[GRASS-SVN] r42298 - grass/trunk/gui/wxpython/gui_modules
Tue May 18 09:17:06 EDT 2010
Author: martinl
Date: 2010-05-18 09:17:05 -0400 (Tue, 18 May 2010)
New Revision: 42298
   grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/wxnviz.py
wxGUI/wxnviz: use Python strings
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py	2010-05-18 13:08:14 UTC (rev 42297)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py	2010-05-18 13:17:05 UTC (rev 42298)
@@ -1,20 +1,21 @@
 @package nviz_mapdisp.py
- at brief Nviz extension for wxGUI
+ at brief wxGUI 3D view mode (map canvas)
-This module implements 3D visualization mode of map display.
+This module implements 3D visualization mode for map display.
 List of classes:
+ - NvizThread
  - GLWindow
-(C) 2008-2009 by the GRASS Development Team
+(C) 2008-2010 by the GRASS Development Team
 This program is free software under the GNU General Public
 License (>=v2). Read the file COPYING that comes with GRASS
 for details.
- at author Martin Landa <landa.martin gmail.com> (Google SoC 2008)
+ at author Martin Landa <landa.martin gmail.com> (Google SoC 2008/2010)
 import os
Modified: grass/trunk/gui/wxpython/gui_modules/wxnviz.py
--- grass/trunk/gui/wxpython/gui_modules/wxnviz.py	2010-05-18 13:08:14 UTC (rev 42297)
+++ grass/trunk/gui/wxpython/gui_modules/wxnviz.py	2010-05-18 13:17:05 UTC (rev 42298)
@@ -1,281 +1,286 @@
+ at package wxnviz.py
+List of classes:
+ - Nviz
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Pythonized by Glynn Clements
 from ctypes import *
 from grass.lib.grass import *
-from grass.lib.ogsf import *
-from grass.lib.nviz import *
+from grass.lib.ogsf  import *
+from grass.lib.nviz  import *
 def G_debug(level, str, *args):
     print str, args
 class Nviz(object):
-# \brief Initialize Nviz class instance
     def __init__(self, log):
+        """!Initialize Nviz class instance
+        @param log logging area
         G_gisinit("")       # GRASS functions
         # logStream = log
         # G_set_error_routine(&print_error)
         # G_set_percent_routine(&print_percent)
         GS_libinit()
         GVL_libinit()
         # GS_set_swap_func(swap_gl)
         self.data_obj = nv_data()
         self.data = pointer(self.data_obj)
         G_debug(1, "Nviz::Nviz()")
-# \brief Destroy Nviz class instance
     def __del__(self):
+        """!Destroy Nviz class instance"""
         # G_unset_error_routine()
         # G_unset_percent_routine()
         del self.data
         del self.data_obj
         # logStream = None
-# \brief GL canvas resized
-# \param width window width
-# \param height window height
-# \return 1 on success
-# \return 0 on failure (window resized by default to 20x20 px)
     def ResizeWindow(self, width, height):
+        """!GL canvas resized
+        @param width window width
+        @param height window height
+        @return 1 on success
+        @return 0 on failure (window resized by default to 20x20 px)
         G_debug(1, "Nviz::ResizeWindow(): width=%d height=%d",
                 width, height)
         return Nviz_resize_window(width, height)
-# \brief Set default view (based on loaded data)
-# \return z-exag value, default, min and max height
     def SetViewDefault(self):
+        """!Set default view (based on loaded data)
+        @return z-exag value, default, min and max height
         # determine z-exag
         z_exag = Nviz_get_exag()
         Nviz_change_exag(self.data, z_exag)
         # determine height
         hdef = c_float()
         hmin = c_float()
         hmax = c_float()
         Nviz_get_exag_height(byref(hdef), byref(hmin), byref(hmax))
         G_debug(1, "Nviz::SetViewDefault(): hdef=%f, hmin=%f, hmax=%f",
                 hdef, hmin, hmax)
         return (z_exag, hdef.value, hmin.value, hmax.value)
