[GRASS-SVN] r43532 - grass/branches/develbranch_6/lib/vector/Vlib
Mon Sep 20 04:02:51 EDT 2010
Author: mmetz
Date: 2010-09-20 08:02:51 +0000 (Mon, 20 Sep 2010)
New Revision: 43532
Added:
   grass/branches/develbranch_6/lib/vector/Vlib/merge_lines.c
add cleaning function for vector import
Added: grass/branches/develbranch_6/lib/vector/Vlib/merge_lines.c
--- grass/branches/develbranch_6/lib/vector/Vlib/merge_lines.c	                        (rev 0)
+++ grass/branches/develbranch_6/lib/vector/Vlib/merge_lines.c	2010-09-20 08:02:51 UTC (rev 43532)
@@ -0,0 +1,199 @@
+   \file merge_lines.c
+   \brief Vector library - clean geometry (merge lines/boundaries)
+   Higher level functions for reading/writing/manipulating vectors.
+   (C) 2001-2009 by the GRASS Development Team
+   This program is free software under the
+   GNU General Public License (>=v2).
+   Read the file COPYING that comes with GRASS
+   for details.
+   \author Markus Metz
+#include <grass/config.h>
+#include <stdlib.h>
+#include <math.h>
+#include <grass/gis.h>
+#include <grass/Vect.h>
+#include <grass/glocale.h>
+   \brief Merge lines or boundaries in vector map.
+   Merges lines specified by type in vector map.
+   Useful for generalization and smoothing.
+   Adjacent boundaries are merged as long as topology is maintained.
+   Adjacent lines are merged as long as there are exactly two different
+   lines connected at a given node.
+   Categories are added up when merging.
+   GV_BUILD_BASE as topo build level is sufficient, areas need not be built.
+   \param Map input vector map
+   \param type feature type
+   \param[out] Err vector map where merged lines/boundaries will be written or NULL
+   \param new_lines  pointer to where number of new lines/boundaries is stored or NULL
+   \return number of merged lines/boundaries
+int Vect_merge_lines(struct Map_info *Map, int type, int *new_lines,
+		     struct Map_info *Err)
+    int line, nlines, i, c, first, last, next_line, curr_line;
+    int merged = 0, newl = 0;
+    int next_node, direction, node_n_lines, same_type;
+    struct Plus_head *Plus;
+    struct ilist *List;
+    struct line_pnts *MPoints, *Points;
+    struct line_cats *MCats, *Cats;
+    struct P_line *Line;
+    if ((type & GV_BOUNDARY) && (type & GV_LINE)) {
+	G_warning
+	    ("Merging is done only with either lines or boundaries, not both types at the same time");
+	return 0;
+    if (!(type & GV_BOUNDARY) && !(type & GV_LINE)) {
+	G_warning
+	    ("Merging is done with lines or boundaries only, not with other types");
+	return 0;
+    Plus = &(Map->plus);
+    nlines = Vect_get_num_lines(Map);
+    Points = Vect_new_line_struct();
+    Cats = Vect_new_cats_struct();
+    MPoints = Vect_new_line_struct();
+    MCats = Vect_new_cats_struct();
+    List = Vect_new_list();
+    for (line = 1; line <= nlines; line++) {
+	G_percent(line, nlines, 2);
+	if (!Vect_line_alive(Map, line))
+	    continue;
+	Line = Plus->Line[line];
+	if (!(Line->type & type))
+	    continue;
+	/* special cases:
+	 *  - loop back to start boundary via several other boundaries
+	 *  - one boundary forming closed loop
+	 *  - node with 3 entries but only 2 boundaries, one of them connecting twice,
+	 *    the other one must then be topologically incorrect in case of boundary */
+	/* go backward as long as there is only one other line/boundary at the current node */
+	G_debug(3, "go backward");
+	next_node = Line->N1;
+	first = -line;
+	while (1) {
+	    node_n_lines = Vect_get_node_n_lines(Map, next_node);
+	    same_type = 0;
+	    next_line = first;
+	    for (i = 0; i < node_n_lines; i++) {
+		curr_line = Vect_get_node_line(Map, next_node, i);
+		if ((Plus->Line[abs(curr_line)]->type & type)) {
+		    same_type++;
+		    if (abs(curr_line) != abs(first))
+			next_line = curr_line;
+	    if (same_type == 2 && abs(next_line) != abs(first) &&
+		abs(next_line) != line) {
+		first = next_line;
+		if (first < 0)
+		    next_node = Plus->Line[-first]->N1;
+		else
+		    next_node = Plus->Line[first]->N2;
+	    else
+		break;
+	/* go forward as long as there is only one other line/boundary at the current node */
+	G_debug(3, "go forward");
+	/* reverse direction */
+	last = -first;
+	if (last < 0)
+	    next_node = Plus->Line[-last]->N1;
+	else
+	    next_node = Plus->Line[last]->N2;
+	Vect_reset_list(List);
+	while (1) {
+	    Vect_list_append(List, last);
+	    same_type = 0;
+	    next_line = last;
+		    same_type++;
+		    if (abs(curr_line) != abs(last))
+	    if (same_type == 2 && abs(next_line) != abs(last) &&
+		abs(next_line) != abs(first)) {
+		last = next_line;
+		if (last < 0)
+		else
+	    else
+		break;
+	/* merge lines */
+	if (List->n_values > 1) {
+	    G_debug(3, "merge %d lines", List->n_values);
+	    Vect_reset_line(MPoints);
+	    Vect_reset_cats(MCats);
+	    for (i = 0; i < List->n_values; i++) {
+		Vect_reset_line(Points);
+		Vect_reset_cats(Cats);
+		Vect_read_line(Map, Points, Cats, abs(List->value[i]));
+		direction = (List->value[i] < 0 ? GV_BACKWARD : GV_FORWARD);
+		Vect_append_points(MPoints, Points, direction);
+		MPoints->n_points--;
+		for (c = 0; c < Cats->n_cats; c++) {
+		    Vect_cat_set(MCats, Cats->field[c], Cats->cat[c]);
+		if (Err) {
+		    /* write out lines/boundaries to be merged */
+		    Vect_write_line(Err, type, Points, Cats);
+		Vect_delete_line(Map, abs(List->value[i]));
+	    MPoints->n_points++;
+	    Vect_write_line(Map, type, MPoints, MCats);
+	    merged += List->n_values;
+	    newl++;
+    G_verbose_message(_("%d boundaries merged"), merged);
+    G_verbose_message(_("%d new boundaries"), newl);
+    if (new_lines)
+	*new_lines = newl;
+    return merged;
Property changes on: grass/branches/develbranch_6/lib/vector/Vlib/merge_lines.c
___________________________________________________________________
Added: svn:keywords
   + Author Date Id
Added: svn:eol-style
   + native
