[GRASS-SVN] r47336 - in grass/trunk/gui/wxpython: . gui_modules
svn_grass at osgeo.org
Mon Aug 1 11:16:57 EDT 2011
Author: martinl
Date: 2011-08-01 08:16:57 -0700 (Mon, 01 Aug 2011)
New Revision: 47336
grass/trunk/gui/wxpython/gui_modules/dbm.py
grass/trunk/gui/wxpython/gui_modules/gdialogs.py
grass/trunk/gui/wxpython/gui_modules/toolbars.py
grass/trunk/gui/wxpython/wxgui.py
wxGUI: launch ATM when creating new vector map
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py 2011-08-01 12:05:37 UTC (rev 47335)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py 2011-08-01 15:16:57 UTC (rev 47336)
@@ -51,10 +51,10 @@
import utils
import gdialogs
import dbm_base
-from debug import Debug
+from debug import Debug
from dbm_dialogs import ModifyTableRecord
from preferences import globalSettings as UserSettings
+from menuform import GNotebook
class Log:
The log output is redirected to the status bar of the containing frame.
@@ -526,13 +526,20 @@
return True
class AttributeManager(wx.Frame):
- GRASS Attribute manager main window
- def __init__(self, parent, id=wx.ID_ANY,
- size = wx.DefaultSize, style = wx.DEFAULT_FRAME_STYLE,
- title=None, vectorName=None, item=None, log=None):
+ def __init__(self, parent, id = wx.ID_ANY,
+ title = None, vectorName = None, item = None, log = None,
+ selection = None, **kwargs):
+ """!GRASS Attribute Table Manager window
+ @param parent parent window
+ @parem id window id
+ @param title window title or None for default title
+ @param vetorName name of vector map
+ @param item item from Layer Tree
+ @param log log window
+ @param selection name of page to be selected
+ @param kwagrs other wx.Frame's arguments
self.vectorName = vectorName
self.parent = parent # GMFrame
self.treeItem = item # item in layer tree
@@ -549,9 +556,9 @@
else:
self.editable = False
- self.cmdLog = log # self.parent.goutput
+ self.cmdLog = log # self.parent.goutput
- wx.Frame.__init__(self, parent, id, style=style)
+ wx.Frame.__init__(self, parent, id, *kwargs)
# title
if not title:
@@ -604,22 +611,7 @@
### {layer: list, widgets...}
self.layerPage = {}
- # auinotebook (browse, manage, settings)
- #self.notebook = wx.aui.AuiNotebook(parent=self, id=wx.ID_ANY,
- # style=wx.aui.AUI_NB_BOTTOM)
- # really needed (ML)
- # self.notebook.SetFont(wx.Font(10, wx.FONTFAMILY_MODERN, wx.NORMAL, wx.NORMAL, 0, ''))
- if globalvar.hasAgw:
- self.notebook = FN.FlatNotebook(parent = self.panel, id = wx.ID_ANY,
- agwStyle = FN.FNB_BOTTOM |
- FN.FNB_NO_NAV_BUTTONS |
- FN.FNB_FANCY_TABS | FN.FNB_NO_X_BUTTON)
- else:
- style = FN.FNB_BOTTOM |
+ self.notebook = GNotebook(self.panel, style = globalvar.FNPageDStyle)
dbmStyle = { 'agwStyle' : globalvar.FNPageStyle }
@@ -628,22 +620,22 @@
self.browsePage = FN.FlatNotebook(self.panel, id = wx.ID_ANY,
**dbmStyle)
- # self.notebook.AddPage(self.browsePage, caption=_("Browse data"))
- self.notebook.AddPage(self.browsePage, text=_("Browse data")) # FN
+ self.notebook.AddPage(page = self.browsePage, text = _("Browse data"),
+ name = 'browse')
self.browsePage.SetTabAreaColour(globalvar.FNPageColor)
self.manageTablePage = FN.FlatNotebook(self.panel, id = wx.ID_ANY,
**dbmStyle)
- #self.notebook.AddPage(self.manageTablePage, caption=_("Manage tables"))
- self.notebook.AddPage(self.manageTablePage, text=_("Manage tables")) # FN
+ self.notebook.AddPage(page = self.manageTablePage, text = _("Manage tables"),
+ name = 'table')
if not self.editable:
self.notebook.GetPage(self.notebook.GetPageCount()-1).Enable(False)
self.manageTablePage.SetTabAreaColour(globalvar.FNPageColor)
self.manageLayerPage = FN.FlatNotebook(self.panel, id = wx.ID_ANY,
**dbmStyle)
- #self.notebook.AddPage(self.manageLayerPage, caption=_("Manage layers"))
- self.notebook.AddPage(self.manageLayerPage, text=_("Manage layers")) # FN
