[GRASS-SVN] r42102 - in grass/branches/develbranch_6/gui/wxpython:
. gui_modules xml
svn_grass at osgeo.org
Tue May 4 04:56:17 EDT 2010
Author: martinl
Date: 2010-05-04 04:56:16 -0400 (Tue, 04 May 2010)
New Revision: 42102
grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/help.py
grass/branches/develbranch_6/gui/wxpython/wxgui.py
grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
wxGUI: search module moved as notebook page in Layer Manager
(merge r42101 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2010-05-04 08:42:01 UTC (rev 42101)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2010-05-04 08:56:16 UTC (rev 42102)
@@ -900,8 +900,8 @@
data.SetValue(p.get('value', ''))
continue
- data = self.FindData(p.get('value', ''),
- p.get('prompt', ''))
+ data = self.model.FindData(p.get('value', ''),
+ p.get('prompt', ''))
if data:
if p.get('age', 'old') == 'old':
self._addLine(data, layer)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py 2010-05-04 08:42:01 UTC (rev 42101)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py 2010-05-04 08:56:16 UTC (rev 42102)
@@ -141,7 +141,7 @@
**kwargs):
wx.SplitterWindow.__init__(self, parent, id, style = style, *kwargs)
self.SetName("GMConsole")
self.panelOutput = wx.Panel(parent = self, id = wx.ID_ANY)
self.panelPrompt = wx.Panel(parent = self, id = wx.ID_ANY)
@@ -182,7 +182,7 @@
self.cmd_output.Bind(wx.EVT_TIMER, self.OnProcessPendingOutputWindowEvents)
self.Bind(EVT_CMD_RUN, self.OnCmdRun)
self.Bind(EVT_CMD_DONE, self.OnCmdDone)
# search & command prompt
@@ -204,12 +204,12 @@
self.cmd_stdout = GMStdout(self)
self.cmd_stderr = GMStderr(self)
# thread
self.cmdThread = CmdThread(self, self.requestQ, self.resultQ)
# buttons
@@ -236,7 +236,7 @@
self.search.Bind(wx.EVT_TEXT, self.OnSearchModule)
self.__layout()
def __layout(self):
"""!Do layout"""
OutputSizer = wx.BoxSizer(wx.VERTICAL)
@@ -276,10 +276,10 @@
OutputSizer.Fit(self)
OutputSizer.SetSizeHints(self)
PromptSizer.Fit(self)
PromptSizer.SetSizeHints(self)
self.panelOutput.SetSizer(OutputSizer)
self.panelPrompt.SetSizer(PromptSizer)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/help.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/help.py 2010-05-04 08:42:01 UTC (rev 42101)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/help.py 2010-05-04 08:56:16 UTC (rev 42102)
@@ -56,20 +56,17 @@
# sizer.SetSizeHints(self)
self.Layout()
-class MenuTreeWindow(wx.Frame):
+class MenuTreeWindow(wx.Panel):
"""!Show menu tree"""
- def __init__(self, parent, id = wx.ID_ANY, title = _("Menu tree window"), **kwargs):
+ def __init__(self, parent, id = wx.ID_ANY, **kwargs):
self.parent = parent # LayerManager
- wx.Frame.__init__(self, parent = parent, id = id, title = title, **kwargs)
- self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
+ wx.Panel.__init__(self, parent = parent, id = id, **kwargs)
- self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
- self.dataBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
+ self.dataBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
label=" %s " % _("Menu tree (double-click to run command)"))
# tree
- self.tree = MenuTree(parent = self.panel, data = menudata.ManagerData())
+ self.tree = MenuTree(parent = self, data = menudata.ManagerData())
self.tree.Load()
self.searchDict = { _('label') : 'label', # i18n workaround
@@ -77,45 +74,34 @@
