[GRASS-SVN] r43871 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Mon Oct 11 14:49:01 EDT 2010
Author: martinl
Date: 2010-10-11 11:49:00 -0700 (Mon, 11 Oct 2010)
New Revision: 43871
grass/branches/develbranch_6/gui/wxpython/gui_modules/colorrules.py
wxGUI: color rules dialog - re-render display on apply
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/colorrules.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/colorrules.py 2010-10-11 18:01:31 UTC (rev 43870)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/colorrules.py 2010-10-11 18:49:00 UTC (rev 43871)
@@ -1,14 +1,14 @@
@package colorrules.py
- at brief Dialog for interactive management of raster color tables and vector
-rgb_column
+ at brief Dialog for interactive management of raster color tables and
+vector rgb_column
Classes:
- ColorTable
- BuferedWindow
-(C) 2008 by the GRASS Development Team
+(C) 2008, 2010 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
@@ -36,24 +36,21 @@
from preferences import globalSettings as UserSettings
class ColorTable(wx.Frame):
- def __init__(self, parent, id=wx.ID_ANY, title='',
- pos=wx.DefaultPosition, size=(-1, -1),
+ def __init__(self, parent, cmd, id=wx.ID_ANY, title = _("Set color table"),
style=wx.DEFAULT_FRAME_STYLE | wx.RESIZE_BORDER,
**kwargs):
- wx.Frame.__init__(self, parent, id, title, pos, size, style)
- Dialog for interactively entering rules for map management
+ """!Dialog for interactively entering rules for map management
commands
@param cmd command (given as list)
self.parent = parent # GMFrame
- self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
+ self.cmd = cmd
- # grass command
- self.cmd = kwargs['cmd']
+ wx.Frame.__init__(self, parent, id, title, style = style, **kwargs)
+ self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
# input map to change
self.inmap = ''
@@ -98,14 +95,7 @@
self.SetTitle(_('Create new color table for vector map'))
self.elem = 'vector'
crlabel = _('Enter vector attribute values or ranges (n or n1 to n2)')
- # Set the size & cursor
- self.SetClientSize(size)
- ### self.panel = wx.Panel(parent=self, id=wx.ID_ANY)
# top controls
if self.cmd == 'r.colors':
maplabel = _('Select raster map:')
@@ -195,7 +185,8 @@
# layout
self.__doLayout()
+ self.SetMinSize(self.GetSize())
self.CentreOnScreen()
self.Show()
@@ -220,7 +211,6 @@
# body & preview
bodySizer = wx.GridBagSizer(hgap=5, vgap=5)
row = 0
bodySizer.Add(item=self.cr_label, pos=(row, 0), span=(1, 3),
flag=wx.ALL, border=5)
@@ -247,6 +237,7 @@
bodySizer.Add(item=self.preview, pos=(row, 2),
flag=wx.EXPAND | wx.LEFT | wx.RIGHT, border=10)
+ bodySizer.AddGrowableRow(row)
bodySizer.AddGrowableCol(2)
row += 1
@@ -270,7 +261,7 @@
sizer.Add(item=bodySizer, proportion=1,
flag=wx.ALL | wx.EXPAND, border=5)
sizer.Add(item=wx.StaticLine(parent=self, id=wx.ID_ANY,
style=wx.LI_HORIZONTAL),
proportion=0,
@@ -330,29 +321,21 @@
self.cr_panel.SetupScrolling()
def InitDisplay(self):
+ """!Initialize preview display, set dimensions and region
- Initialize preview display, set dimensions and region
- #self.width, self.height = self.GetClientSize()
self.width = self.Map.width = 400
self.height = self.Map.height = 300
self.Map.geom = self.width, self.height
def OnErase(self, event):
+ """!Erase the histogram display
- Erase the histogram display
self.PreviewWindow.Draw(self.HistWindow.pdc, pdctype='clear')
def OnCloseWindow(self, event):
- Window closed
+ """!Window closed
Also remove associated rendered images
- #try:
- # self.propwin.Close(True)
- #except:
- # pass
self.Map.Clean()
self.Destroy()
@@ -503,7 +486,10 @@
def OnApply(self, event):
self.CreateColorTable()
+ display = self.parent.GetLayerTree().GetMapDisplay()
+ if display:
+ display.GetWindow().UpdateMap(render = True)
def OnOK(self, event):
self.OnApply(event)
self.Destroy()
