[GRASS-SVN] r43926 - grass/trunk/raster/r.in.png
Fri Oct 15 05:59:25 EDT 2010
Author: glynn
Date: 2010-10-15 02:59:25 -0700 (Fri, 15 Oct 2010)
New Revision: 43926
Added:
   grass/trunk/raster/r.in.png/main.c
Removed:
   grass/trunk/raster/r.in.png/r.in.png.c
Use functions rather than direct acess to the info struct
Cleanup
Copied: grass/trunk/raster/r.in.png/main.c (from rev 43923, grass/trunk/raster/r.in.png/r.in.png.c)
--- grass/trunk/raster/r.in.png/main.c	                        (rev 0)
+++ grass/trunk/raster/r.in.png/main.c	2010-10-15 09:59:25 UTC (rev 43926)
@@ -0,0 +1,569 @@
+ * $Id: r.in.png.c,v 1.11 2002/05/08 10:42:01 glynn Exp $
+ * MODULE:       r.in.png
+ * AUTHOR(S):    Michael Shapiro - CERL
+ *               Alex Shevlakov - sixote at yahoo.com
+ *               Glynn Clements
+ * PURPOSE:      Import non-georeferenced Images in PNG format.
+ * COPYRIGHT:    (C) 2000-2002,2010 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *   	    	 License (>=v2). Read the file COPYING that comes with GRASS
+ *   	    	 for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <math.h>
+#include <png.h>
+#include <grass/gis.h>
+#include <grass/raster.h>
+#include <grass/glocale.h>
+typedef struct
+    const char suffix[4];
+    int active;
+    int fd;
+    CELL *buf;
+    FCELL *fbuf;
+    CELL maxval;
+    char name[256];
+} channel;
+#define C_Y 0
+#define C_P 1
+#define C_R 2
+#define C_G 3
+#define C_B 4
+#define C_A 5
+static channel channels[6] = {
+    {".r"},
+    {".g"},
+    {".b"},
+    {".a"}
+static int Header;
+static int Float;
+static char *input, *output, *title;
+static double f_gamma, d_gamma, alpha, t_gamma;
+static int ialpha;
+static png_structp png_ptr;
+static png_infop info_ptr;
+static png_uint_32 width, height;
+static int bit_depth, color_type, interlace_type, compression_type, filter_type;
+static double gamma_correct(double k)
+    return pow(k, 1.0 / t_gamma);
+static int intensity(double k)
+    return (int) (gamma_correct(k) * 255 + 0.5);
+static int get_byte(png_bytep *pp)
+    return *(*pp)++;
+static int get_png_val(png_bytep *pp, int bit_depth)
+    return (bit_depth == 16)
+	? (get_byte(pp) << 8) | get_byte(pp)
+	: get_byte(pp);
+static void init_channel(channel *c)
+    sprintf(c->name, "%s%s", output, c->suffix);
+    if (Float)
+	c->fd = Rast_open_fp_new(c->name);
+	c->fbuf = Rast_allocate_f_buf();
+    else
+	c->fd = Rast_open_c_new(c->name);
+	c->buf = Rast_allocate_c_buf();
+    c->active = 1;
+static void write_row_int(png_bytep p)
+    int x, c;
+    channel *ch;
+    for (x = 0; x < width; x++)
+	for (c = 0; c < 6; c++)
+	    ch = &channels[c];
+	    if (ch->active)
+		ch->buf[x] = (CELL) get_png_val(&p, bit_depth);
+    if (channels[C_A].active && ialpha > 0)
+	    if (c != C_A && ch->active)
+		    if (channels[C_A].buf[x] <= ialpha)
+			Rast_set_c_null_value(&ch->buf[x], 1);
+	if (ch->active)
+	    Rast_put_c_row(ch->fd, ch->buf);
+static void write_row_float(png_bytep p)