-# \brief Change view settings
-# \param x,y position
-# \param height
-# \param persp perpective
-# \param twist
     def SetView(self, x, y, height, persp, twist):
+        """!Change view settings
+        @param x,y position
+        @param height
+        @param persp perpective
+        @param twist
         Nviz_set_viewpoint_height(self.data, height)
         Nviz_set_viewpoint_position(self.data, x, y)
         Nviz_set_viewpoint_twist(self.data, twist)
         Nviz_set_viewpoint_persp(self.data, persp)
         G_debug(1, "Nviz::SetView(): x=%f, y=%f, height=%f, persp=%f, twist=%f",
         return 1
-# \brief Set z-exag value
-# \param z_exag value
-# \return 1
     def SetZExag(self, z_exag):
+        """!Set z-exag value
+        @param z_exag value
+        @return 1
         G_debug(1, "Nviz::SetZExag(): z_exag=%f", z_exag)
         return Nviz_change_exag(self.data, z_exag)
-# \brief Draw map
-# Draw quick mode:
-#  - DRAW_QUICK_SURFACE
-#  - DRAW_QUICK_VLINES
-#  - DRAW_QUICK_VPOINTS
-#  - DRAW_QUICK_VOLUME
-# \param quick if true draw in wiremode
-# \param quick_mode quick mode
     def Draw(self, quick, quick_mode):
+        """!Draw map
+        Draw quick mode:
+         - DRAW_QUICK_SURFACE
+         - DRAW_QUICK_VLINES
+         - DRAW_QUICK_VPOINTS
+         - DRAW_QUICK_VOLUME
+        @param quick if true draw in wiremode
+        @param quick_mode quick mode
         Nviz_draw_cplane(self.data, -1, -1) # ?
         if quick:
             Nviz_draw_quick(self.data, quick_mode)
         else:
             Nviz_draw_all(self.data)
         G_debug(1, "Nviz::Draw(): quick=%d", quick)
-# \brief Erase map display (with background color)
     def EraseMap(self):
+        """!Erase map display (with background color)
         GS_clear(self.data.bgcolor)
         G_debug(1, "Nviz::EraseMap()")
     def InitView(self):
+        """!Initialize view"""
         # initialize nviz data
         Nviz_init_data(self.data)
         # define default attributes for map objects
         Nviz_set_surface_attr_default()
         # set background color
         Nviz_set_bgcolor(self.data, Nviz_color_from_str("white")) # TODO
         # initialize view
         Nviz_init_view()
         # set default lighting model
         self.SetLightsDefault()
         # clear window
         G_debug(1, "Nviz::InitView()")
-# \brief Set background color
-# \param color_str color string
     def SetBgColor(self, color_str):
+        """!Set background color
+        @param color_str color string
         self.data.bgcolor = Nviz_color_from_str(color_str)
-# \brief Set default lighting model
     def SetLightsDefault(self):
+        """!Set default lighting model
         # first
         Nviz_set_light_position(self.data, 0, 0.68, -0.68, 0.80, 0.0)
         Nviz_set_light_bright(self.data, 0, 0.8)
         Nviz_set_light_color(self.data, 0, 1.0, 1.0, 1.0)
         Nviz_set_light_ambient(self.data, 0, 0.2, 0.2, 0.2)
         # second
         Nviz_set_light_position(self.data, 1, 0.0, 0.0, 1.0, 0.0)
         Nviz_set_light_bright(self.data, 1, 0.5)
         Nviz_set_light_color(self.data, 1, 1.0, 1.0, 1.0)
         Nviz_set_light_ambient(self.data, 1, 0.3, 0.3, 0.3)
         G_debug(1, "Nviz::SetLightsDefault()")
-# \brief Load raster map (surface)
-# \param name raster map name
-# \param color_name raster map for color (NULL for color_value)
-# \param color_value color string (named color or RGB triptet)
-# \return object id
-# \return -1 on failure
     def LoadSurface(self, name, color_name, color_value):
+        """!Load raster map (surface)
+        @param name raster map name
+        @param color_name raster map for color (NULL for color_value)
+        @param color_value color string (named color or RGB triptet)
