[GRASS-SVN] r44073 -
grass/branches/releasebranch_6_4/vector/v.to.rast
svn_grass at osgeo.org
Thu Oct 28 13:10:00 EDT 2010
Author: martinl
Date: 2010-10-28 10:10:00 -0700 (Thu, 28 Oct 2010)
New Revision: 44073
grass/branches/releasebranch_6_4/vector/v.to.rast/main.c
v.to.rast: guisections clean up
(merge r44072 from devbr6)
Modified: grass/branches/releasebranch_6_4/vector/v.to.rast/main.c
--- grass/branches/releasebranch_6_4/vector/v.to.rast/main.c 2010-10-28 17:07:40 UTC (rev 44072)
+++ grass/branches/releasebranch_6_4/vector/v.to.rast/main.c 2010-10-28 17:10:00 UTC (rev 44073)
@@ -36,16 +36,24 @@
module = G_define_module();
module->keywords = _("vector, raster, conversion");
- module->description = _("Converts a binary GRASS vector map "
- "into a GRASS raster map .");
+ module->description = _("Converts (rasterize) a vector map into a raster map.");
input = G_define_standard_option(G_OPT_V_INPUT);
+ field_opt = G_define_standard_option(G_OPT_V_FIELD);
+ field_opt->guisection = _("Selection");
+ type_opt = G_define_standard_option(G_OPT_V_TYPE);
+ type_opt->options = "point,line,area";
+ type_opt->answer = "point,line,area";
+ type_opt->guisection = _("Selection");
output = G_define_standard_option(G_OPT_R_OUTPUT);
use_opt = G_define_option();
use_opt->key = "use";
use_opt->type = TYPE_STRING;
- use_opt->required = NO;
+ use_opt->required = YES;
use_opt->multiple = NO;
use_opt->options = "attr,cat,val,z,dir";
use_opt->answer = "attr";
@@ -55,26 +63,32 @@
"val;use value specified by value option;"
"z;use z coordinate (points or contours only);"
"dir;output as flow direction (lines only)");
- type_opt = G_define_standard_option(G_OPT_V_TYPE);
- type_opt->options = "point,line,area";
- type_opt->answer = "point,line,area";
- field_opt = G_define_standard_option(G_OPT_V_FIELD);
/* for GRASS 7, IMHO this should be changed to "attrcolumn" */
col = G_define_standard_option(G_OPT_COLUMN);
col->description =
- _("Name of column for attr parameter (data type must be numeric)");
+ _("Name of column for 'attr' parameter (data type must be numeric)");
col->guisection = _("Attributes");
+ rgbcol_opt = G_define_standard_option(G_OPT_COLUMN);
+ rgbcol_opt->key = "rgbcolumn";
+ rgbcol_opt->description =
+ _("Name of color definition column (with RRR:GGG:BBB entries)");
+ rgbcol_opt->guisection = _("Attributes");
+ label_opt = G_define_standard_option(G_OPT_COLUMN);
+ label_opt->key = "labelcolumn";
+ label_opt->description =
+ _("Name of column used as raster category labels");
+ label_opt->guisection = _("Attributes");
val_opt = G_define_option();
val_opt->key = "value";
val_opt->type = TYPE_DOUBLE;
val_opt->required = NO;
val_opt->multiple = NO;
val_opt->answer = "1";
- val_opt->description = _("Raster value");
+ val_opt->description = _("Raster value (for use=val)");
rows = G_define_option();
rows->key = "rows";
@@ -84,18 +98,6 @@
rows->answer = "4096";
rows->description = _("Number of rows to hold in memory");
- rgbcol_opt = G_define_standard_option(G_OPT_COLUMN);
- rgbcol_opt->key = "rgbcolumn";
- rgbcol_opt->description =
- _("Name of color definition column (with RRR:GGG:BBB entries)");
- rgbcol_opt->guisection = _("Attributes");
- label_opt = G_define_standard_option(G_OPT_COLUMN);
- label_opt->key = "labelcolumn";
- label_opt->description =
- _("Name of column used as raster category labels");
- label_opt->guisection = _("Attributes");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
