nrows);
- if(out_streams_length)
- streams_length = (FCELL **) G_malloc(sizeof(FCELL *) * nrows);
+ streams = (CELL **) G_malloc(sizeof(CELL *) * nrows);
+ if (out_streams_length)
+ streams_length = (FCELL **) G_malloc(sizeof(FCELL *) * nrows);
r_dirs = (CELL *) G_malloc(sizeof(CELL) * ncols);
r_streams = (CELL *) G_malloc(sizeof(CELL) * ncols);
G_message("Reading maps...");
for (r = 0; r < nrows; ++r) {
@@ -58,65 +56,62 @@
/* dirs & streams */
dirs[r] = G_malloc(sizeof(CELL) * ncols);
streams[r] = G_malloc(sizeof(CELL) * ncols);
- streams_length[r] = G_malloc(sizeof(FCELL *) * ncols);
+ streams_length[r] = G_malloc(sizeof(FCELL *) * ncols);
if (G_get_c_raster_row(in_dir_fd, r_dirs, r) < 0 ||
- G_get_c_raster_row(in_stm_fd, r_streams, r) < 0 )
+ G_get_c_raster_row(in_stm_fd, r_streams, r) < 0) {
G_close_cell(in_dir_fd);
G_close_cell(in_stm_fd);
G_fatal_error(_("Unable to read raster maps at row <%d>"), r);
for (c = 0; c < ncols; ++c) {
- if (G_is_c_null_value(&r_dirs[c]))
+ if (G_is_c_null_value(&r_dirs[c]))
dirs[r][c] = 0;
- else
+ else
dirs[r][c] = r_dirs[c];
if (G_is_c_null_value(&r_streams[c]))
streams[r][c] = 0;
- else
- streams[r][c] = r_streams[c];
- streams_length[r][c] = 0.;
+ else
+ streams[r][c] = r_streams[c];
+ streams_length[r][c] = 0.;
} /* end for c */
- } /* end for r */
+ } /* end for r */
G_free(r_streams);
G_free(r_dirs);
- G_percent(r, nrows, 2);
+ G_percent(r, nrows, 2);
return 0;
} /* end create base maps */
-int stream_number(void)
- char *cur_mapset;
- CELL c_min, c_max;
- struct Range stream_range;
- G_init_range(&stream_range);
- cur_mapset = G_find_cell2(in_streams, "");
- G_read_range(in_streams,cur_mapset,&stream_range);
- G_get_range_min_max(&stream_range, &c_min, &c_max);
- stream_num=c_max;
- return 0;
+ int stream_number(void)
+ char *cur_mapset;
+ CELL c_min, c_max;
+ struct Range stream_range;
+ G_init_range(&stream_range);
+ cur_mapset = G_find_cell2(in_streams, "");
+ G_read_range(in_streams,cur_mapset,&stream_range);
+ G_get_range_min_max(&stream_range, &c_min, &c_max);
+ stream_num=c_max;
+ return 0;
int write_maps_f(char *mapname, FCELL ** map)
- int r, c;
+ int r;
int fd = 0;
if ((fd = G_open_raster_new(mapname, FCELL_TYPE)) < 0)
@@ -136,7 +131,7 @@
int write_maps_c(char *mapname, CELL ** map)
- int r, c;
+ int r;
int fd = 0;
if ((fd = G_open_raster_new(mapname, CELL_TYPE)) < 0)
Modified: grass-addons/raster/r.stream.pos/main.c
--- grass-addons/raster/r.stream.pos/main.c 2010-06-03 11:33:08 UTC (rev 42459)
+++ grass-addons/raster/r.stream.pos/main.c 2010-06-03 11:33:50 UTC (rev 42460)
@@ -25,15 +25,15 @@
int main(int argc, char *argv[])
struct GModule *module; /* GRASS module for parsing arguments */
- struct Option *in_dir_opt, *in_stm_opt, *in_multipier, *in_order, *out_str_length, *out_str; /* options */
- struct Flag *out_seq; /* flags */
+ struct Option *in_dir_opt, *in_stm_opt, *in_multipier, *out_str_length, *out_str; /* options */
+ struct Flag *out_seq; /* flags */
/* initialize GIS environment */
G_gisinit(argv[0]); /* reads grass env, stores program name to G_program_name() */
/* initialize module */
