[GRASS-SVN] r42313 - grass/trunk/vector/v.info
svn_grass at osgeo.org
Wed May 19 03:24:08 EDT 2010
Author: mmetz
Date: 2010-05-19 03:24:08 -0400 (Wed, 19 May 2010)
New Revision: 42313
grass/trunk/vector/v.info/local_proto.h
grass/trunk/vector/v.info/main.c
grass/trunk/vector/v.info/parse.c
remove level 1 flag, simplify automated level handling
Modified: grass/trunk/vector/v.info/local_proto.h
--- grass/trunk/vector/v.info/local_proto.h 2010-05-19 01:47:35 UTC (rev 42312)
+++ grass/trunk/vector/v.info/local_proto.h 2010-05-19 07:24:08 UTC (rev 42313)
@@ -6,7 +6,7 @@
/* parse.c */
void parse_args(int, char**,
char **, char**,
- int *, int *, int *, int *, int *, int *);
+ int *, int *, int *, int *, int *);
/* print.c */
void format_double(double, char *);
Modified: grass/trunk/vector/v.info/main.c
--- grass/trunk/vector/v.info/main.c 2010-05-19 01:47:35 UTC (rev 42312)
+++ grass/trunk/vector/v.info/main.c 2010-05-19 07:24:08 UTC (rev 42313)
@@ -27,7 +27,7 @@
struct GModule *module;
char *input_opt, *field_opt;
- int hist_flag, col_flag, reg_flag, topo_flag, title_flag, level1_flag;
+ int hist_flag, col_flag, reg_flag, topo_flag, title_flag;
struct Map_info Map;
@@ -42,25 +42,20 @@
parse_args(argc, argv,
&input_opt, &field_opt,
- &hist_flag, &col_flag, ®_flag, &topo_flag, &title_flag, &level1_flag);
+ &hist_flag, &col_flag, ®_flag, &topo_flag, &title_flag);
- if (!level1_flag) {
- /* try to open head-only on level 2 */
- if (Vect_open_old_head2(&Map, input_opt, "", field_opt) < 2) {
- G_warning(_("Unable to open vector map <%s> on level 2, using level 1"),
- Vect_get_full_name(&Map));
- Vect_close(&Map);
- level1_flag = 1;
- /* force level 1, open fully
- * NOTE: number of points, lines, boundaries, centroids, faces, kernels is still available */
- if (level1_flag) {
+ /* try to open head-only on level 2 */
+ if (Vect_open_old_head2(&Map, input_opt, "", field_opt) < 2) {
+ /* force level 1, open fully
+ * NOTE: number of points, lines, boundaries, centroids, faces, kernels is still available */
+ Vect_close(&Map);
Vect_set_open_level(1); /* no topology */
if (Vect_open_old2(&Map, input_opt, "", field_opt) < 1)
G_fatal_error(_("Unable to open vector map <%s>"), Vect_get_full_name(&Map));
- level_one_info(&Map);
+ /* level one info not needed for history, title, columns */
+ if (!hist_flag && !title_flag && !col_flag)
+ level_one_info(&Map);
if (hist_flag) {
Modified: grass/trunk/vector/v.info/parse.c
--- grass/trunk/vector/v.info/parse.c 2010-05-19 01:47:35 UTC (rev 42312)
+++ grass/trunk/vector/v.info/parse.c 2010-05-19 07:24:08 UTC (rev 42313)
@@ -5,10 +5,10 @@
void parse_args(int argc, char** argv,
char** input, char** field,
- int* history, int* columns, int* region, int* topo, int* title, int* level1)
+ int* history, int* columns, int* region, int* topo, int* title)
struct Option *input_opt, *field_opt;
- struct Flag *hist_flag, *col_flag, *region_flag, *topo_flag, *title_flag, *level1_flag;
+ struct Flag *hist_flag, *col_flag, *region_flag, *topo_flag, *title_flag;
input_opt = G_define_standard_option(G_OPT_V_MAP);
@@ -40,10 +40,6 @@
topo_flag->description = _("Print topology information only");
topo_flag->guisection = _("Print");
- level1_flag = G_define_flag();
- level1_flag->key = 'l';
- level1_flag->description = _("Open vector map without topology (level 1)");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -55,5 +51,4 @@
*region = region_flag-> answer ? 1 : 0;
*title = title_flag-> answer ? 1 : 0;
*topo = topo_flag-> answer ? 1 : 0;
- *level1 = level1_flag-> answer ? 1 : 0;
