[GRASS-SVN] r44440 - in grass-addons/vector: . v.mkhexgrid
svn_grass at osgeo.org
Fri Nov 26 17:20:35 EST 2010
Author: tsw
Date: 2010-11-26 14:20:35 -0800 (Fri, 26 Nov 2010)
New Revision: 44440
Added:
grass-addons/vector/v.mkhexgrid/
grass-addons/vector/v.mkhexgrid/Makefile
grass-addons/vector/v.mkhexgrid/description.html
grass-addons/vector/v.mkhexgrid/v.mkhexgrid
New script for making hexagonal grids uploaded
Added: grass-addons/vector/v.mkhexgrid/Makefile
--- grass-addons/vector/v.mkhexgrid/Makefile (rev 0)
+++ grass-addons/vector/v.mkhexgrid/Makefile 2010-11-26 22:20:35 UTC (rev 44440)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = v.mkhexgrid
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/vector/v.mkhexgrid/description.html
--- grass-addons/vector/v.mkhexgrid/description.html (rev 0)
+++ grass-addons/vector/v.mkhexgrid/description.html 2010-11-26 22:20:35 UTC (rev 44440)
@@ -0,0 +1,19 @@
+<H2>DESCRIPTION</H2>
+<EM>v.mkhexgrid</EM> is a python script that creates a hexagonal grid for the selected region.
+<H2>NOTES</H2>
+This script functions by creating a number of GRASS ASCII files and them importing and cleaning them.
+<h2>SEE ALSO</h2>
+<em>
+ <a HREF="v.mkgrid.html">v.mkgrid</a>
+</em>
+<H2>AUTHOR</H2>
+Trevor Wiens
+<H2>REFERENCES</H2>
+<p><i>Last changed: $Date: 2010-11-24 $</i>
Added: grass-addons/vector/v.mkhexgrid/v.mkhexgrid
--- grass-addons/vector/v.mkhexgrid/v.mkhexgrid (rev 0)
+++ grass-addons/vector/v.mkhexgrid/v.mkhexgrid 2010-11-26 22:20:35 UTC (rev 44440)
@@ -0,0 +1,291 @@
+#!/usr/bin/python
+# MODULE: v.mkhexgrid for GRASS 6.4 (2010-11-23)
+# AUTHOR(S): Trevor Wiens
+# PURPOSE: Makes a hexagonal grid
+# REQUIREMENTS: GRASS 6.4 and above
+# COPYRIGHT: (C) Trevor Wiens, 2010 GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+# EXAMPLE:
+# v.mkhexgrid output=test regionname=default at PERMANENT sidelength=1000
+#%Module
+#% description: creates a hexagonal grid
+#% keywords: vector
+#% keywords: grid
+#% keywords: hexagon
+#% keywords: attribute table
+#%End
+#%option
+#% key: output
+#% type: string
+#% gisprompt: new,vector,vector
+#% label: Output Vector Name
+#% description: Name of hexagon grid file to create
+#% required : yes
+#%end
+#%option
+#% key: regionname
+#% type: string
+#% gisprompt: old,windows,region
+#% label: Named region to set size of output grid
+#% description: Named region for geographic extent of region to survey
+#% required: yes
+#%end
+#%option
+#% key: sidelength
+#% type: double
+#% label: Side length
+#% description: Size of side length in map units
+#% required: yes
+#%end
+import sys
+import os
+import subprocess
+import time
+import csv
+import math
+from grass.script import core as grass
+from grass.script import vector as gvect
+from grass.script import db as gdb
+# WriteHexGridVectors - Using basic trig and the fact that hexagons are constructed from 6 equalateral triangles
+# hexagons are created
+def WriteHexGridVectors(vf, af, side_len, xstart, ystart, xlimit, ylimit):
+ # basic trig
+ angle_a = math.radians(30)
+ hyp = side_len
+ side_b = hyp * math.cos(angle_a)
+ side_a = hyp * math.sin(angle_a)
+ # adjust starting line so that entire grid shape is convex
+ x = xstart + side_len + side_a
+ y = ystart + side_b
+ row = 1
+ col = 1
+ cat = 1
+ while y + (2*side_b) < ylimit:
+ while x + (2*side_len) < xlimit:
+ name = 'x%f_y%f' % (x,y)
+ outstring = CreateHexagon((x, y), side_len, cat)
+ vf.write(outstring)
+ outstring = '%d,%d,%d,"%d_%d"\n' % (cat, row, col, row, col)
+ af.write(outstring)
+ cat = cat + 1
+ x = x + (2*side_len) + (2*side_a)
+ col = col + 1
+ y = y + side_b
+ row = row + 1
+ if row % 2 <> 0:
+ else:
+ x = xstart
+ col = 1
+# CreateHexagonGrid - creates hexagons based on six equalateral triangles
+def CreateHexagon(origin, side_len, cat):
+ # Get the x and y from the tuple
+ orgx = origin[0]
+ orgy = origin[1]
+ # basic trig
+ hyp = side_len
+ cx = orgx + (hyp / 2.0)
+ cy = orgy + side_b
+ # create coordinate string
+ outstring = """B 2
+%f %f
+%f %f
+B 2
+%f %f
+%f %f
+B 2
+%f %f
+%f %f
+B 2
+%f %f
+%f %f
+B 2
+%f %f
+%f %f
+B 2
+%f %f
+%f %f
+C 1 1
+%f %f
+1 %d\n""" % (
+ orgx, orgy,
+ orgx + hyp, orgy,
