[GRASS-SVN] r43539 - grass/trunk/raster/r.surf.contour
svn_grass at osgeo.org
Mon Sep 20 13:03:03 EDT 2010
Author: mmetz
Date: 2010-09-20 17:03:02 +0000 (Mon, 20 Sep 2010)
New Revision: 43539
grass/trunk/raster/r.surf.contour/contour.h
grass/trunk/raster/r.surf.contour/find_con.c
grass/trunk/raster/r.surf.contour/main.c
grass/trunk/raster/r.surf.contour/read_cell.c
add fp and NULL (nodata) support
Modified: grass/trunk/raster/r.surf.contour/contour.h
--- grass/trunk/raster/r.surf.contour/contour.h 2010-09-20 17:01:22 UTC (rev 43538)
+++ grass/trunk/raster/r.surf.contour/contour.h 2010-09-20 17:03:02 UTC (rev 43539)
@@ -24,7 +24,7 @@
extern int maxr;
extern int array_size;
extern double i_val_l_f;
-extern CELL **con;
+extern DCELL **con;
extern FLAG *seen, *mask;
extern NODE *zero;
@@ -35,8 +35,8 @@
NODE *addpts(NODE *, int, int, int, int, int *);
/* find_con.c */
-int find_con(int, int, double *, double *, CELL *, CELL *);
+int find_con(int, int, double *, double *, DCELL *, DCELL *);
/* read_cell.c */
-CELL **read_cell(const char *);
-void free_cell(CELL **);
+DCELL **read_cell(const char *);
+void free_cell(DCELL **);
Modified: grass/trunk/raster/r.surf.contour/find_con.c
--- grass/trunk/raster/r.surf.contour/find_con.c 2010-09-20 17:01:22 UTC (rev 43538)
+++ grass/trunk/raster/r.surf.contour/find_con.c 2010-09-20 17:03:02 UTC (rev 43539)
@@ -1,15 +1,18 @@
#include <math.h>
#include "contour.h"
-int find_con(int r, int c, double *d1, double *d2, CELL * con1, CELL * con2)
+int find_con(int r, int c, double *d1, double *d2, DCELL * con1, DCELL * con2)
int ct, low_ct, node_ct;
int rr, cc, dor, doc;
double dd, shortest;
- CELL value;
+ DCELL value;
- *con1 = 0;
+/* *con1 = 0;
*con2 = 0;
+ Rast_set_d_null_value(con1, 1);
+ Rast_set_d_null_value(con2, 1);
*d1 = *d2 = 1.0;
shortest = nrows * ncols;
for (rr = minr; rr <= maxr; rr++) {
@@ -42,9 +45,9 @@
if (rr >= 0 && cc >= 0 && rr < nrows && cc < ncols
&& zero[ct].d < shortest && !flag_get(mask, rr, cc)) {
value = con[rr][cc];
- if (value == 0)
+ if (Rast_is_d_null_value(&value))
zero = addpts(zero, r, c, rr, cc, &node_ct);
- else if (*con1 == 0) {
+ else if (Rast_is_d_null_value(con1)) {
*con1 = value;
*d1 = MIN(dor, doc) * 1.414 + ABS(dor - doc);
shortest = *d1 * 2.0 * i_val_l_f;
@@ -56,7 +59,7 @@
shortest = dd * 2.0 * i_val_l_f;
- else if (*con2 == 0) {
+ else if (Rast_is_d_null_value(con2)) {
*con2 = value;
*d2 = MIN(dor, doc) * 1.414 + ABS(dor - doc);
shortest = *d2;
Modified: grass/trunk/raster/r.surf.contour/main.c
--- grass/trunk/raster/r.surf.contour/main.c 2010-09-20 17:01:22 UTC (rev 43538)
+++ grass/trunk/raster/r.surf.contour/main.c 2010-09-20 17:03:02 UTC (rev 43539)
@@ -36,19 +36,19 @@
int maxr;
int array_size;
