[GRASS-SVN] r42545 - in grass/trunk/gui/wxpython: gui_modules xml
Sun Jun 13 05:14:22 EDT 2010
Author: martinl
Date: 2010-06-10 19:52:14 +0000 (Thu, 10 Jun 2010)
New Revision: 42545
   grass/trunk/gui/wxpython/gui_modules/gmodeler.py
   grass/trunk/gui/wxpython/gui_modules/preferences.py
   grass/trunk/gui/wxpython/xml/grass-gxm.dtd
   grass/trunk/gui/wxpython/xml/menudata_modeler.xml
wxGUI/modeler: start implementing loops
Modified: grass/trunk/gui/wxpython/gui_modules/gmodeler.py
--- grass/trunk/gui/wxpython/gui_modules/gmodeler.py	2010-06-10 14:30:50 UTC (rev 42544)
+++ grass/trunk/gui/wxpython/gui_modules/gmodeler.py	2010-06-10 19:52:14 UTC (rev 42545)
@@ -7,6 +7,7 @@
  - Model
  - ModelFrame
  - ModelCanvas
+ - ModelObject
  - ModelAction
  - ModelSearchDialog
  - ModelData
@@ -19,7 +20,8 @@
  - ModelParamDialog
  - VariablesDialog
  - ValiablesListCtrl
+ - ModelLoop
 (C) 2010 by the GRASS Development Team
 This program is free software under the GNU General Public License
 (>=v2). Read the file COPYING that comes with GRASS for details.
@@ -74,6 +76,8 @@
     def __init__(self, canvas = None):
         self.actions    = list()    # list of recorded actions
         self.data       = list()    # list of recorded data items
+        self.loops      = list()    # list of recorded loops
         # model properties
         self.properties = { 'name'        : _("model"),
                             'description' : _("Script generated by wxGUI Graphical Modeler."),
@@ -91,6 +95,10 @@
         """!Return list of actions"""
         return self.actions
+    def GetLoops(self):
+        """!Return list of loops"""
+        return self.loops
     def GetProperties(self):
         """!Get model properties"""
         return self.properties
@@ -222,6 +230,16 @@
             actionItem.AddData(dataItem)
+        # load loops
+        for loop in gxmXml.loops:
+            loopItem = ModelLoop(parent = self,
+                                 x = loop['pos'][0],
+                                 y = loop['pos'][1],
+                                 width = loop['size'][0],
+                                 height = loop['size'][1],
+                                 text = loop['text'])
+            self.loops.append(loopItem)
     def IsValid(self):
         """Return True if model is valid"""
         if self.Validate():
@@ -996,6 +1014,20 @@
         self.defineRelation = { 'from' : None,
                                 'to'   : None }
+    def OnDefineLoop(self, event):
+        """!Define new loop in the model"""
+        self.ModelChanged()
+        width, height = self.canvas.GetSize()
+        loop = ModelLoop(self, x = width/2, y = height/2)
+        self.canvas.diagram.AddShape(loop)
+        loop.Show(True)
+        self._addEvent(loop)
+        # self.model.AddAction(action)
+        self.canvas.Refresh()
     def OnAddAction(self, event):
         """!Add action to model"""
         if self.searchDialog is None:
@@ -1224,6 +1256,12 @@
             for rel in data.GetRelations():
                 self.AddLine(rel)
+        # load loops
+        for loop in self.model.GetLoops():
+            loop.Show(True)
         self.SetStatusText('', 0)
         self.canvas.Refresh(True)
@@ -1237,11 +1275,7 @@
         self.ModelChanged(False)
         tmpfile = tempfile.TemporaryFile(mode='w+b')
         try:
-            WriteModelFile(fd = tmpfile,
-                           actions = self.model.GetActions(),
-                           data = self.model.GetData(),
-                           properties = self.model.GetProperties(),
-                           variables = self.model.GetVariables())
+            WriteModelFile(fd = tmpfile, model = self.model)
         except StandardError:
             GMessage(parent = self,
                      message = _("Writing current settings to model file failed."))
