[GRASS-SVN] r41511 - in grass/trunk: lib/gpde raster/r.gwflow raster/r.solute.transport
Sun Mar 21 12:52:45 EDT 2010
Author: huhabla
Date: 2010-03-21 12:52:44 -0400 (Sun, 21 Mar 2010)
New Revision: 41511
   grass/trunk/lib/gpde/N_parse_options.c
   grass/trunk/raster/r.gwflow/main.c
   grass/trunk/raster/r.gwflow/r.gwflow.html
   grass/trunk/raster/r.gwflow/valid_calc_7x7.py
   grass/trunk/raster/r.gwflow/valid_calc_excavation.py
   grass/trunk/raster/r.solute.transport/example.py
   grass/trunk/raster/r.solute.transport/main.c
   grass/trunk/raster/r.solute.transport/r.solute.transport.html
   grass/trunk/raster/r.solute.transport/seguin_verify.py
   grass/trunk/raster/r.solute.transport/seguin_verify_well.py
Typo fixes
Using G_define_standard_option()
Renamed recharge and retardation options
Removed translation form options and default answers
Modified: grass/trunk/lib/gpde/N_parse_options.c
--- grass/trunk/lib/gpde/N_parse_options.c	2010-03-21 15:42:22 UTC (rev 41510)
+++ grass/trunk/lib/gpde/N_parse_options.c	2010-03-21 16:52:44 UTC (rev 41511)
@@ -54,7 +54,7 @@
 	Opt->key_desc = "name";
 	Opt->answer = "cg";
 	Opt->options = "gauss,lu,cholesky,jacobi,sor,cg,bicgstab,pcg";
-        Opt->guisection = _("solver");
+        Opt->guisection = "Solver";
 	Opt->description =
 	    ("The type of solver which should solve the symmetric linear equation system");
 	break;
@@ -66,7 +66,7 @@
 	Opt->answer = "bicgstab";
 	Opt->options = "gauss,lu,jacobi,sor,bicgstab";
 	Opt->description =
 	    ("The type of solver which should solve the linear equation system");
 	break;
@@ -75,7 +75,7 @@
 	Opt->type = TYPE_INTEGER;
 	Opt->required = NO;
 	Opt->answer = "100000";
 	Opt->description =
 	    ("Maximum number of iteration used to solver the linear equation system");
 	break;
@@ -84,7 +84,7 @@
 	Opt->type = TYPE_DOUBLE;
 	Opt->required = NO;
 	Opt->answer = "0.0000000001";
 	Opt->description =
 	    ("Error break criteria for iterative solvers (jacobi, sor, cg or bicgstab)");
 	break;
@@ -93,7 +93,7 @@
 	Opt->required = NO;
 	Opt->answer = "1";
 	Opt->description =
 	    ("The relaxation parameter used by the jacobi and sor solver for speedup or stabilizing");
 	break;
@@ -102,7 +102,7 @@
 	Opt->required = YES;
 	Opt->answer = "86400";
 	Opt->description = _("The calculation time in seconds");
 	break;
Modified: grass/trunk/raster/r.gwflow/main.c
--- grass/trunk/raster/r.gwflow/main.c	2010-03-21 15:42:22 UTC (rev 41510)
+++ grass/trunk/raster/r.gwflow/main.c	2010-03-21 16:52:44 UTC (rev 41511)
@@ -52,101 +52,67 @@
 void set_params(void)
-    param.phead = G_define_option();
+    param.phead = G_define_standard_option(G_OPT_R_INPUT);
     param.phead->key = "phead";
-    param.phead->type = TYPE_STRING;
-    param.phead->required = YES;
-    param.phead->gisprompt = "old,raster,raster";
     param.phead->description = _("The initial piezometric head in [m]");
-    param.status = G_define_option();
+    param.status = G_define_standard_option(G_OPT_R_INPUT);
     param.status->key = "status";
-    param.status->type = TYPE_STRING;
-    param.status->required = YES;
-    param.status->gisprompt = "old,raster,raster";
     param.status->description =
 	_("Boundary condition status, 0-inactive, 1-active, 2-dirichlet");
