[GRASS-SVN] r42295 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Tue May 18 08:33:55 EDT 2010
Author: martinl
Date: 2010-05-18 08:33:55 -0400 (Tue, 18 May 2010)
New Revision: 42295
grass/trunk/lib/vector/Vlib/write_ogr.c
vlib: add missing doxygen strings
Modified: grass/trunk/lib/vector/Vlib/write_ogr.c
--- grass/trunk/lib/vector/Vlib/write_ogr.c 2010-05-18 12:31:08 UTC (rev 42294)
+++ grass/trunk/lib/vector/Vlib/write_ogr.c 2010-05-18 12:33:55 UTC (rev 42295)
@@ -137,8 +137,19 @@
return Map->fInfo.ogr.offset_num++;
+ \brief Writes feature on level 2
+ \param Map pointer to Map_info structure
+ \param type feature type
+ \param points pointer to line_pnts structure (feature geometry)
+ \param cats pointer to line_cats structure (feature categories)
+ \return feature offset into file
+ \return -1 on error
off_t V2_write_line_ogr(struct Map_info *Map, int type,
- const struct line_pnts *points, const struct line_cats *cats)
+ const struct line_pnts *points, const struct line_cats *cats)
int line;
off_t offset;
@@ -147,10 +158,11 @@
line = 0;
- G_debug(3, "V2_write_line_nat()");
+ G_debug(3, "V2_write_line_ogr()");
offset = V1_write_line_ogr(Map, type, points, cats);
if (offset < 0)
return -1;
/* Update topology */
plus = &(Map->plus);
/* Add line */
