[GRASS-SVN] r42112 -
grass/branches/releasebranch_6_4/vector/v.buffer
svn_grass at osgeo.org
Tue May 4 11:14:31 EDT 2010
Author: martinl
Date: 2010-05-04 11:14:30 -0400 (Tue, 04 May 2010)
New Revision: 42112
grass/branches/releasebranch_6_4/vector/v.buffer/main.c
v.buffer: be more verbose
(merge r42111 from devbr6)
Modified: grass/branches/releasebranch_6_4/vector/v.buffer/main.c
--- grass/branches/releasebranch_6_4/vector/v.buffer/main.c 2010-05-04 15:01:46 UTC (rev 42111)
+++ grass/branches/releasebranch_6_4/vector/v.buffer/main.c 2010-05-04 15:14:30 UTC (rev 42112)
@@ -641,7 +641,9 @@
nareas = Vect_get_num_areas(&Out);
Areas = (char *)G_calloc(nareas + 1, sizeof(char));
+ G_message(_("Calculating centroids for areas..."));
for (area = 1; area <= nareas; area++) {
+ G_percent(area, nareas, 2);
G_debug(3, "area = %d", area);
/*** BUG *** if dynamic bufcol was used, "buffer" will only hold last value ***/
@@ -681,7 +683,9 @@
G_debug(3, "nlines = %d", nlines);
Lines = (char *)G_calloc(nlines + 1, sizeof(char));
+ G_message(_("Generating list of boundaries to be deleted..."));
for (line = 1; line <= nlines; line++) {
+ G_percent(line, nlines, 2);
int j, side[2], areas[2];
G_debug(3, "line = %d", line);
@@ -711,7 +715,9 @@
G_free(Areas);
/* Delete boundaries */
+ G_message(_("Deleting boundaries..."));
if (Lines[line]) {
G_debug(3, " delete line %d", line);
Vect_delete_line(&Out, line);
@@ -724,7 +730,10 @@
Vect_reset_cats(Cats);
Vect_cat_set(Cats, 1, 1);
double x, y;