@@ -1803,6 +1837,12 @@
         self.frame.ModelChanged()
         if self._previousHandler:
             self._previousHandler.OnBeginDragLeft(x, y, keys, attachment)
+    def OnEndSize(self, x, y):
+        """!Resize shape"""
+        self.frame.ModelChanged()
+        if self._previousHandler:
+            self._previousHandler.OnEndSize(x, y)
     def OnRightClick(self, x, y, keys = 0, attachment = 0):
         """!Right click -> pop-up menu"""
@@ -2077,11 +2117,13 @@
         self.variables  = dict()
         self.data    = list()
         self._processProperties()
         self._processVariables()
         self._processActions()
         self._processData()
+        self._processLoops()
     def _filterValue(self, value):
         """!Filter value
@@ -2127,7 +2169,10 @@
     def _processVariables(self):
         """!Process model variables"""
-        for node in self.root.findall('variable'):
+        vnode = self.root.find('variables')
+        if vnode is None:
+            return
+        for node in vnode.findall('variable'):
             name = node.get('name', '')
             if not name:
                 continue # should not happen
@@ -2264,15 +2309,26 @@
                 task.set_param(name, True, element = 'parameterized')
         return task
+    def _processLoops(self):
+        """!Process model loops"""
+        for node in self.root.findall('loop'):
+            pos, size = self._getDim(node)
+            text = self._filterValue(self._getNodeText(node, 'value')).strip()
+            self.loops.append({ 'pos' : pos,
+                                'size': size,
+                                'text' : text })
 class WriteModelFile:
     """!Generic class for writing model file"""
-    def __init__(self, fd, actions, data, properties, variables):
+    def __init__(self, fd, model):
         self.fd         = fd
-        self.actions    = actions
-        self.data       = data
-        self.properties = properties
-        self.variables  = variables
+        self.actions    = model.GetActions()
+        self.data       = model.GetData()
+        self.properties = model.GetProperties()
+        self.variables  = model.GetVariables()
+        self.loops      = model.GetLoops()
         self.indent = 0
@@ -2282,6 +2338,7 @@
         self._variables()
         self._actions()
         self._data()
+        self._loops()
         self._footer()
@@ -2322,6 +2379,8 @@
     def _variables(self):
         """!Write model variables"""
+        self.fd.write('%s<variables>\n' % (' ' * self.indent))
+        self.indent += 4
         for name, values in self.variables.iteritems():
             self.fd.write('%s<variable name="%s" type="%s">\n' % \
                               (' ' * self.indent, name, values['type']))
@@ -2334,6 +2393,8 @@
                                   (' ' * self.indent, values['description']))
             self.indent -= 4
             self.fd.write('%s</variable>\n' % (' ' * self.indent))
+        self.indent -= 4
+        self.fd.write('%s</variables>\n' % (' ' * self.indent))
     def _actions(self):
         """!Write actions"""
@@ -2425,6 +2486,21 @@
             self.indent -= 4
             self.fd.write('%s</data>\n' % (' ' * self.indent))
+    def _loops(self):
+        """!Write loops"""
+        for loop in self.loops:
+            self.fd.write('%s<loop pos="%d,%d" size="%d,%d">\n' % \
+                              (' ' * self.indent, loop.GetX(), loop.GetY(),
+                               loop.GetWidth(), loop.GetHeight()))
+            text = loop.GetText()
+            if text:
+                self.indent += 4
+                self.fd.write('%s<value>%s</value>\n' %
+                              (' ' * self.indent, self._filterValue(text)))
+                self.indent -= 4
+            self.fd.write('%s</loop>\n' % (' ' * self.indent))
 class PreferencesDialog(PreferencesBaseDialog):
     """!User preferences dialog"""
@@ -3189,7 +3265,33 @@
     def OnColClick(self, event):
         """!Click on column header (order by)"""
         event.Skip()
+class ModelLoop(ogl.RectangleShape):
+    def __init__(self, parent, x, y, width = None, height = None, text = None):
+        """!Defines a loop"""
+        self.parent  = parent
+        self.text    = text
+        if not width:
+            width = UserSettings.Get(group='modeler', key='loop', subkey=('size', 'width'))
+        if not height:
+            height = UserSettings.Get(group='modeler', key='loop', subkey=('size', 'height'))
+        if self.parent.GetCanvas():
+            ogl.RectangleShape.__init__(self, width, height)
+            self.SetCanvas(self.parent)
+            self.SetX(x)
+            self.SetY(y)
+            self.SetPen(wx.BLACK_PEN)
+            self.SetCornerRadius(100)
+            if text:
+                self.AddText(text)
+    def GetText(self):
+        """!Get loop text"""
+        return self.text
 def main():
     app = wx.PySimpleApp()
     wx.InitAllImageHandlers()
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py	2010-06-10 14:30:50 UTC (rev 42544)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py	2010-06-10 19:52:14 UTC (rev 42545)
@@ -552,6 +552,12 @@
                         'height' : 50,
+                'loop' : {
+                    'size' : {
+                        'width' : 175,
+                        'height' : 50,
Modified: grass/trunk/gui/wxpython/xml/grass-gxm.dtd
--- grass/trunk/gui/wxpython/xml/grass-gxm.dtd	2010-06-10 14:30:50 UTC (rev 42544)
+++ grass/trunk/gui/wxpython/xml/grass-gxm.dtd	2010-06-10 19:52:14 UTC (rev 42545)
@@ -14,7 +14,7 @@
 <!ELEMENT grass-gxm (gxm)>
-<!ELEMENT gxm (action*, data*, properties?, variable*)>
+<!ELEMENT gxm (action*, data*, properties?, variables?)>
 <!--    an action defines action properties (usually GRASS modules)
@@ -90,6 +90,7 @@
 <!--	a variable describes model variable
+<!ELEMENT variables       (variable*)>
 <!ELEMENT variable        (description?, value?)>
 <!ATTLIST variable  name  CDATA                      #REQUIRED>
 <!ATTLIST variable  type  (integer | float | string) #REQUIRED>
Modified: grass/trunk/gui/wxpython/xml/menudata_modeler.xml
--- grass/trunk/gui/wxpython/xml/menudata_modeler.xml	2010-06-10 14:30:50 UTC (rev 42544)
+++ grass/trunk/gui/wxpython/xml/menudata_modeler.xml	2010-06-10 19:52:14 UTC (rev 42545)
@@ -82,6 +82,12 @@
 	  <handler>OnDefineRelation</handler>
 	</menuitem>
 	<menuitem>
+	  <label>Define loop</label>
+	  <help>Defines loop in the model</help>
+	  <handler>OnDefineLoop</handler>
+	  <shortcut>Ctrl+L</shortcut>
+	</menuitem>
+	<menuitem>
 	  <label>Remove item</label>
 	  <help>Remove action/data from model</help>
 	  <handler>OnRemoveItem</handler>
