[GRASS-SVN] r42461 - grass-addons/raster/r.stream.stats
svn_grass at osgeo.org
Thu Jun 3 07:34:35 EDT 2010
Author: mmetz
Date: 2010-06-03 07:34:35 -0400 (Thu, 03 Jun 2010)
New Revision: 42461
grass-addons/raster/r.stream.stats/global.h
grass-addons/raster/r.stream.stats/io.c
grass-addons/raster/r.stream.stats/main.c
grass-addons/raster/r.stream.stats/print_stats.c
grass-addons/raster/r.stream.stats/stats.c
format and clean up code
Modified: grass-addons/raster/r.stream.stats/global.h
--- grass-addons/raster/r.stream.stats/global.h 2010-06-03 11:33:50 UTC (rev 42460)
+++ grass-addons/raster/r.stream.stats/global.h 2010-06-03 11:34:35 UTC (rev 42461)
@@ -18,54 +18,54 @@
#define SQRT2 1.414214
#define POINT struct points
POINT {
- int r, c;
- int is_outlet;
+ int r, c;
+ int is_outlet;
#define STREAM struct strs
STREAM {
- int index;
- int is_outlet;
- int r, c; /* outlet */
- float elev_diff;
- float elev_spring, elev_outlet;
- float slope; /* cumulative */
- float gradient;
- float length; /* cumulative */
- int order;
- double basin_area; /* basin order */
- int cell_num;
+ int index;
+ int is_outlet;
+ int r, c; /* outlet */
+ float elev_diff;
+ float elev_spring, elev_outlet;
+ float slope; /* cumulative */
+ float gradient;
+ float length; /* cumulative */
+ int order;
+ double basin_area; /* basin order */
+ int cell_num;
#define STATS struct statistics
STATS {
- int order;
- int stream_num;
- float sum_length;
- float avg_length;
- float std_length;
- float avg_slope;
- float std_slope;
- float avg_gradient;
- float std_gradient;
- double sum_area;
- double avg_area;
- double std_area;
- float avg_elev_diff;
- float std_elev_diff;
- float bifur_ratio;
- float std_bifur_ratio;
- float length_ratio;
- float std_length_ratio;
- float area_ratio;
- float std_area_ratio;
- float slope_ratio;
- float std_slope_ratio;
- float gradient_ratio;
- float std_gradient_ratio;
- float stream_frequency;
- float drainage_density;
+ int order;
+ int stream_num;
+ float sum_length;
+ float avg_length;
+ float std_length;
+ float avg_slope;
+ float std_slope;
+ float avg_gradient;
+ float std_gradient;
+ double sum_area;
+ double avg_area;
+ double std_area;
+ float avg_elev_diff;
+ float std_elev_diff;
+ float bifur_ratio;
+ float std_bifur_ratio;
+ float length_ratio;
+ float std_length_ratio;
+ float area_ratio;
+ float std_area_ratio;
+ float slope_ratio;
+ float std_slope_ratio;
+ float gradient_ratio;
+ float std_gradient_ratio;
+ float stream_frequency;
+ float drainage_density;
/* functions.c */
@@ -78,6 +78,7 @@
int init_streams (void);
double fill_basin (int r,int c);
int calculate_basins (void);
+int calculate_streams(void);
int stats(void);
int fifo_insert (POINT point);
POINT fifo_return_del (void);
Modified: grass-addons/raster/r.stream.stats/io.c
--- grass-addons/raster/r.stream.stats/io.c 2010-06-03 11:33:50 UTC (rev 42460)
+++ grass-addons/raster/r.stream.stats/io.c 2010-06-03 11:34:35 UTC (rev 42461)
@@ -60,7 +60,6 @@
streams = (CELL **) G_malloc(sizeof(CELL *) * nrows);
elevation = (FCELL **) G_malloc(sizeof(FCELL *) * nrows);
for (r = 0; r < nrows; ++r) {
/* dirs & streams */
@@ -116,7 +115,6 @@
} /* end switch */
for (c = 0; c < ncols; ++c) {
if (G_is_c_null_value(&r_dirs[c])) {
dirs[r][c] = 0;
Modified: grass-addons/raster/r.stream.stats/main.c
--- grass-addons/raster/r.stream.stats/main.c 2010-06-03 11:33:50 UTC (rev 42460)
+++ grass-addons/raster/r.stream.stats/main.c 2010-06-03 11:34:35 UTC (rev 42461)
@@ -31,7 +31,6 @@
int main(int argc, char *argv[])
struct GModule *module; /* GRASS module for parsing arguments */
struct Option *in_dir_opt, *in_stm_opt, *in_elev_opt; /* options */
struct Flag *out_hack; /* flags */
@@ -67,7 +66,6 @@
in_elev_opt->gisprompt = "old,cell,raster";
in_elev_opt->description = "Name of elevation map";
/* Define the different flags */
out_hack = G_define_flag();
Modified: grass-addons/raster/r.stream.stats/print_stats.c
--- grass-addons/raster/r.stream.stats/print_stats.c 2010-06-03 11:33:50 UTC (rev 42460)
