[GRASS-SVN] r43431 - in grass-addons/gui/wxpython: . wx.class
svn_grass at osgeo.org
Wed Sep 8 17:16:34 EDT 2010
Author: rashadkm
Date: 2010-09-08 21:16:34 +0000 (Wed, 08 Sep 2010)
New Revision: 43431
Added:
grass-addons/gui/wxpython/wx.class/
grass-addons/gui/wxpython/wx.class/README.txt
grass-addons/gui/wxpython/wx.class/wx.class.py
created wx.class addon which does not require Xterm
Added: grass-addons/gui/wxpython/wx.class/README.txt
--- grass-addons/gui/wxpython/wx.class/README.txt (rev 0)
+++ grass-addons/gui/wxpython/wx.class/README.txt 2010-09-08 21:16:34 UTC (rev 43431)
@@ -0,0 +1,14 @@
+Start GRASS using North Carolina location [nc_spm_08] and landsat mapset (because wx.class is under development)
+download wx.class.py
+cd path/to/download/dir
+python wx.class.py
+A mapdisplay window appears with landsat map (lsat7_2002_10).It draws histogram of six satellite images
+lsat7_2002_10, lsat7_2002_20, lsat7_2002_30, lsat7_2002_40, lsat7_2002_50, lsat7_2002_60
+Double click left mouse button to select first point and do the same to select next point this will draw a red line using the first and second points
+repeat for selecting next points
+Double click right mouse button to close the region and draw the histogram on the left of mapdisplay.
+If any error message(maybe ZeroDivisionError: float division) is displayed on GRASS terminal redraw the region as explained above.
Property changes on: grass-addons/gui/wxpython/wx.class/README.txt
___________________________________________________________________
Added: svn:executable
Added: grass-addons/gui/wxpython/wx.class/wx.class.py
--- grass-addons/gui/wxpython/wx.class/wx.class.py (rev 0)
+++ grass-addons/gui/wxpython/wx.class/wx.class.py 2010-09-08 21:16:34 UTC (rev 43431)
@@ -0,0 +1,1181 @@
+ at package wx.class.py
+ at brief Interface implementation of i.class module without Xterm.
+Many thanks to Markus Neteler for his help which allowed me to
+know about i.class and its usage.
+Classes:
+- IClass
+- BufferedWindow2
+- IClassApp
+(C) 2006-2010 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Mohammed Rashad K.M <rashadkm [at] gmail [dot] com>
+import os
+import sys
+import glob
+import math
+import tempfile
+import copy
+gbase = os.getenv("GISBASE")
+pypath = os.path.join(gbase,'etc','wxpython','gui_modules')
+sys.path.append(pypath)
+import globalvar
+if not os.getenv("GRASS_WXBUNDLED"):
+ globalvar.CheckForWx()
+import wx
+import wx.aui
+try:
+ import subprocess
+except:
+ CompatPath = os.path.join(globalvar.ETCWXDIR)
+ sys.path.append(CompatPath)
+ from compat import subprocess
+gmpath = os.path.join(globalvar.ETCWXDIR, "icons")
+sys.path.append(gmpath)
+grassPath = os.path.join(globalvar.ETCDIR, "python")
+sys.path.append(grassPath)
+import render
+import toolbars
+from preferences import globalSettings as UserSettings
+from icon import Icons
+from mapdisp import Command
+from mapdisp_window import BufferedWindow
+from mapdisp_window import MapWindow
+from mapdisp import MapFrame
+from debug import Debug
+import images
+import gcmd
+from grass.script import core as grass1
+from grass.lib import grass as grasslib
+import toolbars
+imagepath = images.__path__[0]
+sys.path.append(imagepath)
+#from Numeric import *
+from ctypes import *
+import platform
+if platform.system() == "Linux":
+ grass = CDLL("libgrass_gis.so")
+else:
+ grass = CDLL("libgrass_gis.6.4.0RC6.dll")
+s = subprocess.Popen(['g.version','-r'], stdout=subprocess.PIPE).communicate()[0]
+for line in s.splitlines():
+ if line.startswith('Revision:'):
+ version = '$' + line + '$'
+grass.G__gisinit(version, '')
+class IClass(MapFrame):
