[GRASS-SVN] r42595 - grass-addons/gui/wxpython/wx.path
svn_grass at osgeo.org
Sun Jun 20 06:40:55 EDT 2010
Author: rashadkm
Date: 2010-06-20 10:40:55 +0000 (Sun, 20 Jun 2010)
New Revision: 42595
grass-addons/gui/wxpython/wx.path/wx.path.py
removed unwanted tool from toolbar
Modified: grass-addons/gui/wxpython/wx.path/wx.path.py
--- grass-addons/gui/wxpython/wx.path/wx.path.py 2010-06-20 09:25:44 UTC (rev 42594)
+++ grass-addons/gui/wxpython/wx.path/wx.path.py 2010-06-20 10:40:55 UTC (rev 42595)
@@ -53,7 +53,7 @@
sys.path.append(grassPath)
import render
-from toolbars import MapToolbar
+import toolbars
from preferences import globalSettings as UserSettings
from icon import Icons
from mapdisp_command import Command
@@ -306,10 +306,10 @@
gcmd.CommandThread(command,stdout=None,stderr=None).run()
command=["v.net", "input=myroads",'points=startend', 'out=vnet_out', 'op=connect', 'thresh=200']
- gcmd.CommandThread(command,stdout=None,stderr=None).run()
+ gcmd.CommandThread(command).run()
command=["v.net.path", 'vnet_out','afcol=forward', 'abcol=backward', 'out=tmp_vnet_path','file=tmp2']
self.mapname = 'tmp_vnet_path@' + grass.gisenv()['MAPSET']
self.cmd= ['d.vect', str("map=" + self.mapname),'col=red','width=2']
@@ -333,7 +333,87 @@
def GetLayerManager(self):
return self
+ def AddToolbar(self, name):
+ """!Add defined toolbar to the window
+ # default toolbar
+ self.toolbars['map'] = Toolbar(self, self.Map)
+ self._mgr.AddPane(self.toolbars['map'],
+ wx.aui.AuiPaneInfo().
+ Name("maptoolbar").Caption(_("Map Toolbar")).
+ ToolbarPane().Top().
+ LeftDockable(False).RightDockable(False).
+ BottomDockable(False).TopDockable(True).
+ CloseButton(False).Layer(2).
+ BestSize((self.toolbars['map'].GetSize())))
+class Toolbar(toolbars.MapToolbar):
+ def __init__(self, parent, mapcontent):
+ """!Map Display constructor
+ @param parent reference to MapFrame
+ @param mapcontent reference to render.Map (registred by MapFrame)
+ self.mapcontent = mapcontent # render.Map
+ toolbars.AbstractToolbar.__init__(self, parent = parent) # MapFrame
+ self.InitToolbar(self.ToolbarData())
+ # optional tools
+ self.action = { 'id' : self.pointer }
+ self.defaultAction = { 'id' : self.pointer,
+ 'bind' : self.parent.OnPointer }
+ self.OnTool(None)
+ self.EnableTool(self.zoomback, False)
+ self.FixSize(width = 90)
+ def ToolbarData(self):
+ """!Toolbar data"""
+ self.pointer = wx.NewId()
+ self.query = wx.NewId()
+ self.pan = wx.NewId()
+ self.zoomin = wx.NewId()
+ self.zoomout = wx.NewId()
+ self.zoomback = wx.NewId()
+ self.zoommenu = wx.NewId()
+ self.zoomextent = wx.NewId()
+ # tool, label, bitmap, kind, shortHelp, longHelp, handler
+ return (
+ (self.pointer, "pointer", Icons["pointer"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["pointer"].GetLabel(), Icons["pointer"].GetDesc(),
+ self.parent.OnPointer),
+ (self.query, "query", Icons["query"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["query"].GetLabel(), Icons["query"].GetDesc(),
+ self.parent.OnQuery),
+ (self.pan, "pan", Icons["pan"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["pan"].GetLabel(), Icons["pan"].GetDesc(),
+ self.parent.OnPan),
+ (self.zoomin, "zoom_in", Icons["zoom_in"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["zoom_in"].GetLabel(), Icons["zoom_in"].GetDesc(),
+ self.parent.OnZoomIn),
+ (self.zoomout, "zoom_out", Icons["zoom_out"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["zoom_out"].GetLabel(), Icons["zoom_out"].GetDesc(),
+ self.parent.OnZoomOut),
+ (self.zoomextent, "zoom_extent", Icons["zoom_extent"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["zoom_extent"].GetLabel(), Icons["zoom_extent"].GetDesc(),
+ self.parent.OnZoomToMap),
+ (self.zoomback, "zoom_back", Icons["zoom_back"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["zoom_back"].GetLabel(), Icons["zoom_back"].GetDesc(),
+ self.parent.OnZoomBack),
class PathApp(wx.App):
MapApp class
@@ -344,7 +424,7 @@
Map = render.Map()
else:
Map = None
- self.mapname = 'roads at PERMANENT'
+ self.mapname = 'myroads at PERMANENT'
self.cmd= ['d.vect', str("map=" + self.mapname)]
Map.AddLayer(type='vector', name=self.mapname, command=self.cmd)
@@ -359,9 +439,9 @@
if __name__ == "__main__":
- gm_map = PathApp(0)
+ path_app = PathApp(0)
- gm_map.MainLoop()
+ path_app.MainLoop()
sys.exit(0)
