[GRASS-SVN] r42094 - in grass-addons/vector: . v.in.osm2
svn_grass at osgeo.org
Mon May 3 18:37:58 EDT 2010
Author: hamish
Date: 2010-05-03 18:37:57 -0400 (Mon, 03 May 2010)
New Revision: 42094
Added:
grass-addons/vector/v.in.osm2/
grass-addons/vector/v.in.osm2/Makefile
grass-addons/vector/v.in.osm2/v.in.osm
v.in.osm: import from OpenStreetMap Xapi API 0.6
Added: grass-addons/vector/v.in.osm2/Makefile
--- grass-addons/vector/v.in.osm2/Makefile (rev 0)
+++ grass-addons/vector/v.in.osm2/Makefile 2010-05-03 22:37:57 UTC (rev 42094)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = v.in.osm
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/vector/v.in.osm2/Makefile
___________________________________________________________________
Added: svn:mime-type
+ text/x-makefile
Added: svn:eol-style
+ native
Added: grass-addons/vector/v.in.osm2/v.in.osm
--- grass-addons/vector/v.in.osm2/v.in.osm (rev 0)
+++ grass-addons/vector/v.in.osm2/v.in.osm 2010-05-03 22:37:57 UTC (rev 42094)
@@ -0,0 +1,124 @@
+#!/bin/sh
+# MODULE: v.in.osm
+# AUTHOR(S): Hamish Bowman, Dunedin, New Zealand
+# PURPOSE: Import vector data direct from OpenStreetMap's database
+# COPYRIGHT: (c) 2010 Hamish Bowman, and the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+# -- Experimental --
+# See http://wiki.openstreetmap.org/wiki/Xapi
+# REQUIREMENTS: gpsbabel 1.3.5 or newer
+# wget
+# g.region from GRASS 6.5 or newer (needs the -w flag)
+#%Module
+#% description: Import vector data for the current region direct from OpenStreetMap's database
+#% keywords: vector, import, osm
+#%End
+#%option
+#% key: output
+#% type: string
+#% gisprompt: new,vector,output
+#% description: Name for output map
+#% required : yes
+#%end
+#%option
+#% key: feature
+#% type: string
+#% description: Import as nodes or ways (GpsBabel only allows one)
+#% options: nodes,ways
+#% answer: ways
+#%end
+#%option
+#% key: query
+#% type: string
+#% label: Xapi query string
+#% description: For example: "way[highway=track|path]"
+#% required : no
+#%end
+if [ -z "$GISBASE" ] ; then
+ echo "You must be in GRASS GIS to run this program." >&2
+ exit 1
+fi
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+ exec g.parser "$0" "$@"
+fi
+#### check if we have wget and gpsbabel
+if [ ! -x "`which wget`" ] ; then
+ g.message -e "wget required, please install it first"
+ exit 1
+fi
+if [ ! -x "`which gpsbabel`" ] ; then
+ g.message -e "GpsBabel required, please install it first"
+ exit 1
+fi
+#### check if we have new enough software
+if [ `g.region --interface-description | grep -c '<flag name="w">'` -ne 1 ] ; then
+ g.message -e "Newer version of GRASS is required."
+ exit 1
+fi
+if [ `gpsbabel --help | grep -wc osm` -ne 1 ] ; then
+ g.message -e "Newer version of GpsBabel is required."
+ exit 1
+fi
+# get bounding box in WGS84
+eval `g.region -bg`
+BBOX="$ll_w,$ll_s,$ll_e,$ll_n"
+#### setup temporary file
+TEMPFILE="`g.tempfile pid=$$`"
+if [ $? -ne 0 ] || [ -z "$TEMPFILE" ] ; then
+ g.message -e "Unable to create temporary files"
+ exit 1
+fi
+BASEURL="http://osmxapi.hypercube.telascience.org/api/0.6"
+if [ -z "$GIS_OPT_QUERY" ] ; then
+ wget -O "$TEMPFILE" "$BASEURL/map?bbox=$BBOX"
+else
+ wget -O "$TEMPFILE" "$BASEURL/$GIS_OPT_QUERY[bbox=$BBOX]"
+fi
+if [ $? -ne 1 ] ; then
+ g.message -e "Download failed."
+ \rm "$TEMPFILE"
+ exit 1
+fi
+if [ "$GIS_OPT_FEATURE" = "ways" ] ; then
+ FEAT="-t"
+else
+ FEAT="-w"
+fi
+v.in.gpsbabel $FEAT input="$TEMPFILE" output="$GIS_OPT_OUTPUT" format=osm
+ g.message -e "Import failed."
+ \rm "$TEMPFILE"
+ exit 1
+fi
+\rm "$TEMPFILE"
+g.message "Done."
Property changes on: grass-addons/vector/v.in.osm2/v.in.osm
Added: svn:executable
+ text/x-sh
+ native