+ def __init__(self, parent=None, id=wx.ID_ANY, title=_("Imagery - wx.class"),
+ pos=wx.DefaultPosition, size=wx.DefaultSize,
+ style=wx.DEFAULT_FRAME_STYLE, toolbars=["map"],
+ tree=None, notebook=None, gismgr=None, page=None,
+ Map=None, auimgr=None):
+ self._layerManager = gismgr
+ self.Map = Map
+ self.gismanager = gismgr # GIS Manager object
+ self.Map = Map # instance of render.Map
+ self.tree = tree # GIS Manager layer tree object
+ self.page = page # Notebook page holding the layer tree
+ self.layerbook = notebook # GIS Manager layer tree notebook
+ self.parent = parent
+ # available cursors
+ self.counter = 0
+ self.cursors = {
+ # default: cross
+ # "default" : wx.StockCursor(wx.CURSOR_DEFAULT),
+ "default" : wx.StockCursor(wx.CURSOR_ARROW),
+ "cross" : wx.StockCursor(wx.CURSOR_CROSS),
+ "hand" : wx.StockCursor(wx.CURSOR_HAND),
+ "pencil" : wx.StockCursor(wx.CURSOR_PENCIL),
+ "sizenwse": wx.StockCursor(wx.CURSOR_SIZENWSE)
+ wx.Frame.__init__(self, parent, id, title, pos, size, style)
+ self.SetName("MapWindow")
+ # set the size & system icon
+ self.SetClientSize(size)
+ self.iconsize = (16, 16)
+ self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_map.ico'), wx.BITMAP_TYPE_ICO))
+ # Fancy gui
+ # self._mgr = auimgr
+ self._mgr = wx.aui.AuiManager(self)
+ # Add toolbars
+ self.toolbars = { 'map' : None,
+ 'vdigit' : None,
+ 'georect' : None,
+ 'nviz' : None }
+ for toolb in toolbars:
+ self.AddToolbar(toolb)
+ # Add statusbar
+ self.statusbar = self.CreateStatusBar(number=4, style=0)
+ self.statusbar.SetStatusWidths([-5, -2, -1, -1])
+ self.statusbarWin = dict()
+ self.statusbarWin['toggle'] = wx.Choice(self.statusbar, wx.ID_ANY,
+ choices = globalvar.MAP_DISPLAY_STATUSBAR_MODE)
+ self.statusbarWin['toggle'].SetSelection(UserSettings.Get(group='display',
+ key='statusbarMode',
+ subkey='selection'))
+ self.statusbar.Bind(wx.EVT_CHOICE, self.OnToggleStatus, self.statusbarWin['toggle'])
+ # auto-rendering checkbox
+ self.statusbarWin['render'] = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
+ label=_("Render"))
+ self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleRender, self.statusbarWin['render'])
+ self.statusbarWin['render'].SetValue(UserSettings.Get(group='display',
+ key='autoRendering',
+ subkey='enabled'))
+ self.statusbarWin['render'].SetToolTip(wx.ToolTip (_("Enable/disable auto-rendering")))
+ # show region
+ self.statusbarWin['region'] = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
+ label=_("Show computational extent"))
+ self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleShowRegion, self.statusbarWin['region'])
+ self.statusbarWin['region'].SetValue(False)
+ self.statusbarWin['region'].Hide()
+ self.statusbarWin['region'].SetToolTip(wx.ToolTip (_("Show/hide computational "
+ "region extent (set with g.region). "
+ "Display region drawn as a blue box inside the "
+ "computational region, "
+ "computational region inside a display region "
+ "as a red box).")))
+ # set resolution
+ self.statusbarWin['resolution'] = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
+ label=_("Constrain display resolution to computational settings"))
+ self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleResolution, self.statusbarWin['resolution'])
+ self.statusbarWin['resolution'].SetValue(UserSettings.Get(group='display', key='compResolution', subkey='enabled'))
+ self.statusbarWin['resolution'].Hide()
+ self.statusbarWin['resolution'].SetToolTip(wx.ToolTip (_("Constrain display resolution "
+ "to computational region settings. "
+ "Default value for new map displays can "
+ "be set up in 'User GUI settings' dialog.")))