+ self.notebook.AddPage(page = self.manageLayerPage, text = _("Manage layers"),
+ name = 'layers')
self.manageLayerPage.SetTabAreaColour(globalvar.FNPageColor)
@@ -652,11 +644,10 @@
self.__createManageTablePage()
self.__createManageLayerPage()
- self.notebook.SetSelection(0) # select browse tab
+ if selection:
+ wx.CallAfter(self.notebook.SetSelectionByName, selection) # select browse tab
# buttons
self.btnQuit = wx.Button(parent=self.panel, id=wx.ID_EXIT)
self.btnQuit.SetToolTipString(_("Close Attribute Table Manager"))
self.btnReload = wx.Button(parent=self.panel, id=wx.ID_REFRESH)
@@ -2049,8 +2040,7 @@
event.Skip()
def OnExtractSelected(self, event):
- Extract vector objects selected in attribute browse window
+ """!Extract vector objects selected in attribute browse window
to new vector map
list = self.FindWindowById(self.layerPage[self.layer]['data'])
@@ -2063,24 +2053,26 @@
return
else:
# dialog to get file name
- name, add = gdialogs.CreateNewVector(parent = self, title = _('Extract selected features'),
- log = self.cmdLog,
- cmd = (('v.extract',
- { 'input' : self.vectorName,
- 'list' : utils.ListOfCatsToRange(cats) },
- 'output')),
- disableTable = True)
- if name and add:
+ dlg = gdialogs.CreateNewVector(parent = self, title = _('Extract selected features'),
+ log = self.cmdLog,
+ cmd = (('v.extract',
+ { 'input' : self.vectorName,
+ 'list' : utils.ListOfCatsToRange(cats) },
+ 'output')),
+ disableTable = True)
+ if not dlg:
+ return
+ if dlg.GetName() and dlg.IsChecked('add'):
+ name = dlg.GetName() + '@' + grass.gisenv()['MAPSET']
# add layer to map layer tree
- self.parent.curr_page.maptree.AddLayer(ltype='vector',
- lname=name,
- lchecked=True,
- lopacity=1.0,
- lcmd=['d.vect', 'map=%s' % name])
+ self.parent.curr_page.maptree.AddLayer(ltype = 'vector',
+ lname = name,
+ lcmd = ['d.vect', 'map=%s' % name])
+ dlg.Destroy()
def OnDeleteSelected(self, event):
- Delete vector objects selected in attribute browse window
+ """!Delete vector objects selected in attribute browse window
(attribures and geometry)
@@ -2128,9 +2120,7 @@
def UpdateDialog(self, layer):
"""!Updates dialog layout for given layer"""
# delete page
if layer in self.mapDBInfo.layers.keys():
# delete page
# draging pages disallowed
@@ -2140,7 +2130,7 @@
self.browsePage.DeletePage(self.mapDBInfo.layers.keys().index(layer))
self.manageTablePage.DeletePage(self.mapDBInfo.layers.keys().index(layer))
# set current page selection
- self.notebook.SetSelection(2)
+ self.notebook.SetSelectionByName('layers')
# fetch fresh db info
self.mapDBInfo = dbm_base.VectorDBInfo(self.vectorName)
@@ -2154,7 +2144,7 @@
# 'manage tables' page
self.__createManageTablePage(layer)
# 'manage layers' page
Modified: grass/trunk/gui/wxpython/gui_modules/gdialogs.py
--- grass/trunk/gui/wxpython/gui_modules/gdialogs.py 2011-08-01 12:05:37 UTC (rev 47335)
+++ grass/trunk/gui/wxpython/gui_modules/gdialogs.py 2011-08-01 15:16:57 UTC (rev 47336)
@@ -216,14 +216,25 @@
return self.GetElement()
class NewVectorDialog(ElementDialog):
- """!Dialog for creating new vector map"""
- def __init__(self, parent, id, title, disableAdd=False, disableTable=False,
- style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
+ def __init__(self, parent, id = wx.ID_ANY, title = _('Create new vector map'),
+ disableAdd = False, disableTable = False,
+ style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER, *kwargs):
+ """!Dialog for creating new vector map
+ @param id window id
+ @param disableAdd disable 'add layer' checkbox
+ @param disableTable disable 'create table' checkbox
+ @param style window style
+ @param kwargs other argumentes for ElementDialog
+ @return dialog instance
ElementDialog.__init__(self, parent, title, label = _("Name for new vector map:"))