+    int x, c;
+    channel *ch;
+	    if (ch->active)
+		ch->fbuf[x] = (FCELL) get_png_val(&p, bit_depth)
+		    / ch->maxval;
+    if (t_gamma != 1.0)
+		    ch->fbuf[x] = gamma_correct(ch->fbuf[x]);
+		    if (channels[C_A].fbuf[x] <= alpha)
+			Rast_set_f_null_value(&ch->fbuf[x], 1);
+	if (ch->active)
+	    Rast_put_f_row(ch->fd, ch->fbuf);
+static void write_colors_int(int c)
+    channel *ch = &channels[c];
+    CELL i0 = 0;
+    CELL i1 = ch->maxval;
+    struct Colors colors;
+    int i;
+    Rast_init_colors(&colors);
+    if (color_type == PNG_COLOR_TYPE_PALETTE)
+	png_colorp palette;
+	int num_palette;
+	png_get_PLTE(png_ptr, info_ptr, &palette, &num_palette);
+	for (i = 0; i < num_palette; i++)
+	    png_colorp col = &palette[i];
+	    Rast_set_c_color((CELL) i, col->red, col->green, col->blue, &colors);
+    else if (c == C_A || t_gamma == 1.0)
+	Rast_add_c_color_rule(&i0,   0,   0,   0,
+			      &i1, 255, 255, 255,
+			      &colors);
+    else
+	for (i = 0; i <= i1; i++)
+	    int v = intensity((double) i / i1);
+	    Rast_set_c_color((CELL) i, v, v, v, &colors);
+    Rast_write_colors(ch->name, G_mapset(), &colors);
+static void write_colors_float(int c)
+    FCELL i0 = 0.0;
+    FCELL i1 = 1.0;
+    Rast_add_f_color_rule(&i0,   0,   0,   0,
+			  &colors);
+static void print_header(void)
+    char gamma_string[80] = "";
+    const char *type_string = "";
+    const char *alpha_string = "";
+    switch (color_type)
+    case PNG_COLOR_TYPE_GRAY:
+	type_string = "gray";
+	alpha_string = "";
+	break;
+    case PNG_COLOR_TYPE_GRAY_ALPHA:
+	alpha_string = "+alpha";
+	break;
+    case PNG_COLOR_TYPE_PALETTE:
+	type_string = "palette";
+	break;
+    case PNG_COLOR_TYPE_RGB:
+	type_string = "truecolor";
+	break;
+    case PNG_COLOR_TYPE_RGB_ALPHA:
+	break;
+    if (png_get_valid(png_ptr, info_ptr, PNG_INFO_tRNS))
+	alpha_string = "+transparency";
+    if (png_get_valid(png_ptr, info_ptr, PNG_INFO_gAMA))
+	sprintf(gamma_string, ", image gamma = %4.2f", f_gamma);
+    fprintf(stderr, "%lu x %lu image, %d bit%s %s%s%s%s\n",
+	    (unsigned long) width, (unsigned long) height,
+	    bit_depth, bit_depth > 1 ? "s" : "",
+	    type_string, alpha_string,
+	    gamma_string,
+	    interlace_type ? ", Adam7 interlaced" : "");
+static void read_png(void)
+    unsigned char sig_buf[8];
+    png_bytep png_buffer;
+    png_bytep *png_rows;
+    int linesize;
+    struct Cell_head cellhd;
+    int y, c;
+    png_color_8p sig_bit;
+    int sbit, interlace;
+    FILE *ifp;
+    /* initialize input stream and PNG library */
+    ifp = fopen(input, "rb");
+    if (!ifp)
+	G_fatal_error("unable to open PNG file %s", input);
+    if (fread(sig_buf, sizeof(sig_buf), 1, ifp) != 1)
+	G_fatal_error("input file empty or too short");
+    if (png_sig_cmp(sig_buf, 0, sizeof(sig_buf)) != 0)
+	G_fatal_error("input file not a PNG file");
+    png_ptr = png_create_read_struct(PNG_LIBPNG_VER_STRING, NULL, NULL, NULL);
+    if (!png_ptr)
