[GRASS-SVN] r41321 - grass/branches/develbranch_6/mswindows
svn_grass at osgeo.org
Sun Mar 7 11:28:06 EST 2010
Author: hellik
Date: 2010-03-07 11:28:06 -0500 (Sun, 07 Mar 2010)
New Revision: 41321
grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi
wingrass-installer improvements - part 3:
invoking g.mkfontcap by the wingrass-installer
Modified: grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi
--- grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi 2010-03-07 16:23:29 UTC (rev 41320)
+++ grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi 2010-03-07 16:28:06 UTC (rev 41321)
@@ -417,7 +417,64 @@
;add GRASS files
SetOutPath "$INSTALL_DIR"
File /r ${PACKAGE_FOLDER}\*.*
+ ;create run_gmkfontcap.bat
+ ClearErrors
+ FileOpen $0 $INSTALL_DIR\etc\run_gmkfontcap.bat w
+ IfErrors done_create_run_gmkfontcap.bat
+ FileWrite $0 '@echo off$\r$\n'
+ FileWrite $0 'rem #########################################################################$\r$\n'
+ FileWrite $0 'rem #$\r$\n'
+ FileWrite $0 'rem # Run g.mkfontcap outside a grass session during installation$\r$\n'
+ FileWrite $0 'echo Setup of WinGRASS-${VERSION_NUMBER}$\r$\n'
+ FileWrite $0 'echo Generating the font configuration file by scanning various directories for fonts.$\r$\n'
+ FileWrite $0 'echo Please wait. Console window will close automatically ....$\r$\n'
+ FileWrite $0 '$\r$\n'
+ FileWrite $0 'rem set gisbase$\r$\n'
+ FileWrite $0 'set GISBASE=$INSTALL_DIR$\r$\n'
+ FileWrite $0 'rem set path to freetype dll$\r$\n'
+ FileWrite $0 'set FREETYPEBASE=$INSTALL_DIR\extralib$\r$\n'
+ FileWrite $0 'rem set dependecies path$\r$\n'
+ FileWrite $0 'set PATH=%FREETYPEBASE%;%PATH%$\r$\n'
+ FileWrite $0 'rem run g.mkfontcap outside a grass session$\r$\n'
+ FileWrite $0 '"%GISBASE%\bin\g.mkfontcap.exe"$\r$\n'
+ FileWrite $0 'exit$\r$\n'
+ FileClose $0
+ done_create_run_gmkfontcap.bat:
+ ;create run_gmkfontcap.bat.manifest
+ ClearErrors
+ FileOpen $0 $INSTALL_DIR\etc\run_gmkfontcap.bat.manifest w
+ IfErrors done_create_run_gmkfontcap.bat.manifest
+ FileWrite $0 ' <?xml version="1.0" encoding="UTF-8" standalone="yes"?>$\r$\n'
+ FileWrite $0 '<assembly xmlns="urn:schemas-microsoft-com:asm.v1" manifestVersion="1.0">$\r$\n'
+ FileWrite $0 ' <assemblyIdentity version="1.0.0.0"$\r$\n'
+ FileWrite $0 ' processorArchitecture="X86"$\r$\n'
+ FileWrite $0 ' name="run_gmkfontcap"$\r$\n'
+ FileWrite $0 ' type="win32"/>$\r$\n'
+ FileWrite $0 ' <description>GRASS help script:run_gmkfontcap<description>$\r$\n'
+ FileWrite $0 ' <!-- Identify the application security requirements. -->$\r$\n'
+ FileWrite $0 ' <trustInfo xmlns="urn:schemas-microsoft-com:asm.v2">$\r$\n'
+ FileWrite $0 ' <security>$\r$\n'
+ FileWrite $0 ' <requestedPrivileges>$\r$\n'
+ FileWrite $0 ' <requestedExecutionLevel$\r$\n'
+ FileWrite $0 ' level="asInvoker"$\r$\n'
+ FileWrite $0 ' uiAccess="false"/>$\r$\n'
+ FileWrite $0 ' </requestedPrivileges>$\r$\n'
+ FileWrite $0 ' </security>$\r$\n'
+ FileWrite $0 ' </trustInfo>$\r$\n'
+ FileWrite $0 '</assembly>$\r$\n'
+ FileClose $0
+ done_create_run_gmkfontcap.bat.manifest:
+ ;Run g.mkfontcap outside a grass session during installation to catch all fonts
+ ExecWait '"$INSTALL_DIR\etc\run_gmkfontcap.bat"'
;Install demolocation into the GIS_DATABASE directory
SetOutPath "$GIS_DATABASE\demolocation"
File /r ${DEMOLOCATION_PATH}\*.*
