[GRASS-SVN] r42662 - in grass/branches/develbranch_6: . locale/po
svn_grass at osgeo.org
Sun Jun 27 03:39:23 EDT 2010
Author: neteler
Date: 2010-06-27 07:39:23 +0000 (Sun, 27 Jun 2010)
New Revision: 42662
grass/branches/develbranch_6/locale/po/grasswxpy_it.po
grass/branches/develbranch_6/translators.csv
Francesco de Virgilio: cont'ed
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_it.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_it.po 2010-06-27 07:38:48 UTC (rev 42661)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_it.po 2010-06-27 07:39:23 UTC (rev 42662)
@@ -4385,7 +4385,7 @@
#: ../gui/wxpython/gui_modules/mcalc_builder.py:136
msgid "exponent"
-msgstr ""
+msgstr "esponente"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:138
msgid "divide"
@@ -4401,7 +4401,7 @@
#: ../gui/wxpython/gui_modules/mcalc_builder.py:144
msgid "modulus"
-msgstr ""
+msgstr "modulo"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:146
msgid "multiply"
@@ -4461,7 +4461,7 @@
#: ../gui/wxpython/gui_modules/mcalc_builder.py:178
msgid "logical AND"
-msgstr ""
+msgstr "AND logico"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:180
msgid "logical AND (ignores NULLs"
@@ -4469,26 +4469,25 @@
#: ../gui/wxpython/gui_modules/mcalc_builder.py:182
msgid "logical OR"
-msgstr ""
+msgstr "OR logico"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:184
msgid "logical OR (ignores NULLs"
msgstr ""
#: ../gui/wxpython/gui_modules/mcalc_builder.py:186
-#, fuzzy
msgid "conditional"
-msgstr "Opzionale"
+msgstr "opzionale"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:198
#, fuzzy, python-format
msgid "Name for new %s to create"
-msgstr "Nome per il nuovo vettore:"
+msgstr "Nome per il nuovo %s:"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:201
msgid "Insert existing %s"
-msgstr "sovrascrivi il file esistente"
+msgstr "Inserisci %s esistente"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:205
#, fuzzy
@@ -5798,7 +5797,7 @@
#: ../gui/wxpython/gui_modules/nviz_tools.py:309
#: ../gui/wxpython/gui_modules/nviz_tools.py:991
msgid "constant"
-msgstr ""
+msgstr "costante"
#: ../gui/wxpython/gui_modules/nviz_tools.py:369
#: ../gui/wxpython/gui_modules/nviz_tools.py:858
@@ -5825,7 +5824,7 @@
#: ../gui/wxpython/gui_modules/nviz_tools.py:391
#: ../gui/wxpython/gui_modules/nviz_tools.py:879
msgid "Shading:"
-msgstr ""
+msgstr "Ombreggiatura:"
#: ../gui/wxpython/gui_modules/nviz_tools.py:394
#: ../gui/wxpython/gui_modules/nviz_tools.py:651
@@ -5843,8 +5842,9 @@
msgstr ""
#: ../gui/wxpython/gui_modules/nviz_tools.py:404
+#, fuzzy
msgid "Use draw settings for all loaded surfaces"
-msgstr ""
+msgstr "Usa impostazioni di disegno per tutte le superfici caricate"
#: ../gui/wxpython/gui_modules/nviz_tools.py:411
msgid "Coarse:"
@@ -6216,9 +6216,8 @@
msgstr "File"
#: ../gui/wxpython/gui_modules/gselect.py:915
-#, fuzzy
msgid "Directory"
-msgstr "Direzione"
+msgstr "Cartella"
#: ../gui/wxpython/gui_modules/gselect.py:919
#: ../gui/wxpython/gui_modules/dbm.py:2276
@@ -6247,24 +6246,20 @@
#: ../gui/wxpython/gui_modules/gselect.py:959
#: ../gui/wxpython/gui_modules/gselect.py:1202
-#, fuzzy
msgid "Choose file"
-msgstr "Scegli file DXF:"
+msgstr "Scegli file:"
#: ../gui/wxpython/gui_modules/gselect.py:990
-#, fuzzy
msgid "File:"
-msgstr "File"
+msgstr "File:"
#: ../gui/wxpython/gui_modules/gselect.py:993
-#, fuzzy
msgid "Directory:"
-msgstr "Direzione"
+msgstr "Cartella:"
#: ../gui/wxpython/gui_modules/gselect.py:996
-#, fuzzy
msgid "Database:"
-msgstr "Database"
+msgstr "Database:"
#: ../gui/wxpython/gui_modules/gselect.py:999
#, fuzzy
@@ -6499,8 +6494,9 @@
msgstr "Aggiungi record nella tabella"
#: ../gui/wxpython/gui_modules/vdigit.py:1478
+#, fuzzy
msgid "Mode"
-msgstr ""
+msgstr "Modalità"
#: ../gui/wxpython/gui_modules/vdigit.py:1500
@@ -7834,14 +7830,15 @@
msgstr "Cancella tutte le colonne"
#: ../gui/wxpython/gui_modules/dbm.py:1703
-#, fuzzy, python-format
+#, python-format
msgid ""
"Selected columns\n"
"%s\n"
"will PERMANENTLY removed from table. Do you want to drop the columns?"