+	G_fatal_error("cannot allocate PNG structure");
+    info_ptr = png_create_info_struct(png_ptr);
+    if (!info_ptr)
+	G_fatal_error("cannot allocate PNG structures");
+    if (setjmp(png_jmpbuf(png_ptr)))
+	G_fatal_error("PNG error");
+    png_init_io(png_ptr, ifp);
+    png_set_sig_bytes(png_ptr, sizeof(sig_buf));
+    png_read_info(png_ptr, info_ptr);
+    png_get_IHDR(png_ptr, info_ptr, &width, &height, &bit_depth,
+		 &color_type, &interlace_type, &compression_type, &filter_type);
+    if (Header || G_verbose() == G_verbose_max())
+	print_header();
+    if (Header)
+	fclose(ifp);
+	exit(0);
+    /* read image parameters and set up data conversions */
+    if (png_get_bit_depth(png_ptr, info_ptr) < 8)
+	png_set_packing(png_ptr);
+    sbit = png_get_sBIT(png_ptr, info_ptr, &sig_bit);
+    if (sbit)
+        png_set_shift(png_ptr, sig_bit);
+    if (!png_get_gAMA(png_ptr, info_ptr, &f_gamma))
+	f_gamma = 0.0;
+	png_set_tRNS_to_alpha(png_ptr);
+    if (Float && color_type == PNG_COLOR_TYPE_PALETTE)
+        png_set_palette_to_rgb(png_ptr);
+    png_read_update_info(png_ptr, info_ptr);
+    interlace = (interlace_type != PNG_INTERLACE_NONE);
+    ialpha = (int) (alpha * channels[C_A].maxval);
+    t_gamma = (f_gamma != 0.0 && d_gamma != 0.0)
+	? f_gamma * d_gamma
+	: 1.0;
+    /* allocate input buffer */
+    linesize = png_get_rowbytes(png_ptr, info_ptr);
+    png_buffer = G_malloc(interlace
+			  ? height * linesize
+			  : linesize);
+    if (interlace)
+	png_rows = G_malloc(height * sizeof(png_bytep));
+	for (y = 0; y < height; y++)
+	    png_rows[y] = png_buffer + y * linesize;
+    /* initialize cell header */
+    Rast_get_window(&cellhd);
+    cellhd.rows = height;
+    cellhd.cols = width;
+    cellhd.north = cellhd.rows;
+    cellhd.south = 0.0;
+    cellhd.east = cellhd.cols;
+    cellhd.west = 0.0;
+    cellhd.ns_res = 1;
+    cellhd.ew_res = 1;
+    Rast_set_window(&cellhd);
+    /* initialize channel information */
+	init_channel(&channels[C_Y]);
+	break;
+	init_channel(&channels[C_A]);
+	break;
+	init_channel(&channels[C_P]);
+	break;
+	init_channel(&channels[C_R]);
+	init_channel(&channels[C_G]);
+	init_channel(&channels[C_B]);
+	break;
+	break;
+    if (sbit)
+	channels[C_R].maxval = (1 << sig_bit->red  ) - 1;
+	channels[C_G].maxval = (1 << sig_bit->green) - 1;
+	channels[C_B].maxval = (1 << sig_bit->blue ) - 1;
+	channels[C_Y].maxval = (1 << sig_bit->gray ) - 1;
+	channels[C_A].maxval = (1 << sig_bit->alpha) - 1;
+    else
+	channels[C_R].maxval = (1 << bit_depth) - 1;
+	channels[C_G].maxval = (1 << bit_depth) - 1;
+	channels[C_B].maxval = (1 << bit_depth) - 1;
+	channels[C_Y].maxval = (1 << bit_depth) - 1;
+	channels[C_A].maxval = (1 << bit_depth) - 1;
+    /* read image and write raster layers */
+    if (interlace)
+	png_read_image(png_ptr, png_rows);
+	png_bytep p;
+	if (interlace)
+	    p = png_rows[y];
+	else
+	    png_read_row(png_ptr, png_buffer, NULL);
+	    p = png_buffer;
+	if (Float)