module = G_define_module();
- module->keywords =
- _("stream, order, route azimuth, route direction");
+ module->keywords = _("stream, order, route azimuth, route direction");
module->description =
_("Route azimuth, direction and relation to streams of higher order");
@@ -54,71 +54,70 @@
in_dir_opt->gisprompt = "old,cell,raster";
in_dir_opt->description =
"Name of direction input map (r.watershed or r.stream.extract)";
in_multipier = G_define_option();
in_multipier->key = "multipier";
in_multipier->label = _("Multipier to store stream index value");
in_multipier->description = _("Must be > 0");
- in_multipier->required = YES;
- in_multipier->answer = "1000";
- in_multipier->type = TYPE_INTEGER;
- out_str = G_define_option();
- out_str->key = "cells";
- out_str->label = _("File to store pixel's position");
- out_str->required = NO;
- out_str->answer = NULL;
- out_str->type = TYPE_STRING;
- out_str->gisprompt = "new,cell,raster";
- out_str_length = G_define_option();
- out_str_length->key = "lengths";
- out_str_length->label = _("File to store current stream length");
- out_str_length->required = NO;
- out_str_length->answer = NULL;
- out_str_length->type = TYPE_STRING;
- out_str_length->gisprompt = "new,cell,raster";
- out_seq = G_define_flag();
- out_seq->key = 's';
- out_seq->description = _("Create new stream category sequence");
+ in_multipier->required = YES;
+ in_multipier->answer = "1000";
+ in_multipier->type = TYPE_INTEGER;
+ out_str = G_define_option();
+ out_str->key = "cells";
+ out_str->label = _("File to store pixel's position");
+ out_str->required = NO;
+ out_str->answer = NULL;
+ out_str->type = TYPE_STRING;
+ out_str->gisprompt = "new,cell,raster";
+ out_str_length = G_define_option();
+ out_str_length->key = "lengths";
+ out_str_length->label = _("File to store current stream length");
+ out_str_length->required = NO;
+ out_str_length->answer = NULL;
+ out_str_length->type = TYPE_STRING;
+ out_str_length->gisprompt = "new,cell,raster";
+ out_seq = G_define_flag();
+ out_seq->key = 's';
+ out_seq->description = _("Create new stream category sequence");
if (G_parser(argc, argv)) /* parser */
exit(EXIT_FAILURE);
- if (!out_str->answer && !out_str_length->answer)
- G_fatal_error("You must select one or more output maps: cells or lengths or both ");
+ if (!out_str->answer && !out_str_length->answer)
+ G_fatal_error
+ ("You must select one or more output maps: cells or lengths or both ");
G_get_window(&window);
/* stores input options to variables */
in_dirs = in_dir_opt->answer;
in_streams = in_stm_opt->answer;
out_streams_length = out_str_length->answer;
out_streams = out_str->answer;
seq_cats = (out_seq->answer == 0);
multipier = atoi(in_multipier->answer);
if (multipier <= 0)
G_fatal_error("Multipier must be > 0");
/* stores output options to variables */
nrows = G_window_rows();
ncols = G_window_cols();
create_base_maps();
find_inits();
calculate();
- if (out_streams_length) {
+ if (out_streams_length) {
set_null_f(streams_length);
write_maps_f(out_streams_length, streams_length);
- if (out_streams) {
+ if (out_streams) {
set_null_c(streams);