-    param.hc_x = G_define_option();
+    param.hc_x =G_define_standard_option(G_OPT_R_INPUT);
     param.hc_x->key = "hc_x";
-    param.hc_x->type = TYPE_STRING;
-    param.hc_x->required = YES;
-    param.hc_x->gisprompt = "old,raster,raster";
     param.hc_x->description =
 	_("X-part of the hydraulic conductivity tensor in [m/s]");
-    param.hc_y = G_define_option();
+    param.hc_y = G_define_standard_option(G_OPT_R_INPUT);
     param.hc_y->key = "hc_y";
-    param.hc_y->type = TYPE_STRING;
-    param.hc_y->required = YES;
-    param.hc_y->gisprompt = "old,raster,raster";
     param.hc_y->description =
 	_("Y-part of the hydraulic conductivity tensor in [m/s]");
-    param.q = G_define_option();
+    param.q = G_define_standard_option(G_OPT_R_INPUT);
     param.q->key = "q";
-    param.q->type = TYPE_STRING;
-    param.q->required = NO;
-    param.q->gisprompt = "old,raster,raster";
-    param.q->description = _("Raster amp water sources and sinks in [m^3/s]");
+    param.q->description = _("Raster map water sources and sinks in [m^3/s]");
-    param.s = G_define_option();
+    param.s = G_define_standard_option(G_OPT_R_INPUT);
     param.s->key = "s";
-    param.s->type = TYPE_STRING;
-    param.s->required = YES;
-    param.s->gisprompt = "old,raster,raster";
     param.s->description = _("Specific yield in [1/m]");
-    param.r = G_define_option();
-    param.r->key = "r";
-    param.r->type = TYPE_STRING;
+    param.r = G_define_standard_option(G_OPT_R_INPUT);
+    param.r->key = "recharge";
     param.r->required = NO;
-    param.r->gisprompt = "old,raster,raster";
+    param.r->guisection = _("Recharge");
     param.r->description =
 	_("Recharge map e.g: 6*10^-9 per cell in [m^3/s*m^2]");
-    param.top = G_define_option();
+    param.top = G_define_standard_option(G_OPT_R_INPUT);
     param.top->key = "top";
-    param.top->type = TYPE_STRING;
-    param.top->required = YES;
-    param.top->gisprompt = "old,raster,raster";
     param.top->description = _("Top surface of the aquifer in [m]");
-    param.bottom = G_define_option();
+    param.bottom = G_define_standard_option(G_OPT_R_INPUT);
     param.bottom->key = "bottom";
-    param.bottom->type = TYPE_STRING;
-    param.bottom->required = YES;
-    param.bottom->gisprompt = "old,raster,raster";
     param.bottom->description = _("Bottom surface of the aquifer in [m]");
-    param.output = G_define_option();
+    param.output = G_define_standard_option(G_OPT_R_OUTPUT);
     param.output->key = "output";
-    param.output->type = TYPE_STRING;
-    param.output->required = YES;
-    param.output->gisprompt = "new,raster,raster";
     param.output->description = _("The map storing the numerical result [m]");
-    param.vector_x = G_define_option();
+    param.vector_x = G_define_standard_option(G_OPT_R_OUTPUT);
     param.vector_x->key = "vx";
-    param.vector_x->type = TYPE_STRING;
     param.vector_x->required = NO;
-    param.vector_x->gisprompt = "new,raster,raster";
     param.vector_x->description =
 	_("Calculate and store the groundwater filter velocity vector part in x direction [m/s]\n");
-    param.vector_y = G_define_option();
+    param.vector_y = G_define_standard_option(G_OPT_R_OUTPUT);
