[GRASS-SVN] r43672 -
grass/branches/releasebranch_6_4/imagery/i.atcorr
svn_grass at osgeo.org
Fri Sep 24 10:03:16 EDT 2010
Author: neteler
Date: 2010-09-24 14:03:15 +0000 (Fri, 24 Sep 2010)
New Revision: 43672
grass/branches/releasebranch_6_4/imagery/i.atcorr/description.html
added Convert DN (digital numer = pixel values) to Radiance
Modified: grass/branches/releasebranch_6_4/imagery/i.atcorr/description.html
--- grass/branches/releasebranch_6_4/imagery/i.atcorr/description.html 2010-09-24 13:41:30 UTC (rev 43671)
+++ grass/branches/releasebranch_6_4/imagery/i.atcorr/description.html 2010-09-24 14:03:15 UTC (rev 43672)
@@ -6,7 +6,7 @@
<a href="http://modis-sr.ltdri.org/index.html">Land Surface Reflectance Science
Computing Facility website</a> and Mauro A. Homem Antunes <a
href="http://www.ltid.inpe.br/dsr/mauro/6s/download_6s.html">website about his
-6s version</a>.
+6S version</a>.
<p>
Current region settings are ignored. The region is adjusted to cover the input
@@ -564,8 +564,50 @@
</pre></div>
If the overpass time is unknown, use the <a href="http://www-air.larc.nasa.gov/tools/predict.htm">Satellite Overpass Predictor</a>.
+<p>
+Convert DN (digital numer = pixel values) to Radiance at top-of-atmosphere (TOA), using the
+formula
+<div class="code"><pre>
+ Lλ = ((LMAXλ - LMINλ)/(QCALMAX-QCALMIN)) * (QCAL-QCALMIN) + LMINλ
+</pre></div>
+Where:
+<ul>
+<li> Lλ = Spectral Radiance at the sensor's aperture in Watt/(meter squared * ster * μm), the
+ apparent radiance as seen by the satellite sensor;</li>
+<li> QCAL = the quantized calibrated pixel value in DN;</li>
+<li> LMINλ = the spectral radiance that is scaled to QCALMIN in watts/(meter squared * ster * μm);</li>
+<li> LMAXλ = the spectral radiance that is scaled to QCALMAX in watts/(meter squared * ster * μm);</li>
+<li> QCALMIN = the minimum quantized calibrated pixel value (corresponding to LMINλ) in DN;</li>
+<li> QCALMAX = the maximum quantized calibrated pixel value (corresponding to LMAXλ) in DN=255.</li>
+</ul>
+LMINλ and LMAXλ are the radiances related to the minimal and maximal DN value, and are reported
+in the metadata file for each image, or in the table 1. High gain or low gain is also reported
+in the metadata file of each Landsat image. The minimal DN value (QCALMIN) is 1 for Landsat ETM+
+images (see
+<a href="http://landsathandbook.gsfc.nasa.gov/handbook/handbook_htmls/chapter11/chapter11.html">Landsat handbook</a>),
+and the maximal DN value (QCALMAX) is 255. QCAL is the DN value for every
+separate pixel in the Landsat image.
+<p>
+We extract the coefficients and apply them in order to obtain the radiance map:
+CHAN=4
+r.info lsat7_2002_${CHAN}0 -h | tr '\n' ' ' | sed 's+ ++g' | tr ':' '\n' | grep "LMIN_BAND${CHAN}\|LMAX_BAND${CHAN}"
+LMAX_BAND4=241.100,p016r035_7x20020524.met
+LMIN_BAND4=-5.100,p016r035_7x20020524.met
+QCALMAX_BAND4=255.0,p016r035_7x20020524.met
+QCALMIN_BAND4=1.0,p016r035_7x20020524.met
+</pre></div>
+Conversion to radiance (this calculation is done for band 4, for the other bands, the numbers in italics
+need to be replaced with their related values):
+r.mapcalc "lsat7_2002_40_rad=((241.1 - (-5.1)) / (255.0 - 1.0)) * (lsat7_2002_40 - 1.0) + (-5.1)"
+</pre></div>
# using an integer DEM greatly accelerates the i.atcorr computations
r.mapcalc "elev_int = round(elevation)"
@@ -593,7 +635,7 @@
Finally, run the atmospheric correction (-r for reflectance input map; -a for date >July 2000;
-o to use cache acceleration):
-i.atcorr -r -a -o lsat7_2002_40 ialt=elev_int icnd=icnd_lsat4.txt oimg=lsat7_2002_40_atcorr
+i.atcorr -r -a -o lsat7_2002_40_rad ialt=elev_int icnd=icnd_lsat4.txt oimg=lsat7_2002_40_atcorr
</pre></div>
Note that the altitude value from 'icnd_lsat4.txt' file is read at the beginning
@@ -637,9 +679,9 @@
Second simulation of the satellite signal in the solar spectrum, 6S: An
overview., IEEE Trans. Geosc. and Remote Sens. 35(3):675-686.
-<li> <a href="http://modis-sr.ltdri.org/6S_code/6S_code2_thinner_stuff/6S_ltdri_org_manual.html">6s manual</a> at the <a href="http://modis-sr.ltdri.org/6S_code/index.html">6s homepage</a> of the Land Surface Reflectance Science Computing Facility (also <a href="www.rsgis.ait.ac.th/~honda/textbooks/advrs/6smanv2.0_P1.pdf">PDF1</a>, <a href="www.rsgis.ait.ac.th/~honda/textbooks/advrs/6smanv2.0_P2.pdf">PDF2</a>, and <a href="www.rsgis.ait.ac.th/~honda/textbooks/advrs/6smanv2.0_P3.pdf">PDF3</a>)
+<li> <a href="http://modis-sr.ltdri.org/6S_code/6S_code2_thinner_stuff/6S_ltdri_org_manual.html">6S manual</a> at the <a href="http://modis-sr.ltdri.org/6S_code/index.html">6S homepage</a> of the Land Surface Reflectance Science Computing Facility (also <a href="www.rsgis.ait.ac.th/~honda/textbooks/advrs/6smanv2.0_P1.pdf">PDF1</a>, <a href="www.rsgis.ait.ac.th/~honda/textbooks/advrs/6smanv2.0_P2.pdf">PDF2</a>, and <a href="www.rsgis.ait.ac.th/~honda/textbooks/advrs/6smanv2.0_P3.pdf">PDF3</a>)
-<li>Mauro A. Homem Antunes <a href="http://www.ltid.inpe.br/dsr/mauro/6s/download_6s.html">website about his 6s version</a>
+<li>Mauro A. Homem Antunes <a href="http://www.ltid.inpe.br/dsr/mauro/6s/download_6s.html">website about his 6S version</a>
</ul>
<p><i>Last changed: $Date$</i>