+        @return object id
+        @return -1 on failure
         mapset = G_find_raster2(name, "")
         if mapset is None:
             G_warning(_("Raster map <%s> not found"), name)
             return -1
         # topography
         id = Nviz_new_map_obj(MAP_OBJ_SURF,
                               G_fully_qualified_name(name, mapset), 0.0,
                               self.data)
         if color_name:      # check for color map
             mapset = G_find_raster2(color_name, "")
             if mapset is None:
                 G_warning(_("Raster map <%s> not found"), color_name)
                 GS_delete_surface(id)
                 return -1
             Nviz_set_attr(id, MAP_OBJ_SURF, ATT_COLOR, MAP_ATT,
                           G_fully_qualified_name(color_name, mapset), -1.0,
                           self.data)
         elif color_value:   # check for color value
             Nviz_set_attr(id, MAP_OBJ_SURF, ATT_COLOR, CONST_ATT,
                           None, Nviz_color_from_str(color_value),
                           self.data)
         else:               # use by default elevation map for coloring
                           G_fully_qualified_name(name, mapset), -1.0,
                           self.data)
         # if (i > 1)
         #     set_default_wirecolors(self.data, i)
         # focus on loaded self.data
         Nviz_set_focus_map(MAP_OBJ_UNDEFINED, -1)
         G_debug(1, "Nviz::LoadRaster(): name=%s -> id=%d", name, id)
         return id
-# \brief Unload surface
-# \param id surface id
     def UnloadSurface(self, id):
+        """!Unload surface
+        @param id surface id
         if not GS_surf_exists(id):
             return 0
         G_debug(1, "Nviz::UnloadSurface(): id=%d", id)
         if GS_delete_surface(id) < 0:
             return 0
         return 1
-# \brief Load vector map overlay
-# \param name vector map name
-# \param points if true load 2d points rather then 2d lines
     def LoadVector(self, name, points):
+        """!Load vector map overlay
+        @param name vector map name
+        @param points if true load 2d points rather then 2d lines
+        @return object id
         if GS_num_surfs() == 0:     # load base surface if no loaded
             Nviz_new_map_obj(MAP_OBJ_SURF, NULL, 0.0, self.data)
             nsurf = c_int()
             surf_list = GS_get_surf_list(byref(nsurf))
             GS_set_att_const(surf_list[0], ATT_TRANSP, 255)
         mapset = G_find_vector2 (name, "")
         if mapset is None:
             G_warning(_("Vector map <%s> not found"),
                       name)
         if points:
             id = Nviz_new_map_obj(MAP_OBJ_SITE,
@@ -284,23 +289,22 @@
             id = Nviz_new_map_obj(MAP_OBJ_VECT,
                                   self.data)
         G_debug(1, "Nviz::LoadVector(): name=%s -> id=%d", name, id)
         return id
-# \brief Unload vector set
-# \param id vector set id
-# \param points vector points or lines set
     def UnloadVector(self, id, points):
+        """!Unload vector set
+        @param id vector set id
+        @param points vector points or lines set
         G_debug(1, "Nviz::UnloadVector(): id=%d", id)
         if points:
             if not GP_site_exists(id):
                 return 0
@@ -311,31 +315,30 @@
                 return 0
             if GV_delete_vector(id) < 0:
                 return 0
         return 1
-# \brief Load 3d raster map (volume)
-# \param name 3d raster map name
-# \param color_name 3d raster map for color (NULL for color_value)
     def LoadVolume(self, name, color_name, color_value):
+        """!Load 3d raster map (volume)
+        @param name 3d raster map name
+        @param color_name 3d raster map for color (NULL for color_value)