     param.vector_y->key = "vy";
-    param.vector_y->type = TYPE_STRING;
     param.vector_y->required = NO;
-    param.vector_y->gisprompt = "new,raster,raster";
     param.vector_y->description =
 	_("Calculate and store the groundwater filter velocity vector part in y direction [m/s]\n");
-    param.budget = G_define_option();
+    param.budget = G_define_standard_option(G_OPT_R_OUTPUT);
     param.budget->key = "budget";
-    param.budget->type = TYPE_STRING;
     param.budget->required = NO;
-    param.budget->gisprompt = "new,raster,raster";
     param.budget->description =
 	_("Store the groundwater budget for each cell [m^3/s]\n");
@@ -154,51 +120,43 @@
     param.type->key = "type";
     param.type->type = TYPE_STRING;
     param.type->required = YES;
-    param.type->answer = _("confined");
-    param.type->options = _("confined,unconfined");
+    param.type->answer = "confined";
+    param.type->options = "confined,unconfined";
     param.type->description = _("The type of groundwater flow");
     /*Variants of the cauchy boundary condition */
-    param.river_bed = G_define_option();
+    param.river_bed = G_define_standard_option(G_OPT_R_INPUT);
     param.river_bed->key = "river_bed";
-    param.river_bed->type = TYPE_STRING;
     param.river_bed->required = NO;
-    param.river_bed->gisprompt = "old,raster,raster";
     param.river_bed->description = _("The height of the river bed in [m]");
-    param.river_bed->guisection = _("river");
+    param.river_bed->guisection = "River";
-    param.river_head = G_define_option();
+    param.river_head = G_define_standard_option(G_OPT_R_INPUT);
     param.river_head->key = "river_head";
-    param.river_head->type = TYPE_STRING;
     param.river_head->required = NO;
-    param.river_head->gisprompt = "old,raster,raster";
-    param.river_head->guisection = _("river");
+    param.river_head->guisection = "River";
     param.river_head->description =
 	_("Water level (head) of the river with leakage connection in [m]");
-    param.river_leak = G_define_option();
+    param.river_leak = G_define_standard_option(G_OPT_R_INPUT);
     param.river_leak->key = "river_leak";
-    param.river_leak->type = TYPE_STRING;
     param.river_leak->required = NO;
-    param.river_leak->gisprompt = "old,raster,raster";
-    param.river_leak->guisection = _("river");
+    param.river_leak->guisection = "River";
     param.river_leak->description =
 	_("The leakage coefficient of the river bed in [1/s].");
-    param.drain_bed = G_define_option();
+    param.drain_bed = G_define_standard_option(G_OPT_R_INPUT);
     param.drain_bed->key = "drain_bed";
     param.drain_bed->type = TYPE_STRING;
     param.drain_bed->required = NO;
     param.drain_bed->gisprompt = "old,raster,raster";
-    param.drain_bed->guisection = _("drainage");
+    param.drain_bed->guisection = "Drainage";
     param.drain_bed->description = _("The height of the drainage bed in [m]");
-    param.drain_leak = G_define_option();
+    param.drain_leak = G_define_standard_option(G_OPT_R_INPUT);
     param.drain_leak->key = "drain_leak";
-    param.drain_leak->type = TYPE_STRING;
     param.drain_leak->required = NO;
-    param.drain_leak->gisprompt = "old,raster,raster";
