[GRASS-SVN] r43505 -
grass/branches/releasebranch_6_4/imagery/i.atcorr
svn_grass at osgeo.org
Sat Sep 18 12:01:00 EDT 2010
Author: neteler
Date: 2010-09-18 16:01:00 +0000 (Sat, 18 Sep 2010)
New Revision: 43505
Added:
grass/branches/releasebranch_6_4/imagery/i.atcorr/create_iwave.py
backported utility script
Added: grass/branches/releasebranch_6_4/imagery/i.atcorr/create_iwave.py
--- grass/branches/releasebranch_6_4/imagery/i.atcorr/create_iwave.py (rev 0)
+++ grass/branches/releasebranch_6_4/imagery/i.atcorr/create_iwave.py 2010-09-18 16:01:00 UTC (rev 43505)
@@ -0,0 +1,242 @@
+#!/usr/bin/env python
+Created on Sat Mar 27 11:35:32 2010
+Program to interpolate filter function to correct
+step. Should be 2.5 nm
+Then output filter function in a format similar to
+what is needed in the Iwave.cpp file
+Needs numpy and scipy
+ at author: daniel victoria, 2010
+contact: daniel {dot} victoria {at} gmail {dot} com
+usage() explains how this is supposed to work
+Basically it needs a .csv file with spectral response for each
+band in a column. First column has to be wavelength (nm)
+First line (and only first) is a header with Wl, followed by band names
+file name is used for sensor name
+Updated by: Anne Ghisla, 2010
+import os
+import sys
+import numpy as np
+from scipy import interpolate
+def usage():
+ """How to use this..."""
+ print "create_iwave.py <csv file>"
+ print "Generate filter function IWave.cpp template from csv file"
+ print "csv file must have wl response for each band in each column"
+ print "first line must be a header with wl followed by band names"
+ print "following lines will be the data."
+ print "If response is null, leave empty in csv file. Ex.:"
+ print "WL(nm),band 1,band 2,band 3,band 4"
+ print "455,0.93,,,"
+ print "485,0.94,0.00,,"
+ print "545,0.00,0.87,0.00,"
+ print "Program will interpolate filter function to 2.5 nm steps"
+ print "and output a cpp template file in the IWave format"
+def read_input(csvfile):
+ Function to read input file
+ return number of bands and array of values for each band
+ should be a .csv file with the values
+ of the filter function for each band in the sensor
+ one column for band
+ first line must have a header with sensor band name
+ first column is wavelength
+ infile = open(csvfile, 'r')
+ # get number of bands and band names
+ bands = infile.readline().split(',')
+ bands.remove(bands[0])
+ bands[-1] = bands[-1].strip()
+ infile.close()
+ # create converter dictionary for import
+ # fix nodata or \n
+ conv = {}
+ for b in range(len(bands)):
+ conv[b+1] = lambda s: float(s or -99)
+ values = np.loadtxt(csvfile, delimiter=',', skiprows=1, converters = conv)
+ return (bands, values)
+def interpolate_band(values):
+ Receive wavelength and response for one band
+ interpolate at 2.5 nm steps
+ return interpolated filter func
+ and min, max wl values
+ values must be numpy array with 2 columns
+ # These 2 lines select the subarray
+ # remove nodata (-99) lines in values array
+ # where response is nodata?
+ w = values[:,1] >= 0
+ response = values[w]
+ # interpolating
+ f = interpolate.interp1d(response[:,0],response[:,1])
+ filter_f = f(np.arange(response[0,0], response[-1,0], 2.5))
+ # convert limits from nanometers to micrometers
+ lowerlimit = response[0,0]/1000
+ upperlimit = response[-1,0]/1000
+ return(filter_f, (lowerlimit, upperlimit))
+def plot_filter(values):
+ """Plot wl response values and interpolated
+ filter function. This is just for checking...
+ value is a 2 column numpy array
+ function has to be used inside Spyder python environment
+ filter_f, limits = interpolate_band(values)
+ # removing nodata
+ plot(response[:,0],response[:,1], 'ro')
+ plot(arange(limits[0], limits[1], 2.5), filter_f)
+ return
+def pretty_print(filter_f):
+ Create pretty string out of filter function
+ 8 values per line, with spaces, commas and all the rest
+ pstring = ''
+ for i in range(len(filter_f)):
+ if i%8 is 0:
+ if i is not 1:
+ # trim the trailing whitespace at the end of line
+ pstring = pstring.rstrip()
+ pstring += "\n\t\t"
+ else:
+ value_wo_leading_zero = ('%.4f' % (filter_f[i-1])).lstrip('0')
+ pstring += value_wo_leading_zero+', '
+ # trim starting \n and trailing ,
+ pstring = pstring.lstrip("\n").rstrip(", ")
+ return pstring
+def write_cpp(bands, values, sensor, folder):
+ from bands, values and sensor name
+ create output file in cpp style
+ needs other functions: interpolate_bands, pretty_print
+ # getting necessary data
+ # single or multiple bands?