+ # map scale
+ self.statusbarWin['mapscale'] = wx.ComboBox(parent = self.statusbar, id = wx.ID_ANY,
+ style = wx.TE_PROCESS_ENTER,
+ size=(150, -1))
+ self.statusbarWin['mapscale'].SetItems(['1:1000',
+ '1:5000',
+ '1:10000',
+ '1:25000',
+ '1:50000',
+ '1:100000',
+ '1:1000000'])
+ self.statusbarWin['mapscale'].Hide()
+ self.statusbar.Bind(wx.EVT_TEXT_ENTER, self.OnChangeMapScale, self.statusbarWin['mapscale'])
+ self.statusbar.Bind(wx.EVT_COMBOBOX, self.OnChangeMapScale, self.statusbarWin['mapscale'])
+ # go to
+ self.statusbarWin['goto'] = wx.TextCtrl(parent=self.statusbar, id=wx.ID_ANY,
+ value="", style=wx.TE_PROCESS_ENTER,
+ size=(300, -1))
+ self.statusbarWin['goto'].Hide()
+ self.statusbar.Bind(wx.EVT_TEXT_ENTER, self.OnGoTo, self.statusbarWin['goto'])
+ # projection
+ self.statusbarWin['projection'] = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
+ label=_("Use defined projection"))
+ self.statusbarWin['projection'].SetValue(False)
+ size = self.statusbarWin['projection'].GetSize()
+ self.statusbarWin['projection'].SetMinSize((size[0] + 150, size[1]))
+ self.statusbarWin['projection'].SetToolTip(wx.ToolTip (_("Reproject coordinates displayed "
+ "in the statusbar. Projection can be "
+ "defined in GUI preferences dialog "
+ "(tab 'Display')")))
+ self.statusbarWin['projection'].Hide()
+ # mask
+ self.statusbarWin['mask'] = wx.StaticText(parent = self.statusbar, id = wx.ID_ANY,
+ label = '')
+ self.statusbarWin['mask'].SetForegroundColour(wx.Colour(255, 0, 0))
+ # on-render gauge
+ self.statusbarWin['progress'] = wx.Gauge(parent=self.statusbar, id=wx.ID_ANY,
+ range=0, style=wx.GA_HORIZONTAL)
+ self.statusbarWin['progress'].Hide()
+ self.StatusbarReposition() # reposition statusbar
+ # Init map display (buffered DC & set default cursor)
+ self.MapWindow2D = BufferedWindow2(self, id=wx.ID_ANY,
+ Map=self.Map, tree=self.tree, lmgr=self.gismanager)
+ # default is 2D display mode
+ self.MapWindow = self.MapWindow2D
+ self.MapWindow.Bind(wx.EVT_MOTION, self.MapWindow.OnMotion)
+ self.MapWindow.SetCursor(self.cursors["default"])
+ # used by Nviz (3D display mode)
+ self.MapWindow3D = None
+ self.MapWindow.Bind(wx.EVT_LEFT_DCLICK,self.OnButtonDClick)
+ self.MapWindow.Bind(wx.EVT_RIGHT_DCLICK,self.RDClick)
+ # initialize region values
+ self.width, self.height = self.GetClientSize()
+ self.Map.ChangeMapSize(self.GetClientSize())
+ self.Map.region = self.Map.GetRegion()
+ # Bind various events
+ #self.Bind(wx.EVT_ACTIVATE, self.OnFocus)
+ self.Bind(wx.EVT_CLOSE, self.OnCloseWindow)
+ self.Bind(render.EVT_UPDATE_PRGBAR, self.OnUpdateProgress)
+ # Update fancy gui style
+ self._mgr.AddPane(self.MapWindow, wx.aui.AuiPaneInfo().CentrePane().
+ Dockable(False).BestSize((-1,-1)).
+ CloseButton(False).DestroyOnClose(True).
+ Layer(0))
+ self._mgr.Update()
+ # Init print module and classes
+ #self.printopt = disp_print.PrintOptions(self, self.MapWindow)
+ # Initialization of digitization tool
+ self.digit = None
+ # Init zoom history
+ self.MapWindow.ZoomHistory(self.Map.region['n'],
+ self.Map.region['s'],
+ self.Map.region['e'],
+ self.Map.region['w'])
+ # Re-use dialogs
+ self.dialogs = {}
+ self.dialogs['attributes'] = None
+ self.dialogs['category'] = None
+ self.dialogs['barscale'] = None
+ self.dialogs['legend'] = None
+ self.decorationDialog = None # decoration/overlays
+ # Re-use dialogs
+ self.coords = []
+ self.coor = []
+ self.mapname = 'lsat7_2000_10@' + grass1.gisenv()['MAPSET']
+ self.cmd= ['d.rast', str("map=" + self.mapname)]
