[GRASS-SVN] r42661 - in grass/branches/releasebranch_6_4: .
locale/po
svn_grass at osgeo.org
Sun Jun 27 03:38:48 EDT 2010
Author: neteler
Date: 2010-06-27 07:38:48 +0000 (Sun, 27 Jun 2010)
New Revision: 42661
grass/branches/releasebranch_6_4/locale/po/grasswxpy_it.po
grass/branches/releasebranch_6_4/translators.csv
Francesco de Virgilio: cont'ed
Modified: grass/branches/releasebranch_6_4/locale/po/grasswxpy_it.po
--- grass/branches/releasebranch_6_4/locale/po/grasswxpy_it.po 2010-06-26 17:32:06 UTC (rev 42660)
+++ grass/branches/releasebranch_6_4/locale/po/grasswxpy_it.po 2010-06-27 07:38:48 UTC (rev 42661)
@@ -799,7 +799,7 @@
#: ../gui/wxpython/gui_modules/mcalc_builder.py:129
msgid "exponent"
-msgstr ""
+msgstr "esponente"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:131
msgid "divide"
@@ -815,7 +815,7 @@
#: ../gui/wxpython/gui_modules/mcalc_builder.py:137
msgid "modulus"
-msgstr ""
+msgstr "modulo"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:139
msgid "multiply"
@@ -875,7 +875,7 @@
#: ../gui/wxpython/gui_modules/mcalc_builder.py:171
msgid "logical AND"
-msgstr ""
+msgstr "AND logico"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:173
msgid "logical AND (ignores NULLs"
@@ -883,26 +883,25 @@
#: ../gui/wxpython/gui_modules/mcalc_builder.py:175
msgid "logical OR"
-msgstr ""
+msgstr "OR logico"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:177
msgid "logical OR (ignores NULLs"
msgstr ""
#: ../gui/wxpython/gui_modules/mcalc_builder.py:179
-#, fuzzy
msgid "conditional"
-msgstr "Opzionale"
+msgstr "opzionale"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:191
#, fuzzy, python-format
msgid "Name for new %s to create"
-msgstr "Nome per il nuovo vettore:"
+msgstr "Nome per il nuovo %s:"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:194
msgid "Insert existing %s"
-msgstr "sovrascrivi il file esistente"
+msgstr "Inserisci %s esistente"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:198
#, fuzzy
@@ -1900,7 +1899,7 @@
#: ../gui/wxpython/gui_modules/nviz_tools.py:275
#: ../gui/wxpython/gui_modules/nviz_tools.py:878
msgid "constant"
-msgstr ""
+msgstr "costante"
#: ../gui/wxpython/gui_modules/nviz_tools.py:335
#: ../gui/wxpython/gui_modules/nviz_tools.py:745
@@ -1952,7 +1951,7 @@
#: ../gui/wxpython/gui_modules/nviz_tools.py:401
#: ../gui/wxpython/gui_modules/nviz_tools.py:766
msgid "Shading:"
-msgstr ""
+msgstr "Ombreggiatura:"
#: ../gui/wxpython/gui_modules/nviz_tools.py:404
#: ../gui/wxpython/gui_modules/nviz_tools.py:581
@@ -1974,8 +1973,9 @@
msgstr ""
#: ../gui/wxpython/gui_modules/nviz_tools.py:430
+#, fuzzy
msgid "Use draw settings for all loaded surfaces"
-msgstr ""
+msgstr "Usa impostazioni di disegno per tutte le superfici caricate"
#: ../gui/wxpython/gui_modules/nviz_tools.py:444
msgid "Mask zeros:"
@@ -2472,8 +2472,9 @@
msgstr "Categoria"
#: ../gui/wxpython/gui_modules/vdigit.py:1420
+#, fuzzy
msgid "Mode"
-msgstr ""
+msgstr "Modalità"
#: ../gui/wxpython/gui_modules/vdigit.py:1442
@@ -3288,14 +3289,15 @@
msgstr "Cancella tutte le colonne"
#: ../gui/wxpython/gui_modules/dbm.py:1611
-#, fuzzy, python-format
+#, python-format
msgid ""
"Selected columns\n"
"%s\n"
"will PERMANENTLY removed from table. Do you want to drop the columns?"
msgstr ""
-"I record (%d) selezionati saranno permanentemente eliminati della tabella. "
-"Vuoi eliminarli?"
