[GRASS-SVN] r42314 - grass/branches/develbranch_6/vector/v.info
svn_grass at osgeo.org
Wed May 19 03:39:36 EDT 2010
Author: mmetz
Date: 2010-05-19 03:39:35 -0400 (Wed, 19 May 2010)
New Revision: 42314
grass/branches/develbranch_6/vector/v.info/main.c
remove level 1 flag, simplify automated level handling(backport from trunk)
Modified: grass/branches/develbranch_6/vector/v.info/main.c
--- grass/branches/develbranch_6/vector/v.info/main.c 2010-05-19 07:24:08 UTC (rev 42313)
+++ grass/branches/develbranch_6/vector/v.info/main.c 2010-05-19 07:39:35 UTC (rev 42314)
@@ -43,12 +43,11 @@
struct GModule *module;
struct Option *in_opt, *fieldopt;
- struct Flag *histf, *columns, *gflag, *tflag, *mflag, *lflag;
+ struct Flag *histf, *columns, *gflag, *tflag, *mflag;
struct Map_info Map;
BOUND_BOX box;
char *mapset, line[200], buf[1001];
int i;
- int level1_flag;
int with_z;
struct field_info *fi;
dbDriver *driver = NULL;
@@ -86,10 +85,6 @@
gflag->description = _("Print map region only");
gflag->guisection = _("Print");
- lflag = G_define_flag();
- lflag->key = 'l';
- lflag->description = _("Open Vector without topology (level 1)");
mflag = G_define_flag();
mflag->key = 'm';
mflag->description = _("Print map title only");
@@ -108,24 +103,16 @@
G_fatal_error(_("Vector map <%s> not found"), in_opt->answer);
- level1_flag = lflag->answer;
- if (!level1_flag) {
- /* try to open head-only on level 2 */
- if (Vect_open_old_head(&Map, in_opt->answer, "") < 2) {
- G_warning(_("Unable to open vector map <%s> on level 2, using level 1"),
- Vect_get_full_name(&Map));
- Vect_close(&Map);
- level1_flag = 1;
- /* force level 1, open fully
- * NOTE: number of points, lines, boundaries, centroids, faces, kernels is still available */
- if (level1_flag) {
+ /* try to open head-only on level 2 */
+ if (Vect_open_old_head(&Map, in_opt->answer, "") < 2) {
+ /* force level 1, open fully
+ * NOTE: number of points, lines, boundaries, centroids, faces, kernels is still available */
+ Vect_close(&Map);
Vect_set_open_level(1); /* no topology */
if (Vect_open_old(&Map, in_opt->answer, "") < 1)
G_fatal_error(_("Unable to open vector map <%s>"), Vect_get_full_name(&Map));
- level_one_info(&Map);
+ if (!histf->answer && !mflag->answer && ((gflag->answer || tflag->answer) || !columns->answer))
+ level_one_info(&Map);
with_z = Vect_is_3d(&Map);
