[GRASS-SVN] r47335 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Mon Aug 1 08:05:37 EDT 2011
Author: martinl
Date: 2011-08-01 05:05:37 -0700 (Mon, 01 Aug 2011)
New Revision: 47335
grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
wxGUI/dbm: error trapping for v.db.select
(merge r47334 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py 2011-08-01 12:01:05 UTC (rev 47334)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py 2011-08-01 12:05:37 UTC (rev 47335)
@@ -191,20 +191,22 @@
if columns:
ret = gcmd.RunCommand('v.db.select',
quiet = True,
+ parent = self,
flags = 'c',
map = self.mapDBInfo.map,
layer = layer,
columns = ','.join(columns),
where = where,
- stdout=outFile)
+ stdout = outFile)
else:
quiet = True,
+ parent = self,
flags = 'c',
layer = layer,
where = where,
- stdout=outFile)
+ stdout = outFile)
# These two should probably be passed to init more cleanly
# setting the numbers of items = number of elements in the dictionary
@@ -699,9 +701,12 @@
win.Bind(wx.EVT_LIST_ITEM_ACTIVATED, self.OnDataItemActivated)
self.layerPage[layer] = {'browsePage': panel.GetId()}
+ label = _("Table")
+ if not self.editable:
+ label += _(" (readonly)")
self.browsePage.AddPage(page=panel, text=" %d / %s %s" % \
- (layer, _("Table"), self.mapDBInfo.layers[layer]['table']))
+ (layer, label, self.mapDBInfo.layers[layer]['table']))
pageSizer = wx.BoxSizer(wx.VERTICAL)
