[GRASS-SVN] r43540 - in grass/branches/releasebranch_6_4: include lib/stats raster/r.neighbors raster/r.resamp.stats raster/r.series
Mon Sep 20 13:04:26 EDT 2010
Author: neteler
Date: 2010-09-20 17:04:26 +0000 (Mon, 20 Sep 2010)
New Revision: 43540
Added:
   grass/branches/releasebranch_6_4/lib/stats/c_thresh.c
   grass/branches/releasebranch_6_4/include/stats.h
   grass/branches/releasebranch_6_4/lib/stats/c_ave.c
   grass/branches/releasebranch_6_4/lib/stats/c_count.c
   grass/branches/releasebranch_6_4/lib/stats/c_divr.c
   grass/branches/releasebranch_6_4/lib/stats/c_intr.c
   grass/branches/releasebranch_6_4/lib/stats/c_kurt.c
   grass/branches/releasebranch_6_4/lib/stats/c_max.c
   grass/branches/releasebranch_6_4/lib/stats/c_maxx.c
   grass/branches/releasebranch_6_4/lib/stats/c_median.c
   grass/branches/releasebranch_6_4/lib/stats/c_min.c
   grass/branches/releasebranch_6_4/lib/stats/c_minx.c
   grass/branches/releasebranch_6_4/lib/stats/c_mode.c
   grass/branches/releasebranch_6_4/lib/stats/c_percentile.c
   grass/branches/releasebranch_6_4/lib/stats/c_range.c
   grass/branches/releasebranch_6_4/lib/stats/c_reg.c
   grass/branches/releasebranch_6_4/lib/stats/c_skew.c
   grass/branches/releasebranch_6_4/lib/stats/c_stddev.c
   grass/branches/releasebranch_6_4/lib/stats/c_sum.c
   grass/branches/releasebranch_6_4/lib/stats/c_var.c
   grass/branches/releasebranch_6_4/raster/r.neighbors/main.c
   grass/branches/releasebranch_6_4/raster/r.resamp.stats/main.c
   grass/branches/releasebranch_6_4/raster/r.series/main.c
backport: threshold and quantiles for r.series
Modified: grass/branches/releasebranch_6_4/include/stats.h
--- grass/branches/releasebranch_6_4/include/stats.h	2010-09-20 17:03:02 UTC (rev 43539)
+++ grass/branches/releasebranch_6_4/include/stats.h	2010-09-20 17:04:26 UTC (rev 43540)
@@ -4,8 +4,8 @@
 #include <grass/gis.h>
-typedef void stat_func(DCELL *, DCELL *, int);
-typedef void stat_func_w(DCELL *, DCELL(*)[2], int);
+typedef void stat_func(DCELL *, DCELL *, int, const void *);
+typedef void stat_func_w(DCELL *, DCELL(*)[2], int, const void *);
 extern stat_func c_ave;
 extern stat_func c_count;
@@ -19,6 +19,7 @@
 extern stat_func c_mode;
 extern stat_func c_stddev;
 extern stat_func c_sum;
+extern stat_func c_thresh;
 extern stat_func c_var;
 extern stat_func c_range;
 extern stat_func c_reg_m;
@@ -27,6 +28,7 @@
 extern stat_func c_quart1;
 extern stat_func c_quart3;
 extern stat_func c_perc90;
+extern stat_func c_quant;
 extern stat_func c_skew;
 extern stat_func c_kurt;
Modified: grass/branches/releasebranch_6_4/lib/stats/c_ave.c
--- grass/branches/releasebranch_6_4/lib/stats/c_ave.c	2010-09-20 17:03:02 UTC (rev 43539)
+++ grass/branches/releasebranch_6_4/lib/stats/c_ave.c	2010-09-20 17:04:26 UTC (rev 43540)
@@ -1,6 +1,6 @@
-void c_ave(DCELL * result, DCELL * values, int n)
+void c_ave(DCELL * result, DCELL * values, int n, const void *closure)
     DCELL sum;
     int count;
@@ -23,7 +23,7 @@
 	*result = sum / count;
-void w_ave(DCELL * result, DCELL(*values)[2], int n)
+void w_ave(DCELL * result, DCELL(*values)[2], int n, const void *closure)
