[GRASS-SVN] r42103 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue May 4 05:02:21 EDT 2010
Author: martinl
Date: 2010-05-04 05:02:19 -0400 (Tue, 04 May 2010)
New Revision: 42103
grass/trunk/gui/wxpython/gui_modules/goutput.py
grass/trunk/gui/wxpython/gui_modules/help.py
wxGUI: SearchModuleWindow added
Modified: grass/trunk/gui/wxpython/gui_modules/goutput.py
--- grass/trunk/gui/wxpython/gui_modules/goutput.py 2010-05-04 08:56:16 UTC (rev 42102)
+++ grass/trunk/gui/wxpython/gui_modules/goutput.py 2010-05-04 09:02:19 UTC (rev 42103)
@@ -40,6 +40,7 @@
from debug import Debug
from preferences import globalSettings as UserSettings
+from help import SearchModuleWindow
wxCmdOutput, EVT_CMD_OUTPUT = NewEvent()
wxCmdProgress, EVT_CMD_PROGRESS = NewEvent()
@@ -164,7 +165,7 @@
self.requestQ = Queue.Queue()
self.resultQ = Queue.Queue()
# progress bar
@@ -184,19 +185,11 @@
self.Bind(EVT_CMD_RUN, self.OnCmdRun)
self.Bind(EVT_CMD_DONE, self.OnCmdDone)
# search & command prompt
- self.searchBy = wx.Choice(parent = self.panelPrompt, id = wx.ID_ANY,
- choices = [_("description"),
- _("keywords")])
+ self.search = SearchModuleWindow(parent = self.panelPrompt)
- self.search = wx.TextCtrl(parent = self.panelPrompt, id = wx.ID_ANY,
- value = "", size = (-1, 25))
self.cmd_prompt = prompt.GPromptSTC(parent = self)
if self.parent.GetName() != 'LayerManager':
- self.searchBy.Hide()
self.search.Hide()
self.cmd_prompt.Hide()
@@ -227,7 +220,7 @@
size=(125,-1))
self.btn_abort.SetToolTipString(_("Abort the running command"))
self.btn_abort.Enable(False)
self.btn_cmd_clear.Bind(wx.EVT_BUTTON, self.cmd_prompt.OnCmdErase)
self.btn_console_clear.Bind(wx.EVT_BUTTON, self.ClearHistory)
self.btn_console_save.Bind(wx.EVT_BUTTON, self.SaveHistory)
@@ -242,25 +235,16 @@
"""!Do layout"""
OutputSizer = wx.BoxSizer(wx.VERTICAL)
PromptSizer = wx.BoxSizer(wx.VERTICAL)
- SearchSizer = wx.BoxSizer(wx.HORIZONTAL)
ButtonSizer = wx.BoxSizer(wx.HORIZONTAL)
OutputSizer.Add(item=self.cmd_output, proportion=1,
flag=wx.EXPAND | wx.ALL, border=3)
OutputSizer.Add(item=self.console_progressbar, proportion=0,
flag=wx.EXPAND | wx.LEFT | wx.RIGHT, border=3)
- if self.searchBy.IsShown():
- SearchSizer.Add(item = wx.StaticText(parent = self.panelPrompt, id = wx.ID_ANY,
- label = _("Find module:")),
- proportion = 0, flag = wx.LEFT | wx.ALIGN_CENTER_VERTICAL, border = 3)
- SearchSizer.Add(item = self.searchBy,
- proportion = 0, flag = wx.LEFT, border = 3)
- SearchSizer.Add(item = self.search,
- proportion = 1, flag = wx.LEFT | wx.EXPAND, border = 3)
- PromptSizer.Add(item=SearchSizer, proportion=0,
- flag=wx.EXPAND | wx.ALL, border=1)
+ if self.search.IsShown():
+ PromptSizer.Add(item=self.search, proportion=0,
+ flag=wx.EXPAND | wx.ALL, border=1)
PromptSizer.Add(item=self.cmd_prompt, proportion=1,
flag=wx.EXPAND | wx.LEFT | wx.RIGHT | wx.TOP, border=3)
@@ -570,7 +554,7 @@
iFound = 0
for module, data in self.cmd_prompt.moduleDesc.iteritems():
found = False
- if self.searchBy.GetSelection() == 0: # -> description
+ if self.search.GetSelection() == 'description': # -> description
if text in data['desc']:
found = True
else: # -> keywords
Modified: grass/trunk/gui/wxpython/gui_modules/help.py
--- grass/trunk/gui/wxpython/gui_modules/help.py 2010-05-04 08:56:16 UTC (rev 42102)
+++ grass/trunk/gui/wxpython/gui_modules/help.py 2010-05-04 09:02:19 UTC (rev 42103)
@@ -5,6 +5,7 @@
Classes:
- HelpWindow
+ - FindModuleWindow
- MenuTreeWindow
- AboutWindow
@@ -56,24 +57,16 @@
# sizer.SetSizeHints(self)
self.Layout()
-class MenuTreeWindow(wx.Panel):
- """!Show menu tree"""
+class SearchModuleWindow(wx.Panel):
+ """!Search module window (used in MenuTreeWindow)"""
def __init__(self, parent, id = wx.ID_ANY, **kwargs):
- self.parent = parent # LayerManager
wx.Panel.__init__(self, parent = parent, id = id, **kwargs)