+        @return object id
         mapset = G_find_grid3(name, "")
         if mapset is None:
             G_warning(_("3d raster map <%s> not found"),
                       name)
             return -1
         # topography
         id = Nviz_new_map_obj(MAP_OBJ_VOL,
                               self.data)
             mapset = G_find_grid3(color_name, "")
             if mapset is None:
@@ -343,7 +346,7 @@
                           color_name)
                 GVL_delete_vol(id)
                 return -1
             Nviz_set_attr(id, MAP_OBJ_VOL, ATT_COLOR, MAP_ATT,
                           self.data)
@@ -355,134 +358,126 @@
                           self.data)
         G_debug(1, "Nviz::LoadVolume(): name=%s -> id=%d", name, id)
         return id
-# \brief Unload volume
-# \param id volume id
     def UnloadVolume(self, id):
+        """!Unload volume
+        @param id volume id
         if not GVL_vol_exists(id):
             return 0
         G_debug(1, "Nviz::UnloadVolume(): id=%d", id)
         if GVL_delete_vol(id) < 0:
           return 0
         return 1
-# \brief Set surface topography
-# \param map if true use map otherwise constant
-# \param value map name of value
-# \return -1 surface not found
-# \return -2 setting attributes failed
     def SetSurfaceTopo(self, id, map, value):
+        """!Set surface topography
+        @param map if true use map otherwise constant
+        @param value map name of value
+        @return -1 surface not found
+        @return -2 setting attributes failed
         return self.SetSurfaceAttr(id, ATT_TOPO, map, value)
-# \brief Set surface color
     def SetSurfaceColor(self, id, map, value):
+        """!Set surface color
         return self.SetSurfaceAttr(id, ATT_COLOR, map, value)
-# \brief Set surface mask
-# @todo invert
-# \param invert if true invert mask
     def SetSurfaceMask(self, id, invert, value):
+        """!Set surface mask
+        @todo invert
+        @param invert if true invert mask
         return self.SetSurfaceAttr(id, ATT_MASK, true, value)
-# @todo invert
     def SetSurfaceTransp(self, id, map, value):
+        @todo invert
         return self.SetSurfaceAttr(id, ATT_TRANSP, map, value)
-# \brief Set surface shininess
     def SetSurfaceShine(self, id, map, value):
+        """!Set surface shininess
         return self.SetSurfaceAttr(id, ATT_SHINE, map, value)
-# \brief Set surface emission
     def SetSurfaceEmit(self, id, map, value):
+        """!Set surface emission
         return self.SetSurfaceAttr(id, ATT_EMIT, map, value)
-# \brief Set surface attribute
-# \param attr attribute desc
     def SetSurfaceAttr(self, id, attr, map, value):
+        """!Set surface attribute
+        @param attr attribute desc
             return -1
         if map:
             ret = Nviz_set_attr(id, MAP_OBJ_SURF, attr, MAP_ATT,
                                 value, -1.0, self.data)
@@ -491,162 +486,155 @@
                 val = Nviz_color_from_str(value)
             else:
                 val = atof(value)
             ret = Nviz_set_attr(id, MAP_OBJ_SURF, attr, CONST_ATT,
                                 NULL, val, self.data)
         G_debug(1, "Nviz::SetSurfaceAttr(): id=%d, attr=%d, map=%d, value=%s",
         return 1 if ret else -2
-# \brief Unset surface mask
     def UnsetSurfaceMask(self, id):
+        """!Unset surface mask
         return self.UnsetSurfaceAttr(id, ATT_MASK)
-# \brief Unset surface transparency
     def UnsetSurfaceTransp(self, id):
+        """!Unset surface transparency
         return self.UnsetSurfaceAttr(id, ATT_TRANSP)
-# \brief Unset surface emission
     def UnsetSurfaceEmit(self, id):
+        """!Unset surface emission
         return self.UnsetSurfaceAttr(id, ATT_EMIT)
