[GRASS-SVN] r42463 - grass/branches/develbranch_6/locale/po
svn_grass at osgeo.org
Thu Jun 3 10:56:51 EDT 2010
Author: neteler
Date: 2010-06-03 10:56:50 -0400 (Thu, 03 Jun 2010)
New Revision: 42463
grass/branches/develbranch_6/locale/po/grasswxpy_it.po
Andrea Giacomelli : cont'ed
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_it.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_it.po 2010-06-03 14:56:14 UTC (rev 42462)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_it.po 2010-06-03 14:56:50 UTC (rev 42463)
@@ -14,8 +14,8 @@
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
+"Plural-Forms: nplurals=2; plural=(n != 1);\n"
"X-Generator: Lokalize 1.0\n"
-"Plural-Forms: nplurals=2; plural=(n != 1);\n"
#: ../gui/wxpython/wxgui.py:101
msgid "GRASS GIS Layer Manager"
@@ -492,11 +492,11 @@
#: ../gui/wxpython/icons/icon.py:212
msgid "Add raster flow arrows"
-msgstr ""
+msgstr "Aggiungi le direzioni di flusso raster"
#: ../gui/wxpython/icons/icon.py:214
msgid "Add raster cell numbers"
-msgstr ""
+msgstr "Aggiungi i valori numerici delle celle raster"
#: ../gui/wxpython/icons/icon.py:216
msgid "Add thematic layer"
@@ -512,11 +512,11 @@
#: ../gui/wxpython/icons/icon.py:222
msgid "Add geodesic line layer"
-msgstr ""
+msgstr "Aggiungi layer di linee geodetiche"
#: ../gui/wxpython/icons/icon.py:224
msgid "Add rhumbline layer"
-msgstr ""
+msgstr "Aggiungi layer di linee lossodromiche"
#: ../gui/wxpython/icons/icon.py:226
msgid "Add labels"
@@ -974,7 +974,6 @@
msgstr "Importa più raster usando GDAL"
#: ../gui/wxpython/menustrings.py:22
-#, fuzzy
msgid "Converts selected GDAL layers to GRASS raster maps using r.in.gdal"
msgstr ""
"Converti i layer GDAL selezionati in una mappa raster GRASS usando r.in.gdal"
@@ -992,7 +991,6 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:26
-#, fuzzy
msgid "Link GDAL supported raster files to a binary raster map layers"
msgstr "Importa file raster supportato da GDAL in un layer raster binario"
@@ -1111,7 +1109,6 @@
msgstr "Importa diversi dati vettoriali usando OGR"
#: ../gui/wxpython/menustrings.py:53
-#, fuzzy
msgid "Converts selected OGR layers to GRASS vector maps using v.in.ogr"
msgstr "Converte i layer OGR selezionati in vettori GRASS usando v.in.ogr"
@@ -1128,7 +1125,6 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:57
-#, fuzzy
msgid "Creates a new vectors as a read-only link to OGR layers"
msgstr "Crea nuovo vettore come link in sola lettura a un layer OGR"
@@ -1169,7 +1165,6 @@
msgstr "Importa diversi layer DXF"
#: ../gui/wxpython/menustrings.py:67
-#, fuzzy
msgid "Converts selected DXF layers to GRASS vector maps (using v.in.dxf)"
msgstr ""
"Converte i layer DXF selezionati in mappe vettoriali GRASS (usando v.in.dxf)"
@@ -4338,7 +4333,7 @@
#: ../gui/wxpython/gui_modules/histogram.py:351
msgid "Select font for histogram text"
-msgstr ""
+msgstr "Seleziona il tipo di carattere per il testo dell'istogramma"
#: ../gui/wxpython/gui_modules/histogram.py:397
#: ../gui/wxpython/gui_modules/mapdisp.py:1187
@@ -4394,26 +4389,23 @@
#: ../gui/wxpython/gui_modules/mcalc_builder.py:138
msgid "divide"
-msgstr ""
+msgstr "dividi"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:140
-#, fuzzy
msgid "add"
-msgstr "Aggiungi"
+msgstr "somma"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:142
-#, fuzzy
msgid "subtract"
-msgstr "superficie"
+msgstr "sottrai"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:144
msgid "modulus"
msgstr ""
#: ../gui/wxpython/gui_modules/mcalc_builder.py:146
-#, fuzzy
msgid "multiply"
-msgstr "[multiplo]"
+msgstr "moltiplica"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:151
msgid "left shift"
@@ -4428,40 +4420,36 @@
msgstr ""
#: ../gui/wxpython/gui_modules/mcalc_builder.py:157
-#, fuzzy
msgid "greater than"
-msgstr "più corto di"
+msgstr "maggiore di"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:159
-#, fuzzy
msgid "greater than or equal to"
msgstr "Crea o ricrea topologia"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:161
msgid "less than or equal to"
