[GRASS-SVN] r43504 -
grass/branches/releasebranch_6_4/scripts/v.rast.stats
svn_grass at osgeo.org
Sat Sep 18 11:48:20 EDT 2010
Author: neteler
Date: 2010-09-18 15:48:20 +0000 (Sat, 18 Sep 2010)
New Revision: 43504
grass/branches/releasebranch_6_4/scripts/v.rast.stats/v.rast.stats
backport: cleanup quoting for some variables, add some debug messages; DBFDRIVER col name limit test
Modified: grass/branches/releasebranch_6_4/scripts/v.rast.stats/v.rast.stats
--- grass/branches/releasebranch_6_4/scripts/v.rast.stats/v.rast.stats 2010-09-18 14:53:09 UTC (rev 43503)
+++ grass/branches/releasebranch_6_4/scripts/v.rast.stats/v.rast.stats 2010-09-18 15:48:20 UTC (rev 43504)
@@ -174,10 +174,10 @@
#Temporarily setting raster resolution to $RASTER resolution
#keep boundary settings
-g.region nsres=$NSRES ewres=$EWRES -a
+g.region nsres="$NSRES" ewres="$EWRES" -a
#prepare raster MASK
-v.to.rast in="$VECTOR" out="${VECTOR}_${TMPNAME}" use=cat --quiet
+v.to.rast in="$VECTOR" out="${VECTOR}_$TMPNAME" use=cat --quiet
if [ $? -ne 0 ] ; then
g.message -e "An error occurred while converting vector to raster"
cleanup
@@ -186,7 +186,7 @@
#dump cats to file to avoid "too many argument" problem:
-r.category "${VECTOR}_${TMPNAME}" fs=';' --quiet | cut -d';' -f1 > "$TEMPFILE.cats"
+r.category "${VECTOR}_$TMPNAME" fs=';' --quiet | cut -d';' -f1 > "$TEMPFILE.cats"
#echo "List of categories found: $CATSLIST"
NUMBER=`cat "$TEMPFILE.cats" | wc -l | awk '{print $1}'`
if [ $NUMBER -lt 1 ] ; then
@@ -206,9 +206,24 @@
# in case a table is missing, we'll trap a crash later...
DBFDRIVER=0
fi
+if [ "$DBFDRIVER" -eq 1 ] ; then
+ # `wc -c` reports number of chars + 1 for the newline
+ if [ `echo "$COLPREFIX" | wc -c` -gt 7 ] ; then
+ g.message -e "Cannot create unique names for columns. \
+ Either use a shorter column prefix or switch to another DB \
+ backend such as SQLite. DBF limits the length to 10 characters"
+ cleanup
+ exit 1
+ fi
+fi
# we need this for non-DBF driver:
DB_SQLDRIVER=`v.db.connect -g "$VECTOR" fs=";" | cut -d';' -f5`
+g.message -d message="sql driver: [$DB_SQLDRIVER]"
DB_DATABASE="`v.db.connect -g "$VECTOR" fs=";" | cut -d';' -f4`"
+g.message -d message="database: [$DB_DATABASE]"
#Find out which table is linked to the vector map on the given layer
TABLE=`v.db.connect map="$VECTOR" -g fs=";" | grep -w "^$GIS_OPT_LAYER" | awk -F ";" '{print $2}'`
@@ -216,14 +231,15 @@
g.message -e 'There is no table connected to this map! Run v.db.connect or v.db.addtable first.'
exit 1
fi
+g.message -d message="table: [$TABLE]"
BASECOLS="n min max range mean stddev variance cf_var sum"
# do extended stats?
-if [ $GIS_FLAG_E -eq 1 ] ; then
+if [ "$GIS_FLAG_E" -eq 1 ] ; then
# namespace is limited in DBF but the % value is important
- if [ $DBFDRIVER -eq 1 ] ; then
+ if [ "$DBFDRIVER" -eq 1 ] ; then
PERCCOL="per$GIS_OPT_PERCENTILE"
else
PERCCOL="percentile_$GIS_OPT_PERCENTILE"
@@ -237,15 +253,16 @@
unset ADDCOLS
for i in $BASECOLS $EXTRACOLS ; do
#check if column already present
- CURRCOLUMN="`echo "${COLPREFIX}_${i}" | cut -b1-10`"
+ CURRCOLUMN="`echo "${COLPREFIX}_$i" | cut -b1-10`"
else
- CURRCOLUMN="${COLPREFIX}_${i}"
+ CURRCOLUMN="${COLPREFIX}_$i"
fi
- v.info -c $VECTOR --quiet | sed 's+^+|+g' | sed 's+$+|+g' | \
+ g.message -d message="Looking for <$CURRCOLUMN> in <$VECTOR> ..."
+ v.info -c "$VECTOR" --quiet | sed -e 's+^+|+' -e 's+$+|+' | \
grep "|$CURRCOLUMN|" -q
if [ $? -eq 0 ] ; then
- if [ $GIS_FLAG_C -ne 1 ] ; then
+ if [ "$GIS_FLAG_C" -ne 1 ] ; then
g.message -e "Cannot create column <$CURRCOLUMN> (already present). \
Use -c flag to update values in this column."
cleanup
@@ -307,11 +324,11 @@
eval value=\${$var}
- colname="`echo "${COLPREFIX}_${var}" | cut -b1-10`"
+ colname="`echo "${COLPREFIX}_$var" | cut -b1-10`"
else
- colname="${COLPREFIX}_${var}"
+ colname="${COLPREFIX}_$var"
fi
+ g.message -d debug=3 message="UPDATE $TABLE SET ${colname}=${value} WHERE cat=$i;"
echo "UPDATE $TABLE SET ${colname}=${value} WHERE cat=$i;" >> "$SQLTMP"
done
@@ -320,7 +337,7 @@
g.message "Updating the database ..."
-db.execute input="$SQLTMP" database="${DB_DATABASE}" driver="$DB_SQLDRIVER"
+db.execute input="$SQLTMP" database="$DB_DATABASE" driver="$DB_SQLDRIVER"
EXITCODE=$?