-# \brief Unset surface attribute
-# \param attr attribute descriptor
     def UnsetSurfaceAttr(self, id, attr):
+        """!Unset surface attribute
+        @param attr attribute descriptor
             return -1
         G_debug(1, "Nviz::UnsetSurfaceAttr(): id=%d, attr=%d",
                 id, attr)
         ret = Nviz_unset_attr(id, MAP_OBJ_SURF, attr)
-# \brief Set surface resolution
-# \param fine x/y fine resolution
-# \param coarse x/y coarse resolution
     def SetSurfaceRes(self, id, fine, coarse):
+        """!Set surface resolution
+        @param fine x/y fine resolution
+        @param coarse x/y coarse resolution
         G_debug(1, "Nviz::SetSurfaceRes(): id=%d, fine=%d, coarse=%d",
                 id, fine, coarse)
         if id > 0:
                 return -1
             if GS_set_drawres(id, fine, fine, coarse, coarse) < 0:
                 return -2
         else:
             GS_setall_drawres(fine, fine, coarse, coarse)
         return 1
-# \brief Set draw style
-# Draw styles:
-#  - DM_GOURAUD
-#  - DM_FLAT
-#  - DM_FRINGE
-#  - DM_WIRE
-#  - DM_COL_WIRE
-#  - DM_POLY
-#  - DM_WIRE_POLY
-#  - DM_GRID_WIRE
-#  - DM_GRID_SURF
-# \param id surface id (<= 0 for all)
-# \param style draw style
     def SetSurfaceStyle(self, id, style):
+        """!Set draw style
+        Draw styles:
+         - DM_GOURAUD
+         - DM_FLAT
+         - DM_FRINGE
+         - DM_WIRE
+         - DM_COL_WIRE
+         - DM_POLY
+         - DM_WIRE_POLY
+         - DM_GRID_WIRE
+         - DM_GRID_SURF
+        @param id surface id (<= 0 for all)
+        @param style draw style
         G_debug(1, "Nviz::SetSurfaceStyle(): id=%d, style=%d",
                 id, style)
         if id > 0:
                 return -1
             if GS_set_drawmode(id, style) < 0:
                 return -2
             return 1
         if GS_setall_drawmode(style) < 0:
             return -2
         return 1
-# \brief Set color of wire
-# \todo all
-# \param surface id (< 0 for all)
-# \param color color string (R:G:B)
     def SetWireColor(self, id, color_str):
+        """!Set color of wire
+        @todo all
+        @param surface id (< 0 for all)
+        @param color color string (R:G:B)
         G_debug(1, "Nviz::SetWireColor(): id=%d, color=%s",
                 id, color_str)
         if id > 0:
                 return -1
             GS_set_wire_color(id, color)
         else:
             nsurfs = c_int()
@@ -654,365 +642,346 @@
             for i in xrange(nsurfs.value):
                 id = surf_list[i]
             G_free(surf_list)
             surf_list = None
         return 1
-# \brief Get surface position
-# \return x,y,z
-# \return zero-length vector on error
     def GetSurfacePosition(self, id):
+        """!Get surface position
+        @return x,y,z
+        @return zero-length vector on error
             return []
         x, y, z = c_float(), c_float(), c_float()
         GS_get_trans(id, byref(x), byref(y), byref(z))
         G_debug(1, "Nviz::GetSurfacePosition(): id=%d, x=%f, y=%f, z=%f",
                 id, x, y, z)
         return [x.value, y.value, z.value]
-# \brief Set surface position
-# \param x,y,z translation values
-# \return -2 setting position failed
     def SetSurfacePosition(self, id, x, y, z):
+        """!Set surface position
+        @param x,y,z translation values
+        @return -2 setting position failed
             return -1
         G_debug(1, "Nviz::SetSurfacePosition(): id=%d, x=%f, y=%f, z=%f",
                 id, x, y, z)
         GS_set_trans(id, x, y, z)
         return 1
-# \brief Set mode of vector line overlay
-# \param id vector id
-# \param width line width
-# \param flat display flat or on surface
-# \return -1 vector set not found
-# \return -2 on failure