-msgstr ""
+msgstr "minore o uguale a"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:163
-#, fuzzy
msgid "less than"
-msgstr "più lungo di"
+msgstr "minore di"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:165
msgid "equal to"
-msgstr ""
+msgstr "uguale a"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:167
msgid "not equal to"
-msgstr ""
+msgstr "non uguale a"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:170
-#, fuzzy
msgid "one's complement"
msgstr "Mostra region computazionale"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:172
msgid "NOT"
-msgstr ""
+msgstr "NOT"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:174
msgid "bitwise AND"
@@ -5702,7 +5690,7 @@
#: ../gui/wxpython/gui_modules/nviz_tools.py:166
#: ../gui/wxpython/gui_modules/nviz_tools.py:2638
msgid "Z-exag:"
-msgstr ""
+msgstr "esagerazione verticale"
#: ../gui/wxpython/gui_modules/nviz_tools.py:180
msgid "Look at:"
@@ -6061,9 +6049,8 @@
msgstr "Larghezza:"
#: ../gui/wxpython/gui_modules/nviz_tools.py:2779
-#, fuzzy
msgid "Marker:"
-msgstr "Livello:"
+msgstr ""
#: ../gui/wxpython/gui_modules/nviz_tools.py:2793
#: ../gui/wxpython/gui_modules/preferences.py:1465
@@ -6242,11 +6229,11 @@
#: ../gui/wxpython/gui_modules/gselect.py:923
msgid "Protocol"
-msgstr ""
+msgstr "Protocollo"
#: ../gui/wxpython/gui_modules/gselect.py:927
msgid "Source type"
-msgstr ""
+msgstr "Tipo di sorgente"
#: ../gui/wxpython/gui_modules/gselect.py:941
#: ../gui/wxpython/gui_modules/gselect.py:1077
@@ -8078,6 +8065,8 @@
"Drag %s with mouse in pointer mode to position.\n"
"Double-click to change options."
msgstr ""
+"Trascina %s con il mouse in modalità puntatore per posizionarlo.\n"
+"Dai un doppio clic per modificare le opzioni."
#: ../gui/wxpython/gui_modules/gdialogs.py:420
msgid ""
@@ -8111,6 +8100,8 @@
"Drag text with mouse in pointer mode to position.\n"
"Double-click to change options"
msgstr ""
+"Trascina il testo con il mouse in modalità puntatore per posizionarlo.\n"
#: ../gui/wxpython/gui_modules/gdialogs.py:733
msgid "&Load"
@@ -8544,7 +8535,7 @@
#: ../gui/wxpython/gui_modules/layertree.py:714
msgid "raster flow arrows"
-msgstr ""
+msgstr "direzioni di flusso raster"
#: ../gui/wxpython/gui_modules/layertree.py:717
#: ../gui/wxpython/gui_modules/georect.py:316
@@ -8569,7 +8560,7 @@
#: ../gui/wxpython/gui_modules/layertree.py:732
msgid "rhumbline"
-msgstr ""
+msgstr "linea lossodromica"
#: ../gui/wxpython/gui_modules/layertree.py:735
msgid "vector labels"
@@ -9667,6 +9658,26 @@
"non lo hai gi? fatto. Una scelta popolare ? \"grassdata\", situata nella tua "
"home"
+#, fuzzy
+msgid "Creates a lines vector map from an ASCII x,y points file."
+msgstr "Crea un vettore da file ASCI points o ASCII vector"
+msgid ""
+"Georeference, rectify, and import Terra-ASTER imagery and relative DEM's "
+"using gdalwarp."
+msgstr ""
+"Georeferenzia, rettifica e importa immagine Terra-ASTER e relativo DEM "
+"usando gdalwarp"
+msgid "Latitude/longitude maps"
+msgstr "Mappa latitudine/longitudine"
+msgid "Potential Sunshine Hours"
+msgstr "Ore potenziali di insolazione"
+msgid "Actual Evapotranspiration"
+msgstr "Evapotraspirazione attuale"
#~ msgid "Input DXF file"
#~ msgstr "File DXF di input"
@@ -9728,10 +9739,6 @@
#~ msgid "Link OGR layers"
#~ msgstr "Collegati a layers OGR"
-#, fuzzy
-#~ msgid "Creates a lines vector map from an ASCII x,y points file."
-#~ msgstr "Crea un vettore da file ASCI points o ASCII vector"
#~ msgid " (those in bold typeface are required)"
#~ msgstr " (quelli in grassetto sono richiesti)"
@@ -9820,13 +9827,6 @@
#~ msgstr "Rendi celle nulle opache"
#~ msgid ""
-#~ "Georeference, rectify, and import Terra-ASTER imagery and relative DEM's "
-#~ "using gdalwarp."
-#~ msgstr ""
-#~ "Georeferenzia, rettifica e importa immagine Terra-ASTER e relativo DEM "
-#~ "usando gdalwarp"
-#~ msgid ""
#~ "Converts coordinates from one projection to another (cs2cs frontend)."
#~ msgstr "Converti coordinate da una proiezione ad un'altra (cs2cs frontend)."