+	    write_row_float(p);
+	else
+	    write_row_int(p);
+    png_read_end(png_ptr, NULL);
+    fclose(ifp);
+    /* close output files */
+	if (!ch->active)
+	    continue;
+	Rast_close(ch->fd);
+	if (Float)
+	    G_free(ch->fbuf);
+	else
+	    G_free(ch->buf);
+    /* write title and color table */
+    G_verbose_message(_("Creating support files for <%s>"), output);
+	if (!ch->active)
+	    continue;
+	if (title && *title)
+	    Rast_put_cell_title(ch->name, title);
+	if (Float)
+	    write_colors_float(c);
+	else
+	    write_colors_int(c);
+    G_free(png_buffer);
+    if (interlace)
+	G_free(png_rows);
+    png_destroy_read_struct(&png_ptr, &info_ptr, NULL);
+int main(int argc, char *argv[])
+    struct Option *inopt, *outopt, *titleopt, *gammaopt, *alphaopt;
+    struct Flag *fflag, *hflag;
+    struct GModule *module;
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    module->description = "Import non-georeferenced PNG format image.";
+    inopt = G_define_standard_option(G_OPT_F_INPUT);
+    outopt = G_define_standard_option(G_OPT_R_OUTPUT);
+    titleopt = G_define_option();
+    titleopt->key	= "title";
+    titleopt->type	= TYPE_STRING;
+    titleopt->required	= NO;
+    titleopt->description = _("Title for new raster file.");
+    gammaopt = G_define_option();
+    gammaopt->key	= "gamma";
+    gammaopt->type	= TYPE_DOUBLE;
+    gammaopt->required	= NO;
+    gammaopt->description = _("Display gamma.");
+    alphaopt = G_define_option();
+    alphaopt->key	= "alpha";
+    alphaopt->type	= TYPE_DOUBLE;
+    alphaopt->required	= NO;
+    alphaopt->description = _("Alpha threshold.");
+    fflag = G_define_flag();
+    fflag->key		= 'f';
+    fflag->description	= _("Create floating-point maps (0.0 - 1.0).");
+    hflag = G_define_flag();
+    hflag->key		= 'h';
+    hflag->description	= _("Output image file header only.");
+    if(G_parser(argc, argv))
+	exit(1);
+    input   = inopt->answer;
+    output  = outopt->answer;
+    title   = titleopt->answer;
+    d_gamma = gammaopt->answer ? atof(gammaopt->answer) : 0.0;
+    alpha   = alphaopt->answer ? atof(alphaopt->answer) : -1.0;
+    Float   = fflag->answer;
+    Header  = hflag->answer;
+    read_png();
+    return 0;
Deleted: grass/trunk/raster/r.in.png/r.in.png.c
--- grass/trunk/raster/r.in.png/r.in.png.c	2010-10-15 09:49:51 UTC (rev 43925)
+++ grass/trunk/raster/r.in.png/r.in.png.c	2010-10-15 09:59:25 UTC (rev 43926)
@@ -1,559 +0,0 @@
- * $Id: r.in.png.c,v 1.11 2002/05/08 10:42:01 glynn Exp $
- * MODULE:       r.in.png
- * AUTHOR(S):    Michael Shapiro - CERL
- *               Alex Shevlakov - sixote at yahoo.com
- *               Glynn Clements
- * PURPOSE:      Import non-georeferenced Images in PNG format.
- * COPYRIGHT:    (C) 2000-2002,2010 by the GRASS Development Team
- *               This program is free software under the GNU General Public
- *   	    	 License (>=v2). Read the file COPYING that comes with GRASS
- *   	    	 for details.
