[GRASS-SVN] r42111 - grass/branches/develbranch_6/vector/v.buffer
Tue May 4 11:01:47 EDT 2010
Author: martinl
Date: 2010-05-04 11:01:46 -0400 (Tue, 04 May 2010)
New Revision: 42111
   grass/branches/develbranch_6/vector/v.buffer/main.c
v.buffer: be more verbose
Modified: grass/branches/develbranch_6/vector/v.buffer/main.c
--- grass/branches/develbranch_6/vector/v.buffer/main.c	2010-05-04 12:05:43 UTC (rev 42110)
+++ grass/branches/develbranch_6/vector/v.buffer/main.c	2010-05-04 15:01:46 UTC (rev 42111)
@@ -641,7 +641,9 @@
     nareas = Vect_get_num_areas(&Out);
     Areas = (char *)G_calloc(nareas + 1, sizeof(char));
+    G_message(_("Calculating centroids for areas..."));
     for (area = 1; area <= nareas; area++) {
+	G_percent(area, nareas, 2);
 	G_debug(3, "area = %d", area);
 /*** BUG *** if dynamic bufcol was used, "buffer" will only hold last value ***/
@@ -681,7 +683,9 @@
     G_debug(3, "nlines = %d", nlines);
     Lines = (char *)G_calloc(nlines + 1, sizeof(char));
+    G_message(_("Generating list of boundaries to be deleted..."));
     for (line = 1; line <= nlines; line++) {
+	G_percent(line, nlines, 2);
 	int j, side[2], areas[2];
 	G_debug(3, "line = %d", line);
@@ -711,7 +715,9 @@
     G_free(Areas);
     /* Delete boundaries */
+    G_message(_("Deleting boundaries..."));
 	if (Lines[line]) {
 	    G_debug(3, " delete line %d", line);
 	    Vect_delete_line(&Out, line);
@@ -724,7 +730,10 @@
     Vect_reset_cats(Cats);
     Vect_cat_set(Cats, 1, 1);
 	double x, y;