- self.dataBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
- label=" %s " % _("Menu tree (double-click to run command)"))
- # tree
- self.tree = MenuTree(parent = self, data = menudata.ManagerData())
- self.tree.Load()
+ self._searchDict = { _('label') : 'label', # i18n workaround
+ _('help') : 'help',
+ _('command') : 'command',
+ _('keywords') : 'keywords' }
- self.searchDict = { _('label') : 'label', # i18n workaround
- _('help') : 'help',
- _('command') : 'command',
- _('keywords') : 'keywords' }
- # search
self.searchBy = wx.Choice(parent = self, id = wx.ID_ANY,
choices = [_('label'),
_('help'),
@@ -85,6 +78,49 @@
value = "", size = (-1, 25),
style = wx.TE_PROCESS_ENTER)
+ self._layout()
+ def _layout(self):
+ """!Do layout"""
+ # search
+ sizer = wx.BoxSizer(wx.HORIZONTAL)
+ sizer.Add(item = wx.StaticText(parent = self, id = wx.ID_ANY,
+ label = _("Find module by:")),
+ proportion = 0,
+ flag = wx.ALIGN_RIGHT | wx.ALIGN_CENTER_VERTICAL | wx.ALL,
+ border = 3)
+ sizer.Add(item = self.searchBy, proportion = 0,
+ flag = wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT | wx.LEFT | wx.RIGHT,
+ border = 5)
+ sizer.Add(item = self.search, proportion = 1,
+ flag = wx.EXPAND | wx.RIGHT | wx.ALIGN_CENTER_VERTICAL,
+ border = 5)
+ self.SetSizer(sizer)
+ sizer.Fit(self)
+ def GetSelection(self):
+ """!Get selected element"""
+ selection = self.searchBy.GetStringSelection()
+ return self._searchDict[selection]
+class MenuTreeWindow(wx.Panel):
+ """!Show menu tree"""
+ def __init__(self, parent, id = wx.ID_ANY, **kwargs):
+ self.parent = parent # LayerManager
+ wx.Panel.__init__(self, parent = parent, id = id, **kwargs)
+ self.dataBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
+ label=" %s " % _("Menu tree (double-click to run command)"))
+ # tree
+ self.tree = MenuTree(parent = self, data = menudata.ManagerData())
+ self.tree.Load()
+ # search widget
+ self.search = SearchModuleWindow(parent = self)
# buttons
self.btnRun = wx.Button(self, id = wx.ID_OK, label = _("Run"))
self.btnRun.SetToolTipString(_("Run selected command"))
@@ -92,10 +128,10 @@
# bindings
self.btnRun.Bind(wx.EVT_BUTTON, self.OnRun)
+ self.tree.Bind(wx.EVT_TREE_ITEM_ACTIVATED, self.OnItemActivated)
+ self.tree.Bind(wx.EVT_TREE_SEL_CHANGED, self.OnItemSelected)
self.search.Bind(wx.EVT_TEXT_ENTER, self.OnShowItem)
self.search.Bind(wx.EVT_TEXT, self.OnUpdateStatusBar)
- self.tree.Bind(wx.EVT_TREE_ITEM_ACTIVATED, self.OnItemActivated)
- self.tree.Bind(wx.EVT_TREE_SEL_CHANGED, self.OnItemSelected)
self._layout()
@@ -110,20 +146,6 @@
dataSizer.Add(item = self.tree, proportion =1,
flag = wx.EXPAND)
- # search
- searchSizer = wx.BoxSizer(wx.HORIZONTAL)
- searchSizer.Add(item = wx.StaticText(parent = self, id = wx.ID_ANY,
- label = _("Search:")),
- proportion = 0,
- flag = wx.ALIGN_RIGHT | wx.ALIGN_CENTER_VERTICAL | wx.ALL,
- border = 3)
- searchSizer.Add(item = self.searchBy, proportion = 0,
- flag = wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT | wx.LEFT | wx.RIGHT,
- border = 5)
- searchSizer.Add(item = self.search, proportion = 1,
- flag = wx.EXPAND | wx.RIGHT | wx.ALIGN_CENTER_VERTICAL,
- border = 5)
# buttons
btnSizer = wx.BoxSizer(wx.HORIZONTAL)
btnSizer.Add(item = self.btnRun, proportion = 0,
@@ -132,7 +154,7 @@
sizer.Add(item = dataSizer, proportion = 1,
flag = wx.EXPAND | wx.ALL, border = 5)
- sizer.Add(item = searchSizer, proportion=0,
+ sizer.Add(item = self.search, proportion=0,
flag = wx.EXPAND | wx.LEFT | wx.RIGHT | wx.BOTTOM, border = 5)
sizer.Add(item = btnSizer, proportion=0,
@@ -233,7 +255,7 @@
def OnUpdateStatusBar(self, event):
"""!Update statusbar text"""
- element = self.searchDict[self.searchBy.GetStringSelection()]
+ element = self.search.GetSelection()
self.tree.itemsMarked = self.SearchItems(element = element,
value = event.GetString())
self.tree.itemSelected = None