- self.element = gselect.Select(parent=self.panel, id=wx.ID_ANY, size=globalvar.DIALOG_GSELECT_SIZE,
- type='vector', mapsets=[grass.gisenv()['MAPSET'],])
+ self.element = gselect.Select(parent = self.panel, id = wx.ID_ANY, size = globalvar.DIALOG_GSELECT_SIZE,
+ type = 'vector', mapsets = [grass.gisenv()['MAPSET'],])
self.table = wx.CheckBox(parent = self.panel, id = wx.ID_ANY,
label = _("Create attribute table"))
@@ -241,55 +252,76 @@
self.PostInit()
- self.__Layout()
+ self._layout()
self.SetMinSize(self.GetSize())
def OnMapName(self, event):
"""!Name for vector map layer given"""
self.OnElement(event)
- def __Layout(self):
+ def _layout(self):
"""!Do layout"""
- self.dataSizer.Add(self.element, proportion=0,
- flag=wx.EXPAND | wx.ALL, border=1)
+ self.dataSizer.Add(self.element, proportion = 0,
+ flag = wx.EXPAND | wx.ALL, border = 1)
- self.dataSizer.Add(self.table, proportion=0,
+ self.dataSizer.Add(self.table, proportion = 0,
self.dataSizer.AddSpacer(5)
- self.dataSizer.Add(item=self.addbox, proportion=0,
+ self.dataSizer.Add(item = self.addbox, proportion = 0,
self.panel.SetSizer(self.sizer)
self.sizer.Fit(self)
def GetName(self):
- """!Return (mapName, overwrite)"""
+ """!Get name of vector map to be created"""
return self.GetElement().split('@', 1)[0]
-def CreateNewVector(parent, cmd, title=_('Create new vector map'),
- exceptMap=None, log=None, disableAdd=False, disableTable=False):
+ def IsChecked(self, key):
+ """!Get dialog properties
+ @param key window key ('add', 'table')
+ @return True/False
+ @return None on error
+ if key == 'add':
+ return self.addbox.IsChecked()
+ elif key == 'table':
+ return self.table.IsChecked()
+ return None
+def CreateNewVector(parent, cmd, title = _('Create new vector map'),
+ exceptMap = None, log = None, disableAdd = False, disableTable = False):
"""!Create new vector map layer
+ @param cmd (prog, **kwargs)
+ @param exceptMap list of maps to be excepted
+ @param log
- @cmd cmd (prog, **kwargs)
+ dlg = NewVectorDialog(parent, title = title,
+ disableAdd = disableAdd, disableTable = disableTable)
- @return tuple (name of create vector map, add to layer tree)
- @return None of failure
- dlg = NewVectorDialog(parent, wx.ID_ANY, title,
- disableAdd, disableTable)
if dlg.ShowModal() == wx.ID_OK:
outmap = dlg.GetName()
if outmap == exceptMap:
- wx.MessageBox(parent=parent,
- message=_("Unable to create vector map <%s>.") % outmap,
- caption=_("Error"),
- style=wx.ID_OK | wx.ICON_ERROR | wx.CENTRE)
- return (None, None)
+ gcmd.GError(parent = parent,
+ message = _("Unable to create vector map <%s>.") % outmap)
+ dlg.Destroy()
+ return None
if outmap == '': # should not happen
+ dlg.Destroy()
+ return None
cmd[1][cmd[2]] = outmap
@@ -299,20 +331,21 @@
listOfVectors = []
overwrite = False
- if not UserSettings.Get(group='cmd', key='overwrite', subkey='enabled') and \
+ if not UserSettings.Get(group = 'cmd', key = 'overwrite', subkey = 'enabled') and \
outmap in listOfVectors:
- dlgOw = wx.MessageDialog(parent, message=_("Vector map <%s> already exists "
- "in the current mapset. "
- "Do you want to overwrite it?") % outmap,
- caption=_("Overwrite?"),
- style=wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
+ dlgOw = wx.MessageDialog(parent, message = _("Vector map <%s> already exists "
+ "in the current mapset. "
+ "Do you want to overwrite it?") % outmap,
+ caption = _("Overwrite?"),
+ style = wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
if dlgOw.ShowModal() == wx.ID_YES:
overwrite = True
else:
dlgOw.Destroy()
- if UserSettings.Get(group='cmd', key='overwrite', subkey='enabled') is True:
+ dlg.Destroy()
+ return None
+ if UserSettings.Get(group = 'cmd', key = 'overwrite', subkey = 'enabled'):
overwrite = True
try:
@@ -322,13 +355,12 @@
