[GRASS-SVN] r42546 - in grass/branches/develbranch_6/gui/wxpython:
gui_modules xml
svn_grass at osgeo.org
Sun Jun 13 05:14:22 EDT 2010
Author: martinl
Date: 2010-06-10 20:21:11 +0000 (Thu, 10 Jun 2010)
New Revision: 42546
grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
grass/branches/develbranch_6/gui/wxpython/xml/grass-gxm.dtd
grass/branches/develbranch_6/gui/wxpython/xml/menudata_modeler.xml
wxGUI/modeler: start implementing loops
(merge r42545 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2010-06-10 19:52:14 UTC (rev 42545)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2010-06-10 20:21:11 UTC (rev 42546)
@@ -7,6 +7,7 @@
- Model
- ModelFrame
- ModelCanvas
+ - ModelObject
- ModelAction
- ModelSearchDialog
- ModelData
@@ -19,7 +20,8 @@
- ModelParamDialog
- VariablesDialog
- ValiablesListCtrl
+ - ModelLoop
(C) 2010 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
@@ -74,6 +76,8 @@
def __init__(self, canvas = None):
self.actions = list() # list of recorded actions
self.data = list() # list of recorded data items
+ self.loops = list() # list of recorded loops
# model properties
self.properties = { 'name' : _("model"),
'description' : _("Script generated by wxGUI Graphical Modeler."),
@@ -91,6 +95,10 @@
"""!Return list of actions"""
return self.actions
+ def GetLoops(self):
+ """!Return list of loops"""
+ return self.loops
def GetProperties(self):
"""!Get model properties"""
return self.properties
@@ -222,6 +230,16 @@
actionItem.AddData(dataItem)
+ # load loops
+ for loop in gxmXml.loops:
+ loopItem = ModelLoop(parent = self,
+ x = loop['pos'][0],
+ y = loop['pos'][1],
+ width = loop['size'][0],
+ height = loop['size'][1],
+ text = loop['text'])
+ self.loops.append(loopItem)
def IsValid(self):
"""Return True if model is valid"""
if self.Validate():
@@ -996,6 +1014,20 @@
self.defineRelation = { 'from' : None,
'to' : None }
+ def OnDefineLoop(self, event):
+ """!Define new loop in the model"""
+ self.ModelChanged()
+ width, height = self.canvas.GetSize()
+ loop = ModelLoop(self, x = width/2, y = height/2)
+ self.canvas.diagram.AddShape(loop)
+ loop.Show(True)
+ self._addEvent(loop)
+ # self.model.AddAction(action)
+ self.canvas.Refresh()
def OnAddAction(self, event):
"""!Add action to model"""
if self.searchDialog is None:
@@ -1224,6 +1256,12 @@
for rel in data.GetRelations():
self.AddLine(rel)
+ # load loops
+ for loop in self.model.GetLoops():
+ loop.Show(True)
self.SetStatusText('', 0)
self.canvas.Refresh(True)
@@ -1237,11 +1275,7 @@
self.ModelChanged(False)
tmpfile = tempfile.TemporaryFile(mode='w+b')
try:
- WriteModelFile(fd = tmpfile,
- actions = self.model.GetActions(),
- data = self.model.GetData(),
- properties = self.model.GetProperties(),
- variables = self.model.GetVariables())
+ WriteModelFile(fd = tmpfile, model = self.model)
except StandardError:
GMessage(parent = self,
message = _("Writing current settings to model file failed."))
@@ -1803,6 +1837,12 @@
self.frame.ModelChanged()
if self._previousHandler:
self._previousHandler.OnBeginDragLeft(x, y, keys, attachment)
+ def OnEndSize(self, x, y):
+ """!Resize shape"""
+ self.frame.ModelChanged()
+ if self._previousHandler:
+ self._previousHandler.OnEndSize(x, y)
def OnRightClick(self, x, y, keys = 0, attachment = 0):
"""!Right click -> pop-up menu"""
@@ -2077,11 +2117,13 @@
self.variables = dict()
self.data = list()
self._processProperties()
self._processVariables()
self._processActions()
self._processData()
+ self._processLoops()
def _filterValue(self, value):
"""!Filter value
@@ -2127,7 +2169,10 @@
def _processVariables(self):
"""!Process model variables"""
- for node in self.root.findall('variable'):
+ vnode = self.root.find('variables')
+ if vnode is None:
+ return
+ for node in vnode.findall('variable'):
name = node.get('name', '')
if not name:
continue # should not happen
@@ -2264,15 +2309,26 @@
task.set_param(name, True, element = 'parameterized')
return task
+ def _processLoops(self):
+ """!Process model loops"""
+ for node in self.root.findall('loop'):
+ pos, size = self._getDim(node)
+ text = self._filterValue(self._getNodeText(node, 'value')).strip()
+ self.loops.append({ 'pos' : pos,
+ 'size': size,
+ 'text' : text })