_('command') : 'command',
_('keywords') : 'keywords' }
# search
- self.searchBy = wx.Choice(parent = self.panel, id = wx.ID_ANY,
+ self.searchBy = wx.Choice(parent = self, id = wx.ID_ANY,
choices = [_('label'),
_('help'),
_('command'),
_('keywords')])
self.searchBy.SetSelection(3)
- self.search = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY,
+ self.search = wx.TextCtrl(parent = self, id = wx.ID_ANY,
value = "", size = (-1, 25),
style = wx.TE_PROCESS_ENTER)
- # statusbar
- self.statusbar = self.CreateStatusBar(number=1)
- # close on run
- self.closeOnRun = wx.CheckBox(parent = self.panel, id = wx.ID_ANY,
- label = _("Close dialog on run"))
- self.closeOnRun.SetValue(True)
# buttons
- self.btnRun = wx.Button(self.panel, id = wx.ID_OK, label = _("Run"))
+ self.btnRun = wx.Button(self, id = wx.ID_OK, label = _("Run"))
self.btnRun.SetToolTipString(_("Run selected command"))
self.btnRun.Enable(False)
- self.btnClose = wx.Button(self.panel, id = wx.ID_CLOSE)
- self.btnClose.SetToolTipString(_("Close dialog"))
# bindings
- self.btnClose.Bind(wx.EVT_BUTTON, self.OnCloseWindow)
self.btnRun.Bind(wx.EVT_BUTTON, self.OnRun)
self.search.Bind(wx.EVT_TEXT_ENTER, self.OnShowItem)
self.search.Bind(wx.EVT_TEXT, self.OnUpdateStatusBar)
self.tree.Bind(wx.EVT_TREE_ITEM_ACTIVATED, self.OnItemActivated)
self.tree.Bind(wx.EVT_TREE_SEL_CHANGED, self.OnItemSelected)
- self.__Layout()
+ self._layout()
self.search.SetFocus()
- def __Layout(self):
+ def _layout(self):
"""!Do dialog layout"""
sizer = wx.BoxSizer(wx.VERTICAL)
@@ -126,7 +112,7 @@
# search
searchSizer = wx.BoxSizer(wx.HORIZONTAL)
- searchSizer.Add(item = wx.StaticText(parent = self.panel, id = wx.ID_ANY,
+ searchSizer.Add(item = wx.StaticText(parent = self, id = wx.ID_ANY,
label = _("Search:")),
proportion = 0,
flag = wx.ALIGN_RIGHT | wx.ALIGN_CENTER_VERTICAL | wx.ALL,
@@ -142,8 +128,6 @@
btnSizer = wx.BoxSizer(wx.HORIZONTAL)
btnSizer.Add(item = self.btnRun, proportion = 0,
flag = wx.LEFT | wx.RIGHT, border = 5)
- btnSizer.Add(item = self.btnClose, proportion = 0,
- flag = wx.LEFT | wx.RIGHT, border = 5)
sizer.Add(item = dataSizer, proportion = 1,
flag = wx.EXPAND | wx.ALL, border = 5)
@@ -154,15 +138,14 @@
sizer.Add(item = btnSizer, proportion=0,
flag = wx.ALIGN_RIGHT | wx.ALL, border = 5)
- sizer.Add(item = self.closeOnRun, proportion=0,
- flag = wx.EXPAND | wx.LEFT | wx.RIGHT | wx.BOTTOM, border = 5)
+ sizer.Fit(self)
+ sizer.SetSizeHints(self)
- self.panel.SetAutoLayout(True)
- self.panel.SetSizer(sizer)
- sizer.Fit(self.panel)
+ self.SetSizer(sizer)
+ self.Fit()
+ self.SetAutoLayout(True)
self.Layout()
- self.SetSize((530, 370))
def OnCloseWindow(self, event):
"""!Close window"""
@@ -188,9 +171,6 @@
else:
eval(handler)(None)
- if self.closeOnRun.IsChecked():
- self.OnCloseWindow(None)
def OnItemActivated(self, event):
"""!Item activated (double-click)"""
item = event.GetItem()
@@ -220,7 +200,7 @@
else:
label = data['help']
- self.statusbar.SetStatusText(label, 0)
+ self.parent.SetStatusText(label, 0)
def OnShowItem(self, event):
"""!Highlight first found item in menu tree"""
@@ -260,9 +240,9 @@
nItems = len(self.tree.itemsMarked)
if event.GetString():
- self.statusbar.SetStatusText(_("%d items match") % nItems, 0)
+ self.parent.SetStatusText(_("%d items match") % nItems, 0)
else:
- self.statusbar.SetStatusText("", 0)
+ self.parent.SetStatusText("", 0)