     def SetVectorLineMode(self, id, color_str, width, flat):
+        """!Set mode of vector line overlay
+        @param id vector id
+        @param width line width
+        @param flat display flat or on surface
+        @return -1 vector set not found
+        @return -2 on failure
         if not GV_vect_exists(id):
             return -1
         G_debug(1, "Nviz::SetVectorMode(): id=%d, color=%s, width=%d, flat=%d",
         # use memory by default
         if GV_set_vectmode(id, 1, color, width, flat) < 0:
             return -2
         return 1
-# \brief Set vector height above surface (lines)
-# \param height
     def SetVectorLineHeight(self, id, height):
+        """!Set vector height above surface (lines)
+        @param height
             return -1
         G_debug(1, "Nviz::SetVectorLineHeight(): id=%d, height=%f",
                 id, height)
         GV_set_trans(id, 0.0, 0.0, height)
         return 1
-# \brief Set reference surface of vector set (lines)
-# \param surf_id surface id
-# \return -2 surface not found
-# \return -3 on failure
     def SetVectorLineSurface(self, id, surf_id):
+        """!Set reference surface of vector set (lines)
+        @param surf_id surface id
+        @return -2 surface not found
+        @return -3 on failure
             return -1
         if not GS_surf_exists(surf_id):
             return -2
         if GV_select_surf(id, surf_id) < 0:
             return -3
         return 1
-# \brief Set mode of vector point overlay
-# \param flat
     def SetVectorPointMode(self, id, color_str, width, size, marker):
+        """!Set mode of vector point overlay
+        @param flat
             return -1
         G_debug(1, "Nviz::SetVectorPointMode(): id=%d, color=%s, "
                 "width=%d, size=%f, marker=%d",
         if GP_set_style(id, color, width, size, marker) < 0:
             return -2
         return 1
-# \brief Set vector height above surface (points)
-# \param height
     def SetVectorPointHeight(self, id, height):
+        """!Set vector height above surface (points)
+        @param height
             return -1
         G_debug(1, "Nviz::SetVectorPointHeight(): id=%d, height=%f",
                 id, height)
         GP_set_trans(id, 0.0, 0.0, height)
         return 1
-# \brief Set reference surface of vector set (points)
     def SetVectorPointSurface(self, id, surf_id):
+        """!Set reference surface of vector set (points)
             return -1
             return -2
         if GP_select_surf(id, surf_id) < 0:
             return -3
         return 1
-# \brief Add new isosurface
-# \param level isosurface level (topography)
     def AddIsosurface(self, id, level):
+        """!Add new isosurface
+        @param level isosurface level (topography)
             return -1
         if GVL_isosurf_add(id) < 0:
             return -1
         # set topography level
         nisosurfs = GVL_isosurf_num_isosurfs(id)
         return GVL_isosurf_set_att_const(id, nisosurfs - 1, ATT_TOPO, level)
-# \brief Delete isosurface
-# \param isosurf_id isosurface id
-# \return -1 volume not found
-# \return -2 isosurface not found
     def DeleteIsosurface(self, id, isosurf_id):
+        """!Delete isosurface
+        @param isosurf_id isosurface id
+        @return -1 volume not found
+        @return -2 isosurface not found
             return -1
         if isosurf_id > GVL_isosurf_num_isosurfs(id):
             return -2
         ret = GVL_isosurf_del(id, isosurf_id)
         return -3 if ret < 0 else 1
-# \brief Move isosurface up/down in the list
-# \param up if true move up otherwise down
     def MoveIsosurface(self, id, isosurf_id, up):
+        """!Move isosurface up/down in the list
+        @param up if true move up otherwise down