+ self.Map.AddLayer(type='raster', name=self.mapname, command=self.cmd)
+ self.MapWindow.UpdateMap(render=True)
+ self.dialogs = {}
+ #self.Maximize()
+ self.X = []
+ self.Y = []
+ self.tempX = []
+ self.tempY = []
+ self.npoints = 0
+ self.VX = []
+ self.VY = []
+ self.perimeter_npoints = 0
+ self.perimeterX = []
+ self.perimeterY = []
+ self.Region_perimeter= []
+ # initialize
+ self.data_type = []
+ self.inrast = []
+ self.infd = []
+ self.Band_sum = []
+ self.Bandbuf = []
+ self.Band_histo = []
+ self.Band_Product = []
+ self.Band_min = []
+ self.Band_max = []
+ self.np = 0
+ # find map in search path
+ self.name = ['lsat7_2002_10','lsat7_2002_20','lsat7_2002_30','lsat7_2002_40','lsat7_2002_50','lsat7_2002_70']
+ # determine the inputmap type (CELL/FCELL/DCELL) */
+ # for n in range(0,6):
+ # self.data_type = grass.G_raster_map_type(name[n], mapset)
+ # self.infd.append( grass.G_open_cell_old(name[n], mapset))
+ self.mapset ='PERMANENT'
+ self.mapset = c_char_p(self.mapset).value
+ self.open_band_files()
+ self.vnrows = 0
+ self.vncols = 0
+ self.hnrows = 0
+ self.hncols = 0
+ self.htop = self.hbottom = self.hleft = self.hright = 0
+ self.view()
+ self.viewhistogram()
+ self.cellhd = grasslib.Cell_head()
+ if (grasslib.G_get_cellhd('lsat7_2002_10', self.mapset, self.cellhd))!=0 :
+ print "error1"
+ self.Band_cellhd = self.cellhd
+ self.dst = self.adjust_window_to_box(self.cellhd, self.vnrows, self.vncols)
+ self.vcleft = self.vleft + (self.vncols - self.dst.cols) / 2
+ self.vcright = self.vcleft + self.dst.cols - 1
+ self.vctop = self.vtop + (self.vnrows - self.dst.rows) / 2
+ self.vcbottom = self.vctop + self.dst.rows - 1
+ self.vc_ns_res = self.cellhd.ns_res
+ self.vc_ew_res = self.cellhd.ew_res
+ for b in xrange(6):
+ self.Band_sum.append(0.0)
+ self.Band_histo.append([])
+ for b2 in xrange(256):
+ self.Band_Product.append([])
+ self.Band_histo[b].append(0.0)
+ for b2 in xrange(255):
+ self.Band_Product[b].append(0)
+#define AFTER_STD 1
+#define BEFORE_STD 0
+ def histograms(self, nbands, bsum, histo,np,inmin,inmax,b_or_a):
+ nrows = self.hnrows
+ ncols = self.hncols
+ nbands = 6
+ old_range = 0
+ BORDER = 10
+ MIN_HISTO_WIDTH = 1
+ MAX_HISTO_WIDTH = 11
+ if (b_or_a == 1):
+ max_range = 1
+ for b in xrange(nbands):
+ if (inmax[b] - inmin[b] > max_range):
+ max_range = inmax[b] - inmin[b]
+ old_range = max_range
+ else:
+ max_range = old_range
+ try:
+ histo_width = (ncols - BORDER * 2) / max_range
+ except:
+ histo_width = ncols
+ if (histo_width % 2 == 0):
+ histo_width = histo_width - 1
+ if (histo_width < MIN_HISTO_WIDTH):
+ histo_width = MIN_HISTO_WIDTH
+ elif (histo_width > MAX_HISTO_WIDTH):
+ histo_width = MAX_HISTO_WIDTH
+ height = (nrows - BORDER * 2) / nbands
+ width = (ncols - BORDER * 2) / histo_width * histo_width
+ nbars = width / histo_width
+ h_top = self.htop + BORDER
+ h_left = self.hleft + BORDER
+ h_right = h_left + width - 1
+ grand_max = 0;
+ for x1 in xrange(256):
+ if (histo[b][x1] > grand_max):
+ grand_max = histo[b][x1]
+ LEGEND_SPACE = 3 * (width/30)
+ if (grand_max > 0):
+ scale = (height - LEGEND_SPACE) / grand_max;
+ else:
+ scale = 0;
+ h_bottom = h_top + height - 1
+ bottom_adjusted = h_bottom - 2 * LEGEND_SPACE / 3
+ mean = (self.Band_sum[b]/self.np)
+ #std_dev = self.std_dev(b)
+ cat = mean - (nbars - 1) / 2
+ y1 = y2 = bottom_adjusted
+ x1 = h_left
+ x2 = h_left + histo_width - 1
+ bar = 0
+ nbars = int(nbars)
+ cat = int(cat)
+ while ((bar < nbars) and (cat < 256)):
+ if (cat >= 0):
+ y2 = bottom_adjusted - (histo[b][cat] * scale + .5)