     DCELL sum;
     DCELL count;
Modified: grass/branches/releasebranch_6_4/lib/stats/c_count.c
--- grass/branches/releasebranch_6_4/lib/stats/c_count.c	2010-09-20 17:03:02 UTC (rev 43539)
+++ grass/branches/releasebranch_6_4/lib/stats/c_count.c	2010-09-20 17:04:26 UTC (rev 43540)
@@ -1,6 +1,6 @@
-void c_count(DCELL * result, DCELL * values, int n)
+void c_count(DCELL * result, DCELL * values, int n, const void *closure)
     int count;
     int i;
@@ -14,7 +14,7 @@
     *result = count;
-void w_count(DCELL * result, DCELL(*values)[2], int n)
+void w_count(DCELL * result, DCELL(*values)[2], int n, const void *closure)
     DCELL count;
     int i;
Modified: grass/branches/releasebranch_6_4/lib/stats/c_divr.c
--- grass/branches/releasebranch_6_4/lib/stats/c_divr.c	2010-09-20 17:03:02 UTC (rev 43539)
+++ grass/branches/releasebranch_6_4/lib/stats/c_divr.c	2010-09-20 17:04:26 UTC (rev 43540)
@@ -1,7 +1,7 @@
 #include <grass/stats.h>
-void c_divr(DCELL * result, DCELL * values, int n)
+void c_divr(DCELL * result, DCELL * values, int n, const void *closure)
     int count;
     DCELL prev;
Modified: grass/branches/releasebranch_6_4/lib/stats/c_intr.c
--- grass/branches/releasebranch_6_4/lib/stats/c_intr.c	2010-09-20 17:03:02 UTC (rev 43539)
+++ grass/branches/releasebranch_6_4/lib/stats/c_intr.c	2010-09-20 17:04:26 UTC (rev 43540)
@@ -1,7 +1,7 @@
-void c_intr(DCELL * result, DCELL * values, int n)
+void c_intr(DCELL * result, DCELL * values, int n, const void *closure)
     DCELL center;
     int count;
Modified: grass/branches/releasebranch_6_4/lib/stats/c_kurt.c
--- grass/branches/releasebranch_6_4/lib/stats/c_kurt.c	2010-09-20 17:03:02 UTC (rev 43539)
+++ grass/branches/releasebranch_6_4/lib/stats/c_kurt.c	2010-09-20 17:04:26 UTC (rev 43540)
@@ -1,6 +1,6 @@
-void c_kurt(DCELL * result, DCELL * values, int n)
+void c_kurt(DCELL * result, DCELL * values, int n, const void *closure)
     DCELL sum, ave, sumsq, sumqt, var;
     int count;
@@ -42,7 +42,7 @@
     *result = sumqt / (count * var * var) - 3;
-void w_kurt(DCELL * result, DCELL(*values)[2], int n)
+void w_kurt(DCELL * result, DCELL(*values)[2], int n, const void *closure)
     int count;
Modified: grass/branches/releasebranch_6_4/lib/stats/c_max.c
--- grass/branches/releasebranch_6_4/lib/stats/c_max.c	2010-09-20 17:03:02 UTC (rev 43539)
+++ grass/branches/releasebranch_6_4/lib/stats/c_max.c	2010-09-20 17:04:26 UTC (rev 43540)
@@ -1,6 +1,6 @@
-void c_max(DCELL * result, DCELL * values, int n)
+void c_max(DCELL * result, DCELL * values, int n, const void *closure)
     DCELL max;
     int i;
@@ -20,3 +20,24 @@
     else
 	*result = max;
+void w_max(DCELL * result, DCELL(*values)[2], int n, const void *closure)
+    DCELL max;
+    int i;
+    G_set_d_null_value(&max, 1);
+    for (i = 0; i < n; i++) {
+	if (G_is_d_null_value(&values[i][0]))
+	    continue;
+	if (G_is_d_null_value(&max) || max < values[i][0])
+	    max = values[i][0];
+    if (G_is_d_null_value(&max))
+	G_set_d_null_value(result, 1);
+    else
+	*result = max;
Modified: grass/branches/releasebranch_6_4/lib/stats/c_maxx.c