-#include <stdio.h>
-#include <stdlib.h>
-#include <string.h>
-#include <math.h>
-#include <png.h>
-#include <grass/gis.h>
-#include <grass/raster.h>
-#include <grass/glocale.h>
-typedef struct
-    const char suffix[4];
-    int active;
-    int fd;
-    CELL *buf;
-    FCELL *fbuf;
-    CELL maxval;
-    char name[256];
-} channel;
-#define C_Y 0
-#define C_P 1
-#define C_R 2
-#define C_G 3
-#define C_B 4
-#define C_A 5
-static channel channels[6] = {
-    {".r"},
-    {".g"},
-    {".b"},
-    {".a"}
-static int Header;
-static int Float;
-static char *input, *output, *title;
-static double d_gamma, alpha, t_gamma;
-static int ialpha;
-static png_structp png_ptr;
-static png_infop info_ptr;
-static double gamma_correct(double k)
-    return pow(k, 1.0 / t_gamma);
-static int intensity(double k)
-    return (int) (gamma_correct(k) * 255 + 0.5);
-static int get_byte(png_bytep *pp)
-    return *(*pp)++;
-static int get_png_val(png_bytep *pp, int bit_depth)
-    return (bit_depth == 16)
-	? (get_byte(pp) << 8) | get_byte(pp)
-	: get_byte(pp);
-static void init_channel(channel *c)
-    sprintf(c->name, "%s%s", output, c->suffix);
-    if (Float)
-	c->fd = Rast_open_fp_new(c->name);
-	c->fbuf = Rast_allocate_f_buf();
-    else
-	c->fd = Rast_open_c_new(c->name);
-	c->buf = Rast_allocate_c_buf();
-    c->active = 1;
-static void write_row_int(png_bytep p)
-    int x, c;
-    channel *ch;
-    for (x = 0; x < info_ptr->width; x++)
-	for (c = 0; c < 6; c++)
-	    ch = &channels[c];
-	    if (ch->active)
-		ch->buf[x] = (CELL) get_png_val(&p, info_ptr->bit_depth);
-    if (channels[C_A].active && ialpha > 0)
-	    if (c != C_A && ch->active)
-		    if (channels[C_A].buf[x] <= ialpha)
-			Rast_set_c_null_value(&ch->buf[x], 1);
-	if (ch->active)
-	    Rast_put_c_row(ch->fd, ch->buf);
-static void write_row_float(png_bytep p)
-    int x, c;
-    channel *ch;
-	    if (ch->active)
-		ch->fbuf[x] = (FCELL) get_png_val(&p, info_ptr->bit_depth)
-		    / ch->maxval;
-    if (t_gamma != 1.0)
-		    ch->fbuf[x] = gamma_correct(ch->fbuf[x]);
-		    if (channels[C_A].fbuf[x] <= alpha)
-			Rast_set_f_null_value(&ch->fbuf[x], 1);
-	if (ch->active)
-	    Rast_put_f_row(ch->fd, ch->fbuf);
-static void write_colors_int(int c)
-    channel *ch = &channels[c];
-    CELL i0 = 0;
-    CELL i1 = ch->maxval;
-    struct Colors colors;
-    int i;
-    Rast_init_colors(&colors);
-    if (info_ptr->color_type == PNG_COLOR_TYPE_PALETTE)
-	for (i = 0; i < info_ptr->num_palette; i++)
-	    png_colorp col = &info_ptr->palette[i];
-	    Rast_set_c_color((CELL) i, col->red, col->green, col->blue, &colors);
-    else if (c == C_A || t_gamma == 1.0)
-	Rast_add_c_color_rule(&i0,   0,   0,   0,
-			      &i1, 255, 255, 255,
-			      &colors);
-    else
-	for (i = 0; i <= i1; i++)
-	    int v = intensity((double) i / i1);
-	    Rast_set_c_color((CELL) i, v, v, v, &colors);
-    Rast_write_colors(ch->name, G_mapset(), &colors);
-static void write_colors_float(int c)
-    FCELL i0 = 0.0;
-    FCELL i1 = 1.0;
-    Rast_add_f_color_rule(&i0,   0,   0,   0,
-			  &colors);
-static void print_header(void)
-    char gamma_string[80] = "";
-    const char *type_string = "";
-    const char *alpha_string = "";
-    switch (info_ptr->color_type)
-    case PNG_COLOR_TYPE_GRAY:
-	type_string = "gray";
-	alpha_string = "";
-	break;