@@ -9839,15 +9839,6 @@
#~ msgid "Mosaics several images and extends colormap"
#~ msgstr "Crea un mosaico da più immagini ed estende la mappa dei colore"
-#~ msgid "Latitude/longitude maps"
-#~ msgstr "Mappa latitudine/longitudine"
-#~ msgid "Potential Sunshine Hours"
-#~ msgstr "Ore potenziali di insolazione"
-#~ msgid "Actual Evapotranspiration"
-#~ msgstr "Evapotraspirazione attuale"
#~ msgid "actual evapotranspiration for diurnal period (Bastiaanssen, 1995)"
#~ msgstr ""
#~ "Evapotraspirazione attuale per il periodo diurno (Bastiaanssen, 1995)"
@@ -10325,3 +10316,120 @@
#~ msgid "Univariate attribute statistics"
#~ msgstr "Statistiche univariate attributi"
+#~ msgid ""
+#~ "Reading workspace file <%s> failed. Invalid file, unable to parse XML "
+#~ "document."
+#~ msgstr ""
+#~ "Lettura file dell'ambiente di lavoro <%s> fallita. File invalido, "
+#~ "impossibile parsare il documento XML."
+#~ msgid "Official GRASS site: http://grass.osgeo.org"
+#~ msgstr "Sito ufficiale di GRASS: http://grass.osgeo.org"
+#~ msgid "GIS Library"
+#~ msgstr "Librerie GIS"
+#~ msgid "Force re-rendering of all layers"
+#~ msgstr "Forza l'aggiornamento di tutti i layers"
+#~ msgid "Show Nviz settings dialog"
+#~ msgstr "Mostra impostazioni NVIZ"
+#~ msgid "Nviz properties"
+#~ msgstr "Proprietà di NVIZ"
+#, fuzzy
+#~ msgid "Unable to read EPGS file: '%s'"
+#~ msgstr "Impossibile leggere i codici EPSG: %s"
+#, fuzzy
+#~ msgid "3D View Tools"
+#~ msgstr "Strumenti visualizzazione 3D"
+#~ msgid "Layer properties"
+#~ msgstr "Proprietà del layer"
+#~ msgid "Vector map <%s> is 3D"
+#~ msgstr "Mappa vettoriale <%s> è 3D"
+#~ msgid "Vector map <%s> is 2D"
+#~ msgstr "Mappa vettoriale <%s> è 2D"
+#~ msgid "Quit wxGUI. GRASS is not running."
+#~ msgstr "Esci da wxGUI. GRASS non è in esecuzione."
+#~ msgid "Unable to open file"
+#~ msgstr "Impossibile aprire il file"
+#, fuzzy
+#~ msgid "DXF file:"
+#~ msgstr "Scegli file DXF:"
+#~ msgid "Parameter not found: %s"
+#~ msgstr "Paramentro non trovato:%s"
+#~ msgid "Parameter %(name)s (%(desc)s) is missing.\n"
+#~ msgstr "Parametro %(name)s (%(desc)s) manca.\n"
+#~ msgid "Copy the current command string to the clipboard"
+#~ msgstr "Copia la seguente stringa di comando negli appunti"
+#~ msgid "Vector point layer not found (id=%d)"
+#~ msgstr "Vettore puntuale non trovato (id=%d)"
+#~ msgid "Unable to set data layer properties (id=%d)"
+#~ msgstr "Impossibile impostare proprietà del layer (id=%d)"
+#~ msgid "User GUI settings"
+#~ msgstr "Impostazione dell'interfaccia grafica"
+#~ msgid ""
+#~ "Check mapset to make it accessible, uncheck it to hide it.%sNote: "
+#~ "PERMANENT and current mapset are always accessible."
+#~ msgstr ""
+#~ "Marca mapset per renderlo accessibile, demarca per nasconderlo.%sNote: "
+#~ "PERMANENT e mapset corrente sono sembre accessibili"
+#~ msgid "Select file extension:"
+#~ msgstr "Seleziona l'estensione del file:"
+#~ msgid "Export GRASS raster as non-georeferenced PNG image format."
+#~ msgstr "Esporta raster GRASS in un'immagine PNG non georeferenziata"
+#~ msgid "E&xit"
+#~ msgstr "E&sci"
+#~ msgid "Raster"
+#~ msgstr "Raster"
+#~ msgid "Finds shortest path for selected starting and ending node."
+#~ msgstr ""
+#~ "Trova il percorso più breve per i nodi di partenza ed arrivo selezionati"
+#~ msgid "Volumes"
+#~ msgstr "Volumi"
+#~ msgid "Reconnect vector to database"
+#~ msgstr "Riconnetti mappa vettoriale al database"
+#~ msgid "GRASS GIS help"
+#~ msgstr "Aiuto GRASS GIS"
+#~ msgid "Warning: flag <%s> not found in '%s'"
+#~ msgstr "Attenzione: opzione <%s> non trovata in '%s'"
+#~ msgid "Warning: option <%s> not found in '%s'"
+#~ msgid "Close dialog on run"
+#~ msgstr "Chiudi dialogo dopo l'invio"
+#~ msgid "Search:"
+#~ msgstr "Cerca:"
+#~ msgid "Find module:"
+#~ msgstr "Trova modulo:"
+#~ msgid "Manage extensions"
+#~ msgstr "Gestisci estensioni"