+ orgx + hyp, orgy,
+ orgx + hyp + side_a, orgy + side_b,
+ orgx + hyp, orgy + (2 * side_b),
+ orgx, orgy + (2 * side_b),
+ orgx - side_a, orgy + side_b,
+ orgx, orgy, cx, cy, cat)
+ return(outstring)
+# WriteGrassHeader - writes GRASS header to temporary text file
+def WriteGrassHeader(f,outfile,xstart,ystart,xmax,ymax):
+ today = time.strftime("%Y.%m.%d %H:%M:%S",time.localtime())
+ outtext = """ORGANIZATION: n/a
+DIGIT DATE: %s
+DIGIT NAME: v.mkhexgrid
+MAP NAME: %s
+MAP DATE: %s
+MAP SCALE:
+OTHER INFO: Hexagon Grid
+ZONE: 0
+WEST EDGE: %s
+EAST EDGE: %s
+SOUTH EDGE: %s
+NORTH EDGE: %s
+MAP THRESH: 0.000000
+VERTI:\n""" % (today,outfile,today,xstart,xmax,ystart,ymax)
+ f.write(outtext)
+ return()
+def main():
+ errpipe = subprocess.PIPE
+ outpipe = subprocess.PIPE
+ grass.message('Creating GRASS ascii file with hexagons')
+ # assign name to temporary text file
+ tempname= 'tempgrid%d' % os.getpid()
+ vectorfile = tempname + '.asc'
+ attrfile = tempname + '.csv'
+ attrdesc = tempname + '.csvt'
+ # set region
+ try:
+ r = grass.run_command('g.region', region='%s' % options['regionname'])
+ if r <> 0:
+ raise
+ except:
+ msgtext="An error occured when selecting the specified region. \n"
+ grass.message(msgtext, flag='e')
+ return(-1)
+ current_region = grass.region()
+ xstart = current_region['w']
+ ystart = current_region['s']
+ xmax = current_region['e']
+ ymax = current_region['n']
+ side_len = options['sidelength']
+ #print "filename: %s\nx: %s, y: %s\nxmax: %s, ymax: %s\nside_length: %s" % (outfile, xstart, ystart, xmax, ymax, side_len)
+ vf = open(vectorfile, "w")
+ af = open(attrfile, "w")
+ af.write('"cat","row_num","col_num","row_col"\n')
+ adf = open(attrdesc, "w")
+ adf.write('"Integer","Integer","Integer","String"')
+ adf.close()
+ WriteGrassHeader(vf,vectorfile,xstart,ystart,xmax,ymax)
+ WriteHexGridVectors(vf, af, float(side_len), float(xstart), float(ystart), float(xmax), float(ymax))
+ vf.close()
+ af.close()
+ # now import and clean up the vector
+ grass.message('Importing GRASS ascii file')
+ try:
+ r = grass.run_command('v.in.ascii', input=vectorfile, output=tempname, format='standard', fs=',')
+ if r <> 0:
+ raise
+ except:
+ msgtext="An error occured when importing ascii file. \n"
+ return(-1)
+ grass.message('Cleaning and building topology')
+ try:
+ r = grass.run_command('v.clean', flags='-q', input=tempname, \
+ output=options['output'], type='point,line,boundary,centroid,area', tool='rmdupl')
+ if r <> 0:
+ raise
+ except:
+ msgtext="An error occured when cleaning grid layer. \n"
+ return(-1)
+ grass.message('Importing and linking attributes')
+ # import attributes
+ table_name = options['output'].split('@')[0]
+ schema = gdb.db_connection()['schema']
+ try:
+ # import under temporary name
+ r = grass.run_command('db.in.ogr', dsn=attrfile, output=tempname)
+ except:
+ pass
+ try:
+ # drop connection
+ r = grass.run_command('v.db.connect', flags='d', map=tempname)
+ if r <> 0:
+ raise
+ except:
+ msgtext="An error occured separating attribute table from empty vector. \n"
+ return(-1)
+ try:
+ # rename table
+ sqltext = "ALTER TABLE %s.%s RENAME TO %s;" % (schema, tempname, table_name)
+ r = grass.write_command('db.execute', stdin = sqltext, stdout = outpipe, stderr = errpipe)
+ if r <> 0:
+ raise
+ except:
+ msgtext="An error occured renaming attribute table. \n"
+ grass.message(msgtext + '\n' + sqltext, flag='e')
+ return(-1)
+ try:
+ # link to proper table
+ r = grass.run_command('v.db.connect', flags='o', map=options['output'], table=schema+'.'+table_name)
+ # drop temp vector
+ if r <> 0:
+ raise
+ except:
+ msgtext="An error occured connecting attribute table. \n"
+ return(-1)
+ grass.message('Removing temporary files')
+ try:
+ r = grass.run_command('g.remove', vect=tempname)
+ if r <> 0:
+ raise
+ except:
+ msgtext="An error occured when removing temporary layer. \n"
+ return(-1)
+ os.remove(vectorfile)
+ os.remove(attrfile)
+ os.remove(attrdesc)
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ sys.exit(main())
Property changes on: grass-addons/vector/v.mkhexgrid/v.mkhexgrid
___________________________________________________________________
Added: svn:executable