msgstr ""
-"I record (%d) selezionati saranno permanentemente eliminati della tabella. "
-"Vuoi eliminarli?"
+"Le colonne selezionate\n"
+"%s\n"
+"saranno PERMANENTEMENTE eliminate della tabella. Vuoi eliminarle?"
#: ../gui/wxpython/gui_modules/dbm.py:1741
msgid "Unable to add column to the table. No column name defined."
@@ -7901,13 +7898,12 @@
msgstr "Chiave"
#: ../gui/wxpython/gui_modules/dbm.py:2352
-#, fuzzy
msgid ""
"Unknown default DB connection. Please define DB connection using db.connect "
"module."
msgstr ""
"Impossibile determinare le impostazioni della connessione del DB. Per favore "
-"definire la connessione al DB usando il modulo db.connect"
+"definire la connessione al DB usando il modulo db.connect."
#: ../gui/wxpython/gui_modules/dbm.py:2373
msgid "Add layer"
@@ -9506,6 +9502,8 @@
#: ../gui/wxpython/gis_set.py:208 ../gui/wxpython/gis_set.py:572
msgid "Unable to set GRASS database. Check your locale settings."
msgstr ""
+"Impossibile impostare il database di GRASS. Controlla le tue impostazioni "
+"locali."
#: ../gui/wxpython/gis_set.py:226
#, python-format
@@ -9523,6 +9521,9 @@
"\n"
"This mapset cannot be renamed."
msgstr ""
+"È richiesto il mapset <PERMANENT> per una location di GRASS valida.\n"
+"\n"
+"Questo mapset non può essere rinominato."
#: ../gui/wxpython/gis_set.py:445 ../gui/wxpython/gis_set.py:480
@@ -9582,6 +9583,9 @@
"\n"
"This mapset cannot be deleted."
msgstr ""
+"\n"
+"Questo mapset non può essere cancellato."
#: ../gui/wxpython/gis_set.py:522
#, python-format
@@ -10362,9 +10366,8 @@
#~ msgid "Unable to open file"
#~ msgstr "Impossibile aprire il file"
-#, fuzzy
#~ msgid "DXF file:"
-#~ msgstr "Scegli file DXF:"
+#~ msgstr "File DXF:"
#~ msgid "Parameter not found: %s"
#~ msgstr "Paramentro non trovato:%s"
Modified: grass/branches/develbranch_6/translators.csv
--- grass/branches/develbranch_6/translators.csv 2010-06-27 07:38:48 UTC (rev 42661)
+++ grass/branches/develbranch_6/translators.csv 2010-06-27 07:39:23 UTC (rev 42662)
@@ -29,6 +29,7 @@
Lorenzo Moretti,<lorenzo.moretti bologna.enea.it>,IT
Luca Delucchi,<lucadeluge gmail.com>,IT
Andrea Giacomelli,<pibinko gmail.com>,IT
+Francesco de Virgilio,<fradeve11 gmail.com>,IT
Luciano Montanaro,<mikelima cirulla.net>,IT
Tobias Vigl,<vigltobias icqmail.com>,IT
Stefano Costa,<steko iosa.it>,IT