event.Skip()
Modified: grass/branches/develbranch_6/gui/wxpython/wxgui.py
--- grass/branches/develbranch_6/gui/wxpython/wxgui.py 2010-05-04 08:42:01 UTC (rev 42101)
+++ grass/branches/develbranch_6/gui/wxpython/wxgui.py 2010-05-04 08:56:16 UTC (rev 42102)
@@ -131,7 +131,6 @@
self.dialogs['atm'] = list()
# creating widgets
- # -> self.notebook, self.goutput, self.outpage
self.menubar = menu.Menu(parent = self, data = menudata.ManagerData())
self.SetMenuBar(self.menubar)
self.menucmd = self.menubar.GetCmd()
@@ -165,9 +164,11 @@
self.SetSize((w, h))
except:
pass
+ self.Layout()
+ self.Centre()
self.Show()
# load workspace file if requested
if self.workspaceFile:
# load given workspace file
@@ -197,41 +198,32 @@
def __createNoteBook(self):
"""!Creates notebook widgets"""
- #create main notebook widget
nbStyle = FN.FNB_FANCY_TABS | \
FN.FNB_BOTTOM | \
FN.FNB_NO_NAV_BUTTONS | \
FN.FNB_NO_X_BUTTON
self.notebook = FN.FlatNotebook(parent=self, id=wx.ID_ANY, style=nbStyle)
- #self.notebook = wx.aui.AuiNotebook(parent=self, id=wx.ID_ANY, style=wx.aui.AUI_NB_BOTTOM)
- #self.notebook.SetFont(wx.Font(pointSize=11, family=wx.FONTFAMILY_DEFAULT, style=wx.NORMAL, weight=0))
# create displays notebook widget and add it to main notebook page
cbStyle = globalvar.FNPageStyle
self.gm_cb = FN.FlatNotebook(self, id=wx.ID_ANY, style=cbStyle)
self.gm_cb.SetTabAreaColour(globalvar.FNPageColor)
self.notebook.AddPage(self.gm_cb, text=_("Map layers for each display"))
# create command output text area and add it to main notebook page
self.goutput = goutput.GMConsole(self, pageid=1)
self.outpage = self.notebook.AddPage(self.goutput, text=_("Command console"))
+ # create 'search module' notebook page
+ self.search = MenuTreeWindow(parent = self)
+ self.notebook.AddPage(self.search, text = _("Search module"))
# bindings
self.gm_cb.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CHANGED, self.OnCBPageChanged)
self.notebook.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CHANGED, self.OnPageChanged)
self.gm_cb.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CLOSING, self.OnCBPageClosed)
- sizer = wx.BoxSizer(wx.VERTICAL)
- sizer.Add(item=self.goutput, proportion=1,
- flag=wx.EXPAND | wx.ALL, border=1)
- self.SetSizer(sizer)
-# self.out_sizer.Fit(self.outpage)
- self.Layout()
- self.Centre()
return self.notebook
def __createToolBar(self):
@@ -348,7 +340,8 @@
# remove '(...)'
self.notebook.SetPageText(page, _("Command console"))
self.goutput.cmd_prompt.SetSTCFocus(True)
+ self.SetStatusText('', 0)
event.Skip()
def OnCBPageClosed(self, event):
@@ -517,13 +510,7 @@
lchecked=True,
lopacity=1.0,
lcmd=['d.vect', 'map=%s' % name])
- def OnMenuTree(self, event):
- """!Show dialog with menu tree"""
- dlg = MenuTreeWindow(self)
- dlg.CentreOnScreen()
- dlg.Show()
def OnAboutGRASS(self, event):
"""!Display 'About GRASS' dialog"""
win = AboutWindow(self)
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml 2010-05-04 08:42:01 UTC (rev 42101)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml 2010-05-04 08:56:16 UTC (rev 42102)
@@ -2934,12 +2934,6 @@
</menuitem>
<separator />
<menuitem>
- <label>Show menu tree</label>
- <help>Show menu tree in new window</help>
- <handler>OnMenuTree</handler>
- </menuitem>
- <separator />
- <menuitem>
<label>About GRASS GIS</label>
<help>About GRASS GIS</help>
<handler>OnAboutGRASS</handler>