             return -1
             return -2
         if up:
             ret = GVL_isosurf_move_up(id, isosurf_id)
         else:
             ret = GVL_isosurf_move_down(id, isosurf_id)
-# \brief Set isosurface color
-# \param isosurf_id isosurface id (0 - MAX_ISOSURFS)
     def SetIsosurfaceColor(self, id, isosurf_id, map, value):
+        """!Set isosurface color
+        @param isosurf_id isosurface id (0 - MAX_ISOSURFS)
         return self.SetIsosurfaceAttr(id, isosurf_id, ATT_COLOR, map, value)
-# \brief Set isosurface mask
-# @todo invert
-# \param invert true for invert mask
-# \param value map name to be used for mask
     def SetIsosurfaceMask(self, id, isosurf_id, invert, value):
+        """!Set isosurface mask
+        @todo invert
+        @param invert true for invert mask
+        @param value map name to be used for mask
         return self.SetIsosurfaceAttr(id, isosurf_id, ATT_MASK, true, value)
-# \brief Set isosurface transparency
     def SetIsosurfaceTransp(self, id, isosurf_id, map, value):
+        """!Set isosurface transparency
         return self.SetIsosurfaceAttr(id, isosurf_id, ATT_TRANSP, map, value)
-# \brief Set isosurface shininess
     def SetIsosurfaceShine(self, id, isosurf_id, map, value):
+        """!Set isosurface shininess
         return self.SetIsosurfaceAttr(id, isosurf_id, ATT_SHINE, map, value)
-# \brief Set isosurface emission
     def SetIsosurfaceEmit(self, id, isosurf_id, map, value):
+        """!Set isosurface emission
         return self.SetIsosurfaceAttr(id, isosurf_id, ATT_EMIT, map, value)
-# \brief Set isosurface attribute
-# \return -3 setting attributes failed
     def SetIsosurfaceAttr(self, id, isosurf_id, attr, map, value):
+        """!Set isosurface attribute
+        @return -3 setting attributes failed
             return -1
         if isosurf_id > GVL_isosurf_num_isosurfs(id) - 1:
             return -2
         if map:
             ret = GVL_isosurf_set_att_map(id, isosurf_id, attr, value)
         else:
@@ -1020,113 +989,107 @@
             else:
                 val = float(value)
             ret = GVL_isosurf_set_att_const(id, isosurf_id, attr, val)
         G_debug(1, "Nviz::SetIsosurfaceAttr(): id=%d, isosurf=%d, "
                 "attr=%d, map=%d, value=%s",
         return 1 if ret > 0 else -2
-# \brief Unset isosurface mask
     def UnsetIsosurfaceMask(self, id, isosurf_id):
+        """!Unset isosurface mask
         return self.UnsetIsosurfaceAttr(id, isosurf_id, ATT_MASK)
-# \brief Unset isosurface transparency
     def UnsetIsosurfaceTransp(self, id, isosurf_id):
+        """!Unset isosurface transparency
         return self.UnsetIsosurfaceAttr(id, isosurf_id, ATT_TRANSP)
-# \brief Unset isosurface emission
     def UnsetIsosurfaceEmit(self, id, isosurf_id):
+        """!Unset isosurface emission
         return self.UnsetIsosurfaceAttr(id, isosurf_id, ATT_EMIT)
     def UnsetIsosurfaceAttr(self, id, isosurf_id, attr):
             return -1
             return -2
         G_debug(1, "Nviz::UnsetSurfaceAttr(): id=%d, isosurf_id=%d, attr=%d",
         ret = GVL_isosurf_unset_att(id, isosurf_id, attr)
-# \brief Set draw mode for isosurfaces
-# \param mode
-# \return -1 volume set not found
     def SetIsosurfaceMode(self, id, mode):
+        """!Set draw mode for isosurfaces
+        @param mode
+        @return -1 volume set not found
             return -1
         ret = GVL_isosurf_set_drawmode(id, mode)
         return -2 if ret < 0 else 1
-# \brief Set draw resolution for isosurfaces
-# \param res resolution value
     def SetIsosurfaceRes(self, id, res):
+        """!Set draw resolution for isosurfaces
+        @param res resolution value
             return -1
         ret = GVL_isosurf_set_drawres(id, res, res, res)