-    case PNG_COLOR_TYPE_GRAY_ALPHA:
-	alpha_string = "+alpha";
-	break;
-    case PNG_COLOR_TYPE_PALETTE:
-	type_string = "palette";
-	break;
-    case PNG_COLOR_TYPE_RGB:
-	type_string = "truecolor";
-	break;
-    case PNG_COLOR_TYPE_RGB_ALPHA:
-	break;
-    if (info_ptr->valid & PNG_INFO_tRNS)
-	alpha_string = "+transparency";
-    if (info_ptr->valid & PNG_INFO_gAMA)
-	sprintf(gamma_string, ", image gamma = %4.2f", info_ptr->gamma);
-    fprintf(stderr, "%ld x %ld image, %d bit%s %s%s%s%s\n",
-	    info_ptr->width, info_ptr->height,
-	    info_ptr->bit_depth, info_ptr->bit_depth > 1 ? "s" : "",
-	    type_string, alpha_string,
-	    gamma_string,
-	    info_ptr->interlace_type ? ", Adam7 interlaced" : "");
-static void read_png(void)
-    char sig_buf[8];
-    png_bytep png_buffer;
-    png_bytep *png_rows;
-    int linesize;
-    struct Cell_head cellhd;
-    int y, c;
-    png_color_8p sig_bit;
-    int sbit, interlace;
-    double f_gamma;
-    FILE *ifp;
-    /* initialize input stream and PNG library */
-    ifp = fopen(input, "rb");
-    if (!ifp)
-	G_fatal_error("unable to open PNG file %s", input);
-    if (fread(sig_buf, sizeof(sig_buf), 1, ifp) != 1)
-	G_fatal_error("input file empty or too short");
-    if (png_sig_cmp(sig_buf, 0, sizeof(sig_buf)) != 0)
-	G_fatal_error("input file not a PNG file");
-    png_ptr = png_create_read_struct(PNG_LIBPNG_VER_STRING, NULL, NULL, NULL);
-    if (!png_ptr)
-	G_fatal_error("cannot allocate PNG structure");
-    info_ptr = png_create_info_struct(png_ptr);
-    if (!info_ptr)
-	G_fatal_error("cannot allocate PNG structures");
-    if (setjmp(png_jmpbuf(png_ptr)))
-	G_fatal_error("PNG error");
-    png_init_io(png_ptr, ifp);
-    png_set_sig_bytes(png_ptr, sizeof(sig_buf));
-    png_read_info(png_ptr, info_ptr);
-    if (Header || G_verbose() == G_verbose_max())
-	print_header();
-    if (Header)
-	fclose(ifp);
-	exit(0);
-    /* read image parameters and set up data conversions */
-    if (png_get_bit_depth(png_ptr, info_ptr) < 8)
-	png_set_packing(png_ptr);
-    sbit = png_get_sBIT(png_ptr, info_ptr, &sig_bit);
-    if (sbit)
-        png_set_shift(png_ptr, sig_bit);
-    if (!png_get_gAMA(png_ptr, info_ptr, &f_gamma))
-	f_gamma = 0.0;
-    if (png_get_valid(png_ptr, info_ptr, PNG_INFO_tRNS))
-	png_set_tRNS_to_alpha(png_ptr);
-    if (Float && info_ptr->color_type == PNG_COLOR_TYPE_PALETTE)
-        png_set_palette_to_rgb(png_ptr);
-    png_read_update_info(png_ptr, info_ptr);
-    interlace = (info_ptr->interlace_type != PNG_INTERLACE_NONE);
-    ialpha = (int) (alpha * channels[C_A].maxval);
-    t_gamma = (f_gamma != 0.0 && d_gamma != 0.0)
-	? f_gamma * d_gamma
-	: 1.0;
-    /* allocate input buffer */
-    linesize = png_get_rowbytes(png_ptr, info_ptr);
-    png_buffer = G_malloc(interlace
-			  ? info_ptr->height * linesize
-			  : linesize);
-    if (interlace)
-	png_rows = G_malloc(info_ptr->height * sizeof(png_bytep));
-	for (y = 0; y < info_ptr->height; y++)
-	    png_rows[y] = png_buffer + y * linesize;
-    /* initialize cell header */
-    Rast_get_window(&cellhd);
-    cellhd.rows = info_ptr->height;
-    cellhd.cols = info_ptr->width;
-    cellhd.north = cellhd.rows;
-    cellhd.south = 0.0;
-    cellhd.east = cellhd.cols;
-    cellhd.west = 0.0;
-    cellhd.ns_res = 1;
-    cellhd.ew_res = 1;
-    Rast_set_window(&cellhd);