+"Le colonne selezionate\n"
+"%s\n"
+"saranno PERMANENTEMENTE eliminate della tabella. Vuoi eliminarle?"
#: ../gui/wxpython/gui_modules/dbm.py:1648
msgid "Unable to add column to the table. No column name defined."
@@ -3366,13 +3368,12 @@
msgstr "Chiave"
#: ../gui/wxpython/gui_modules/dbm.py:2228
-#, fuzzy
msgid ""
"Unknown default DB connection. Please define DB connection using db.connect "
"module."
msgstr ""
"Impossibile determinare le impostazioni della connessione del DB. Per favore "
-"definire la connessione al DB usando il modulo db.connect"
+"definire la connessione al DB usando il modulo db.connect."
#: ../gui/wxpython/gui_modules/dbm.py:2249
msgid "Add layer"
@@ -3647,9 +3648,8 @@
msgstr "Scegli file DXF da importare"
#: ../gui/wxpython/gui_modules/gdialogs.py:842
-#, fuzzy
msgid "DXF file:"
-msgstr "Scegli file DXF:"
+msgstr "File DXF:"
#: ../gui/wxpython/gui_modules/gdialogs.py:848
msgid "Source type"
@@ -3661,9 +3661,8 @@
msgstr "File"
#: ../gui/wxpython/gui_modules/gdialogs.py:851
-#, fuzzy
msgid "Directory"
-msgstr "Direzione"
+msgstr "Cartella"
#: ../gui/wxpython/gui_modules/gdialogs.py:853
msgid "Protocol"
@@ -3681,9 +3680,8 @@
#: ../gui/wxpython/gui_modules/gdialogs.py:880
#: ../gui/wxpython/gui_modules/gdialogs.py:1332
-#, fuzzy
msgid "Choose file"
+msgstr "Scegli file:"
#: ../gui/wxpython/gui_modules/gdialogs.py:899
#, fuzzy
@@ -3691,19 +3689,16 @@
msgstr "Formato"
#: ../gui/wxpython/gui_modules/gdialogs.py:912
-#, fuzzy
msgid "File:"
-msgstr "File"
+msgstr "File:"
#: ../gui/wxpython/gui_modules/gdialogs.py:915
-#, fuzzy
msgid "Directory:"
-msgstr "Direzione"
+msgstr "Cartella:"
#: ../gui/wxpython/gui_modules/gdialogs.py:918
-#, fuzzy
msgid "Database:"
-msgstr "Database"
+msgstr "Database:"
#: ../gui/wxpython/gui_modules/gdialogs.py:921
#, fuzzy
@@ -4808,6 +4803,8 @@
#: ../gui/wxpython/gis_set.py:208 ../gui/wxpython/gis_set.py:587
msgid "Unable to set GRASS database. Check your locale settings."
msgstr ""
+"Impossibile impostare il database di GRASS. Controlla le tue impostazioni "
+"locali."
#: ../gui/wxpython/gis_set.py:225
#, python-format
@@ -4825,6 +4822,9 @@
"\n"
"This mapset cannot be renamed."
msgstr ""
+"È richiesto il mapset <PERMANENT> per una location di GRASS valida.\n"
+"\n"
+"Questo mapset non può essere rinominato."
#: ../gui/wxpython/gis_set.py:453 ../gui/wxpython/gis_set.py:488
@@ -4884,6 +4884,9 @@
"\n"
"This mapset cannot be deleted."
msgstr ""
+"\n"
+"Questo mapset non può essere cancellato."
#: ../gui/wxpython/gis_set.py:530
#, python-format
Modified: grass/branches/releasebranch_6_4/translators.csv
--- grass/branches/releasebranch_6_4/translators.csv 2010-06-26 17:32:06 UTC (rev 42660)
+++ grass/branches/releasebranch_6_4/translators.csv 2010-06-27 07:38:48 UTC (rev 42661)
@@ -28,6 +28,7 @@
Lorenzo Moretti,<lorenzo.moretti bologna.enea.it>,IT
Luca Delucchi,<lucadeluge gmail.com>,IT
Andrea Giacomelli,<pibinko gmail.com>,IT
+Francesco de Virgilio,<fradeve11 gmail.com>,IT
Luciano Montanaro,<mikelima cirulla.net>,IT
Tobias Vigl,<vigltobias icqmail.com>,IT
Stefano Costa,<steko iosa.it>,IT
