[GRASS-SVN] r44085 - grass/trunk/imagery/i.rectify
svn_grass at osgeo.org
Fri Oct 29 12:04:47 EDT 2010
Author: mmetz
Date: 2010-10-29 09:04:47 -0700 (Fri, 29 Oct 2010)
New Revision: 44085
grass/trunk/imagery/i.rectify/i.rectify.html
update manual
Modified: grass/trunk/imagery/i.rectify/i.rectify.html
--- grass/trunk/imagery/i.rectify/i.rectify.html 2010-10-29 16:04:17 UTC (rev 44084)
+++ grass/trunk/imagery/i.rectify/i.rectify.html 2010-10-29 16:04:47 UTC (rev 44085)
@@ -108,17 +108,19 @@
<h3>Resampling method</h3>
<p>
-The rectified data is resampled with one of five different methods:
-<em>nearest</em>, <em>bilinear</em>, <em>cubic</em>, <em>bilinear_f</em>
-or <em>cubic_f</em>.
+The rectified data is resampled with one of seven different methods:
+<em>nearest</em>, <em>bilinear</em>, <em>cubic</em>, <em>lanczos</em>,
+<em>bilinear_f</em>, <em>cubic_f</em>, or <em>lanczos_f</em>.
<p>
The <em>method=nearest</em> method, which performs a nearest neighbor assignment,
-is the fastest of the three resampling methods. It is primarily used for
+is the fastest of the resampling methods. It is primarily used for
categorical data such as a land use classification, since it will not change
the values of the data cells. The <em>method=bilinear</em> method determines the new
value of the cell based on a weighted distance average of the 4 surrounding
cells in the input map. The <em>method=cubic</em> method determines the new value of
the cell based on a weighted distance average of the 16 surrounding cells in
+the input map. The <em>method=lanczos</em> method determines the new value of
+the cell based on a weighted distance average of the 25 surrounding cells in
the input map.
<p>
The bilinear, cubic and lanczos interpolation methods are most appropriate for