--- grass/branches/releasebranch_6_4/lib/stats/c_maxx.c	2010-09-20 17:03:02 UTC (rev 43539)
+++ grass/branches/releasebranch_6_4/lib/stats/c_maxx.c	2010-09-20 17:04:26 UTC (rev 43540)
@@ -1,6 +1,6 @@
-void c_maxx(DCELL * result, DCELL * values, int n)
+void c_maxx(DCELL * result, DCELL * values, int n, const void *closure)
     DCELL max, maxx;
     int i;
Modified: grass/branches/releasebranch_6_4/lib/stats/c_median.c
--- grass/branches/releasebranch_6_4/lib/stats/c_median.c	2010-09-20 17:03:02 UTC (rev 43539)
+++ grass/branches/releasebranch_6_4/lib/stats/c_median.c	2010-09-20 17:04:26 UTC (rev 43540)
@@ -1,7 +1,7 @@
-void c_median(DCELL * result, DCELL * values, int n)
+void c_median(DCELL * result, DCELL * values, int n, const void *closure)
     n = sort_cell(values, n);
@@ -11,7 +11,7 @@
 	*result = (values[(n - 1) / 2] + values[n / 2]) / 2;
-void w_median(DCELL * result, DCELL(*values)[2], int n)
+void w_median(DCELL * result, DCELL(*values)[2], int n, const void *closure)
     DCELL total;
     int i;
Modified: grass/branches/releasebranch_6_4/lib/stats/c_min.c
--- grass/branches/releasebranch_6_4/lib/stats/c_min.c	2010-09-20 17:03:02 UTC (rev 43539)
+++ grass/branches/releasebranch_6_4/lib/stats/c_min.c	2010-09-20 17:04:26 UTC (rev 43540)
@@ -1,6 +1,6 @@
-void c_min(DCELL * result, DCELL * values, int n)
+void c_min(DCELL * result, DCELL * values, int n, const void *closure)
     DCELL min;
     int i;
@@ -20,3 +20,24 @@
     else
 	*result = min;
+void w_min(DCELL * result, DCELL(*values)[2], int n, const void *closure)
+    DCELL min;
+    int i;
+    G_set_d_null_value(&min, 1);
+	    continue;
+	if (G_is_d_null_value(&min) || min > values[i][0])
+	    min = values[i][0];
+    if (G_is_d_null_value(&min))
+    else
+	*result = min;
Modified: grass/branches/releasebranch_6_4/lib/stats/c_minx.c
--- grass/branches/releasebranch_6_4/lib/stats/c_minx.c	2010-09-20 17:03:02 UTC (rev 43539)
+++ grass/branches/releasebranch_6_4/lib/stats/c_minx.c	2010-09-20 17:04:26 UTC (rev 43540)
@@ -1,7 +1,7 @@
-void c_minx(DCELL * result, DCELL * values, int n)
+void c_minx(DCELL * result, DCELL * values, int n, const void *closure)
     DCELL min, minx;
     int i;
Modified: grass/branches/releasebranch_6_4/lib/stats/c_mode.c
--- grass/branches/releasebranch_6_4/lib/stats/c_mode.c	2010-09-20 17:03:02 UTC (rev 43539)
+++ grass/branches/releasebranch_6_4/lib/stats/c_mode.c	2010-09-20 17:04:26 UTC (rev 43540)
@@ -1,7 +1,7 @@
-void c_mode(DCELL * result, DCELL * values, int n)
+void c_mode(DCELL * result, DCELL * values, int n, const void *closure)
     DCELL mode;
     int max;
@@ -34,7 +34,7 @@
 	*result = mode;
-void w_mode(DCELL * result, DCELL(*values)[2], int n)
+void w_mode(DCELL * result, DCELL(*values)[2], int n, const void *closure)
     DCELL mode;
     DCELL max;
Modified: grass/branches/releasebranch_6_4/lib/stats/c_percentile.c
--- grass/branches/releasebranch_6_4/lib/stats/c_percentile.c	2010-09-20 17:03:02 UTC (rev 43539)
+++ grass/branches/releasebranch_6_4/lib/stats/c_percentile.c	2010-09-20 17:04:26 UTC (rev 43540)
@@ -1,9 +1,11 @@
 #include <math.h>
-static void percentile(DCELL * result, DCELL * values, int n, double percent)