+ xy1 = x1,y2
+ xy2 = x2,y2
+ self.coor.append(xy1)
+ self.coor.append(xy2)
+ y1 = y2
+ x1 = x2
+ bar = bar +1
+ cat = cat +1
+ x2 = x2+histo_width
+ h_top = h_bottom + 1
+ self.polypen = wx.Pen(colour="GREEN", width=1, style=wx.SOLID)
+ pdc = wx.PaintDC(self.MapWindow)
+ pdc.BeginDrawing()
+ pdc.SetBrush(wx.Brush(wx.CYAN, wx.TRANSPARENT))
+ pdc.SetPen(self.polypen)
+ if (len(self.coor) < 2):
+ return
+ i = 1
+ while i < len(self.coor):
+ pdc.DrawLinePoint(wx.Point(self.coor[i-1][0], self.coor[i-1][1]),
+ wx.Point(self.coor[i][0], self.coor[i][1]))
+ i += 1
+ pdc.EndDrawing()
+ self.coor = []
+ def viewhistogram(self):
+ SCREEN_TOP = 0
+ SCREEN_BOTTOM=480
+ SCREEN_LEFT =0
+ SCREEN_RIGHT =640
+#VIEW_HISTO = makeview(2.5, 100.0, 0.0, 50.0);
+#static View *makeview(double bottom, double top, double left, double right)
+ top =100.0
+ bottom =2.5
+ left =0.0
+ right =50.0
+ top = 100 - top
+ bottom = 100 - bottom
+ self.htop = SCREEN_TOP + (SCREEN_BOTTOM - SCREEN_TOP) * top / 100.0
+ self.hbottom = SCREEN_TOP + (SCREEN_BOTTOM - SCREEN_TOP) * bottom / 100.0
+ self.hleft = SCREEN_LEFT + (SCREEN_RIGHT - SCREEN_LEFT) * left / 100.0
+ self.hright = SCREEN_LEFT + (SCREEN_RIGHT - SCREEN_LEFT) * right / 100.0
+ if self.htop < SCREEN_TOP:
+ if self.hbottom > SCREEN_BOTTOM:
+ self.hbottom = SCREEN_BOTTOM
+ if self.hleft < SCREEN_LEFT:
+ if self.hright > SCREEN_RIGHT:
+ self.hright = SCREEN_RIGHT
+ self.htop+=1
+ self.hbottom-=1
+ self.hleft+=1
+ self.hright-=1
+ self.hnrows = self.hbottom - self.htop + 1
+ self.hncols = self.hright - self.hleft + 1
+ def open_band_files(self):
+ for n in xrange(6):
+ self.data_type.append(grass.G_raster_map_type(self.name[n], self.mapset))
+ if self.data_type[n] == 0:
+ ptype = POINTER(c_int)
+ elif self.data_type[n] == 1:
+ ptype = POINTER(c_float)
+ elif self.data_type[n] == 2:
+ ptype = POINTER(c_double)
+ self.infd.append(grass.G_open_cell_old(self.name[n], self.mapset))
+ self.Bandbuf.append(grass.G_allocate_raster_buf(self.data_type[n]))
+ self.Bandbuf[n] = cast(c_void_p(self.Bandbuf[n]), ptype)
+ def readbands(self,y):
+ self.y = int(y)
+ if self.y < 0:
+ self.y = 0
+ for n in range(0,6):
+ grass.G_get_raster_row(self.infd[n], self.Bandbuf[n], self.y, self.data_type[n])
+ def prepare(self,nbands):
+ i = 1
+ self.nbands = nbands
+ while(i < self.perimeter_npoints):
+ y = self.perimeterY[i]
+ self.readbands(y)
+ x0 = int(self.perimeterX[i-1] - 1)
+ x1 = int(self.perimeterX[i] - 1)
+ if x0 > x1 :
+ #print "error0"
+ return -1
+ x = x0
+ while x <= x1:
+ self.np +=1
+ for b in range(0,self.nbands):
+ n = self.Bandbuf[b][x]
+ if ( (n <0) or (n > 255)):
+ print "error2"
+ return
+ self.Band_sum[b] = self.Band_sum[b] + n
+ self.Band_histo[b][n]= self.Band_histo[b][n] + 1
+ if self.np == 1:
+ self.Band_min.append(n)
+ self.Band_max.append(n)
+ if self.Band_min[b] > n:
+ self.Band_min[b] = n
+ if self.Band_max[b] < n:
+ self.Band_max[b] = n
+ b2 = 0
+ while b2<=b:
+ self.Band_Product[b][b2] += n * self.Bandbuf[b2][x]
+ b2 = b2 +1
+ x = x + 1
+ i = i + 2
+ def Redraw(self):
+ self.polypen = wx.Pen(colour="RED", width=1, style=wx.SOLID)
+ if (len(self.coords) < 2):
+ return
+ i = 1
+ while i < len(self.coords):
+ pdc.DrawLinePoint(wx.Point(self.coords[i-1][0], self.coords[i-1][1]),
+ wx.Point(self.coords[i][0], self.coords[i][1]))
+ i += 1
+ pdc.EndDrawing()
+ def RDClick(self,event):
+ self.outline()
+ self.add_point(self.X[0] , self.Y[0])
+ self.Redraw()
+ self.prepare(6)
+ self.histograms(6, self.Band_sum, self.Band_histo,self.np,self.Band_min,self.Band_max,0)