class WriteModelFile:
"""!Generic class for writing model file"""
- def __init__(self, fd, actions, data, properties, variables):
+ def __init__(self, fd, model):
self.fd = fd
- self.actions = actions
- self.data = data
- self.properties = properties
- self.variables = variables
+ self.actions = model.GetActions()
+ self.data = model.GetData()
+ self.properties = model.GetProperties()
+ self.variables = model.GetVariables()
+ self.loops = model.GetLoops()
self.indent = 0
@@ -2282,6 +2338,7 @@
self._variables()
self._actions()
self._data()
+ self._loops()
self._footer()
@@ -2322,6 +2379,8 @@
def _variables(self):
"""!Write model variables"""
+ self.fd.write('%s<variables>\n' % (' ' * self.indent))
+ self.indent += 4
for name, values in self.variables.iteritems():
self.fd.write('%s<variable name="%s" type="%s">\n' % \
(' ' * self.indent, name, values['type']))
@@ -2334,6 +2393,8 @@
(' ' * self.indent, values['description']))
self.indent -= 4
self.fd.write('%s</variable>\n' % (' ' * self.indent))
+ self.indent -= 4
+ self.fd.write('%s</variables>\n' % (' ' * self.indent))
def _actions(self):
"""!Write actions"""
@@ -2425,6 +2486,21 @@
self.indent -= 4
self.fd.write('%s</data>\n' % (' ' * self.indent))
+ def _loops(self):
+ """!Write loops"""
+ for loop in self.loops:
+ self.fd.write('%s<loop pos="%d,%d" size="%d,%d">\n' % \
+ (' ' * self.indent, loop.GetX(), loop.GetY(),
+ loop.GetWidth(), loop.GetHeight()))
+ text = loop.GetText()
+ if text:
+ self.indent += 4
+ self.fd.write('%s<value>%s</value>\n' %
+ (' ' * self.indent, self._filterValue(text)))
+ self.indent -= 4
+ self.fd.write('%s</loop>\n' % (' ' * self.indent))
class PreferencesDialog(PreferencesBaseDialog):
"""!User preferences dialog"""
@@ -3189,7 +3265,33 @@
def OnColClick(self, event):
"""!Click on column header (order by)"""
event.Skip()
+class ModelLoop(ogl.RectangleShape):
+ def __init__(self, parent, x, y, width = None, height = None, text = None):
+ """!Defines a loop"""
+ self.parent = parent
+ self.text = text
+ if not width:
+ width = UserSettings.Get(group='modeler', key='loop', subkey=('size', 'width'))
+ if not height:
+ height = UserSettings.Get(group='modeler', key='loop', subkey=('size', 'height'))
+ if self.parent.GetCanvas():
+ ogl.RectangleShape.__init__(self, width, height)
+ self.SetCanvas(self.parent)
+ self.SetX(x)
+ self.SetY(y)
+ self.SetPen(wx.BLACK_PEN)
+ self.SetCornerRadius(100)
+ if text:
+ self.AddText(text)
+ def GetText(self):
+ """!Get loop text"""
+ return self.text
def main():
app = wx.PySimpleApp()
wx.InitAllImageHandlers()
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py 2010-06-10 19:52:14 UTC (rev 42545)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py 2010-06-10 20:21:11 UTC (rev 42546)
@@ -561,6 +561,12 @@
'height' : 50,
+ 'loop' : {
+ 'size' : {
+ 'width' : 175,
+ 'height' : 50,
Modified: grass/branches/develbranch_6/gui/wxpython/xml/grass-gxm.dtd
--- grass/branches/develbranch_6/gui/wxpython/xml/grass-gxm.dtd 2010-06-10 19:52:14 UTC (rev 42545)
+++ grass/branches/develbranch_6/gui/wxpython/xml/grass-gxm.dtd 2010-06-10 20:21:11 UTC (rev 42546)
@@ -14,7 +14,7 @@
<!ELEMENT grass-gxm (gxm)>
-<!ELEMENT gxm (action*, data*, properties?, variable*)>
+<!ELEMENT gxm (action*, data*, properties?, variables?)>
<!-- an action defines action properties (usually GRASS modules)
@@ -90,6 +90,7 @@
<!-- a variable describes model variable
+<!ELEMENT variables (variable*)>
<!ELEMENT variable (description?, value?)>
<!ATTLIST variable name CDATA #REQUIRED>
<!ATTLIST variable type (integer | float | string) #REQUIRED>
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata_modeler.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata_modeler.xml 2010-06-10 19:52:14 UTC (rev 42545)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata_modeler.xml 2010-06-10 20:21:11 UTC (rev 42546)
@@ -82,6 +82,12 @@
<handler>OnDefineRelation</handler>
</menuitem>
<menuitem>
+ <label>Define loop</label>
+ <help>Defines loop in the model</help>
+ <handler>OnDefineLoop</handler>
+ <shortcut>Ctrl+L</shortcut>
+ </menuitem>
+ <menuitem>
<label>Remove item</label>
<help>Remove action/data from model</help>
<handler>OnRemoveItem</handler>
