[GRASS-SVN] r43925 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Fri Oct 15 05:49:51 EDT 2010
Author: martinl
Date: 2010-10-15 02:49:51 -0700 (Fri, 15 Oct 2010)
New Revision: 43925
grass/branches/develbranch_6/gui/wxpython/gui_modules/location_wizard.py
fix #1167 (wx location wizard: proj4 terms fall off edge of window)
(thanks to Anna Kratochvilova)
(merge r43924 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/location_wizard.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/location_wizard.py 2010-10-15 09:47:19 UTC (rev 43924)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/location_wizard.py 2010-10-15 09:49:51 UTC (rev 43925)
@@ -91,10 +91,9 @@
size=size)
class TitledPage(BaseClass, wiz.WizardPageSimple):
+ """!Class to make wizard pages. Generic methods to make labels,
+ text entries, and buttons.
- Class to make wizard pages. Generic methods to make
- labels, text entries, and buttons.
def __init__(self, parent, title):
self.page = wiz.WizardPageSimple.__init__(self, parent)
@@ -109,19 +108,17 @@
def DoLayout(self):
"""!Do page layout"""
self.pagesizer.Add(item=self.title, proportion=0,
- flag=wx.ALIGN_CENTRE | wx.ALL,
- border=5)
+ flag=wx.ALIGN_CENTRE | wx.ALL,
+ border=5)
self.pagesizer.Add(item=wx.StaticLine(self, -1), proportion=0,
- flag=wx.EXPAND | wx.ALL,
- border=0)
- self.pagesizer.Add(item=self.sizer)
+ flag=wx.EXPAND | wx.ALL,
+ border=0)
+ self.pagesizer.Add(item=self.sizer, proportion = 1,
+ flag = wx.EXPAND)
self.SetAutoLayout(True)
self.SetSizer(self.pagesizer)
- # tmpsizer.Fit(self)
self.Layout()
class DatabasePage(TitledPage):
@@ -168,22 +165,14 @@
wx.ALIGN_CENTER_VERTICAL |
wx.ALL, border=5,
pos=(2, 2))
- # self.sizer.Add(item=self.MakeLabel(_("(projection/coordinate system)")),
- # flag=wx.ALIGN_LEFT |
- # wx.ALIGN_CENTER_VERTICAL |
- # wx.ALL, border=5,
- # pos=(2, 4))
# bindings
self.Bind(wx.EVT_BUTTON, self.OnBrowse, self.bbrowse)
self.Bind(wiz.EVT_WIZARD_PAGE_CHANGING, self.OnPageChanging)
self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
self.tgisdbase.Bind(wx.EVT_TEXT, self.OnChangeName)
self.tlocation.Bind(wx.EVT_TEXT, self.OnChangeName)
- # do page layout
- # self.DoLayout()
def OnChangeName(self, event):
"""!Name for new location was changed"""
nextButton = wx.FindWindowById(wx.ID_FORWARD)
@@ -650,15 +639,12 @@
if len(data) > 0:
return data[0]
else:
-# self.Populate(self.sourceData)
return []
class ProjParamsPage(TitledPage):
+ """!Wizard page for selecting method of setting coordinate system
+ parameters (select coordinate system option)
- Wizard page for selecting method of setting coordinate system parameters
- (select coordinate system option)
def __init__(self, wizard, parent):
TitledPage.__init__(self, wizard, _("Choose projection parameters"))
global coordsys
@@ -671,7 +657,10 @@
self.p4projparams = ''
self.projdesc = ''
+ self.sizer.AddGrowableCol(1)
+ self.sizer.AddGrowableRow(1)
radioSBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
label = " %s " % _("Select datum or ellipsoid (next page)"))
radioSBSizer = wx.StaticBoxSizer(radioSBox)
@@ -759,8 +748,8 @@
self.prjParamSizer = wx.GridBagSizer(vgap=0, hgap=0)
- self.pagesizer.Add(item = paramSBSizer, proportion = 1,
- flag = wx.EXPAND | wx.ALIGN_TOP | wx.ALL, border = 10)
+ self.sizer.Add(item = paramSBSizer, pos=(1, 1),
