[GRASS-SVN] r46102 - grass-addons/gui/wxpython/wx.psmap/gui_modules
svn_grass at osgeo.org
Mon Apr 25 13:01:06 EDT 2011
Author: annakrat
Date: 2011-04-25 10:01:06 -0700 (Mon, 25 Apr 2011)
New Revision: 46102
grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap_dialogs.py
wx.psmap: fix problems with missing ScriptError
Modified: grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap_dialogs.py
--- grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap_dialogs.py 2011-04-25 10:05:54 UTC (rev 46101)
+++ grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap_dialogs.py 2011-04-25 17:01:06 UTC (rev 46102)
@@ -592,7 +592,7 @@
try:
RunCommand(cmd[0], **cmd[1])
- except grass.ScriptException, e:
+ except grass.ScriptError, e:
GError(_("Region cannot be set\n%s") % e)
return False
@@ -1167,14 +1167,14 @@
if discrete == 'y':
cols = cols if cols else 1
- try:
+ rinfo = grass.raster_info(raster)
+ if rinfo['datatype'] in ('DCELL', 'FCELL'):
+ minim, maxim = rinfo['min'], rinfo['max']
+ rows = ceil( maxim / cols )
+ else:
cat = grass.read_command('r.category', map = raster,
- fs = ':').strip().split('\n')
+ fs = ':').strip().split('\n')
rows = ceil( float(len(cat)) / cols )
- except grass.ScriptException:
- rinfo = grass.raster_info(raster)
- minim, maxim = rinfo['min'], rinfo['max']
- rows = ceil( maxim / cols )
height = self.unitConv.convert(value = 1.5 * rows * fontsize, fromUnit = 'point', toUnit = 'inch')
@@ -1300,7 +1300,7 @@
return False
try:
info = grass.find_file(map, element = 'cell')
GError(message = e.value)
return False
instr['raster'] = info['fullname']
@@ -1338,7 +1338,7 @@
vmap = line.split()[1]
try:
info = grass.find_file(vmap, element = 'vector')
return False
vmap = info['fullname']
@@ -1453,15 +1453,15 @@
instr = {}
try:
info = grass.find_file(name = text[0].split()[1], element = 'vector')
return False
instr['name'] = info['fullname']
#connection
instr['connection'] = True
- try:
- self.mapDBInfo = dbm_base.VectorDBInfo(instr['name'])
+ self.mapDBInfo = dbm_base.VectorDBInfo(instr['name'])
+ self.layers = self.mapDBInfo.layers.keys()
+ if not self.layers:
instr['connection'] = False
# points
@@ -2240,10 +2240,14 @@
mapFrameDict['map'] = self.select.GetValue()
mapFrameDict['mapType'] = self.mapType
mapFrameDict['region'] = None
if mapFrameDict['drawMap']:
if mapFrameDict['mapType'] == 'raster':
+ mapFile = grass.find_file(mapFrameDict['map'], element = 'cell')
+ if mapFile['file'] == '':
+ GMessage("Raster %s not found" % mapFrameDict['map'])
+ return False
raster = self.instruction.FindInstructionByType('raster')
if raster:
raster['raster'] = mapFrameDict['map']
@@ -2254,7 +2258,12 @@
self.instruction.AddInstruction(raster)
elif mapFrameDict['mapType'] == 'vector':
+ mapFile = grass.find_file(mapFrameDict['map'], element = 'vector')
+ GMessage("Vector %s not found" % mapFrameDict['map'])
+ return False
vector = self.instruction.FindInstructionByType('vector')
isAdded = False
if vector:
@@ -2262,8 +2271,8 @@
if each[0] == mapFrameDict['map']:
isAdded = True
if not isAdded:
- try:
- topoInfo = grass.vector_info_topo(map = mapFrameDict['map'])
+ topoInfo = grass.vector_info_topo(map = mapFrameDict['map'])
+ if topoInfo:
if bool(topoInfo['areas']):
topoType = 'areas'
elif bool(topoInfo['lines']):
@@ -2271,9 +2280,7 @@
else:
topoType = 'points'
label = '('.join(mapFrameDict['map'].split('@')) + ')'
- pass
- else:
if not vector:
vector = Vector(wx.NewId())
vector['list'] = []
@@ -2283,7 +2290,9 @@
vProp = VProperties(id, topoType)
vProp['name'], vProp['label'], vProp['lpos'] = mapFrameDict['map'], label, 1
self.instruction.AddInstruction(vProp)
+ else:
+ return False
self.scale[0], self.center[0], self.rectAdjusted = AutoAdjust(self, scaleType = 0, map = mapFrameDict['map'],
mapType = self.mapType, rect = self.mapFrameDict['rect'])
@@ -2593,19 +2602,20 @@
vmap = self.select.GetValue()
try:
topoInfo = grass.vector_info_topo(map = vmap)
+ except grass.ScriptError:
return
- self.vectorType.EnableItem(2, bool(topoInfo['areas']))
- self.vectorType.EnableItem(1, bool(topoInfo['boundaries']) or bool(topoInfo['lines']))
- self.vectorType.EnableItem(0, bool(topoInfo['centroids'] or bool(topoInfo['points']) ))
- for item in range(2,-1,-1):
- if self.vectorType.IsItemEnabled(item):
- self.vectorType.SetSelection(item)
- break
- self.AddVector.SetFocus()
+ if topoInfo:
+ self.vectorType.EnableItem(2, bool(topoInfo['areas']))
+ self.vectorType.EnableItem(1, bool(topoInfo['boundaries']) or bool(topoInfo['lines']))
+ self.vectorType.EnableItem(0, bool(topoInfo['centroids'] or bool(topoInfo['points']) ))
+ for item in range(2,-1,-1):
+ if self.vectorType.IsItemEnabled(item):
+ self.vectorType.SetSelection(item)
+ break
+ self.AddVector.SetFocus()
def OnAddVector(self, event):
"""!Adds vector map to list"""
@@ -2824,10 +2834,12 @@
try:
self.mapDBInfo = dbm_base.VectorDBInfo(self.vectorName)
self.connection = False
self.layers = []
+ self.connection = False
+ self.layers = []
self.currLayer = self.vPropertiesDict['layer']
@@ -4108,6 +4120,8 @@
if self.rLegendDict['raster']:
# type and range of map
rasterType = getRasterType(self.rLegendDict['raster'])
+ if rasterType is None:
+ return False
self.rLegendDict['type'] = rasterType
@@ -5267,7 +5281,7 @@
if mapType == 'raster':
try:
res = grass.read_command("g.region", flags = 'gu', rast = map)
pass
elif mapType == 'vector':
res = grass.read_command("g.region", flags = 'gu', vect = map)
@@ -5399,16 +5413,19 @@
bb = map(float, grass.read_command('ps.map',
flags = 'b',
input = filename).strip().split('=')[1].split(','))
- except (grass.ScriptException, IndexError):
+ except (grass.ScriptError, IndexError):
GError(message = _("Unable to run `ps.map -b`"))
return None
return wx.Rect2D(bb[0], bb[3], bb[2] - bb[0], bb[1] - bb[3])
def getRasterType(map):
"""!Returns type of raster map (CELL, FCELL, DCELL)"""
- try:
+ if map is None:
+ map = ''
+ file = grass.find_file(name = map, element = 'cell')
+ if file['file']:
rasterType = grass.raster_info(map)['datatype']
- #GError(_("Unable to get type of raster map"))
+ return rasterType
+ else:
return None
- return rasterType