+void c_quant(DCELL * result, DCELL * values, int n, const void *closure)
+    double quant = *(const double *)closure;
     double k;
     int i0, i1;
@@ -14,7 +16,7 @@
 	return;
-    k = n * percent / 100;
+    k = n * quant;
     i0 = (int)floor(k);
     i1 = (int)ceil(k);
@@ -23,24 +25,27 @@
 	: values[i0] * (i1 - k) + values[i1] * (k - i0);
-void c_quart1(DCELL * result, DCELL * values, int n)
+void c_quart1(DCELL * result, DCELL * values, int n, const void *closure)
-    percentile(result, values, n, 25.0);
+    static const double q = 0.25;
+    c_quant(result, values, n, &q);
-void c_quart3(DCELL * result, DCELL * values, int n)
+void c_quart3(DCELL * result, DCELL * values, int n, const void *closure)
-    percentile(result, values, n, 75.0);
+    static const double q = 0.75;
-void c_perc90(DCELL * result, DCELL * values, int n)
+void c_perc90(DCELL * result, DCELL * values, int n, const void *closure)
-    percentile(result, values, n, 90.0);
+    static const double q = 0.90;
-static void percentile_w(DCELL * result, DCELL(*values)[2], int n,
-			 double percent)
+void w_quant(DCELL * result, DCELL(*values)[2], int n, const void *closure)
     DCELL total;
     int i;
     DCELL k;
@@ -59,24 +64,27 @@
     k = 0.0;
 	k += values[i][1];
-	if (k >= total * percent / 100)
+	if (k >= total * quant)
 	    break;
     *result = values[i][0];
-void w_quart1(DCELL * result, DCELL(*values)[2], int n)
+void w_quart1(DCELL * result, DCELL(*values)[2], int n, const void *closure)
-    percentile_w(result, values, n, 25.0);
+    w_quant(result, values, n, &q);
-void w_quart3(DCELL * result, DCELL(*values)[2], int n)
+void w_quart3(DCELL * result, DCELL(*values)[2], int n, const void *closure)
-    percentile_w(result, values, n, 75.0);
-void w_perc90(DCELL * result, DCELL(*values)[2], int n)
+void w_perc90(DCELL * result, DCELL(*values)[2], int n, const void *closure)
-    percentile_w(result, values, n, 90.0);
Modified: grass/branches/releasebranch_6_4/lib/stats/c_range.c
--- grass/branches/releasebranch_6_4/lib/stats/c_range.c	2010-09-20 17:03:02 UTC (rev 43539)
+++ grass/branches/releasebranch_6_4/lib/stats/c_range.c	2010-09-20 17:04:26 UTC (rev 43540)
@@ -1,6 +1,6 @@
-void c_range(DCELL * result, DCELL * values, int n)
+void c_range(DCELL * result, DCELL * values, int n, const void *closure)
     DCELL min, max;
     int i;
Modified: grass/branches/releasebranch_6_4/lib/stats/c_reg.c
--- grass/branches/releasebranch_6_4/lib/stats/c_reg.c	2010-09-20 17:03:02 UTC (rev 43539)
+++ grass/branches/releasebranch_6_4/lib/stats/c_reg.c	2010-09-20 17:04:26 UTC (rev 43540)
@@ -73,17 +73,17 @@
-void c_reg_m(DCELL * result, DCELL * values, int n)
+void c_reg_m(DCELL * result, DCELL * values, int n, const void *closure)
     regression(result, values, n, REGRESSION_SLOPE);
-void c_reg_c(DCELL * result, DCELL * values, int n)
+void c_reg_c(DCELL * result, DCELL * values, int n, const void *closure)
     regression(result, values, n, REGRESSION_OFFSET);
-void c_reg_r2(DCELL * result, DCELL * values, int n)
+void c_reg_r2(DCELL * result, DCELL * values, int n, const void *closure)
