[GRASS-SVN] r44072 - grass/branches/develbranch_6/vector/v.to.rast
Thu Oct 28 13:07:40 EDT 2010
Author: martinl
Date: 2010-10-28 10:07:40 -0700 (Thu, 28 Oct 2010)
New Revision: 44072
   grass/branches/develbranch_6/vector/v.to.rast/main.c
v.to.rast: guisections clean up
Modified: grass/branches/develbranch_6/vector/v.to.rast/main.c
--- grass/branches/develbranch_6/vector/v.to.rast/main.c	2010-10-28 17:04:48 UTC (rev 44071)
+++ grass/branches/develbranch_6/vector/v.to.rast/main.c	2010-10-28 17:07:40 UTC (rev 44072)
@@ -36,16 +36,24 @@
     module = G_define_module();
     module->keywords = _("vector, raster, conversion");
-    module->description = _("Converts a binary GRASS vector map "
-			    "into a GRASS raster map .");
+    module->description = _("Converts (rasterize) a vector map into a raster map.");
     input = G_define_standard_option(G_OPT_V_INPUT);
+    field_opt = G_define_standard_option(G_OPT_V_FIELD);
+    field_opt->guisection = _("Selection");
+    type_opt = G_define_standard_option(G_OPT_V_TYPE);
+    type_opt->options = "point,line,area";
+    type_opt->answer = "point,line,area";
+    type_opt->guisection = _("Selection");
     output = G_define_standard_option(G_OPT_R_OUTPUT);
     use_opt = G_define_option();
     use_opt->key = "use";
     use_opt->type = TYPE_STRING;
-    use_opt->required = NO;
+    use_opt->required = YES;
     use_opt->multiple = NO;
     use_opt->options = "attr,cat,val,z,dir";
     use_opt->answer = "attr";
@@ -55,26 +63,32 @@
 			      "val;use value specified by value option;"
 			      "z;use z coordinate (points or contours only);"
 			      "dir;output as flow direction (lines only)");
-    type_opt = G_define_standard_option(G_OPT_V_TYPE);
-    type_opt->options = "point,line,area";
-    type_opt->answer = "point,line,area";
-    field_opt = G_define_standard_option(G_OPT_V_FIELD);
     /* for GRASS 7, IMHO this should be changed to "attrcolumn" */
     col = G_define_standard_option(G_OPT_COLUMN);
     col->description =
-	_("Name of column for attr parameter (data type must be numeric)");
+	_("Name of column for 'attr' parameter (data type must be numeric)");
     col->guisection = _("Attributes");
+    rgbcol_opt = G_define_standard_option(G_OPT_COLUMN);
+    rgbcol_opt->key = "rgbcolumn";
+    rgbcol_opt->description =
+	_("Name of color definition column (with RRR:GGG:BBB entries)");
+    rgbcol_opt->guisection = _("Attributes");
+    label_opt = G_define_standard_option(G_OPT_COLUMN);
+    label_opt->key = "labelcolumn";
+    label_opt->description =
+	_("Name of column used as raster category labels");
+    label_opt->guisection = _("Attributes");
     val_opt = G_define_option();
     val_opt->key = "value";
     val_opt->type = TYPE_DOUBLE;
     val_opt->required = NO;
     val_opt->multiple = NO;
     val_opt->answer = "1";
-    val_opt->description = _("Raster value");
+    val_opt->description = _("Raster value (for use=val)");
     rows = G_define_option();
     rows->key = "rows";
@@ -84,18 +98,6 @@
     rows->answer = "4096";
     rows->description = _("Number of rows to hold in memory");
-    rgbcol_opt = G_define_standard_option(G_OPT_COLUMN);
-    rgbcol_opt->key = "rgbcolumn";
-    rgbcol_opt->description =
-	_("Name of color definition column (with RRR:GGG:BBB entries)");
-    rgbcol_opt->guisection = _("Attributes");
-    label_opt = G_define_standard_option(G_OPT_COLUMN);
-    label_opt->key = "labelcolumn";
-    label_opt->description =
-	_("Name of column used as raster category labels");
-    label_opt->guisection = _("Attributes");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