+ def outline(self):
+ for cur in range(0,self.npoints):
+ x,y = self.coords[cur]
+ tmpx = self.view_to_row(y)
+ tmpy = self.view_to_col(x)
+ tmp_n = self.row_to_northing(tmpy, 0.5)
+ tmp_e = self.col_to_easting(tmpx, 0.5)
+ self.tempY.append(grasslib.G_northing_to_row(tmp_n, self.Band_cellhd))
+ self.tempX.append(grasslib.G_easting_to_col(tmp_e, self.Band_cellhd))
+ first = -1
+ prev = self.npoints -1
+ if self.tempY[cur]!= self.tempY[prev]:
+ first = cur
+ break
+ skip = 0
+ VN = 0
+ cur = 0
+ if skip == 0:
+ self.VX.append(self.tempX[cur])
+ self.VY.append(self.tempY[cur])
+ VN=VN + 1
+ prev = cur
+ cur = cur + 1
+ if cur >=self.npoints:
+ cur = 0
+ next = cur +1
+ if next >= self.npoints:
+ next = 0
+ skip = ((self.tempY[prev] == self.tempY[cur]) and (self.tempY[next] == self.tempY[cur]))
+ while cur != first:
+ if skip == 0:
+ VN=VN + 1
+ cur = cur + 1
+ prev = cur
+ cur = 0
+ next = cur +1
+ next = 0
+ try:
+ except:
+ pass
+ np = 0
+ prev = VN - 1
+ try:
+ np= np + abs(self.VY[prev] - self.VY[cur])
+ except:
+ pass
+ PN = 0
+ prev = VN - 1
+ cur = 0
+ while(cur< VN):
+ self.edge(self.VX[prev], self.VY[prev],self.VX[cur],self.VY[cur])
+ prev = cur
+ cur = cur + 1
+ prev = VN - 1
+ cur = 0
+ next = cur + 1
+ if next>=VN :
+ next = 0
+ if (((self.VY[prev]<self.VY[cur]) and (self.VY[next]<self.VY[cur])) or ((self.VY[prev]>self.VY[cur]) and (self.VY[next]>self.VY[cur]))) :
+ skip = 1
+ elif (((self.VY[prev]<self.VY[cur]) and (self.VY[cur]<self. VY[next])) or ((self.VY[prev]>self.VY[cur]) and (self.VY[cur]>self. VY[next]))):
+ skip = 0
+ else:
+ skip = 0
+ next +=1
+ if next >= VN :
+ next = 0
+ if (((self.VY[prev]<self.VY[cur]) and (self.VY[next]<self.VY[cur])) or ((self.VY[prev]>self.VY[cur]) and (self.VY[next]>self.VY[cur]))):
+ skip = 1
+ if skip == 0:
+ self.edge_point(self.VX[cur], self.VY[cur])
+ cur = next
+ prev = cur - 1
+ while cur!=0 :
+ next = cur + 1
+ if next>=VN :
+ next = 0
+ skip = 1
+ skip = 0
+ else:
+ skip = 0
+ next +=1
+ if next >= VN :
+ next = 0
+ skip = 1
+ if skip == 0:
+ cur = next
+ prev = cur - 1
+ for i in range(0,len(self.perimeterX)):
+ a = self.perimeterX[i]
+ b = self.perimeterY[i]
+ xy = a,b
+ self.Region_perimeter.append(xy)
+ self.Region_perimeter.sort()
+ def edge(self, x0, y0, x1, y1):
+ if y0 == y1:
+ return 0
+ x =x0
+ m = float((x0 -x1)/(y0-y1))
+ if y0 < y1 :
+ y0+=1
+ while y0 < y1 :
+ x = x+m
+ x0 = x +0.5
+ self.edge_point(x0,y0)
+ y0 = y0 + 1
+ else:
+ y0 = y0 - 1
+ while y0 > y1 :
+ x = x - m
+ x0 = x + 0.5
+ y0 = y0 - 1
+ def edge_point(self, x , y):
+ n = self.perimeter_npoints = self.perimeter_npoints + 1
+ self.perimeterX.append(x)
+ self.perimeterY.append(y)
+ def row_to_northing(self, row, location):
+ return (self.dst.north - (row + location) * self.dst.ns_res)
+ def col_to_easting(self, col, location):
+ return (self.dst.west + (col + location) * self.dst.ew_res)
+ def view_to_row(self, y):
+ return (y - self.vctop)
+ def view_to_col(self, x):
+ return (x - self.vcleft)
+ def adjust_window_to_box(self,src, rows, cols):
+ dst = grasslib.Cell_head()
+ dst = src
+ ns = src.ns_res
+ ns = (src.ns_res * src.rows) / rows
+ ew = (src.ew_res * src.cols) / cols
+ if ns > ew:
+ ew = ns
+ else:
+ ns = ew
+ dst.ns_res = ns
+ dst.ew_res = ew
+ r = int(abs(round(((dst.north - dst.south) / dst.ns_res),0)))
+ c = int(abs(round(( (dst.east - dst.west) / dst.ew_res),0)))
+ dst.rows = r
+ dst.cols = c
+ return dst
+ def view(self):
+ SCREEN_TOP = 0
+ SCREEN_BOTTOM=480
+ SCREEN_LEFT =0
+ SCREEN_RIGHT =640