-    /* initialize channel information */
-	init_channel(&channels[C_Y]);
-	break;
-	init_channel(&channels[C_A]);
-	break;
-	init_channel(&channels[C_P]);
-	break;
-	init_channel(&channels[C_R]);
-	init_channel(&channels[C_G]);
-	init_channel(&channels[C_B]);
-	break;
-	break;
-    if (sbit)
-	channels[C_R].maxval = (1 << sig_bit->red  ) - 1;
-	channels[C_G].maxval = (1 << sig_bit->green) - 1;
-	channels[C_B].maxval = (1 << sig_bit->blue ) - 1;
-	channels[C_Y].maxval = (1 << sig_bit->gray ) - 1;
-	channels[C_A].maxval = (1 << sig_bit->alpha) - 1;
-    else
-	channels[C_R].maxval = (1 << info_ptr->bit_depth) - 1;
-	channels[C_G].maxval = (1 << info_ptr->bit_depth) - 1;
-	channels[C_B].maxval = (1 << info_ptr->bit_depth) - 1;
-	channels[C_Y].maxval = (1 << info_ptr->bit_depth) - 1;
-	channels[C_A].maxval = (1 << info_ptr->bit_depth) - 1;
-    /* read image and write raster layers */
-    if (interlace)
-	png_read_image(png_ptr, png_rows);
-	png_bytep p;
-	if (interlace)
-	    p = png_rows[y];
-	else
-	    png_read_row(png_ptr, png_buffer, NULL);
-	    p = png_buffer;
-	if (Float)
-	    write_row_float(p);
-	else
-	    write_row_int(p);
-    png_read_end(png_ptr, NULL);
-    fclose(ifp);
-    /* close output files */
-	if (!ch->active)
-	    continue;
-	Rast_close(ch->fd);
-	if (Float)
-	    G_free(ch->fbuf);
-	else
-	    G_free(ch->buf);
-    /* write title and color table */
-    G_verbose_message(_("Creating support files for <%s>"), output);
-	if (!ch->active)
-	    continue;
-	if (title && *title)
-	    Rast_put_cell_title(ch->name, title);
-	if (Float)
-	    write_colors_float(c);
-	else
-	    write_colors_int(c);
-    G_free(png_buffer);
-    if (interlace)
-	G_free(png_rows);
-    png_destroy_read_struct(&png_ptr, &info_ptr, NULL);
-int main(int argc, char *argv[])
-    struct Option *inopt, *outopt, *titleopt, *gammaopt, *alphaopt;
-    struct Flag *fflag, *hflag;
-    struct GModule *module;
-    G_gisinit(argv[0]);
-    module = G_define_module();
-    module->description = "Import non-georeferenced PNG format image.";
-    inopt = G_define_standard_option(G_OPT_F_INPUT);
-    outopt = G_define_standard_option(G_OPT_R_OUTPUT);
-    titleopt = G_define_option();
-    titleopt->key	= "title";
-    titleopt->type	= TYPE_STRING;
-    titleopt->required	= NO;
-    titleopt->description = _("Title for new raster file.");
-    gammaopt = G_define_option();
-    gammaopt->key	= "gamma";
-    gammaopt->type	= TYPE_DOUBLE;
-    gammaopt->required	= NO;
-    gammaopt->description = _("Display gamma.");
-    alphaopt = G_define_option();
-    alphaopt->key	= "alpha";
-    alphaopt->type	= TYPE_DOUBLE;
-    alphaopt->required	= NO;
-    alphaopt->description = _("Alpha threshold.");
-    fflag = G_define_flag();
-    fflag->key		= 'f';
-    fflag->description	= _("Create floating-point maps (0.0 - 1.0).");
-    hflag = G_define_flag();
-    hflag->key		= 'h';
-    hflag->description	= _("Output image file header only.");
-    if(G_parser(argc, argv))
-	exit(1);
-    input   = inopt->answer;
-    output  = outopt->answer;
-    title   = titleopt->answer;
-    d_gamma = gammaopt->answer ? atof(gammaopt->answer) : 0.0;
-    alpha   = alphaopt->answer ? atof(alphaopt->answer) : -1.0;
-    Float   = fflag->answer;
-    Header  = hflag->answer;
-    read_png();
-    return 0;