double i_val_l_f;
-CELL **con;
+DCELL **con;
FLAG *seen, *mask;
NODE *zero;
int main(int argc, char *argv[])
int r, c;
- CELL con1, con2;
+ DCELL con1, con2;
double d1, d2;
- CELL *alt_row;
+ DCELL *alt_row;
const char *con_name, *alt_name;
int file_fd;
- CELL value;
+ DCELL value;
struct History history;
struct GModule *module;
struct Option *opt1, *opt2;
@@ -77,15 +77,15 @@
ncols = Rast_window_cols();
i_val_l_f = nrows + ncols;
con = read_cell(con_name);
- alt_row = (CELL *) G_malloc(ncols * sizeof(CELL));
+ alt_row = (DCELL *) G_malloc(ncols * sizeof(DCELL));
seen = flag_create(nrows, ncols);
mask = flag_create(nrows, ncols);
if (NULL != G_find_file("cell", "MASK", G_mapset())) {
file_fd = Rast_open_old("MASK", G_mapset());
for (r = 0; r < nrows; r++) {
- Rast_get_c_row_nomask(file_fd, alt_row, r);
+ Rast_get_d_row_nomask(file_fd, alt_row, r);
for (c = 0; c < ncols; c++)
- if (!alt_row[c])
+ if (Rast_is_d_null_value(&(alt_row[c])))
FLAG_SET(mask, r, c);
Rast_close(file_fd);
@@ -95,25 +95,25 @@
maxc = ncols - 1;
maxr = nrows - 1;
array_size = INIT_AR;
- file_fd = Rast_open_c_new(alt_name);
+ file_fd = Rast_open_new(alt_name, DCELL_TYPE);
G_percent(r, nrows, 1);
for (c = 0; c < ncols; c++) {
if (FLAG_GET(mask, r, c))
continue;
value = con[r][c];
- if (value != 0) {
+ if (!Rast_is_d_null_value(&value)) {
alt_row[c] = value;
continue;
find_con(r, c, &d1, &d2, &con1, &con2);
if (con2 > 0)
- alt_row[c] = (CELL) (d2 * con1 / (d1 + d2) +
- d1 * con2 / (d1 + d2) + 0.5);
+ alt_row[c] = (DCELL) (d2 * con1 / (d1 + d2) +
+ d1 * con2 / (d1 + d2) /* + 0.5 */);
else
alt_row[c] = con1;
- Rast_put_row(file_fd, alt_row, CELL_TYPE);
+ Rast_put_row(file_fd, alt_row, DCELL_TYPE);
G_percent(1, 1, 1);
Modified: grass/trunk/raster/r.surf.contour/read_cell.c
--- grass/trunk/raster/r.surf.contour/read_cell.c 2010-09-20 17:01:22 UTC (rev 43538)
+++ grass/trunk/raster/r.surf.contour/read_cell.c 2010-09-20 17:03:02 UTC (rev 43539)
@@ -2,23 +2,23 @@
#include <grass/raster.h>
#include <grass/glocale.h>
-CELL **read_cell(const char *name)
+DCELL **read_cell(const char *name)
int nrows = Rast_window_rows();
int ncols = Rast_window_cols();
- CELL *buf, **idx;
+ DCELL *buf, **idx;
int fd;
int row;
fd = Rast_open_old(name, "");
- buf = G_malloc((size_t) nrows * ncols * sizeof(CELL));
- idx = G_malloc(nrows * sizeof(CELL *));
+ buf = G_malloc((size_t) nrows * ncols * sizeof(DCELL));
+ idx = G_malloc(nrows * sizeof(DCELL *));
for (row = 0; row < nrows; row++) {
idx[row] = &buf[row * ncols];
- Rast_get_c_row(fd, idx[row], row);
+ Rast_get_d_row(fd, idx[row], row);
Rast_close(fd);
@@ -26,7 +26,7 @@
return idx;
-void free_cell(CELL **idx)
+void free_cell(DCELL **idx)
G_free(idx[0]);
G_free(idx);