+ top =97.5
+ bottom =51.0
+ left =50.0
+ right =100.0
+ top = 100 - top
+ self.vtop = SCREEN_TOP + (SCREEN_BOTTOM - SCREEN_TOP) * top / 100.0
+ self.vbottom = SCREEN_TOP + (SCREEN_BOTTOM - SCREEN_TOP) * bottom / 100.0
+ self.vleft = SCREEN_LEFT + (SCREEN_RIGHT - SCREEN_LEFT) * left / 100.0
+ self.vright = SCREEN_LEFT + (SCREEN_RIGHT - SCREEN_LEFT) * right / 100.0
+ if self.vtop < SCREEN_TOP:
+ if self.vbottom > SCREEN_BOTTOM:
+ self.vbottom = SCREEN_BOTTOM
+ if self.vleft < SCREEN_LEFT:
+ if self.vright > SCREEN_RIGHT:
+ self.vright = SCREEN_RIGHT
+ self.vtop+=1
+ self.vbottom-=1
+ self.vleft+=1
+ self.vright-=1
+ self.vnrows = self.vbottom - self.vtop + 1
+ self.vncols = self.vright - self.vleft + 1
+ def OnButtonDClick(self,event):
+ x,y = event.GetPositionTuple()
+ self.add_point(x,y)
+ self.Redraw()
+ #self.outline()
+ def add_point(self,x, y):
+ last = 0
+ last = self.npoints - 1
+ if last >= 0 and x == self.X[last] and y == self.Y[last]:
+ return 1
+ if self.npoints >= 100 :
+ print "Can't mark another point."
+ return 0
+ xy=x,y
+ last+=1
+ self.X.append(x)
+ self.Y.append(y)
+ self.coords.append(xy)
+ self.npoints+=1;
+ return 1
+class BufferedWindow2(BufferedWindow):
+ """!A Buffered window class.
+ When the drawing needs to change, you app needs to call the
+ UpdateMap() method. Since the drawing is stored in a bitmap, you
+ can also save the drawing to file by calling the
+ SaveToFile(self,file_name,file_type) method.
+ def __init__(self, parent, id = wx.ID_ANY,
+ Map = None, tree = None, lmgr = None,
+ style = wx.NO_FULL_REPAINT_ON_RESIZE, **kwargs):
+ MapWindow.__init__(self, parent, id, Map, tree, lmgr, **kwargs)
+ wx.Window.__init__(self, parent, id, style = style, **kwargs)
+ # flags
+ self.resize = False # indicates whether or not a resize event has taken place
+ self.dragimg = None # initialize variable for map panning
+ # variables for drawing on DC
+ self.pen = None # pen for drawing zoom boxes, etc.
+ self.polypen = None # pen for drawing polylines (measurements, profiles, etc)
+ # List of wx.Point tuples defining a polyline (geographical coordinates)
+ self.polycoords = []
+ # ID of rubber band line
+ self.lineid = None
+ # ID of poly line resulting from cumulative rubber band lines (e.g. measurement)
+ self.plineid = None
+ # event bindings
+ self.Bind(wx.EVT_PAINT, self.OnPaint)
+ self.Bind(wx.EVT_SIZE, self.OnSize)
+ self.Bind(wx.EVT_IDLE, self.OnIdle)
+ ### self.Bind(wx.EVT_MOTION, self.MouseActions)
+ self.Bind(wx.EVT_MOUSE_EVENTS, self.MouseActions)
+ self.Bind(wx.EVT_MOTION, self.OnMotion)
+ self.processMouse = True
+ # render output objects
+ self.mapfile = None # image file to be rendered
+ self.img = None # wx.Image object (self.mapfile)
+ # used in digitization tool (do not redraw vector map)
+ self.imgVectorMap = None
+ # decoration overlays
+ self.overlays = {}
+ # images and their PseudoDC ID's for painting and dragging
+ self.imagedict = {}
+ self.select = {} # selecting/unselecting decorations for dragging
+ self.textdict = {} # text, font, and color indexed by id
+ self.currtxtid = None # PseudoDC id for currently selected text
+ # zoom objects
+ self.zoomhistory = [] # list of past zoom extents
+ self.currzoom = 0 # current set of extents in zoom history being used
+ self.zoomtype = 1 # 1 zoom in, 0 no zoom, -1 zoom out
+ self.hitradius = 10 # distance for selecting map decorations
+ self.dialogOffset = 5 # offset for dialog (e.g. DisplayAttributesDialog)
+ # OnSize called to make sure the buffer is initialized.
