[GRASS-SVN] r42294 - grass/trunk/scripts/r.buffer
svn_grass at osgeo.org
Tue May 18 08:31:08 EDT 2010
Author: martinl
Date: 2010-05-18 08:31:08 -0400 (Tue, 18 May 2010)
New Revision: 42294
grass/trunk/scripts/r.buffer/r.buffer.py
r.buffer: fix cleanup() - remove only existing files
Modified: grass/trunk/scripts/r.buffer/r.buffer.py
--- grass/trunk/scripts/r.buffer/r.buffer.py 2010-05-18 12:19:14 UTC (rev 42293)
+++ grass/trunk/scripts/r.buffer/r.buffer.py 2010-05-18 12:31:08 UTC (rev 42294)
@@ -74,8 +74,10 @@
# what to do in case of user break:
def cleanup():
- grass.run_command('g.remove', quiet = True, flags = 'f', rast = temp_src)
- grass.run_command('g.remove', quiet = True, flags = 'f', rast = temp_dist)
+ if grass.find_file(temp_src)['file']:
+ grass.run_command('g.remove', quiet = True, flags = 'f', rast = temp_src)
+ if grass.find_file(temp_dist)['file']:
+ grass.run_command('g.remove', quiet = True, flags = 'f', rast = temp_dist)
def main():
global temp_dist, temp_src