except gcmd.GException, e:
gcmd.GError(parent = self,
message = e.value)
+ dlg.Destroy()
+ return None
# create attribute table
if dlg.table.IsEnabled() and dlg.table.IsChecked():
- key = UserSettings.Get(group='atm', key='keycolumn', subkey='value')
+ key = UserSettings.Get(group = 'atm', key = 'keycolumn', subkey = 'value')
sql = 'CREATE TABLE %s (%s INTEGER)' % (outmap, key)
gcmd.RunCommand('db.connect',
@@ -347,17 +379,17 @@
table = outmap,
key = key,
layer = '1')
# return fully qualified map name
if '@' not in outmap:
outmap += '@' + grass.gisenv()['MAPSET']
if log:
log.WriteLog(_("New vector map <%s> created") % outmap)
- return (outmap, dlg.addbox.IsChecked())
+ return dlg
- return (None, dlg.addbox.IsChecked())
+ return dlg
class SavedRegion(wx.Dialog):
def __init__(self, parent, id = wx.ID_ANY, title="", loadsave='load',
Modified: grass/trunk/gui/wxpython/gui_modules/toolbars.py
--- grass/trunk/gui/wxpython/gui_modules/toolbars.py 2011-08-01 12:05:37 UTC (rev 47335)
+++ grass/trunk/gui/wxpython/gui_modules/toolbars.py 2011-08-01 15:16:57 UTC (rev 47336)
@@ -966,34 +966,41 @@
openVectorMap = self.mapLayer.GetName(fullyQualified = False)['name']
else:
openVectorMap = None
- mapName = gdialogs.CreateNewVector(self.parent,
- exceptMap = openVectorMap, log = self.log,
- cmd = (('v.edit',
- { 'tool' : 'create' },
- 'map')),
- disableAdd = True)[0]
- if mapName:
+ dlg = gdialogs.CreateNewVector(self.parent,
+ exceptMap = openVectorMap, log = self.log,
+ cmd = (('v.edit',
+ { 'tool' : 'create' },
+ 'map')),
+ disableAdd = True)
+ if dlg and dlg.GetName():
if self.layerTree:
+ mapName = dlg.GetName() + '@' + grass.gisenv()['MAPSET']
self.layerTree.AddLayer(ltype = 'vector',
lname = mapName,
- lchecked = True,
- lopacity = 1.0,
lcmd = ['d.vect', 'map=%s' % mapName])
vectLayers = self.UpdateListOfLayers(updateTool = True)
selection = vectLayers.index(mapName)
- else:
- pass # TODO (no Layer Manager)
+ # create table ?
+ if dlg.IsChecked('table'):
+ lmgr = self.parent.GetLayerManager()
+ if lmgr:
+ lmgr.OnShowAttributeTable(None, selection = 'table')
+ dlg.Destroy()
else:
self.combo.SetValue(_('Select vector map'))
- return
+ if dlg:
+ dlg.Destroy()
+ return
else:
selection = event.GetSelection() - 1 # first option is 'New vector map'
# skip currently selected map
if self.layers[selection] == self.mapLayer:
- return False
+ return
if self.mapLayer:
# deactive map layer for editing
@@ -1003,9 +1010,7 @@
self.StartEditing(self.layers[selection])
event.Skip()
- return True
def StartEditing (self, mapLayer):
"""!Start editing selected vector map layer.
@@ -1127,7 +1132,7 @@
Update list of available vector map layers.
This list consists only editable layers (in the current mapset)
- Optionally also update toolbar
+ @param updateTool True to update also toolbar
Debug.msg (4, "VDigitToolbar.UpdateListOfLayers(): updateTool=%d" % \
updateTool)
@@ -1141,6 +1146,7 @@
layerNameList = []
self.layers = self.mapcontent.GetListOfLayers(l_type = "vector",
l_mapset = grass.gisenv()['MAPSET'])
for layer in self.layers:
if not layer.name in layerNameList: # do not duplicate layer
layerNameList.append (layer.GetName())
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2011-08-01 12:05:37 UTC (rev 47335)
+++ grass/trunk/gui/wxpython/wxgui.py 2011-08-01 15:16:57 UTC (rev 47336)
@@ -1189,7 +1189,7 @@
dlg.Destroy()
- def OnShowAttributeTable(self, event):
+ def OnShowAttributeTable(self, event, selection = None):
"""!Show attribute table of the given vector map layer
if not self.curr_page:
@@ -1226,7 +1226,8 @@
dbmanager = dbm.AttributeManager(parent = self, id = wx.ID_ANY,
size = wx.Size(500, 300),
- item = layer, log = self.goutput)
+ item = layer, log = self.goutput,
+ selection = selection)
busy.Destroy()