+ # This might result in OnSize getting called twice on some
+ # platforms at initialization, but little harm done.
+ ### self.OnSize(None)
+ self.DefinePseudoDC()
+ # redraw all pdc's, pdcTmp layer is redrawn always (speed issue)
+ self.redrawAll = True
+ # will store an off screen empty bitmap for saving to file
+ self._buffer = ''
+ self.Bind(wx.EVT_ERASE_BACKGROUND, lambda x:None)
+# self.Bind(wx.EVT_KEY_DOWN , Bufferedwindow.OnKeyDown)
+ # vars for handling mouse clicks
+ self.dragid = -1
+ self.lastpos = (0, 0)
+ def OnPaint(self, event):
+ Draw PseudoDC's to buffered paint DC
+ self.pdc for background and decorations
+ self.pdcVector for vector map which is edited
+ self.pdcTmp for temporaly drawn objects (self.polycoords)
+ If self.redrawAll is False on self.pdcTmp content is re-drawn
+ Debug.msg(4, "BufferedWindow.OnPaint(): redrawAll=%s" % self.redrawAll)
+ dc = wx.BufferedPaintDC(self, self.buffer)
+ ### dc.SetBackground(wx.Brush("White"))
+ dc.Clear()
+ # use PrepareDC to set position correctly
+ self.PrepareDC(dc)
+ # create a clipping rect from our position and size
+ # and update region
+ rgn = self.GetUpdateRegion().GetBox()
+ dc.SetClippingRect(rgn)
+ switchDraw = False
+ if self.redrawAll is None:
+ switchDraw = True
+ if self.redrawAll: # redraw pdc and pdcVector
+ # draw to the dc using the calculated clipping rect
+ self.pdc.DrawToDCClipped(dc, rgn)
+ # draw vector map layer
+ if self.pdcVector:
+ # decorate with GDDC (transparency)
+ try:
+ gcdc = wx.GCDC(dc)
+ self.pdcVector.DrawToDCClipped(gcdc, rgn)
+ except NotImplementedError, e:
+ print >> sys.stderr, e
+ self.pdcVector.DrawToDCClipped(dc, rgn)
+ self.bufferLast = None
+ else: # do not redraw pdc and pdcVector
+ if self.bufferLast is None:
+ # draw to the dc
+ self.pdc.DrawToDC(dc)
+ try:
+ self.pdcVector.DrawToDC(gcdc)
+ self.pdcVector.DrawToDC(dc)
+ # store buffered image
+ # self.bufferLast = wx.BitmapFromImage(self.buffer.ConvertToImage())
+ self.bufferLast = dc.GetAsBitmap(wx.Rect(0, 0, self.Map.width, self.Map.height))
+ pdcLast = self.PseudoDC(vdigit = False)
+ pdcLast.DrawBitmap(self.bufferLast, 0, 0, False)
+ pdcLast.DrawToDC(dc)
+ # draw decorations (e.g. region box)
+ try:
+ self.pdcDec.DrawToDC(gcdc)
+ self.pdcDec.DrawToDC(dc)
+ # draw temporary object on the foreground
+ ### self.pdcTmp.DrawToDCClipped(dc, rgn)
+ self.pdcTmp.DrawToDC(dc)
+ if switchDraw:
+ self.redrawAll = False
+ self.pdc.BeginDrawing()
+ self.pdc.SetBrush(wx.Brush(wx.CYAN, wx.TRANSPARENT))
+ self.pdc.SetPen(self.polypen)
+ if (len(self.parent.coords) < 2):
+ return
+ i = 1
+ while i < len(self.parent.coords):
+ self.pdc.DrawLinePoint(wx.Point(self.parent.coords[i-1][0], self.parent.coords[i-1][1]),
+ wx.Point(self.parent.coords[i][0], self.parent.coords[i][1]))
+ i += 1
+ self.pdc.EndDrawing()
+ if (len(self.parent.coor) < 2):
+ return
+ i = 1
+ while i < len(self.parent.coor):
+ self.pdc.DrawLinePoint(wx.Point(self.parent.coor[i-1][0], self.parent.coor[i-1][1]),
+ wx.Point(self.parent.coor[i][0], self.parent.coor[i][1]))
+ i += 1
+ self.Refresh()
+class IClassApp(wx.App):
+ MapApp class
+ def OnInit(self):
+ if __name__ == "__main__":
+ Map = render.Map()
+ else:
+ Map = None
+ self.frame = IClass(parent=None, id=wx.ID_ANY, Map=Map,
+ size=globalvar.MAP_WINDOW_SIZE)
+ self.frame.Show()
+ return 1
+# end of class
+if __name__ == "__main__":
+ iclass_app = IClassApp(0)
+ iclass_app.MainLoop()
+ sys.exit(0)
