[GRASS-SVN] r44252 -
grass/branches/releasebranch_6_4/imagery/i.atcorr
svn_grass at osgeo.org
Mon Nov 8 04:28:04 EST 2010
Author: martinl
Date: 2010-11-08 01:28:04 -0800 (Mon, 08 Nov 2010)
New Revision: 44252
grass/branches/releasebranch_6_4/imagery/i.atcorr/6s.cpp
grass/branches/releasebranch_6_4/imagery/i.atcorr/main.cpp
i.atcorr: be less verbose, fix when elevation is not given
(merge r44250 from devbr6)
Modified: grass/branches/releasebranch_6_4/imagery/i.atcorr/6s.cpp
--- grass/branches/releasebranch_6_4/imagery/i.atcorr/6s.cpp 2010-11-08 09:27:08 UTC (rev 44251)
+++ grass/branches/releasebranch_6_4/imagery/i.atcorr/6s.cpp 2010-11-08 09:28:04 UTC (rev 44252)
@@ -158,6 +158,9 @@
static const string head(" 6s version 4.2b ");
+ if (G_verbose() <= G_verbose_std())
+ return;
cout << endl << endl << endl;
Output::Begin(); Output::Repeat(30,'*'); Output::Print(head); Output::Repeat(30,'*'); Output::End();
Modified: grass/branches/releasebranch_6_4/imagery/i.atcorr/main.cpp
--- grass/branches/releasebranch_6_4/imagery/i.atcorr/main.cpp 2010-11-08 09:27:08 UTC (rev 44251)
+++ grass/branches/releasebranch_6_4/imagery/i.atcorr/main.cpp 2010-11-08 09:28:04 UTC (rev 44252)
@@ -296,7 +296,6 @@
if(ialt_fd >= 0) alt = (FCELL*)G_allocate_raster_buf(FCELL_TYPE);
if(ivis_fd >= 0) vis = (FCELL*)G_allocate_raster_buf(FCELL_TYPE);
- G_verbose_message(_("Percent complete..."));
nrows = G_window_rows();
ncols = G_window_cols();
@@ -331,7 +330,8 @@
G_set_f_null_value(&buf[col], 1);
continue;
- alt[col] /= 1000.0f; /* converting to km from input which should be in meter */
+ if (ialt_fd >= 0)
+ alt[col] /= 1000.0f; /* converting to km from input which should be in meter */
/* check if both maps are active and if whether any value has changed */
if((ialt_fd >= 0) && (ivis_fd >= 0) && ((prev_vis != vis[col]) || (prev_alt != alt[col])))
@@ -407,7 +407,8 @@
if(oflt) G_put_raster_row(ofd, buf, FCELL_TYPE);
else write_fp_to_cell(ofd, buf);
+ G_percent(1, 1, 1);
/* free allocated memory */
G_free(buf);
if(ialt_fd >= 0) G_free(alt);