write_maps_c(out_streams, streams);
Modified: grass-addons/raster/r.stream.pos/pos.c
--- grass-addons/raster/r.stream.pos/pos.c 2010-06-03 11:33:08 UTC (rev 42459)
+++ grass-addons/raster/r.stream.pos/pos.c 2010-06-03 11:33:50 UTC (rev 42460)
@@ -4,158 +4,158 @@
#include "global.h"
-{ /* calcualte number of tributuaries */
+{ /* calculate number of tributuaries */
int nextr[9] = { 0, -1, -1, -1, 0, 1, 1, 1, 0 };
int nextc[9] = { 0, 1, 0, -1, -1, -1, 0, 1, 1 };
int trib = 0;
int i, j;
for (i = 1; i < 9; ++i) {
- if (r + nextr[i] < 0 || r + nextr[i] > (nrows - 1) || c + nextc[i] < 0
- || c + nextc[i] > (ncols - 1))
+ if (r + nextr[i] < 0 || r + nextr[i] > (nrows - 1) || c + nextc[i] < 0
+ || c + nextc[i] > (ncols - 1))
continue;
- j = (i + 4) > 8 ? i - 4 : i + 4;
- if (streams[r + nextr[i]][c + nextc[i]] > 0 &&
- dirs[r + nextr[i]][c + nextc[i]] == j)
- trib++;
+ j = (i + 4) > 8 ? i - 4 : i + 4;
+ if (streams[r + nextr[i]][c + nextc[i]] > 0 &&
+ dirs[r + nextr[i]][c + nextc[i]] == j)
+ trib++;
- if(trib>1) {
- for (i = 1; i < 9; ++i) {
- continue;
- if (streams[r + nextr[i]][c + nextc[i]] == streams[r][c] &&
- trib--;
+ if (trib > 1) {
+ for (i = 1; i < 9; ++i) {
+ c + nextc[i] < 0 || c + nextc[i] > (ncols - 1))
+ continue;
+ if (streams[r + nextr[i]][c + nextc[i]] == streams[r][c] &&
+ trib--;
if (trib > 5)
- G_fatal_error("Error finding inits. Stream and direction maps probably do not match...");
+ G_fatal_error
+ ("Error finding inits. Stream and direction maps probably do not match...");
if (trib > 3)
G_warning("Stream network may be too dense...");
- return trib;
+ return trib;
} /* end trib_num */
int r, c;
- stream_num=0;
- s_streams = (STREAM *) G_malloc((nrows+ncols) * sizeof(STREAM));
+ stream_num = 0;
+ s_streams = (STREAM *) G_malloc((nrows + ncols) * sizeof(STREAM));
G_message("Finding inits...");
- for (r = 0; r < nrows; ++r) {
- for (c = 0; c < ncols; ++c) {
- if (streams[r][c] > 0) {
- if (trib_nums(r, c) != 1) { /* adding inits */
- if (stream_num>(2*(nrows+ncols)))
- if (stream_num>(nrows+ncols)) /* almost not possible */
- s_streams = G_realloc(s_streams,2*(nrows+ncols)*sizeof(STREAM));
- s_streams[stream_num].stream = streams[r][c];
- s_streams[stream_num].init_r = r;
- s_streams[stream_num++].init_c = c;
- } /* end if streams */
- } /* c */
+ for (r = 0; r < nrows; ++r) {
+ for (c = 0; c < ncols; ++c) {
+ if (streams[r][c] > 0) {
+ if (trib_nums(r, c) != 1) { /* adding inits */
+ if (stream_num > (2 * (nrows + ncols)))
+ G_fatal_error
+ if (stream_num > (nrows + ncols)) /* almost not possible */
+ s_streams =
+ G_realloc(s_streams,
+ 2 * (nrows + ncols) * sizeof(STREAM));
+ s_streams[stream_num].stream = streams[r][c];
+ s_streams[stream_num].init_r = r;
+ s_streams[stream_num++].init_c = c;
+ } /* end if streams */
+ } /* c */
} /* r */
return 0;
-int calculate (void) {
- int nextr[9] = { 0, -1, -1, -1, 0, 1, 1, 1, 0 };
- int nextc[9] = { 0, 1, 0, -1, -1, -1, 0, 1, 1 };
+ int nextr[9] = { 0, -1, -1, -1, 0, 1, 1, 1, 0 };
+ int nextc[9] = { 0, 1, 0, -1, -1, -1, 0, 1, 1 };
+ int s, d; /* s - streams index; d - direction */
+ int done = 1;
+ int r, c;