-    param.drain_leak->guisection = _("drainage");
+    param.drain_leak->guisection = "Drainage";
     param.drain_leak->description =
 	_("The leakage coefficient of the drainage bed in [1/s]");
@@ -210,7 +168,7 @@
     param.full_les = G_define_flag();
     param.full_les->key = 'f';
-    param.full_les->guisection = _("solver");
+    param.full_les->guisection = "Solver";
     param.full_les->description = _("Allocate a full quadratic linear equation system,"
             " default is a sparse linear equation system.");
Modified: grass/trunk/raster/r.gwflow/r.gwflow.html
--- grass/trunk/raster/r.gwflow/r.gwflow.html	2010-03-21 15:42:22 UTC (rev 41510)
+++ grass/trunk/raster/r.gwflow/r.gwflow.html	2010-03-21 16:52:44 UTC (rev 41511)
@@ -119,12 +119,12 @@
 #confined groundwater flow with cg solver and sparse matrix, river and drain
 #do not work with this confined aquifer (top == 20m)
 r.gwflow --o solver=cg top=top_conf bottom=bottom phead=phead status=status \
-hc_x=hydcond hc_y=hydcond q=well s=syield r=recharge output=gwresult_conf \
+hc_x=hydcond hc_y=hydcond q=well s=syield recharge=recharge output=gwresult_conf \
 dt=8640000 type=confined vx=gwresult_conf_velocity_x vy=gwresult_conf_velocity_y budget=budget_conf
 #unconfined groundwater flow with cg solver and sparse matrix, river and drain are enabled
 r.gwflow --o solver=cg top=top_unconf bottom=bottom phead=phead \
-status=status hc_x=hydcond hc_y=hydcond q=well s=poros r=recharge \
+status=status hc_x=hydcond hc_y=hydcond q=well s=poros recharge=recharge \
 river_bed=river_bed river_head=river_head river_leak=river_leak \
 drain_bed=drain_bed drain_leak=drain_leak \
 output=gwresult_unconf dt=8640000 type=unconfined vx=gwresult_unconf_velocity_x \
Modified: grass/trunk/raster/r.gwflow/valid_calc_7x7.py
--- grass/trunk/raster/r.gwflow/valid_calc_7x7.py	2010-03-21 15:42:22 UTC (rev 41510)
+++ grass/trunk/raster/r.gwflow/valid_calc_7x7.py	2010-03-21 16:52:44 UTC (rev 41511)
@@ -31,13 +31,13 @@
 #First compute the initial groundwater flow
 grass.run_command("r.gwflow", "f", solver="cholesky", top="top_conf", bottom="bottom", phead="phead",\
  status="status", hc_x="hydcond", hc_y="hydcond", q="well", s="syield",\
- r="recharge", output="gwresult_conf", dt=500, type="confined", budget="water_budget")
+ recharge="recharge", output="gwresult_conf", dt=500, type="confined", budget="water_budget")
 count=500
 # loop over the timesteps
 for i in range(20):
     grass.run_command("r.gwflow", "f", solver="cholesky", top="top_conf", bottom="bottom", phead="gwresult_conf",\
     count += 500
Modified: grass/trunk/raster/r.gwflow/valid_calc_excavation.py
--- grass/trunk/raster/r.gwflow/valid_calc_excavation.py	2010-03-21 15:42:22 UTC (rev 41510)
+++ grass/trunk/raster/r.gwflow/valid_calc_excavation.py	2010-03-21 16:52:44 UTC (rev 41511)
@@ -36,4 +36,4 @@
 #compute a steady state groundwater flow
 grass.run_command("r.gwflow", "f", solver="cholesky", top="top", bottom="bottom", phead="phead", \
  status="status", hc_x="hydcond", hc_y="hydcond", q="well", s="syield", \
- r="recharge", output="gwresult", dt=864000000000, type="unconfined", budget="water_budget")
+ recharge="recharge", output="gwresult", dt=864000000000, type="unconfined", budget="water_budget")
