[GRASS-SVN] r44439 - grass/trunk/vector/v.in.ogr
Fri Nov 26 13:54:10 EST 2010
Author: martinl
Date: 2010-11-26 10:54:10 -0800 (Fri, 26 Nov 2010)
New Revision: 44439
   grass/trunk/vector/v.in.ogr/main.c
v.in.ogr: use suppress_required flags
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c	2010-11-26 18:38:08 UTC (rev 44438)
+++ grass/trunk/vector/v.in.ogr/main.c	2010-11-26 18:54:10 UTC (rev 44439)
@@ -104,22 +104,19 @@
     module = G_define_module();
     G_add_keyword(_("vector"));
     G_add_keyword(_("import"));
-    module->description = _("Converts vector layers into a GRASS vector map using OGR.");
+    module->description = _("Converts vector daya into a GRASS vector map using OGR library.");
     dsn_opt = G_define_option();
     dsn_opt->key = "dsn";
     dsn_opt->type = TYPE_STRING;
-    dsn_opt->required = NO;
+    dsn_opt->required =YES;
     dsn_opt->label = _("OGR datasource name");
     dsn_opt->description = _("Examples:\n"
 			     "\t\tESRI Shapefile: directory containing shapefiles\n"
 			     "\t\tMapInfo File: directory containing mapinfo files");
-    dsn_opt->guisection = _("Required");
     out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
-    out_opt->required = NO;
-    out_opt->guisection = _("Required");
     layer_opt = G_define_option();
     layer_opt->key = "layer";
     layer_opt->type = TYPE_STRING;
@@ -182,7 +179,8 @@
     outloc_opt->type = TYPE_STRING;
     outloc_opt->required = NO;
     outloc_opt->description = _("Name for new location to create");
+    outloc_opt->key_desc = "name";
     cnames_opt = G_define_option();
     cnames_opt->key = "cnames";
     cnames_opt->type = TYPE_STRING;
@@ -197,11 +195,13 @@
     list_flag->key = 'l';
     list_flag->description =
 	_("List available layers in data source and exit");
+    list_flag->suppress_required = TRUE;
     formats_flag = G_define_flag();
     formats_flag->key = 'f';
     formats_flag->description = _("List supported formats and exit");
+    formats_flag->suppress_required = TRUE;
     /* if using -c, you lose topological information ! */
     no_clean_flag = G_define_flag();
     no_clean_flag->key = 'c';
@@ -325,11 +325,6 @@
 	exit(EXIT_SUCCESS);
-    /* check if output name was given */
-    if (out_opt->answer == NULL) {
-	G_fatal_error(_("Required parameter <%s> not set"), out_opt->key);
     if (!outloc_opt->answer) {	/* Check if the map exists */
 	if (G_find_vector2(out_opt->answer, G_mapset())) {
 	    if (overwrite)
