[GRASS-SVN] r46101 - grass/branches/releasebranch_6_4/lib/python
svn_grass at osgeo.org
Mon Apr 25 06:05:54 EDT 2011
Author: martinl
Date: 2011-04-25 03:05:54 -0700 (Mon, 25 Apr 2011)
New Revision: 46101
grass/branches/releasebranch_6_4/lib/python/core.py
pythonlib: sync core.py with trunk
Modified: grass/branches/releasebranch_6_4/lib/python/core.py
--- grass/branches/releasebranch_6_4/lib/python/core.py 2011-04-25 10:03:20 UTC (rev 46100)
+++ grass/branches/releasebranch_6_4/lib/python/core.py 2011-04-25 10:05:54 UTC (rev 46101)
@@ -45,10 +45,10 @@
preexec_fn = None, close_fds = False, shell = None,
cwd = None, env = None, universal_newlines = False,
startupinfo = None, creationflags = 0):
if shell == None:
shell = (sys.platform == "win32")
subprocess.Popen.__init__(self, args, bufsize, executable,
stdin, stdout, stderr,
preexec_fn, close_fds, shell,
@@ -94,12 +94,6 @@
return _make_val(list(val))
return str(val)
-def _get_error(string):
- try:
- return string.split('\n')[-2]
- except:
- return ''
def make_command(prog, flags = "", overwrite = False, quiet = False, verbose = False, **options):
"""!Return a list of strings suitable for use as the args parameter to
Popen() or call(). Example:
@@ -187,23 +181,9 @@
@return exit code (0 for success)
- if get_raise_on_error():
- kwargs['stderr'] = PIPE
- env = os.getenv('GRASS_MESSAGE_FORMAT')
- os.environ['GRASS_MESSAGE_FORMAT'] = 'plain'
ps = start_command(*args, **kwargs)
- err = ps.communicate()[1]
- if env:
- os.environ['GRASS_MESSAGE_FORMAT'] = env
- if ps.returncode != 0:
- raise ScriptError(_("Error in %s(%s): %s") % ('run_command', args[0], _get_error(err)))
- return ps.returncode
- else:
- return ps.wait()
+ return ps.wait()
def pipe_command(*args, **kwargs):
"""!Passes all arguments to start_command(), but also adds
"stdout = PIPE". Returns the Popen object.
@@ -250,22 +230,8 @@
@return stdout
ps = pipe_command(*args, **kwargs)
- out, err = ps.communicate()
- if env:
- raise ScriptError(_("Error in %s(%s): %s") % ('read_command', args[0], _get_error(err)))
- return _decode(out)
- else:
- return _decode(ps.communicate()[0])
+ return _decode(ps.communicate()[0])
def parse_command(*args, **kwargs):
"""!Passes all arguments to read_command, then parses the output by
@@ -308,26 +274,11 @@
@return return code
stdin = kwargs['stdin']
p = feed_command(*args, **kwargs)
p.stdin.write(stdin)
- err = p.communicate()[1]
- if env:
- p.stdin.close()
- if p.returncode != 0:
- raise ScriptError(_("Error in %s(%s): %s") % ('write_command', args[0], _get_error(err)))
- return p.returncode
- else:
- p.stdin.close()
- return p.wait()
+ p.stdin.close()
+ return p.wait()
def exec_command(prog, flags = "", overwrite = False, quiet = False, verbose = False, env = None, **kwargs):
"""!Interface to os.execvpe(), but with the make_command() interface.
@@ -433,17 +384,7 @@
global raise_on_error
tmp_raise = raise_on_error
raise_on_error = raise_exp
- return tmp_raise
-def get_raise_on_error():
- """!Get raise_on_error status
- @return True to raise exception
- global raise_on_error
- return raise_on_error
# interface to g.parser
def _parse_opts(lines):
@@ -1143,8 +1084,8 @@
@code
version()
- {'date': '2011', 'libgis_revision': '38990', 'version': '6.5.svn',
- 'libgis_date': '2009-09-05 19:01:13 +0200 (Sat, 05 Sep 2009)'}
+ {'date': '2011', 'libgis_revision': '45093 ', 'version': '6.4.svn',
+ 'libgis_date': '2011-01-20 13:10:50 +0100 (Thu, 20 Jan 2011) ', 'revision': '45136'}
@endcode
return parse_command('g.version',
