[GRASS-SVN] r44253 - in grass/branches/develbranch_6/gui/wxpython:
. gui_modules
svn_grass at osgeo.org
Mon Nov 8 15:36:14 EST 2010
Author: martinl
Date: 2010-11-08 12:36:14 -0800 (Mon, 08 Nov 2010)
New Revision: 44253
grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py
grass/branches/develbranch_6/gui/wxpython/wxgui.py
wxGUI: fix running scripts
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py 2010-11-08 09:28:04 UTC (rev 44252)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py 2010-11-08 20:36:14 UTC (rev 44253)
@@ -528,14 +528,11 @@
else:
# Send any other command to the shell. Send output to
# console output window
- if grass.find_program(command[0]):
- self.cmdThread.RunCmd(GrassCmd,
- onDone,
- command,
- self.cmd_stdout, self.cmd_stderr)
- self.cmd_output_timer.Start(50)
- else:
- self.WriteError(_("Command '%s' not found") % command[0])
+ self.cmdThread.RunCmd(GrassCmd,
+ onDone,
+ command,
+ self.cmd_stdout, self.cmd_stderr)
+ self.cmd_output_timer.Start(50)
return None
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py 2010-11-08 09:28:04 UTC (rev 44252)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py 2010-11-08 20:36:14 UTC (rev 44253)
@@ -791,6 +791,11 @@
# Autocompletion for map/data file name entry after '=', ',', or manually
pos = self.GetCurrentPos()
entry = self.GetTextLeft()
+ if 'r.mapcalc' in entry:
+ self.InsertText(pos, '=')
+ self.CharRight()
+ return
if event.GetKeyCode() != 44:
self.promptType = None
@@ -911,6 +916,7 @@
if len(items) == 1:
cmd = items[0].strip()
if cmd in globalvar.grassCmd['all'] and \
+ cmd != 'r.mapcalc' and \
(not self.cmdDesc or cmd != self.cmdDesc.get_name()):
try:
self.cmdDesc = menuform.GUI().ParseInterface(cmd = [cmd])
Modified: grass/branches/develbranch_6/gui/wxpython/wxgui.py
--- grass/branches/develbranch_6/gui/wxpython/wxgui.py 2010-11-08 09:28:04 UTC (rev 44252)
+++ grass/branches/develbranch_6/gui/wxpython/wxgui.py 2010-11-08 20:36:14 UTC (rev 44253)
@@ -432,8 +432,9 @@
def OnRunScript(self, event):
"""!Run script"""
# open dialog and choose script file
- dlg = wx.FileDialog(parent = self, message = _("Choose script file"),
- defaultDir = os.getcwd(), wildcard = _("Bash script (*.sh)|*.sh|Python script (*.py)|*.py"))
+ dlg = wx.FileDialog(parent = self, message = _("Choose script file to run"),
+ defaultDir = os.getcwd(),
+ wildcard = _("Bash script (*.sh)|*.sh|Python script (*.py)|*.py"))
filename = None
if dlg.ShowModal() == wx.ID_OK:
@@ -443,13 +444,13 @@
return False
if not os.path.exists(filename):
- wx.MessageBox(parent = self,
- message = _("Script file '%s' doesn't exist. Operation cancelled.") % filename,
- caption = _("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+ gcmd.GError(parent = self,
+ message = _("Script file '%s' doesn't exist. "
+ "Operation cancelled.") % filename)
return
self.goutput.WriteCmdLog(_("Launching script '%s'...") % filename)
- self.goutput.RunCmd(filename, switchPage = True)
+ self.goutput.RunCmd([filename], switchPage = True)
def OnChangeLocation(self, event):
"""Change current location"""