+ if len(bands) == 1:
+ else:
+ filter_f = []
+ limits = []
+ fi, li = interpolate_band(values[:,[0,b+1]])
+ filter_f.append(fi)
+ limits.append(li)
+ # writing...
+ outfile = open(os.path.join(folder, sensor+"_cpp_template.txt"), 'w')
+ outfile.write('/* Following filter function created using create_iwave.py */\n\n')
+ outfile.write('void IWave::%s()\n{\n\n' % (sensor.lower()))
+ else:
+ outfile.write('void IWave::%s(int iwa)\n{\n\n' % (sensor.lower()))
+ # single band case
+ outfile.write(' /* %s of %s */\n' % (bands[0], sensor))
+ outfile.write(' static const float sr[%i] = {' % (len(filter_f)))
+ filter_text = pretty_print(filter_f)
+ outfile.write(filter_text)
+ # calculate wl slot for band start
+ # slots range from 250 to 4000 at 2.5 increments (total 1500)
+ s_start = int((limits[0]*1000 - 250)/2.5)
+ outfile.write('\n')
+ outfile.write(' ffu.wlinf = %.4ff;\n' % (limits[0]))
+ outfile.write(' ffu.wlsup = %.4ff;\n' % (limits[1]))
+ outfile.write(' int i = 0;\n')
+ outfile.write(' for(i = 0; i < %i; i++)\tffu.s[i] = 0;\n' % (s_start))
+ outfile.write(' for(i = 0; i < %i; i++)\tffu.s[%i+i] = sr[i];\n' % (len(filter_f), s_start))
+ outfile.write(' for(i = %i; i < 1501; i++)\tffu.s[i] = 0;\n' % (s_start + len(filter_f)))
+ outfile.write('}\n')
+ else: # more than 1 band
+ # writing bands
+ outfile.write(' /* %s of %s */\n' % (bands[b], sensor))
+ outfile.write(' static const float sr%i[%i] = {\n' % (b+1,len(filter_f[b])))
+ filter_text = pretty_print(filter_f[b])
+ outfile.write(filter_text+'\n };\n\t\n')
+ # writing band limits
+ inf = ", ".join(["%.3f" % i[0] for i in limits])
+ sup = ", ".join(["%.3f" % i[1] for i in limits])
+ outfile.write(' static const float wli[%i] = {%s};\n' % (len(bands), inf))
+ outfile.write(' static const float wls[%i] = {%s};\n' % (len(bands), sup))
+ outfile.write(' ffu.wlinf = (float)wli[iwa-1];\n')
+ outfile.write(' ffu.wlsup = (float)wls[iwa-1];\n\n')
+ outfile.write(' int i;\n')
+ outfile.write(' for(i = 0; i < 1501; i++) ffu.s[i] = 0;\n\n')
+ outfile.write(' switch(iwa)\n {\n')
+ # now start of case part...
+ s_start = int((limits[b][0]*1000 - 250)/2.5)
+ outfile.write(' case %i: for(i = 0; i < %i; i++) ffu.s[%i+i] = sr%i[i];\n' % ((b+1), len(filter_f[b]), s_start, (b+1)))
+ outfile.write(' break;\n')
+ outfile.write(' }\n}\n')
+ return
+def main():
+ """ control function """
+ inputfile = sys.argv[1]
+ # getting sensor name from full csv file name
+ sensor = os.path.splitext(os.path.basename(inputfile))[0]
+ print "Getting sensor name from csv file: %s" % (sensor)
+ # getting data from file
+ bands, values = read_input(inputfile)
+ # writing file in same folder of input file
+ write_cpp(bands, values, sensor, os.path.dirname(inputfile))
+ print "Filter function written to %s" % (sensor+"_cpp_template.txt")
+ print "Please check file for possible errors before inserting into IWave.cpp"
+ print "Don't forget to add necessary data to IWave.h"
+ return
+if __name__ == '__main__':
+ if len(sys.argv) == 1:
+ usage()
+ sys.exit()
+ else:
+ main()
Property changes on: grass/branches/releasebranch_6_4/imagery/i.atcorr/create_iwave.py
___________________________________________________________________
Added: svn:executable
