[GRASS-SVN] r41425 - grass/trunk/gui/wxpython/gui_modules
Sat Mar 13 12:35:40 EST 2010
Author: martinl
Date: 2010-03-13 12:35:40 -0500 (Sat, 13 Mar 2010)
New Revision: 41425
   grass/trunk/gui/wxpython/gui_modules/gselect.py
   grass/trunk/gui/wxpython/gui_modules/menuform.py
wxGUI: be more consistent on ColumnSelect events
Modified: grass/trunk/gui/wxpython/gui_modules/gselect.py
--- grass/trunk/gui/wxpython/gui_modules/gselect.py	2010-03-13 17:24:27 UTC (rev 41424)
+++ grass/trunk/gui/wxpython/gui_modules/gselect.py	2010-03-13 17:35:40 UTC (rev 41425)
@@ -657,20 +657,27 @@
         self.SetValue('')
 class ColumnSelect(wx.ComboBox):
+    """!Creates combo box for selecting columns in the attribute table
+    for a vector map.
+    @param parent window parent
+    @param id window id
+    @param value default value
+    @param size window size
+    @param vector vector map name
+    @param layer layer number
+    @param param parameters list (see menuform.py)
+    @param **kwags wx.ComboBox parameters
-    Creates combo box for selecting columns in the attribute table for a vector.
-    The 'layer' terminology is likely to change for GRASS 7
-    def __init__(self, parent,
-                 id=wx.ID_ANY, value='', pos=wx.DefaultPosition,
-                 size=globalvar.DIALOG_COMBOBOX_SIZE, vector=None,
-                 layer=1, choices=[]):
+    def __init__(self, parent, id = wx.ID_ANY, value = '',
+                 size=globalvar.DIALOG_COMBOBOX_SIZE,
+                 vector = None, layer = 1, param = None, **kwargs):
         self.defaultValue = value
+        self.param = param
-        super(ColumnSelect, self).__init__(parent, id, value, pos, size, choices)
+        super(ColumnSelect, self).__init__(parent, id, value, size = size, **kwargs)
+        self.SetName("ColumnSelect")
-        self.SetName("ColumnSelect")
         if vector:
             self.InsertColumns(vector, layer)
@@ -698,14 +705,22 @@
                     if value['type'] not in type:
                         columns.remove(key)
         except (KeyError, ValueError):
-            columns = []
+            columns = list()
         self.SetItems(columns)
         self.SetValue(self.defaultValue)
+        if self.param:
+            self.param['value'] = ''
     def InsertTableColumns(self, table, driver=None, database=None):
-        """!Insert table columns"""
-        columns = []
+        """!Insert table columns
+        @param table table name
+        @param driver driver name
+        @param database database name
+        columns = list()
         ret = gcmd.RunCommand('db.columns',
                               read = True,
@@ -715,10 +730,13 @@
         if ret:
             columns = ret.splitlines()
+        if self.param:
 class LocationSelect(wx.ComboBox):
     """!Widget for selecting GRASS location"""
     def __init__(self, parent, id = wx.ID_ANY, size = globalvar.DIALOG_COMBOBOX_SIZE,
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py	2010-03-13 17:24:27 UTC (rev 41424)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py	2010-03-13 17:35:40 UTC (rev 41425)
@@ -1447,7 +1447,8 @@
                                 win.Bind(wx.EVT_TEXT, self.OnSetValue)
                         elif p.get('prompt', '') == 'dbcolumn':
                             win = gselect.ColumnSelect(parent = which_panel,
-                                                       value = p.get('default', ''))
+                                                       value = p.get('default', ''),
+                                                       param = p)
                             win.Bind(wx.EVT_COMBOBOX, self.OnSetValue)
@@ -1665,6 +1666,8 @@
         for fn, kwargs in event.data.iteritems():
             fn(**kwargs)
+        self.parent.updateValuesHook()
     def OnVerbosity(self, event):
         """!Verbosity level changed"""
         verbose = self.FindWindowById(self.task.get_flag('verbose')['wxId'][0])