+ flag = wx.EXPAND)
paramSBSizer.Add(item = self.panel, proportion = 1,
flag = wx.ALIGN_CENTER | wx.EXPAND)
@@ -841,8 +830,7 @@
self.parent.sumpage.SetPrev(self.parent.ellipsepage)
class DatumPage(TitledPage):
- Wizard page for selecting datum (with associated ellipsoid)
+ """!Wizard page for selecting datum (with associated ellipsoid)
and datum transformation parameters (select coordinate system option)
@@ -1581,12 +1569,13 @@
TitledPage.__init__(self, wizard, _("Summary"))
self.parent = parent
+ self.panel = scrolled.ScrolledPanel(parent = self, id = wx.ID_ANY)
# labels
- self.ldatabase = self.MakeLabel("")
- self.llocation = self.MakeLabel("")
- self.lprojection = self.MakeLabel("")
- self.lproj4string = self.MakeLabel("")
- self.lproj4stringLabel = self.MakeLabel("")
+ self.ldatabase = self.MakeLabel()
+ self.llocation = self.MakeLabel()
+ self.lprojection = self.MakeLabel()
+ self.lproj4string = self.MakeLabel(parent = self.panel)
@@ -1596,6 +1585,17 @@
def __DoLayout(self):
+ self.sizer.AddGrowableRow(4)
+ proj4Sizer = wx.BoxSizer(wx.VERTICAL)
+ proj4Sizer.Add(item = self.lproj4string, proportion = 1,
+ flag = wx.EXPAND | wx.ALL, border = 1)
+ self.panel.SetSizer(proj4Sizer)
+ self.panel.SetAutoLayout(True)
+ proj4Sizer.Fit(self.panel)
+ self.panel.Layout()
+ self.panel.SetupScrolling()
self.sizer.Add(item=self.MakeLabel(_("GRASS Database:")),
flag=wx.ALIGN_LEFT | wx.ALL,
border=5, pos=(1, 0))
@@ -1614,17 +1614,14 @@
self.sizer.Add(item=self.lprojection,
border=5, pos=(3, 1))
- self.sizer.Add(item=self.lproj4stringLabel,
+ self.sizer.Add(item=self.MakeLabel(_("PROJ.4 definition:")),
border=5, pos=(4, 0))
- self.sizer.Add(item=self.lproj4string,
- flag=wx.ALIGN_LEFT | wx.ALL,
+ self.sizer.Add(item=self.panel,
+ flag=wx.ALIGN_LEFT | wx.ALL | wx.EXPAND,
border=5, pos=(4, 1))
- self.sizer.Add(item=(10,20),
- flag=wx.ALIGN_CENTER_HORIZONTAL | wx.ALL,
- border=5, pos=(5, 0), span=(1, 2))
- def OnEnterPage(self,event):
+ def OnEnterPage(self, event):
"""!Insert values into text controls for summary of location
creation options
@@ -1635,14 +1632,7 @@
dtrans = self.parent.datumtrans
global coordsys
- if coordsys not in ['proj', 'epsg']:
- self.lproj4stringLabel.Hide()
- self.lproj4string.Hide()
- self.lproj4stringLabel.SetLabel('')
- self.lproj4string.SetLabel('')
- else:
- self.lproj4string.Show()
- self.lproj4stringLabel.SetLabel(_("PROJ.4 definition:"))
+ if coordsys in ('proj', 'epsg'):
if coordsys == 'proj':
ret, projlabel, err = gcmd.RunCommand('g.proj',
flags = 'jf',
@@ -1659,11 +1649,14 @@
location = location,
getErrorMsg = True,
read = True)
+ finishButton = wx.FindWindowById(wx.ID_FORWARD)
if ret == 0:
self.lproj4string.SetLabel(projlabel.replace(' ', os.linesep))
+ finishButton.Enable(True)
else:
gcmd.GError(err, parent = self)
+ finishButton.Enable(False)
projdesc = self.parent.projpage.projdesc
ellipsedesc = self.parent.ellipsepage.ellipsedesc
@@ -1683,7 +1676,8 @@
elif coordsys == 'xy':
label = ('XY coordinate system (not projected).')
elif coordsys == 'custom':
- label = ('%s' % self.parent.custompage.customstring.replace(' ', os.linesep))
+ label = _("custom")
+ self.lproj4string.SetLabel(('%s' % self.parent.custompage.customstring.replace(' ', os.linesep)))
self.lprojection.SetLabel(label)
def OnFinish(self, event):
