[GRASS-SVN] r42596 - grass/trunk/mswindows
svn_grass at osgeo.org
Sun Jun 20 08:48:54 EDT 2010
Author: hellik
Date: 2010-06-20 12:48:54 +0000 (Sun, 20 Jun 2010)
New Revision: 42596
grass/trunk/mswindows/GRASS-Installer.nsi
attempt to get Grass70-wx-gui and a msys-windows-commandline
see http://lists.osgeo.org/pipermail/grass-dev/2010-June/050937.html
Modified: grass/trunk/mswindows/GRASS-Installer.nsi
--- grass/trunk/mswindows/GRASS-Installer.nsi 2010-06-20 10:40:55 UTC (rev 42595)
+++ grass/trunk/mswindows/GRASS-Installer.nsi 2010-06-20 12:48:54 UTC (rev 42596)
@@ -621,8 +621,13 @@
CreateShortCut "$DESKTOP\GRASS ${VERSION_NUMBER}.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-wxpython"\
"$INSTALL_DIR\icons\GRASS.ico" "" SW_SHOWMINIMIZED "" "Launch GRASS ${VERSION_NUMBER} with the new wxPython GUI"
- CreateShortCut "$DESKTOP\GRASS ${VERSION_NUMBER} with MSYS.lnk" "$INSTALL_DIR\msys\msys.bat" "/grass/bin/${GRASS_COMMAND} -wxpython"\
- "$INSTALL_DIR\icons\GRASS_MSys.ico" "" SW_SHOWNORMAL "" "Launch GRASS ${VERSION_NUMBER} with the new wxPython GUI and a MSYS UNIX terminal"
+ ; not working after changing to start Grass7 by grass70.py
+ ;CreateShortCut "$DESKTOP\GRASS ${VERSION_NUMBER} with MSYS.lnk" "$INSTALL_DIR\msys\msys.bat" "/grass/bin/${GRASS_COMMAND} -wxpython"\
+ ;"$INSTALL_DIR\icons\GRASS_MSys.ico" "" SW_SHOWNORMAL "" "Launch GRASS ${VERSION_NUMBER} with the new wxPython GUI and a MSYS UNIX terminal"
+ ; new attempt to get Grass70-wx-gui and a working msys-shell in a windows command line
+ CreateShortCut "$DESKTOP\GRASS ${VERSION_NUMBER} with MSYS.lnk" "$INSTALL_DIR\set_shell_start_${GRASS_COMMAND}.bat" ""\
+ "$INSTALL_DIR\icons\GRASS_MSys.ico" "" SW_SHOWNORMAL "" "Launch GRASS ${VERSION_NUMBER} with the new wxPython GUI and a MSYS-Windows-commandline"
;Create the Windows Start Menu Shortcuts
SetShellVarContext all
@@ -641,9 +646,12 @@
CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS Web Site.lnk" "$INSTALL_DIR\GRASS-WebSite.url" ""\
"$INSTALL_DIR\icons\GRASS_Web.ico" "" SW_SHOWNORMAL "" "Visit the GRASS website"
- CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS ${VERSION_NUMBER} with MSYS.lnk" "$INSTALL_DIR\msys\msys.bat" "/grass/bin/${GRASS_COMMAND} -wxpython"\
+ ;CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS ${VERSION_NUMBER} with MSYS.lnk" "$INSTALL_DIR\msys\msys.bat" "/grass/bin/${GRASS_COMMAND} -wxpython"\
+ CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS ${VERSION_NUMBER} with MSYS.lnk" "$INSTALL_DIR\set_shell_start_${GRASS_COMMAND}.bat" ""\
; FIXME: ship the WinGrass release notes .html file instead of URL
; http://trac.osgeo.org/grass/browser/grass-web/trunk/grass70/binary/mswindows/native/README.html?format=raw
; probably ship with devel versions too? ie Release Notes, not the Release Announcement press release.
@@ -704,6 +712,29 @@
FileClose $0
done_create_grass_command.bat:
+ ;Create the set_shell_start_grass.bat to start Grass7-wxgui and a msys-windows-commandline
+ ClearErrors
+ FileOpen $0 $INSTALL_DIR\set_shell_start_${GRASS_COMMAND}.bat w
+ IfErrors done_create_set_shell_start_grass.bat
+ FileWrite $0 '@echo off$\r$\n'
+ FileWrite $0 'rem #########################################################################$\r$\n'
+ FileWrite $0 'rem #$\r$\n'
+ FileWrite $0 'rem # File dynamically created by NSIS installer script$\r$\n'
+ FileWrite $0 'rem # Set SHELL and start GRASS$\r$\n'
+ FileWrite $0 '$\r$\n'
+ FileWrite $0 'rem *******Set SHELL***********$\r$\n'
+ FileWrite $0 'set SHELL="$INSTALL_DIR\msys\bin\sh.exe"$\r$\n'
+ FileWrite $0 '"$INSTALL_DIR\${GRASS_COMMAND}.bat"$\r$\n'
+ FileClose $0
+ done_create_set_shell_start_grass.bat:
;Set the UNIX_LIKE GRASS Path
Var /GLOBAL UNIX_LIKE_DRIVE
Var /GLOBAL UNIX_LIKE_GRASS_PATH