+++ grass-addons/raster/r.stream.stats/print_stats.c 2010-06-03 11:34:35 UTC (rev 42461)
@@ -6,7 +6,6 @@
int print_stats(void)
int i;
/* summary statistics */
@@ -88,4 +87,5 @@
ord_stats[i].drainage_density * 1000,
ord_stats[i].stream_frequency * 1000000);
+ return 0;
Modified: grass-addons/raster/r.stream.stats/stats.c
--- grass-addons/raster/r.stream.stats/stats.c 2010-06-03 11:33:50 UTC (rev 42460)
+++ grass-addons/raster/r.stream.stats/stats.c 2010-06-03 11:34:35 UTC (rev 42461)
@@ -6,12 +6,11 @@
int init_streams(void)
- int d, i, j; /* d: direction, i: iteration */
+ int d, i; /* d: direction, i: iteration */
int r, c;
int next_stream = -1, cur_stream;
int out_max = ncols + nrows;
POINT *outlets;
int nextr[9] = { 0, -1, -1, -1, 0, 1, 1, 1, 0 };
int nextc[9] = { 0, 1, 0, -1, -1, -1, 0, 1, 1 };
@@ -43,12 +42,12 @@
if (cur_stream != next_stream) { /* is outlet or node! */
outlets[outlets_num].r = r;
outlets[outlets_num].c = c;
- if (next_stream==-1)
- outlets[outlets_num].is_outlet=1;
- else
- outlets[outlets_num].is_outlet=0;
+ if (next_stream == -1)
+ outlets[outlets_num].is_outlet = 1;
+ else
+ outlets[outlets_num].is_outlet = 0;
outlets_num++;
} /* end if streams */
@@ -77,39 +76,34 @@
int i, j, s, d; /* s - streams index */
int done = 1;
int r, c;
float cur_northing, cur_easting;
float next_northing, next_easting;
float diff_elev, cur_length;
- int cur_stream_order;
G_begin_distance_calculations();
for (s = 0; s < outlets_num; ++s) {
r = stat_streams[s].r;
c = stat_streams[s].c;
- cur_northing = window.north - (r + .5) * window.ns_res;
+ cur_northing = window.north - (r + .5) * window.ns_res;
cur_easting = window.west + (c + .5) * window.ew_res;
- d= (dirs[r][c]==0) ? 2 : abs(dirs[r][c]);
- next_northing =
- window.north - (r + nextr[d] + .5) * window.ns_res;
- next_easting =
- window.west + (c + nextc[d] + .5) * window.ew_res;
+ d = (dirs[r][c] == 0) ? 2 : abs(dirs[r][c]);
+ next_northing = window.north - (r + nextr[d] + .5) * window.ns_res;
+ next_easting = window.west + (c + nextc[d] + .5) * window.ew_res;
-/* init length */
- stat_streams[s].length=
- G_distance(next_easting, next_northing, cur_easting,
- cur_northing);
+ /* init length */
+ stat_streams[s].length =
+ G_distance(next_easting, next_northing, cur_easting,
+ cur_northing);
done = 1;
while (done) {
@@ -159,8 +153,9 @@
int calculate_basins(void)
int i;
- total_basins=0.;
+ total_basins = 0.;
G_begin_cell_area_calculations();
fifo_max = 4 * (nrows + ncols);
fifo_outlet = (POINT *) G_malloc((fifo_max + 1) * sizeof(POINT));
@@ -168,10 +163,10 @@
for (i = 0; i < outlets_num; ++i) {
stat_streams[i].basin_area =
fill_basin(stat_streams[i].r, stat_streams[i].c);
- if (stat_streams[i].is_outlet)
- total_basins += stat_streams[i].basin_area;
+ if (stat_streams[i].is_outlet)
+ total_basins += stat_streams[i].basin_area;
G_free(fifo_outlet);
return 0;
@@ -181,7 +176,6 @@
int i, j;
double area;
POINT n_cell;
@@ -224,7 +218,7 @@
POINT fifo_return_del(void)
- if (head > fifo_max)
+ if (head >= fifo_max)
head = -1;
return fifo_outlet[++head];
@@ -376,24 +370,23 @@
ord_stats[i - 1].bifur_ratio =
ord_stats[i - 1].stream_num / (float)ord_stats[i].stream_num;
- ord_stats[i-1].length_ratio =
- (i==1) ? 0 :
- ord_stats[i].avg_length / ord_stats[i-1].avg_length;
+ ord_stats[i - 1].length_ratio =
+ (i == 1) ? 0 :
+ ord_stats[i].avg_length / ord_stats[i - 1].avg_length;
ord_stats[i].area_ratio =
- (i==1) ? 0 :
- ord_stats[i].avg_area / ord_stats[i-1].avg_area;
+ (i == 1) ? 0 : ord_stats[i].avg_area / ord_stats[i - 1].avg_area;
ord_stats[i - 1].slope_ratio =
ord_stats[i - 1].avg_slope / ord_stats[i].avg_slope;
ord_stats[i - 1].gradient_ratio =
ord_stats[i - 1].avg_gradient / ord_stats[i].avg_gradient;
ord_stats[i].stream_frequency =
ord_stats[i].stream_num / ord_stats[i].sum_area;
ord_stats[i].drainage_density =
ord_stats[i].sum_length / ord_stats[i].sum_area;
@@ -463,5 +456,5 @@
stats_total.drainage_density =
stats_total.sum_length / stats_total.sum_area;
-return 0;
+ return 0;