Modified: grass/trunk/raster/r.solute.transport/example.py
--- grass/trunk/raster/r.solute.transport/example.py	2010-03-21 15:42:22 UTC (rev 41510)
+++ grass/trunk/raster/r.solute.transport/example.py	2010-03-21 16:52:44 UTC (rev 41511)
@@ -28,7 +28,7 @@
 grass.run_command("r.gwflow", solver="cg", top="top_conf", bottom="bottom", phead="phead",\
-  r="recharge", output="gwresult_conf", dt=8640000000000, type="confined")
+  recharge="recharge", output="gwresult_conf", dt=8640000000000, type="confined")
 grass.message(_("generate the transport data"))
 grass.run_command("r.mapcalc", expression="c=if(col() == 15 && row() == 75 , 500.0, 0.0)")
@@ -40,13 +40,13 @@
 # Compute the initial state
 grass.run_command("r.solute.transport", solver="bicgstab", top="top_conf",\
   bottom="bottom", phead="gwresult_conf", status="tstatus", hc_x="hydcond", hc_y="hydcond",\
-  r="R", cs="cs", q="well", nf="poros", output="stresult_conf_0", dt=3600, diff_x="diff",\
+  rd="R", cs="cs", q="well", nf="poros", output="stresult_conf_0", dt=3600, diff_x="diff",\
   diff_y="diff", c="c", al=0.1, at=0.01)
 # Compute the solute transport for 300 days in 10 day steps
 for dt in range(30):
-    r="R", cs="cs", q="well", nf="poros", output="stresult_conf_" + str(dt + 1), dt=864000, diff_x="diff",\
+    rd="R", cs="cs", q="well", nf="poros", output="stresult_conf_" + str(dt + 1), dt=864000, diff_x="diff",\
     diff_y="diff", c="stresult_conf_" + str(dt), al=0.1, at=0.01, vx="vx", vy="vy")
Modified: grass/trunk/raster/r.solute.transport/main.c
--- grass/trunk/raster/r.solute.transport/main.c	2010-03-21 15:42:22 UTC (rev 41510)
+++ grass/trunk/raster/r.solute.transport/main.c	2010-03-21 16:52:44 UTC (rev 41511)
@@ -91,7 +91,7 @@
     param.q->key = "q";
-    param.q->guisection = _("water flow");
+    param.q->guisection = _("Water flow");
     param.q->description = _("Groundwater sources and sinks in [m^3/s]");
@@ -99,7 +99,7 @@
     param.cin->key = "cin";
     param.cin->required = NO;
     param.cin->gisprompt = "old,raster,raster";
-    param.cin->guisection = _("water flow");
+    param.cin->guisection = "Water flow";
     param.cin->description = _("Concentration sources and sinks bounded to a "
             "water source or sink in [kg/s]");
@@ -113,7 +113,7 @@
             "(i.e. a chemical reaction)");
+    param.r->key = "rd";
     param.r->description = _("Retardation factor [-]");
     param.nf = G_define_standard_option(G_OPT_R_INPUT);
@@ -137,7 +137,7 @@
-    param.vector_x->guisection = _("water flow");
+    param.vector_x->guisection = "Water flow";
@@ -146,7 +146,7 @@
-    param.vector_y->guisection = _("water flow");
+    param.vector_y->guisection = "Water flow";
@@ -186,19 +186,19 @@
     param.stab->required = NO;
     param.stab->answer = "full";
     param.stab->options = "full,exp";
-    param.stab->guisection = _("stabelization");
+    param.stab->guisection = "Stabelization";
     param.stab->description =
 	_("Set the flow stabilizing scheme (full or exponential upwinding).");
     param.full_les->description = _("Use a full filled quadratic linear equation system,"
     param.cfl = G_define_flag();
     param.cfl->key = 'c';
-    param.cfl->guisection = _("stabelization");
