[GRASS-SVN] r41426 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat Mar 13 12:50:02 EST 2010
Author: martinl
Date: 2010-03-13 12:50:01 -0500 (Sat, 13 Mar 2010)
New Revision: 41426
grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
wxGUI: be more consistent on ColumnSelect events
(merge r41425 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2010-03-13 17:35:40 UTC (rev 41425)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2010-03-13 17:50:01 UTC (rev 41426)
@@ -617,27 +617,27 @@
self.SetValue('')
class ColumnSelect(wx.ComboBox):
+ """!Creates combo box for selecting columns in the attribute table
+ for a vector map.
+ @param parent window parent
+ @param id window id
+ @param value default value
+ @param size window size
+ @param vector vector map name
+ @param layer layer number
+ @param param parameters list (see menuform.py)
+ @param **kwags wx.ComboBox parameters
- Creates combo box for selecting columns in the attribute table for a vector.
- The 'layer' terminology is likely to change for GRASS 7
- def __init__(self, parent,
- id = wx.ID_ANY, value = '',
- size = globalvar.DIALOG_COMBOBOX_SIZE,
- vector = None, layer = 1, choices = [], readonly = False,
- **kwargs):
- if readonly:
- if kwargs.has_key('style'):
- style |= wx.CB_READONLY
- else:
- style = wx.CB_READONLY
+ def __init__(self, parent, id = wx.ID_ANY, value = '',
+ size=globalvar.DIALOG_COMBOBOX_SIZE,
+ vector = None, layer = 1, param = None, **kwargs):
self.defaultValue = value
+ self.param = param
- super(ColumnSelect, self).__init__(parent, id, value = value, choices = choices, size = size,
- **kwargs)
+ super(ColumnSelect, self).__init__(parent, id, value, size = size, **kwargs)
+ self.SetName("ColumnSelect")
- self.SetName("ColumnSelect")
if vector:
self.InsertColumns(vector, layer)
@@ -665,14 +665,22 @@
if value['type'] not in type:
columns.remove(key)
except (KeyError, ValueError):
- columns = []
+ columns = list()
self.SetItems(columns)
self.SetValue(self.defaultValue)
+ if self.param:
+ self.param['value'] = ''
def InsertTableColumns(self, table, driver=None, database=None):
- """!Insert table columns"""
- columns = []
+ """!Insert table columns
+ @param table table name
+ @param driver driver name
+ @param database database name
+ columns = list()
ret = gcmd.RunCommand('db.columns',
read = True,
@@ -682,10 +690,13 @@
if ret:
columns = ret.splitlines()
+ if self.param:
class LocationSelect(wx.ComboBox):
"""!Widget for selecting GRASS location"""
def __init__(self, parent, id = wx.ID_ANY, size = globalvar.DIALOG_COMBOBOX_SIZE,
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2010-03-13 17:35:40 UTC (rev 41425)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2010-03-13 17:50:01 UTC (rev 41426)
@@ -1342,7 +1342,8 @@
win.Bind(wx.EVT_TEXT, self.OnSetValue)
elif p.get('prompt', '') == 'dbcolumn':
win = gselect.ColumnSelect(parent = which_panel,
- value = p.get('default', ''))
+ value = p.get('default', ''),
+ param = p)
### p['wxGetValue'] = win.GetStringSelection
### win.Bind(wx.EVT_COMBOBOX, self.OnSetValue)
@@ -1512,6 +1513,8 @@
for fn, kwargs in event.data.iteritems():
fn(**kwargs)
+ self.parent.updateValuesHook()
def OnVerbosity(self, event):
"""!Verbosity level changed"""
verbose = self.FindWindowById(self.task.get_flag('verbose')['wxId'])