+ int next_r, next_c;
+ int cur_stream;
+ int cur_cat;
+ float cur_northing, cur_easting;
+ float next_northing, next_easting;
+ int cur_pixel;
+ float cur_length = 0.;
+ float cur_accum = 0.;
- int i, s, d; /* s - streams index; d - direction */
- int done = 1;
- int r, c;
- int next_r, next_c;
- int cur_stream;
- int cur_cat;
- float cur_northing, cur_easting;
- float next_northing, next_easting;
- int cur_pixel;
- float cur_length=0.;
- float cur_accum=0.;
- G_message("Calculating...");
- G_begin_distance_calculations();
- for (s=0; s<stream_num+1; ++s) { /* main loop on treams */
+ G_message("Calculating...");
+ G_begin_distance_calculations();
- if(s_streams[s].stream<0)
- continue;
- r = s_streams[s].init_r;
- c = s_streams[s].init_c;
- cur_stream=streams[r][c];
- cur_cat= (seq_cats) ? cur_stream : s;
+ for (s = 0; s < stream_num + 1; ++s) { /* main loop on treams */
- cur_length=0.;
- cur_accum=0.;
- cur_pixel=0;
- done=1;
+ if (s_streams[s].stream < 0)
+ continue;
- while(done) {
+ r = s_streams[s].init_r;
+ c = s_streams[s].init_c;
- cur_northing = window.north - (r + .5) * window.ns_res;
- cur_easting = window.west + (c + .5) * window.ew_res;
- d=dirs[r][c];
- next_r=r+nextr[d];
- next_c=c+nextc[d];
- if (d<1|| /* end of route: sink */
- r + nextr[d] < 0 || r + nextr[d] > (nrows - 1) || /*border*/
- c + nextc[d] < 0 || c + nextc[d] > (ncols - 1) ||
- streams[next_r][next_c]<1) { /* mask */
- cur_accum += (window.ns_res+window.ew_res)/2;
- cur_pixel++;
- streams_length[r][c] = cur_accum;
- if(out_streams)
- streams[r][c] = cur_cat * multipier + cur_pixel;
- break;
+ cur_stream = streams[r][c];
+ cur_cat = (seq_cats) ? cur_stream : s;
- next_northing = window.north - (next_r + .5) * window.ns_res;
- next_easting = window.west + (next_c + .5) * window.ew_res;
- cur_length = G_distance(next_easting, next_northing, cur_easting, cur_northing);
- cur_accum += cur_length;
- cur_pixel++;
- if(out_streams)
- r=next_r;
- c=next_c;
+ cur_length = 0.;
+ cur_accum = 0.;
+ cur_pixel = 0;
+ done = 1;
- if (streams[next_r][next_c] != cur_stream)
- break;
- } /* end while */
- } /* end for s*/
-return 0;
+ while (done) {
+ cur_northing = window.north - (r + .5) * window.ns_res;
+ cur_easting = window.west + (c + .5) * window.ew_res;
+ d = dirs[r][c];
+ next_r = r + nextr[d];
+ next_c = c + nextc[d];
+ if (d < 1 || /* end of route: sink */
+ r + nextr[d] < 0 || r + nextr[d] > (nrows - 1) || /*border */
+ c + nextc[d] < 0 || c + nextc[d] > (ncols - 1) || streams[next_r][next_c] < 1) { /* mask */
+ cur_accum += (window.ns_res + window.ew_res) / 2;
+ cur_pixel++;
+ streams_length[r][c] = cur_accum;
+ if (out_streams)
+ streams[r][c] = cur_cat * multipier + cur_pixel;
+ break;
+ next_northing = window.north - (next_r + .5) * window.ns_res;
+ next_easting = window.west + (next_c + .5) * window.ew_res;
+ cur_length =
+ G_distance(next_easting, next_northing, cur_easting,
+ cur_northing);
+ cur_accum += cur_length;
+ cur_pixel++;
+ if (out_streams)
+ r = next_r;
+ c = next_c;
+ if (streams[next_r][next_c] != cur_stream)
+ break;
+ } /* end while */
+ } /* end for s */
+ return 0;
