[GRASS-SVN] r43870 - in grass/trunk/gui/wxpython: . gui_modules
svn_grass at osgeo.org
Mon Oct 11 14:01:31 EDT 2010
Author: martinl
Date: 2010-10-11 11:01:31 -0700 (Mon, 11 Oct 2010)
New Revision: 43870
grass/trunk/gui/wxpython/gui_modules/goutput.py
grass/trunk/gui/wxpython/gui_modules/menuform.py
grass/trunk/gui/wxpython/wxgui.py
wxGUI: fix re-rendering when r.colors is called
(merge r43869 from devbr6)
Modified: grass/trunk/gui/wxpython/gui_modules/goutput.py
--- grass/trunk/gui/wxpython/gui_modules/goutput.py 2010-10-11 17:58:42 UTC (rev 43869)
+++ grass/trunk/gui/wxpython/gui_modules/goutput.py 2010-10-11 18:01:31 UTC (rev 43870)
@@ -160,7 +160,6 @@
self.panelPrompt = wx.Panel(parent = self, id = wx.ID_ANY)
# initialize variables
- self.Map = None
self.parent = parent # GMFrame | CmdPanel | ?
if notebook:
self._notebook = notebook
@@ -422,13 +421,6 @@
@param switchPage switch to output page
@param onDone function to be called when command is finished
- # map display window available ?
- try:
- curr_disp = self.parent.curr_page.maptree.mapdisplay
- self.Map = curr_disp.GetRender()
- except:
- curr_disp = None
# command given as a string ?
try:
cmdlist = command.strip().split(' ')
@@ -720,62 +712,68 @@
# set focus on prompt
if self.parent.GetName() == "LayerManager":
self.btn_abort.Enable(False)
+ if event.cmd[0] in ('r.colors'):
+ display = self.parent.GetLayerTree().GetMapDisplay()
+ if display:
+ display.GetWindow().UpdateMap(render = True)
else:
# updated command dialog
dialog = self.parent.parent
if hasattr(self.parent.parent, "btn_abort"):
dialog.btn_abort.Enable(False)
if hasattr(self.parent.parent, "btn_cancel"):
dialog.btn_cancel.Enable(True)
if hasattr(self.parent.parent, "btn_clipboard"):
dialog.btn_clipboard.Enable(True)
if hasattr(self.parent.parent, "btn_help"):
dialog.btn_help.Enable(True)
if hasattr(self.parent.parent, "btn_run"):
dialog.btn_run.Enable(True)
- if event.returncode == 0 and \
- not event.aborted and hasattr(dialog, "addbox") and \
- dialog.addbox.IsChecked():
- # add created maps into layer tree
+ if event.returncode == 0 and not event.aborted:
winName = self.parent.parent.parent.GetName()
if winName == 'LayerManager':
- mapTree = self.parent.parent.parent.curr_page.maptree
+ mapTree = self.parent.parent.parent.GetLayerTree()
+ elif winName == 'LayerTree':
else: # GMConsole
- mapTree = self.parent.parent.parent.parent.curr_page.maptree
+ mapTree = self.parent.parent.parent.parent.GetLayerTree()
cmd = dialog.notebookpanel.createCmd(ignoreErrors = True)
- for p in dialog.task.get_options()['params']:
- prompt = p.get('prompt', '')
- if prompt in ('raster', 'vector', '3d-raster') and \
- p.get('age', 'old') == 'new' and \
- p.get('value', None):
- name = utils.GetLayerNameFromCmd(cmd, fullyQualified=True, param = p.get('name', ''))
- if mapTree.GetMap().GetListOfLayers(l_name = name):
- continue
- if prompt == 'raster':
- lcmd = ['d.rast',
- 'map=%s' % name]
- else:
- lcmd = ['d.vect',
- 'map=%s' % name]
- mapTree.AddLayer(ltype = prompt,
- lcmd = lcmd,
- lname = name)
+ if hasattr(dialog, "addbox") and dialog.addbox.IsChecked():
+ # add created maps into layer tree
+ for p in dialog.task.get_options()['params']:
+ prompt = p.get('prompt', '')
+ if prompt in ('raster', 'vector', '3d-raster') and \
+ p.get('age', 'old') == 'new' and \
+ p.get('value', None):
+ name = utils.GetLayerNameFromCmd(cmd, fullyQualified=True, param = p.get('name', ''))
+ if mapTree.GetMap().GetListOfLayers(l_name = name):
+ continue
+ if prompt == 'raster':
+ lcmd = ['d.rast',
+ 'map=%s' % name]
+ else:
+ lcmd = ['d.vect',
+ 'map=%s' % name]
+ mapTree.AddLayer(ltype = prompt,
+ lcmd = lcmd,
+ lname = name)
if hasattr(dialog, "get_dcmd") and \
dialog.get_dcmd is None and \
dialog.closebox.IsChecked():
time.sleep(1)
dialog.Close()
event.Skip()
def OnProcessPendingOutputWindowEvents(self, event):
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2010-10-11 17:58:42 UTC (rev 43869)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2010-10-11 18:01:31 UTC (rev 43870)
@@ -516,7 +516,7 @@
def has_required(self):
"""!Check if command has at least one required paramater"""
for p in self.params:
- if p.get('required', False) == True:
+ if p.get('required', 'no') == 'yes':
return True
return False
@@ -890,12 +890,16 @@
@param returncode command's return code (0 for success)
- if self.parent and self.parent.GetName() != 'LayerTree' or \
+ if self.parent and self.parent.GetName() not in ('LayerTree', 'LayerManager') or \
returncode != 0:
return
if cmd[0] in ('r.colors'):
- display = self.parent.GetMapDisplay()
+ if self.parent.GetName() == 'LayerTree':
+ display = self.parent.GetMapDisplay()
+ else: # Layer Manager
if display:
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2010-10-11 17:58:42 UTC (rev 43869)
+++ grass/trunk/gui/wxpython/wxgui.py 2010-10-11 18:01:31 UTC (rev 43870)
@@ -382,6 +382,10 @@
event.Skip()
+ def GetLayerTree(self):
+ """!Get current layer tree"""
+ return self.curr_page.maptree
def GetLogWindow(self):
"""!Get widget for command output"""
return self.goutput