     regression(result, values, n, REGRESSION_COEFF_DET);
@@ -157,17 +157,17 @@
-void w_reg_m(DCELL * result, DCELL(*values)[2], int n)
+void w_reg_m(DCELL * result, DCELL(*values)[2], int n, const void *closure)
     regression_w(result, values, n, REGRESSION_SLOPE);
-void w_reg_c(DCELL * result, DCELL(*values)[2], int n)
+void w_reg_c(DCELL * result, DCELL(*values)[2], int n, const void *closure)
     regression_w(result, values, n, REGRESSION_OFFSET);
-void w_reg_r2(DCELL * result, DCELL(*values)[2], int n)
+void w_reg_r2(DCELL * result, DCELL(*values)[2], int n, const void *closure)
     regression_w(result, values, n, REGRESSION_COEFF_DET);
Modified: grass/branches/releasebranch_6_4/lib/stats/c_skew.c
--- grass/branches/releasebranch_6_4/lib/stats/c_skew.c	2010-09-20 17:03:02 UTC (rev 43539)
+++ grass/branches/releasebranch_6_4/lib/stats/c_skew.c	2010-09-20 17:04:26 UTC (rev 43540)
@@ -1,7 +1,7 @@
 #include <math.h>
-void c_skew(DCELL * result, DCELL * values, int n)
+void c_skew(DCELL * result, DCELL * values, int n, const void *closure)
     DCELL sum, ave, sumsq, sumcb, sdev;
     int count;
@@ -43,7 +43,7 @@
     *result = sumcb / (count * sdev * sdev * sdev);
-void w_skew(DCELL * result, DCELL(*values)[2], int n)
+void w_skew(DCELL * result, DCELL(*values)[2], int n, const void *closure)
     int count;
Modified: grass/branches/releasebranch_6_4/lib/stats/c_stddev.c
--- grass/branches/releasebranch_6_4/lib/stats/c_stddev.c	2010-09-20 17:03:02 UTC (rev 43539)
+++ grass/branches/releasebranch_6_4/lib/stats/c_stddev.c	2010-09-20 17:04:26 UTC (rev 43540)
@@ -2,11 +2,11 @@
-void c_stddev(DCELL * result, DCELL * values, int n)
+void c_stddev(DCELL * result, DCELL * values, int n, const void *closure)
     DCELL var;
-    c_var(&var, values, n);
+    c_var(&var, values, n, closure);
     if (G_is_d_null_value(&var))
@@ -14,11 +14,11 @@
 	*result = sqrt(var);
-void w_stddev(DCELL * result, DCELL(*values)[2], int n)
+void w_stddev(DCELL * result, DCELL(*values)[2], int n, const void *closure)
     DCELL var;
-    w_var(&var, values, n);
+    w_var(&var, values, n, closure);
Modified: grass/branches/releasebranch_6_4/lib/stats/c_sum.c
--- grass/branches/releasebranch_6_4/lib/stats/c_sum.c	2010-09-20 17:03:02 UTC (rev 43539)
+++ grass/branches/releasebranch_6_4/lib/stats/c_sum.c	2010-09-20 17:04:26 UTC (rev 43540)
@@ -1,6 +1,6 @@
-void c_sum(DCELL * result, DCELL * values, int n)
+void c_sum(DCELL * result, DCELL * values, int n, const void *closure)
     DCELL sum;
     int count;
@@ -23,7 +23,7 @@
 	*result = sum;
-void w_sum(DCELL * result, DCELL(*values)[2], int n)
+void w_sum(DCELL * result, DCELL(*values)[2], int n, const void *closure)
     DCELL sum;
     DCELL count;
Added: grass/branches/releasebranch_6_4/lib/stats/c_thresh.c
--- grass/branches/releasebranch_6_4/lib/stats/c_thresh.c	                        (rev 0)
+++ grass/branches/releasebranch_6_4/lib/stats/c_thresh.c	2010-09-20 17:04:26 UTC (rev 43540)
@@ -0,0 +1,36 @@
+#include <grass/gis.h>
+#include <math.h>
+void c_thresh(DCELL * result, DCELL * values, int n, const void *closure)
+    DCELL thresh, threshx;
