[GRASS-SVN] r43671 - grass/trunk/imagery/i.atcorr
svn_grass at osgeo.org
Fri Sep 24 09:41:30 EDT 2010
Author: neteler
Date: 2010-09-24 13:41:30 +0000 (Fri, 24 Sep 2010)
New Revision: 43671
grass/trunk/imagery/i.atcorr/i.atcorr.html
Example corrections
Modified: grass/trunk/imagery/i.atcorr/i.atcorr.html
--- grass/trunk/imagery/i.atcorr/i.atcorr.html 2010-09-24 13:40:37 UTC (rev 43670)
+++ grass/trunk/imagery/i.atcorr/i.atcorr.html 2010-09-24 13:41:30 UTC (rev 43671)
@@ -27,12 +27,15 @@
reflectance.
<p>
-An example 6s parameters <em>icnd</em> file for <b>i.atcorr</b>:
+Note that the satellite overpass time has to be specified in Greenwich Mean Time (GMT).
<p>
+An example 6S parameters <em>icnd</em> file for <b>i.atcorr</b>:
+<p>
<div class="code"><pre>
8 - geometrical conditions=Landsat ETM+
-2 19 13.00 -47.410 -20.234 - month day hh.ddd longitude latitude ("hh.ddd" is a decimal hour GMT)
+2 19 13.00 -47.410 -20.234 - month day hh.ddd longitude latitude ("hh.ddd" is in decimal hours GMT)
1 - atmospheric mode=tropical
1 - aerosols model=continental
15 - visibility [km] (aerosol model concentration)
@@ -532,38 +535,64 @@
<h2>EXAMPLES</h2>
-North Carolina sample dataset: Atmospheric correction of a LANDSAT-7 channel:
+<b>Atmospheric correction of a LANDSAT-7 channel</b>
+<p>
+The example is based on the North Carolina sample dataset (GMT -5 hours).
+First we set the computational region to the satellite map, e.g. channel 4:
g.region rast=lsat7_2002_40 -p
+</pre></div>
-# check metadata for sun position (use to verify overpass time with i.atcorr output):
+It is important to verify the available metadata for the sun position which
+has to be defined for the atmospheric correction. An option is to check the
+satellite overpass time with sun position as reported in
+<a href="ftp://ftp.glcf.umiacs.umd.edu/glcf/Landsat/WRS2/p016/r035/p016r035_7x20020524.ETM-EarthSat-Orthorectified/p016r035_7x20020524.met">metadata</a>. For the North Carolina sample dataset, they have also been
+stored for each channel and can be retrieved like this:
+<div class="code"><pre>
r.info lsat7_2002_40
+</pre></div>
+In this case, we have: SUN_AZIMUTH = 120.8810347, SUN_ELEVATION = 64.7730999.
+<p>
+If the sun position metadata are unavailable, we can also calculate them from the
+overpass time as follows (r.sunmask uses <a href="http://www.nrel.gov/midc/solpos/solpos.html">SOLPOS</a>):
+r.sunmask -s elev=elevation out=dummy year=2002 month=5 day=24 hour=10 min=42 sec=7 timezone=-5
+# .. reports: sun azimuth: 121.342461, sun angle above horz.(refraction corrected): 65.396652
+</pre></div>
+If the overpass time is unknown, use the <a href="http://www-air.larc.nasa.gov/tools/predict.htm">Satellite Overpass Predictor</a>.
# using an integer DEM greatly accelerates the i.atcorr computations
r.mapcalc "elev_int = round(elevation)"
# find mean elevation (target above sea level, used as initialization value in control file)
r.univar elev_int
+</pre></div>
-# check satellite overpass time with sun position reported in <a href="ftp://ftp.glcf.umiacs.umd.edu/glcf/Landsat/WRS2/p016/r035/p016r035_7x20020524.ETM-EarthSat-Orthorectified/p016r035_7x20020524.met">metadata</a>
-# here: SUN_AZIMUTH = 120.8810347, SUN_ELEVATION = 64.7730999
-r.sunmask -s elev=elevation out=dummy year=2002 month=5 day=24 hour=11 min=40 sec=0 timezone=-4
-# .. reports: sun azimuth: 120.555206, sun angle above horz.(refraction corrected): 65.028458
+Create a control file 'icnd.txt' for channel 4 (NIR), based on metadata. For the overpass time,
+we need to define decimal hours:<br>
+10:42:07 NC local time = 10.70 decimal hours (decimal minutes: 42 * 100 / 60) which is 15.70 GMT:
-# create control file 'icnd.txt' for channel 4 (NIR), based on metadata
-# 11:40 local time is 15.66 decimal hour GMT(decimal minutes: 40 * 100 / 60):
-echo "8 - geometrical conditions=Landsat ETM+
-5 24 15.66 -78.691 35.749 - month day hh.ddd longitude latitude ("hh.ddd" is a decimal hour GMT)
+#--------- start of control file -----
+8 - geometrical conditions=Landsat ETM+
+5 24 15.70 -78.691 35.749 - month day hh.ddd longitude latitude ("hh.ddd" is in GMT decimal hours)
2 - atmospheric mode=midlatitude summer
50 - visibility [km] (aerosol model concentration)
-0.110 - mean target elevation above sea level [km]
-1000 - sensor on board a satellite
-64 - 4th band of ETM+ Landsat 7" > icnd_lsat4.txt
+64 - 4th band of ETM+ Landsat 7
+#--------- end of control file -------
+</pre></div>
-# run atmospheric correction (-r for reflectance input map; -a for date >July 2000;
-# -o to use cache acceleration):
+Finally, run the atmospheric correction (-r for reflectance input map; -a for date >July 2000;
+-o to use cache acceleration):
i.atcorr -r -a -o lsat7_2002_40 ialt=elev_int icnd=icnd_lsat4.txt oimg=lsat7_2002_40_atcorr
</pre></div>
