[GRASS-SVN] r44086 - grass/trunk/lib/python
svn_grass at osgeo.org
Sat Oct 30 04:52:09 EDT 2010
Author: martinl
Date: 2010-10-30 01:52:09 -0700 (Sat, 30 Oct 2010)
New Revision: 44086
grass/trunk/lib/python/core.py
pythonlib: raise_on_error defined
Modified: grass/trunk/lib/python/core.py
--- grass/trunk/lib/python/core.py 2010-10-29 16:04:47 UTC (rev 44085)
+++ grass/trunk/lib/python/core.py 2010-10-30 08:52:09 UTC (rev 44086)
@@ -55,8 +55,15 @@
PIPE = subprocess.PIPE
STDOUT = subprocess.STDOUT
-fatal_exit = True # abort on fatal()
-debug_level = 0 # DEBUG level
+class ScriptException(Exception):
+ def __init__(self, msg):
+ self.value = msg
+ def __str__(self):
+ return repr(self.value)
+raise_on_error = True # raise exception instead of calling fatal()
+debug_level = 0 # DEBUG level
def call(*args, **kwargs):
return Popen(*args, **kwargs).wait()
@@ -282,45 +289,37 @@
# interface to g.message
def message(msg, flag = None):
- """!Display a message using g.message
+ """!Display a message using `g.message`
@param msg message to be displayed
@param flag flags (given as string)
- @return g.message's exit code
run_command("g.message", flags = flag, message = msg)
def debug(msg, debug = 1):
- """!Display a debugging message using g.message -d
+ """!Display a debugging message using `g.message -d`
@param msg debugging message to be displayed
@param debug debug level (0-5)
run_command("g.message", flags = 'd', message = msg, debug = debug)
def verbose(msg):
- """!Display a verbose message using g.message -v
+ """!Display a verbose message using `g.message -v`
@param msg verbose message to be displayed
message(msg, flag = 'v')
def info(msg):
- """!Display an informational message using g.message -i
+ """!Display an informational message using `g.message -i`
@param msg informational message to be displayed
message(msg, flag = 'i')
def percent(i, n, s):
- """!Display a progress info message using g.message -p
+ """!Display a progress info message using `g.message -p`
@code
message(_("Percent complete..."))
@@ -333,50 +332,44 @@
@param i current item
@param n total number of items
@param s increment size
message("%d %d %d" % (i, n, s), flag = 'p')
def warning(msg):
- """!Display a warning message using g.message -w
+ """!Display a warning message using `g.message -w`
@param msg warning message to be displayed
message(msg, flag = 'w')
def error(msg):
- """!Display an error message using g.message -e
+ """!Display an error message using `g.message -e`
+ Raise exception when on_error is 'raise'.
@param msg error message to be displayed
- message(msg, flag = 'e')
+ if raise_on_error:
+ raise ScriptException(msg)
+ else:
+ message(msg, flag = 'e')
def fatal(msg):
- """!Display an error message using g.message -e, then abort
+ """!Display an error message using `g.message -e`, then abort
error(msg)
+ sys.exit(1)
- global fatal_exit
- if fatal_exit:
- sys.exit(1)
-def set_fatal_exit(exit = True):
- """!Set fatal_exit variable
+def raise_on_error(raise_exp = True):
+ """!Define behaviour on error (error() called)
- @param exit True to abort on fatal() otherwise just error message
- is printed"""
- global fatal_exit
- fatal_exit = exit
+ @param raise_exp True to raise ScriptException instead of calling error()
+ global raise_on_error
+ raise_on_error = raise_exp
# interface to g.parser
def _parse_opts(lines):
