[GRASS-SVN] r42297 - grass/trunk/vector/v.info
svn_grass at osgeo.org
Tue May 18 09:08:15 EDT 2010
Author: mmetz
Date: 2010-05-18 09:08:14 -0400 (Tue, 18 May 2010)
New Revision: 42297
grass/trunk/vector/v.info/main.c
simplify level handling
Modified: grass/trunk/vector/v.info/main.c
--- grass/trunk/vector/v.info/main.c 2010-05-18 12:53:44 UTC (rev 42296)
+++ grass/trunk/vector/v.info/main.c 2010-05-18 13:08:14 UTC (rev 42297)
@@ -44,23 +44,21 @@
&input_opt, &field_opt,
&hist_flag, &col_flag, ®_flag, &topo_flag, &title_flag, &level1_flag);
- /* force level 1
- * NOTE: number of points, lines, boundaries, centroids, faces, kernels is still available */
- if (level1_flag) {
- Vect_set_open_level(1); /* no topology */
- Vect_open_old2(&Map, input_opt, "", field_opt);
if (!level1_flag) {
- /* try to open on level 2 */
- if (Vect_open_old2(&Map, input_opt, "", field_opt) == 1) {
+ /* try to open head-only on level 2 */
+ if (Vect_open_old_head2(&Map, input_opt, "", field_opt) == 1) {
G_warning(_("Unable to open vector map <%s> on level 2, using level 1"),
Vect_get_full_name(&Map));
+ Vect_close(&Map);
level1_flag = 1;
+ /* force level 1, open fully
+ * NOTE: number of points, lines, boundaries, centroids, faces, kernels is still available */
if (level1_flag) {
+ Vect_set_open_level(1); /* no topology */
+ Vect_open_old2(&Map, input_opt, "", field_opt);
level_one_info(&Map);
