[GRASS-SVN] r43531 - grass/branches/develbranch_6/raster/r.out.mpeg
svn_grass at osgeo.org
Sun Sep 19 21:11:59 EDT 2010
Author: hamish
Date: 2010-09-20 01:11:59 +0000 (Mon, 20 Sep 2010)
New Revision: 43531
grass/branches/develbranch_6/raster/r.out.mpeg/main.c
grass/branches/develbranch_6/raster/r.out.mpeg/write.c
remove some unixisms
Modified: grass/branches/develbranch_6/raster/r.out.mpeg/main.c
--- grass/branches/develbranch_6/raster/r.out.mpeg/main.c 2010-09-20 00:55:02 UTC (rev 43530)
+++ grass/branches/develbranch_6/raster/r.out.mpeg/main.c 2010-09-20 01:11:59 UTC (rev 43531)
@@ -273,10 +273,13 @@
write_params(mpfilename, yfiles, outfile, cnt, quality, y_rows, y_cols,
0);
+/* FIXME: use G_spawn() as mpfilename may contain spaces */
+/* FIXME: redirect stderr to G_DEV_NULL work on wingrass? */
if (quiet)
- sprintf(cmd, "%s %s 2> /dev/null > /dev/null", encoder, mpfilename);
+ sprintf(cmd, "%s \"%s\" 2> %s > %s", encoder, mpfilename, G_DEV_NULL
+ G_DEV_NULL);
else
- sprintf(cmd, "%s %s", encoder, mpfilename);
+ sprintf(cmd, "%s \"%s\"", encoder, mpfilename);
if (0 != G_system(cmd))
G_warning(_("mpeg_encode ERROR"));
@@ -303,10 +306,13 @@
mpfilename = G_tempfile();
write_params(mpfilename, vfiles[0], outfile, frames, quality, 0, 0, 1);
if (quiet)
+ sprintf(cmd, "%s \"%s\" 2> %s > %s", encoder, mpfilename, G_DEV_NULL,
+ G_DEV_NULL);
else
@@ -335,6 +341,7 @@
mapset = G_mapset();
G__file_name(path, element, "", mapset);
+/* FIXME: rm UNIXisms (see g.[m]list for hints) */
if (access(path, 0) == 0) {
sprintf(cmd, "cd %s; \\ls %s >> %s 2> /dev/null",
path, wildarg, tfile);
@@ -361,8 +368,7 @@
*num = cnt;
- sprintf(cmd, "\\rm %s", tfile);
- G_system(cmd);
+ unlink(tfile);
G_free(tfile);
return (newfiles);
@@ -381,8 +387,8 @@
int i, j, k, numi, wildnum;
module = G_define_module();
- module->keywords = _("raster");
- module->description = _("Raster File Series to MPEG Conversion Program.");
+ module->keywords = _("raster, animation");
+ module->description = _("Raster File Series to MPEG Conversion.");
*numviews = *numframes = 0;
for (i = 0; i < MAXVIEWS; i++) {
@@ -421,12 +427,13 @@
conv = G_define_flag();
conv->key = 'c';
- conv->description =
- _("Convert on the fly, use less disk space\n\t(requires r.out.ppm with stdout option)");
+ conv->label = _("Convert on the fly, uses less disk space");
+ conv->description = _("(requires r.out.ppm with stdout option)");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
*convert = 0;
if (qt->answer)
quiet = 1;
@@ -469,6 +476,3 @@
Modified: grass/branches/develbranch_6/raster/r.out.mpeg/write.c
--- grass/branches/develbranch_6/raster/r.out.mpeg/write.c 2010-09-20 00:55:02 UTC (rev 43530)
+++ grass/branches/develbranch_6/raster/r.out.mpeg/write.c 2010-09-20 01:11:59 UTC (rev 43531)
@@ -326,18 +326,11 @@
void clean_files(char *file, char *files[], int num)
- char cmd[1000];
int i;
- sprintf(cmd, "\\rm %s", file);
- G_system(cmd);
+ unlink(file);
- for (i = 0; i < num; i++) {
- sprintf(cmd, "\\rm %s", files[i]);
- G_system(cmd);
+ for (i = 0; i < num; i++)
+ unlink(files[i]);