+    double tval = *(const double *)closure;
+    double epsilon = GRASS_EPSILON;
+    int i;
+    G_set_d_null_value(&thresh, 1);
+    G_set_d_null_value(&threshx, 1);
+	/* already found */
+	if (! G_is_d_null_value(&threshx))
+	    continue;
+	if (G_is_d_null_value(&values[i]))
+	    continue;
+	G_debug(2, "values[%d] %f, tval %f", i, values[i], tval);
+	/* for GDD */
+	epsilon = 10.;
+	if (fabs(tval - values[i]) < epsilon ) {
+	    thresh = values[i];
+	    threshx = i + 1;
+	    G_debug(2, "values[%d] %f, thresh %f, threshx %f, diff %f", i, values[i], thresh, threshx, tval - values[i]);
+    if (G_is_d_null_value(&threshx))
+    else
+	*result = threshx;
Property changes on: grass/branches/releasebranch_6_4/lib/stats/c_thresh.c
___________________________________________________________________
Added: svn:eol-style
   + native
Modified: grass/branches/releasebranch_6_4/lib/stats/c_var.c
--- grass/branches/releasebranch_6_4/lib/stats/c_var.c	2010-09-20 17:03:02 UTC (rev 43539)
+++ grass/branches/releasebranch_6_4/lib/stats/c_var.c	2010-09-20 17:04:26 UTC (rev 43540)
@@ -1,6 +1,6 @@
-void c_var(DCELL * result, DCELL * values, int n)
+void c_var(DCELL * result, DCELL * values, int n, const void *closure)
     DCELL sum, ave, sumsq;
     int count;
@@ -39,7 +39,7 @@
     *result = sumsq / count;
-void w_var(DCELL * result, DCELL(*values)[2], int n)
+void w_var(DCELL * result, DCELL(*values)[2], int n, const void *closure)
     int count;
Modified: grass/branches/releasebranch_6_4/raster/r.neighbors/main.c
--- grass/branches/releasebranch_6_4/raster/r.neighbors/main.c	2010-09-20 17:03:02 UTC (rev 43539)
+++ grass/branches/releasebranch_6_4/raster/r.neighbors/main.c	2010-09-20 17:04:26 UTC (rev 43540)
@@ -302,9 +302,9 @@
 		G_set_d_null_value(rp, 1);
 	    else {
 		if (newvalue_w)
-		    newvalue_w(rp, values_w, n);
+		    newvalue_w(rp, values_w, n, NULL);
 		else
-		    newvalue(rp, values, n);
+		    newvalue(rp, values, n, NULL);
 		if (half && !G_is_d_null_value(rp))
 		    *rp += 0.5;
Modified: grass/branches/releasebranch_6_4/raster/r.resamp.stats/main.c
--- grass/branches/releasebranch_6_4/raster/r.resamp.stats/main.c	2010-09-20 17:03:02 UTC (rev 43539)
+++ grass/branches/releasebranch_6_4/raster/r.resamp.stats/main.c	2010-09-20 17:04:26 UTC (rev 43540)
@@ -38,7 +38,7 @@
     {c_sum,    w_sum,    "sum",      "sum of values"},
     {c_var,    w_var,    "variance", "variance value"},
     {c_stddev, w_stddev, "stddev",   "standard deviation"},
-    {NULL, NULL, NULL}
+    {NULL, NULL, NULL, NULL}
 static char *build_method_list(void)
@@ -141,7 +141,7 @@
 	    if (null && nulls)
 		G_set_d_null_value(&outbuf[col], 1);
 	    else
-		(*method_fn) (&outbuf[col], values, n);
+		(*method_fn) (&outbuf[col], values, n, NULL);
 	G_set_window(&dst_w);
@@ -227,7 +227,7 @@
 	    if (null && nulls)
 	    else
Modified: grass/branches/releasebranch_6_4/raster/r.series/main.c
--- grass/branches/releasebranch_6_4/raster/r.series/main.c	2010-09-20 17:03:02 UTC (rev 43539)
+++ grass/branches/releasebranch_6_4/raster/r.series/main.c	2010-09-20 17:04:26 UTC (rev 43540)
@@ -3,7 +3,7 @@