+    param.cfl->guisection = "Stabelization";
     param.cfl->description =
 	_("Use the Courant-Friedrichs-Lewy criteria for time step calculation");
Modified: grass/trunk/raster/r.solute.transport/r.solute.transport.html
--- grass/trunk/raster/r.solute.transport/r.solute.transport.html	2010-03-21 15:42:22 UTC (rev 41510)
+++ grass/trunk/raster/r.solute.transport/r.solute.transport.html	2010-03-21 16:52:44 UTC (rev 41511)
@@ -120,7 +120,7 @@
@@ -132,14 +132,14 @@
     diff_y="diff", c="stresult_conf_" + str(dt), al=0.1, at=0.01)
Modified: grass/trunk/raster/r.solute.transport/seguin_verify.py
--- grass/trunk/raster/r.solute.transport/seguin_verify.py	2010-03-21 15:42:22 UTC (rev 41510)
+++ grass/trunk/raster/r.solute.transport/seguin_verify.py	2010-03-21 16:52:44 UTC (rev 41511)
@@ -48,7 +48,7 @@
 # Compute the steady state groundwater flow
 grass.run_command("r.gwflow", solver="cg", top="top_conf_1", bottom="bottom_1", phead="phead_1",\
  status="status_1", hc_x="hydcond_1", hc_y="hydcond_1", \
- q="well_1", s="syield_1", r="recharge_1", output="gwresult_conf_1",\
+ q="well_1", s="syield_1", recharge="recharge_1", output="gwresult_conf_1",\
@@ -73,7 +73,7 @@
 # Compute the solute transport using the above defined dispersivity coefficients for a timestep of 1000d
 grass.run_command("r.solute.transport", "c", error=0.000000000000001, maxit=1000, solver="bicgstab",\
   top="top_conf_1", bottom="bottom_1", phead="gwresult_conf_1", status="tstatus_1", hc_x="hydcond_1",\
-  hc_y="hydcond_1", r="R_1", cs="cs_1", q="well_1", nf="poros_1", output="stresult_conf_1", dt=86400000,\
+  hc_y="hydcond_1", rd="R_1", cs="cs_1", q="well_1", nf="poros_1", output="stresult_conf_1", dt=86400000,\
   diff_x="diff_1", diff_y="diff_1", cin="cin_1", c="c_1", al=AL, at=AT, vx="stresult_conf_vel_1_x", vy="stresult_conf_vel_1_y")
 # The second computation uses different porosity for higher groundwater velocity
@@ -84,5 +84,5 @@
-  hc_y="hydcond_1", r="R_1", cs="cs_1", q="well_1", nf="poros_2", output="stresult_conf_2", dt=86400000,\
+  hc_y="hydcond_1", rd="R_1", cs="cs_1", q="well_1", nf="poros_2", output="stresult_conf_2", dt=86400000,\
   diff_x="diff_1", diff_y="diff_1", cin="cin_1", c="c_1", al=AL, at=AT, vx="stresult_conf_vel_2_x", vy="stresult_conf_vel_2_y")
Modified: grass/trunk/raster/r.solute.transport/seguin_verify_well.py
--- grass/trunk/raster/r.solute.transport/seguin_verify_well.py	2010-03-21 15:42:22 UTC (rev 41510)
+++ grass/trunk/raster/r.solute.transport/seguin_verify_well.py	2010-03-21 16:52:44 UTC (rev 41511)
@@ -49,7 +49,7 @@
@@ -74,7 +74,7 @@
 # Compute the solute transport using the above defined dispersivity coefficients for a timestep of 250d
-  hc_y="hydcond_1", r="R_1", cs="cs_1", q="well_1", nf="poros_1", output="stresult_conf_1", dt=21600000,\
+  hc_y="hydcond_1", rd="R_1", cs="cs_1", q="well_1", nf="poros_1", output="stresult_conf_1", dt=21600000,\
   diff_x="diff_1", diff_y="diff_1", cin="cin_1", c="c_1", al=AL, at=AT)
 # The second computation uses different dispersivities
@@ -85,6 +85,6 @@
-  hc_y="hydcond_1", r="R_1", cs="cs_1", q="well_1", nf="poros_1", output="stresult_conf_2", dt=21600000,\
+  hc_y="hydcond_1", rd="R_1", cs="cs_1", q="well_1", nf="poros_1", output="stresult_conf_2", dt=21600000,\