  * MODULE:       r.series
  * AUTHOR(S):    Glynn Clements <glynn gclements.plus.com> (original contributor)
- *               Hamish Bowman <hamish_nospam yahoo.com>, Jachym Cepicky <jachym les-ejk.cz>,
+ *               Hamish Bowman <hamish_b yahoo.com>, Jachym Cepicky <jachym les-ejk.cz>,
  *               Martin Wegmann <wegmann biozentrum.uni-wuerzburg.de>
  * PURPOSE:
  * COPYRIGHT:    (C) 2002-2008 by the GRASS Development Team
@@ -39,6 +39,7 @@
     {c_stddev, 0, "stddev",     "standard deviation"},
     {c_range,  0, "range",      "range of values"},
     {c_sum,    0, "sum",        "sum of values"},
+    {c_thresh, 1, "threshold",  "threshold value"},
     {c_var,    0, "variance",   "statistical variance"},
     {c_divr,   1, "diversity",  "number of different values"},
     {c_reg_m,  0, "slope",      "linear regression slope"},
@@ -47,6 +48,7 @@
     {c_quart1, 0, "quart1",     "first quartile"},
     {c_quart3, 0, "quart3",     "third quartile"},
     {c_perc90, 0, "perc90",     "ninetieth percentile"},
+    {c_quant,  0, "quantile",   "arbitrary quantile"},
     {c_skew,   0, "skewness",   "skewness"},
     {c_kurt,   0, "kurtosis",   "kurtosis"},
     {NULL,     0, NULL,         NULL}
@@ -65,6 +67,8 @@
     int fd;
     DCELL *buf;
     stat_func *method_fn;
+    double quantile;
+    double threshold;
@@ -104,7 +108,7 @@
     struct GModule *module;
     struct
-	struct Option *input, *output, *method, *range;
+	struct Option *input, *output, *method, *quantile, *threshold, *range;
     } parm;
     struct
@@ -145,6 +149,21 @@
     parm.method->description = _("Aggregate operation");
     parm.method->multiple = YES;
+    parm.quantile = G_define_option();
+    parm.quantile->key = "quantile";
+    parm.quantile->type = TYPE_DOUBLE;
+    parm.quantile->required = NO;
+    parm.quantile->description = _("Quantile to calculate for method=quantile");
+    parm.quantile->options = "0.0-1.0";
+    parm.quantile->multiple = YES;
+    parm.threshold = G_define_option();
+    parm.threshold->key = "threshold";
+    parm.threshold->type = TYPE_DOUBLE;
+    parm.threshold->required = NO;
+    parm.threshold->description = _("Threshold to calculate for method=threshold");
+    parm.threshold->multiple = YES;
     /* please, remove before GRASS 7 released */
     flag.quiet = G_define_flag();
     flag.quiet->key = 'q';
@@ -218,6 +237,12 @@
 	out->name = output_name;
 	out->method_fn = menu[method].method;
+	out->quantile = (parm.quantile->answer && parm.quantile->answers[i])
+	    ? atof(parm.quantile->answers[i])
+	    : 0;
+	out->threshold = (parm.threshold->answer && parm.threshold->answers[i])
+	    ? atof(parm.threshold->answers[i])
+	    : 0;
 	out->buf = G_allocate_d_raster_buf();
 	out->fd = G_open_raster_new(
 	    output_name, menu[method].is_int ? CELL_TYPE : DCELL_TYPE);
@@ -264,7 +289,7 @@
 		    G_set_d_null_value(&out->buf[col], 1);
 		else {
 		    memcpy(values_tmp, values, num_inputs * sizeof(DCELL));
-		    (*out->method_fn)(&out->buf[col], values_tmp, num_inputs);
+		    (*out->method_fn)(&out->buf[col], values_tmp, num_inputs, &out->threshold);
